Proxmox LXC Bootdisk vergrößern
@crunchip sagte in Proxmox LXC Bootdisk vergrößern:
bei deinem LXC auf Ressourcen, root disk anklicken, dann auf Resize Disk
Ah, das hab ich komplett übersehn.
ansonsten, mal den cache leeren
da kommt eine Fehlermeldung
root@ioBroker:~# sudo -u iobroker npm cache clean --force Error: EACCES: permission denied, scandir '/root' -
merkste selber
stimmt
root braucht kein sudoaber mit
iobroker npm cache clean --forcekommtroot@ioBroker:~# iobroker npm cache clean --force iobroker [command] Commands: iobroker setup Setup ioBroker iobroker start Starts the js-controller iobroker stop stops the js-controller iobroker restart Restarts js-controller iobroker debug <adapter>[.<instance>] Starts a Node.js debugging session for the adapter instance iobroker info Shows the host info iobroker logs [<adapter>] Monitor log iobroker add <adapter> [desiredNumber] Add instance of adapter iobroker install <adapter> Installs a specified adapter iobroker rebuild <adapter>|self Rebuilds a specified adapter iobroker url <url> [<name>] Install adapter from specified url, e.g. GitHub iobroker del <adapter> Remove adapter from system iobroker del <adapter>.<instance> Remove adapter instance iobroker update [<repositoryUrl>] Update repository and list adapters iobroker upgrade Upgrade management iobroker upload Upload management iobroker object Object management iobroker state State management iobroker message <adapter>[.instance] <command> [<message>] Send message to adapter instance/s iobroker list <type> [<filter>] List all entries, like objects iobroker chmod <mode> <file> Change file rights iobroker chown <user> <group> <file> Change file ownership iobroker touch <file> Touch file iobroker rm <file> Remove file iobroker file File management iobroker user User commands iobroker group group management iobroker host <hostname> Set host to given hostname iobroker set <adapter>.<instance> Change settings of adapter config iobroker license <license.file or license.text> Update license by given file iobroker cert Certificate management iobroker clean <yes> Clears all objects and states iobroker backup Create backup iobroker restore <backup name or path> Restore a specified backup iobroker validate <backup name or path> Validate a specified backup iobroker status [all|<adapter>.<instance>] Status of ioBroker or adapter instance iobroker repo [<name>] Show repo information iobroker uuid Show uuid of the installation iobroker unsetup Reset license, installation secret and language iobroker fix Execute the installation fixer script, this updates your ioBroker installation iobroker multihost Multihost management iobroker compact compact group management iobroker plugin Plugin management iobroker version [<adapter>] Show version of js-controller or specified adapter Options: --help Show help [boolean] -v, --version Show version [boolean] root@ioBroker:~# -
@negalein bist ja auch mit root unterwegs
npm cache clean --forcelöscht den cache deines LXC`s
dein iobroker hat aber seinen eigenen cache, dieser liegt in
home/iobroker/.npm
solltest dich mit deinem user anmelden und dann den oben erwähntensudo -u iobroker npm cache clean --forceBefehl absetzen -
dein iobroker hat aber seinen eigenen cache, dieser liegt in home/iobroker/.npm
Ah, jetzt gecheckt
wieder permission error
nega@ioBroker:/root$ sudo -u iobroker npm cache clean --force [sudo] password for nega: Error: EACCES: permission denied, scandir '/root' nega@ioBroker:/root$ -
@negalein sagte in Proxmox LXC Bootdisk vergrößern:
muss ich zuerst in
home/iobroker/.npmwechseln und dannsudo -u iobroker npm cache clean --force? -
@negalein nein, du meldest dich ganz normal an und stehst in deinem home Verzeichnis
hab mit
su negagewechselt
das stimmt dann so nicht?hab jetzt exit gefunden.
dürfte funktioniert haben.
An der Größe hat sich nicht wirklich was geändert.nega@ioBroker:~$ sudo -u iobroker npm cache clean --force [sudo] password for nega: npm WARN using --force I sure hope you know what you are doing. ╭───────────────────────────────────────────────────────────────╮ │ │ │ New major version of npm available! 6.14.13 -> 8.1.1 │ │ Changelog: https://github.com/npm/cli/releases/tag/v8.1.1 │ │ Run npm install -g npm to update! │ │ │ ╰───────────────────────────────────────────────────────────────╯ nega@ioBroker:~$ -
das war auch nur eine Idee, da sich dort mit der Zeit so einiges ansammelt
andernfalls, wenn du nicht weisst, was noch so Platz braucht, kannst du ncdu verwenden, zum suchen.
