    4. Adapter "smartmeter"
      apollon77 @rossi73 last edited by apollon77
      @rossi73 ist der Port anderweitig belegt? Vllt von deinem cat an der Kommandozeile? Ansonsten Konfig ricjtig?
      • M-A Hueb
        M-A Hueb last edited by
        habe iobroker unter Windows am laufen. nach einem Update des js.controllers startet mein smartmeter -Adapter nicht mehr.
        Folgendes steht im Log:
        host.Server(SmartHome)	2021-10-27 12:06:11.367	info	Restart adapter system.adapter.smartmeter.0 because enabled
        host.Server(SmartHome)	2021-10-27 12:06:11.367	error	instance system.adapter.smartmeter.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.Server(SmartHome)	2021-10-27 12:06:11.367	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
        host.Server(SmartHome)	2021-10-27 12:06:11.367	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
        host.Server(SmartHome)	2021-10-27 12:06:11.366	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
        host.Server(SmartHome)	2021-10-27 12:06:11.366	error	Caught by controller[0]: at Object.<anonymous> (C:\Program Files\iobroker\SmartHome\node_modules\@serialport\bindings\lib\win32.js:1:36)
        host.Server(SmartHome)	2021-10-27 12:06:11.366	error	Caught by controller[0]: at bindings (C:\Program Files\iobroker\SmartHome\node_modules\@serialport\bindings\node_modules\bindings\bindings.js:112:48)
        host.Server(SmartHome)	2021-10-27 12:06:11.366	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
        host.Server(SmartHome)	2021-10-27 12:06:11.366	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
        host.Server(SmartHome)	2021-10-27 12:06:11.366	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
        host.Server(SmartHome)	2021-10-27 12:06:11.366	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
        host.Server(SmartHome)	2021-10-27 12:06:11.366	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1057:18)
        host.Server(SmartHome)	2021-10-27 12:06:11.366	error	Caught by controller[0]: \\?\C:\Program Files\iobroker\SmartHome\node_modules\@serialport\bindings\build\Release\bindings.node
        host.Server(SmartHome)	2021-10-27 12:06:11.366	error	Caught by controller[0]: Error: \\?\C:\Program Files\iobroker\SmartHome\node_modules\@serialport\bindings\build\Release\bindings.node ist keine zulässige Win32-Anwendung.
        host.Server(SmartHome)	2021-10-27 12:06:11.366	error	Caught by controller[0]: ^
        host.Server(SmartHome)	2021-10-27 12:06:11.366	error	Caught by controller[0]: throw e;
        host.Server(SmartHome)	2021-10-27 12:06:11.365	error	Caught by controller[0]: C:\Program Files\iobroker\SmartHome\node_modules\@serialport\bindings\node_modules\bindings\bindings.js:121
        host.Server(SmartHome)	2021-10-27 12:06:09.208	info	instance system.adapter.smartmeter.0 started with pid 9080
        Was muss ich machen das es wieder läuft?
        M-A Hueb 1 Reply Last reply Reply Quote 0
        • M-A Hueb
          M-A Hueb @M-A Hueb last edited by
          @m-a-hueb erledigt. Windows reboot hilft
            rossi73 @apollon77 last edited by rossi73
            @apollon77
            Servus, sorry, jetzt kommen DAU-Fragen:
            Wie/Wo finde ich raus ob der Port anderweitig belegt ist?
            Den Befehl cat kannte ich nicht und hab ihn denke ich noch nie benutzt. Den Raspberry hab ich auch schon mal des öfteren ge-rebootet.
            Konfig:
            Danke!
            Homoran R 2 Replies Last reply Reply Quote 0
              Homoran Global Moderator Administrators @rossi73 last edited by
              @rossi73 sagte in Adapter "smartmeter":
              in der Console kann ich DAten vom Lesekopf empfangen (1b 1b 1b 1b...).
              wie kommst du denn da an den Kopf?
              (ohne seinen Port zu nutzen)
                rossi73 @Homoran last edited by
                Hallo, Über Minicom
                sudo apt-get install minicom
                sudo minicom -D /dev/ttyUSB0 -b 9600 --displayhex --wrap
                aber den Befehl beende ich dann ja wieder...
                  und wie gibst du danach den Port weider frei?
                    rossi73 @Homoran last edited by rossi73
                    wahrscheinlich gar nicht wenn du so frägst 😉 wie mach ich das?
