    4. Wunsch: Adapter für Panasonic Viera Smart TV Steuerung
    • Vumer
      Vumer @Adrian-01 last edited by
      @adrian-01
      Hast du so versucht?
      https://forum.iobroker.net/topic/3501/wunsch-adapter-für-panasonic-viera-smart-tv-steuerung/132
        Adrian-01 @Vumer last edited by
        @vumer
        Ja, bzw. Was genau muss ich ab dem Punkt „und los gehts“ tun ?
        Vumer 1 Reply Last reply Reply Quote 0
        • Vumer
          Vumer @Adrian-01 last edited by Vumer
          @adrian-01
          python
          root@viera:~#
          root@viera:~# python
            @vumer
            das sieht schon mal besser aus 🙂
            Aber ich bekomme leider nach der Anfrage rc.request_pin_code() folgende Fehlermeldung:
            Traceback (most recent call last):
              File "<stdin>", line 1, in <module>
              File "/panasonic-viera/panasonic_viera/__init__.py", line 346, in request_pin_code
                raise e # Pass to the next handler
              File "/panasonic-viera/panasonic_viera/__init__.py", line 338, in request_pin_code
                res = self.soap_request(URL_CONTROL_NRC, URN_REMOTE_CONTROL, 'X_DisplayPinCode', params, body_elem="u")
              File "/panasonic-viera/panasonic_viera/__init__.py", line 258, in soap_request
              File "/panasonic-viera/panasonic_viera/__init__.py", line 254, in soap_request
                res = urlopen(req, timeout=5).read()
              File "/usr/lib/python3.9/urllib/request.py", line 214, in urlopen
                return opener.open(url, data, timeout)
              File "/usr/lib/python3.9/urllib/request.py", line 523, in open
                response = meth(req, response)
              File "/usr/lib/python3.9/urllib/request.py", line 632, in http_response
                response = self.parent.error(
              File "/usr/lib/python3.9/urllib/request.py", line 561, in error
                return self._call_chain(*args)
              File "/usr/lib/python3.9/urllib/request.py", line 494, in _call_chain
                result = func(*args)
              File "/usr/lib/python3.9/urllib/request.py", line 641, in http_error_default
                raise HTTPError(req.full_url, code, msg, hdrs, fp)
            urllib.error.HTTPError: HTTP Error 403: Forbidden
            woran könnte das liegen?
            • Vumer
              @adrian-01
              was sagt
              python --version
                @vumer said in Wunsch: Adapter für Panasonic Viera Smart TV Steuerung:
                python --version
                Hallo Vumer,
                sorry für die späte Rückmeldung Version 3.9.2.
                Habe es eben nochmal versucht, leider noch der gleiche Fehler.
                Gruß,
                • Vumer
                  @adrian-01
                  welches Modell hast du?
                  Musst du in der Remote App eine PIN eintragen die auf dem Fernseher erscheint wenn du dich das erste mal verbinden möchtest?
                    @vumer
                    Ja ich musste in der Remote App einen Pin eintragen, der ist auf dem TV erschienen.
                    Ich habe das Model der Serie 55HX900 der TV ist aufjedenfall mit allen KNX Schnittstellen kompatibel, darauf hatte ich beim Kauf geachtet.
                    • Vumer
                      @adrian-01 sagte in Wunsch: Adapter für Panasonic Viera Smart TV Steuerung:
                      HX
                      Die HX Serie ist neuer als meiner. Vielleicht hat Panasonic wieder was geändert? Leider weiß ich auch nicht weiter.
                        @vumer
                        Ohje....
                        Naja dann halt wohl doch dauerhaft über das KNX Gateway von ISE.
                        Komischerweise braucht das aber keinen Code.... 🙂
                          Habs jetzt zwar hinbekommen aber leider sehe ich nicht ob der TV an ist und schalten lässt er sich auch nicht 😞
                            Habe gerade mal geschaut, im LOG steht:
                            2021-11-03 21:44:49.371 - error: panasonic-viera.0 (5414) Error: ping.probe: there was an error while executing the ping program. . Check the path or permissions...
                            habe nochmals den Prozess durchgemacht mit Encryption Key etc.
                              coto @thomke67 last edited by
                              @thomke67 Hi, hast du hierfür schon eine Lösung gefunden. Kämpfe mit dem gleichen Problem.
                                @thomke67 sagte in Wunsch: Adapter für Panasonic Viera Smart TV Steuerung:
                                Immer noch das gleich Verhalten. Ich habe nun 2.0 installiert, aber sobald ich die Lautstärke ändere, steigt die Instanz aus....
                                  thomke67 @coto last edited by
                                  @coto, leider nein. Immer noch das gleiche Verhalten. Auch keinerlei Antwort vom Entwickler...
                                    @thomke67 kannst du mal per SSH nachinstallieren
                                    npm install node-panasonic-viera
                                    https://www.npmjs.com/package/node-panasonic-viera
                                    Seitdem ich das Paket installiert habe, läuft meine Instanz ohne Ausfälle. Vielleicht hilft es bei dir auch.
                                    J T 2 Replies Last reply Reply Quote 0
                                      jack99n @coto last edited by
                                      Bei mir hat es geholfen im Hauptordner 2 Datenpunkte anzulegen, einmal Mute und einmal Volumen.
                                      51E4F7B4-16DB-4CE7-A1A1-8BF901D98075.jpeg 2313AD93-ACC9-459D-A5C2-386B520F1D9E.jpeg 175D16F9-C365-412E-82EC-5D1EBE0B16AB.jpeg
                                        thomke67 @jack99n last edited by
                                        @jack99n, die Datenpunkte habe ich schon drin. Das hat nichts gebracht.
                                          @coto, das war der Trick! Nun funktionert der Adapter. Ich hoffe, dass das auf Dauer so bleibt.
                                          Vielen Dank!
                                          UHU01 W 2 Replies Last reply Reply Quote 0
                                          • UHU01
                                            UHU01 @thomke67 last edited by UHU01
                                            ich würde den Adapter auch gern einsetzen, steige aber nicht wirklich durch. Könnte evtl. jemand eine Schritt für Schritt Anleitung basteln, wann wo welche Scripte zu installieren sind, wie man an die benötigten keys kommt usw? Ich vermute da wären durchaus noch mehr Leute dankbar.
                                            UHU01 1 Reply Last reply Reply Quote 0
                                            175
                                            31338
