    2. Русский
    3. ioBroker
    4. Скрипты
    5. ioBroker скрипты
    6. Вопросы по написанию скриптов
    • I
      Izzm last edited by
      Читаю другое свойство, которое точно существует
      Код взял из сообщения instalator.
      var t;
      t = setInterval(function() {
         var v = getState('javascript.0.RealTemp.temp').val;
          log(v);
      }, 2000);
      Вывод в лог в редакторе скриптов
      19:30:57.235	[info]	javascript.0 Start javascript script.js.script
      19:30:57.235	[info]	javascript.0 script.js.script: setInterval(ms=2000)
      19:30:57.236	[info]	javascript.0 script.js.script: registered 0 subscriptions and 0 schedules
      19:30:59.255	[error]	javascript.0 script.js.script: Cannot use sync getState, use callback instead getState("javascript.0.RealTemp.temp", function (err, state){});
      В глобальном логе
      Server-Izzm	2017-02-16 19:30:59.273	info	Restart adapter system.adapter.javascript.0 because enabled
      host.Server-Izzm	2017-02-16 19:30:59.273	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
      javascript.0	2017-02-16 19:30:59.257	info	terminating
      javascript.0	2017-02-16 19:30:59.248	error	at Timer.listOnTimeout (timers.js:92:15)
      javascript.0	2017-02-16 19:30:59.248	error	at wrapper [as _onTimeout] (timers.js:279:11)
      javascript.0	2017-02-16 19:30:59.248	error	at ontimeout [as _repeat] (timers.js:263:34)
      javascript.0	2017-02-16 19:30:59.248	error	at null. (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2044:44)
      javascript.0	2017-02-16 19:30:59.248	error	at Object. (script.js.script:4:67)
      javascript.0	2017-02-16 19:30:59.248	error	TypeError: Cannot read property 'val' of undefined
      javascript.0	2017-02-16 19:30:59.242	error	uncaught exception: Cannot read property 'val' of undefined
      javascript.0	2017-02-16 19:30:59.233	error	script.js.script: Cannot use sync getState, use callback instead getState("javascript.0.RealTemp.temp", function (err, state){});
      • I
        instalator last edited by
        @Izzm:
        var t;
            log(v);
        }, 2000);
        В глобальном логе
        А так?
        var t;
           	log(JSON.stringify(state));
        }, 2000);
        • I
          Izzm last edited by
          Вывод в лог. У state в val есть нужное значение.
          19:56:08.143	[info]	javascript.0 Start javascript script.js.script
          19:56:08.144	[info]	javascript.0 script.js.script: setInterval(ms=2000)
          19:56:08.144	[info]	javascript.0 script.js.script: registered 0 subscriptions and 0 schedules
          19:56:10.147	[info]	javascript.0 script.js.script: {"val":24.5,"ack":true,"ts":1487264169069,"q":0,"from":"system.adapter.javascript.0","lc":1487263250738}
          И так работает
          var t;
          var vv;
                log(JSON.stringify(state.val));
                vv=state.val;
             log(vv);
          }, 2000);
          20:05:09.423	[info]	javascript.0 Start javascript script.js.script
          20:05:09.424	[info]	javascript.0 script.js.script: setInterval(ms=2000)
          20:05:09.424	[info]	javascript.0 script.js.script: registered 0 subscriptions and 0 schedules
          20:05:11.424	[info]	javascript.0 script.js.script: undefined
          20:05:11.426	[info]	javascript.0 script.js.script: 24.5
          20:05:13.429	[info]	javascript.0 script.js.script: 24.5
          20:05:13.432	[info]	javascript.0 script.js.script: 24.5
          • Bluefox
            Bluefox last edited by
            В настройках javascript есть свойство - Оптимизация состояний. Если убрать его, то getState (bla).val заработает.
              spectrekr last edited by
              Пытаюсь из строки выбрать IP адрес, сделал регулярное выражение и парсю строку.