                      @rossi73 Reboot ist ne gute idee 🙂
                        rossi73 @rossi73 last edited by
                        @apollon77
                        Das ist immer meine erste Option... 😄
                          @homoran @apollon77
                          Kann es daran liegen das ich ioBroker im docker Container laufen lasse? Grüße
                            solche Informationen gehören immer in die erste Anfrage sonst sucht man sich dumm und dämlich 😡
                            Möglich ist das natürlich, da der Docker so seine Spezialitäten hat.
                            und genau deshalb nutze ich ihn nicht und kann da nicht mehr helfen.
                            Aber ioBroker im Docker auf RasPi????
                            und von wo hast du sudo minicom -D /dev/ttyUSB0 -b 9600 --displayhex --wrap aufgerufen?
                              Sorry! 😖
                              Das Problem war das ich den iobroker ohne docker container gar nicht zum Laufen brachte... werde es dann nachher aber nochmal probieren.
                              aufgerufen habe ich es so:
                              pi@raspi001:~ $ cd /opt/iobroker
                              pi@raspi001:/opt/iobroker $ sudo minicom -D /dev/ttyUSB0 -b 9600 --displayhex --        wrap
                              Willkommen zu minicom 2.7.1
                              Optionen: I18n
                              Übersetzt am Aug 13 2017, 15:25:34.
                              Port /dev/ttyUSB0, 17:02:42
                              Drücken Sie CTRL-A  Z für Hilfe zu speziellen Tasten
                              1b 1b 1b 1b 01 01 01 01 76 05 0f 2c 61 07 62 00 62 00 72 63 01 01 76 01 01 05 05
                               0e cb 03 0b 06 49 53 4b 01 0e 1f 58 6e 76 01 01 63 61 27 00 76 05 0f 2c 61 08 6
                              2 00 62 00 72 63 07 01 77 01 0b 06 49 53 4b 01 0e 1f 58 6e 76 07 01 00 62 0a ff
                              ff 72 62 01 65 09 04 94 fd 77 77 07 81 81 c7 82 03 ff 01 01 01 01 04 49 53 4b 01
                               77 07 01 00 00 00 09 ff 01 01 01 01 0b 06 49 53 4b 01 0e 1f 58 6e 76 01 77 07 0
                              1 00 01 08 00 ff 65 00 00 01 82 01 62 1e 52 ff 59 00 00 00 00 07 84 7c 40 01 77
                              07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 07 84 7c 40 01 77 07 01 00
                               01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 77 07 01 00 10 07 0
                              0 ff 01 01 62 1b 52 00 55 00 00 00 2a 01 77 07 81 81 c7 82 05 ff 01 01 01 01 83
                              02 46 de 79 95 02 b5 79 d0 5e ba 80 e1 5a 0c 7c f3 6c e7 83 69 dc bd 92 8d e3 74
                               49 c6 ac 85 9d 9f 03 9a 5a 0a 7c 6f 7e 48 ef 0f c4 5a cd e2 9e e2 01 01 01 63 a
                              Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
                                Thomas Braun Most Active @rossi73 last edited by
                                Auf 'nem Raspberry?!?
                                  dann ist zu befürchten, dass da jetzt auch der Wurm drin ist.
                                  Auf dem Raspi ist es ein Befehl und ioBroker läuft
                                    aus der Konsole des ioBroker-Verzeichnisses im Docker???
                                    @homoran sagte in Adapter "smartmeter":
                                    von wo hast du...
                                    wenn das von da klappt sollte es auch vom Adapter aus klappen
                                      ja, Raspberry Pi 4
                                      @Homoran
                                      sind zwei verschiedene SD-Karten...
                                      und ja, hätte ich auch vermutet aber smartmeter will nicht mit mir kooperieren, egal was ich da in den Einstellungen mache... Zig Kombinationen durchprobiert.
                                      Ein Befehl und es läuft? Schaun ma mal...
                                        ja, Raspberry Pi 4
                                        Da würde ich ja noch mehr als sonst von einem Docker-Container abraten.
                                          rossi73 @Thomas Braun last edited by
                                          Da ich diesbezüglich ein blutiger Anfänger bin könntest du mir das evtl ein wenig erklären?
                                            Thomas Braun Most Active @rossi73 last edited by Thomas Braun
                                            @rossi73
                                            Was? Wie man RaspberryOS und anschließend ioBroker nativ installiert?
                                            3625
                                            2287325