falls nicht installiertsudo apt install ncduwenn installiert, starten mit
sudo ncdu / -
--- / ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 8.4 GiB [##########] /opt 1.0 GiB [# ] /var 1.0 GiB [# ] /usr 46.2 MiB [ ] /lib 29.0 MiB [ ] /home 13.2 MiB [ ] /bin 9.0 MiB [ ] /sbin 7.1 MiB [ ] /root 4.4 MiB [ ] /etc 100.0 KiB [ ] /run 40.0 KiB [ ] /tmp ! 16.0 KiB [ ] /lost+found 12.0 KiB [ ] /mnt . 4.0 KiB [ ] /proc 4.0 KiB [ ] /lib64 e 4.0 KiB [ ] /srv e 4.0 KiB [ ] /media e 4.0 KiB [ ] /boot 4.0 KiB [ ] /dev . 0.0 B [ ] /sys -
Backup mit 4.1 GB
dachte die werden gellöscht nach x Tagen
--- /opt/iobroker/backups --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- /.. 406.3 MiB [##########] .nfs00000000001a056f00000028 406.3 MiB [######### ] iobroker_2021_10_15-23_00_10_Standard_backupiobroker.tar.gz 406.2 MiB [######### ] .nfs00000000001a07880000002a 406.2 MiB [######### ] iobroker_2021_10_17-23_00_10_Standard_backupiobroker.tar.gz 406.2 MiB [######### ] iobroker_2021_10_16-23_00_10_Standard_backupiobroker.tar.gz 406.2 MiB [######### ] .nfs00000000001a056100000029 406.2 MiB [######### ] .nfs00000000001a055800000024 406.2 MiB [######### ] .nfs00000000001a075d00000026 406.2 MiB [######### ] .nfs00000000001a075e00000027 406.1 MiB [######### ] .nfs00000000001a076e00000025 39.0 MiB [ ] historyDB_2021_10_17-23_00_54_Standard_backupiobroker.tar.gz 38.7 MiB [ ] historyDB_2021_10_16-23_00_54_Standard_backupiobroker.tar.gz 38.3 MiB [ ] historyDB_2021_10_15-23_00_51_Standard_backupiobroker.tar.gz 2.2 MiB [ ] homematic_2021_10_16-01_30_11_3.59.6_backupiobroker.tar.sbk 2.2 MiB [ ] homematic_2021_10_13-01_30_11_3.59.6_backupiobroker.tar.sbk 2.2 MiB [ ] homematic_2021_10_10-01_30_11_3.59.6_backupiobroker.tar.sbk 744.0 KiB [ ] javascripts_2021_10_16-23_01_15_Standard_backupiobroker.tar.gz 744.0 KiB [ ] javascripts_2021_10_15-23_01_12_Standard_backupiobroker.tar.gz 744.0 KiB [ ] javascripts_2021_10_17-23_01_16_Standard_backupiobroker.tar.gz 52.0 KiB [ ] grafana_2021_07_17-23_00_51_backupiobroker.tar.gz 52.0 KiB [ ] grafana_2021_07_07-23_00_51_backupiobroker.tar.gz 52.0 KiB [ ] grafana_2021_07_10-23_00_49_backupiobroker.tar.gz 52.0 KiB [ ] grafana_2021_07_08-23_00_50_backupiobroker.tar.gz 52.0 KiB [ ] grafana_2021_07_11-23_00_49_backupiobroker.tar.gz 52.0 KiB [ ] grafana_2021_07_09-23_00_49_backupiobroker.tar.gz -
sollten sie, bzw...kommt darauf an, wie und wohin du ein backup erstellst und ob es Fehler gab.
Klappt ein backup nicht, bleibt es im backup ordner, erstellst du manuell ein backup, verbleibt das dort ebenfalls, in beiden Fällen musst du dies dann manuell löschenalso, hast du ja nun dein Problem gefunden und musst nicht zwangsläufig deinen LXC vergrößern (verkleinern ist nämlich offiziell nicht möglich)...falls du irgendwann auf die idee kommen solltest
Ufff, gerade gesehen, dass nur noch auf den FTP gesichert wurde.
Lokal und Dropbox seit 10 Tagen nicht mehr, obwohl aktiviert.
@negalein da muss ich dich für heute leider alleine lassen mit deinem "Problem"
Bettchen ruft
gab aber die Tage die ein oder andere selbe Meldung im Backup Thread, dass das backup nicht funktionierte -
kannst du dir denken, was das für Files sind?
@negalein Das sind 'Überreste' eines unsauberen umounts einer NFS-Freigabe.
@negalein hab ich oben schon gesehen und mich gewundert
scheint das dein backup, doppelt da liegt, einmal das tar.gz und einmal .nfs, wobei ich mit letzterem nichts anfangen kann