              ! var reg_ip = new RegExp ('(([0-9]|[1-9][0-9]|1[0-9]{2}|2[0-4][0-9]|25[0-5])\.){3}([1-9]|[1-9][0-9]|1[0-9]{2}|2[0-4][0-9]|25[0-4])'); var ip; var str = "first L2TP UDP packet received from 217.15.203.52"; //var str = "error: WARNING: cannot find message with id = 27946818"; ip = reg_ip.exec(str); if(ip){ log("IP: " + ip[0]); } !
              Из первой строки выводит только первые две декты IP, а из второй все число, хотя на IP оно и близко не похоже.
              • Bluefox
                Будь проще 🙂
                var ip = str.match(/\b(\d{1,3}\.\d{1,3}\.\d{1,3}\.\d{1,3})\b/);
                if(ip){
                    log("IP: " + ip[1]);
                • I
                  Izzm last edited by
                  Большое спасибо.
                  А то я уже такие костыли понастроил.
                    Все сдаюсь, "обожаю" асинхронность JS. Есть цикл, надо сообщения выводит с задежркой, чтоб телеграмм не заблочил.
                    for (var a in res.result) {
                    if(res.result[a].work.indexOf('/1') > 0){
                    str = res.result[a].work.replace(new RegExp('/1','g'),' очень низкий');
                            }else
                            if(res.result[a].work.indexOf('/2') > 0){
                                str = res.result[a].work.replace(new RegExp('/2','g'),' _низкий_');
                            }else
                            if(res.result[a].work.indexOf('/3') > 0){
                                str = res.result[a].work.replace(new RegExp('/3','g'),' _средний_');
                            }else
                            if(res.result[a].work.indexOf('/4') > 0){
                                str = res.result[a].work.replace(new RegExp('/4','g'),' _высокий_');
                            }else
                            if(res.result[a].work.indexOf('/5') > 0){
                                str = res.result[a].work.replace(new RegExp('/5','g'),' _очень высокий_');
                            sendTo('telegram.0', {user:   us, text:   '*' + res.result[a].name + '*' + '\n' + str, parse_mode: 'Markdown'});
                      kID last edited by
                      Пытаюсь проделать следующий финт:
                      На закладке объектов создать в корне папку и наполнить ее разными объектами.
                      Например создать папку Flags и там различные объекты к которым могу обращаться из различных инстанций Javascript.0 или Javascript.1
                      Зачем это. Ну просто обособить свои объекты. Насоздавал например объектов в Javascript.1, а затем нечаяно грохнул его и все потерялось. А так все на месте и к ним можно обратиться из Javascript.0. И соответственно скрипты рассчитанные на одновременную работу с данными могут находится в разных инстанциях.
                      Но почему то не могу создать первоначальную папку в корне, куда потом прятать все содержимое. Позволяет только создать состояние|канал|устройство. Но если создавать любой из этих объектов, то все дочерние визуально лежат рядом.
                      • aurodionov
                        aurodionov last edited by
                        Проще создать нужные объекты скриптом
                        CreateState('папка.объект', " ");
                        Пишу с пульта….
                        • I
                          @kID:
                          Чего я неправильно делаю Скриншот 2017-02-25 21.53.53.png `
                          Создай сразу всю ветку. Например kitchen.flag
                            kID last edited by
                            @aurodionov:
                            CreateState('папка.объект', " "); `
                            Но ведь тогда объект создается в той инстанции откуда скрипт запущен
                            т.е скрип
                            createState('flag.alarm_10min', false);
                            createState('flag.alarm_10min', false );
                            запущенный из javascript.0 создаст эти объекты в дереве javascript.0
                            @instalator:
                            Создай сразу всю ветку. Например kitchen.flag `
                            Я чувствую что не догоняю.
                            Только что понял: Корневое название должно состоять из двух частей разделённых точкой. Тогда оно при дальнейшем наполнении становится родителем. Я же просто создавал "Flag" и оно периодами вообще терялось из списка объектов, потом при обновлении появлялось, и главное к нему не цеплялись дочерние объекты, они просто лежали рядом. Хотя к названию дочерних цеплялся Flag.
                              kID last edited by
                              Ну чего-то наворотил, но все же работает как-то не так.
                              Скрипт
                              reateState('Flag.0.Alarm_10min', false);
                              createState('Flag.0.Alarm_5min', false);
                              createState('Flag.0.test', 10);
                              setState (("Flag.0.Alarm_5min"), true, true);
                              setState (("Flag.0.test"/*test*/), 20, true);
                              log("Значение" + getState("Flag.0.test").val);
                              Если таких объектов нигде нет, то все создается в дереве javascript.0
                              И далее с этими объектами работаем как обычно
                              Но если я заранее в корне создаю эти объекты
                              то получаю следующее
                              или так
                              Т.е создается объект в дереве javascript.0 а работаем уже с объектом из корня.
                              Я так понимаю что ситуация как в анекдоте:
                              • Чего-то меня последнее время Гондурас беспокоит
                              • А вы его поменьше чешите
                              Т.е. в корне создавать объекты нельзя!!
                              • I
                                @kID:
                                Скрипт
                                или так
                                Т.е. в корне создавать объекты нельзя!! `
                                Руками можно
                                  Раз вы руками создали в корне, то из скрипта уберите CreateState
                                    kID last edited by
                                    @spectrekr:
                                    Раз вы руками создали в корне, то из скрипта уберите CreateState `
                                    Да я все понял. Я чего хотел показать - что используя одинаковый ID в случае с getState ищется первое вхождение с корня объектов
                                    а для createState игнорируется все что выше Javascript.X
                                    • I
                                      @kID:
                                      @spectrekr:
                                      а для createState игнорируется все что выше Javascript.X `
                                      Это так работает функция createState. Создает переменные в инстанции Javascript драйвера.
                                        Adav last edited by
                                        Появилась задача включать выключать драйвер из скрипта. Необходимость возникла по следующей причине - драйвер, работающий с оборудованием, в случае отключения оборудования продолжает пытаться до него достучаться и слать ошибки в логи. Оборудование не всегда должно быть включенным. Поэтому логично с выключением оборудования принудительно отключать и драйвер, занимающийся его опросом.
                                        Управление драйвером пробовал делать через setState, к примеру в тесте управления включением-выключением history:
                                        setState("system.adapter.history.0.alive", true); и setState("system.adapter.history.0.alive", false);
                                        Оно так работает и я получаю желаемое. Но… отключение драйвера - все нормально, а вот включение всякий раз дает ошибку в логе (но в итоге все равно делает что надо):
                                        history.0 2017-04-27 11:22:54.125 info starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.history, node: v4.8.2
                                        host.AdavHome 2017-04-27 11:22:53.290 info instance system.adapter.history.0 started with pid 11319
                                        host.AdavHome 2017-04-27 11:22:23.277 info Restart adapter system.adapter.history.0 because enabled
                                        host.AdavHome 2017-04-27 11:22:23.276 error instance system.adapter.history.0 terminated with code 7 (Adapter already running)
                                        host.AdavHome 2017-04-27 11:22:22.402 info instance system.adapter.history.0 started with pid 11285
                                        host.AdavHome 2017-04-27 11:22:22.402 info "system.adapter.history.0" enabled
                                        host.AdavHome 2017-04-27 11:22:22.402 info object change system.adapter.history.0
                                        Такое ощущение, что система думает что драйвер уже запущен и сначала его останавливает и только потом запускает. И всякий раз ошибка в лог. Ну и такое отрабатывает заметно медленнее, чем при включении руками.
                                        Может есть какой-то способ сделать это иначе или я что-то не так делаю?
                                          Haus last edited by
                                          @Adav:
                                          Может есть какой-то способ сделать это иначе или я что-то не так делаю? `
                                          alive - это ка бы индикатор для чтения
                                          В драйвере Javascript включи опцию Разрешить команду "setObject"
                                          var obj = getObject("system.adapter.history.0");
                                          obj.common.enabled = false;  //or true
                                          setObject("system.adapter.history.0", obj);
                                            Adav last edited by
                                            Разобрался, все работает, спасибо!
                                            358
                                            104282
