    4. KNX Adapter überholt
      besitzer last edited by
      Hallo Chefkoch,
      blöde Frage, aber wie erkenne ich das?
      Ich glaube 3 stufig, wenn ich das an den Gruppenadressen festmachen kann:
      <grouprange name="Etage 1" rangestart="2048" rangeend="4095"><grouprange name="Lichtsteuerung" rangestart="2048" rangeend="2303"><groupaddress name="Licht Kind 1" address="1/0/0"><groupaddress name="Licht Kind 2" address="1/0/1"><groupaddress name="Licht 1 Eltern Bett" address="1/0/2"><groupaddress name="Licht 2 Eltern Schrank" address="1/0/3"><groupaddress name="Licht Bad Spiegel Etage 1" address="1/0/4"><groupaddress name="Licht Bad Haupt Etage 1" address="1/0/5"><groupaddress name="Licht Flur Etage 1" address="1/0/6"><groupaddress name="Licht Flur Etage 1 - Erdgeschoss " address="1/0/7"></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></grouprange>
      <grouprange name="Jalousiesteuerung" rangestart="2304" rangeend="2559"></grouprange>
      <grouprange name="Erdgeschoss" rangestart="4096" rangeend="6143"><grouprange name="Lichtsteuerung" rangestart="4096" rangeend="4351"><groupaddress name="Licht Küche" address="2/0/0"><groupaddress name="Licht Essen" address="2/0/1"><groupaddress name="Licht Wohnzimmer" address="2/0/2"><groupaddress name="Licht Flur Erdgeschoss" address="2/0/3"><groupaddress name="Licht Bad Erdgeschoss" address="2/0/4"><groupaddress name="Licht Erdgeschoss - Keller" address="2/0/5"><groupaddress name="Licht Hausaussenlicht" address="2/0/6"><groupaddress name="Licht Flur Erdgeschoss - Keller" address="2/0/7"><groupaddress name="Licht - KüchenLEDs" address="2/0/8"><groupaddress name="Licht - Alle Lichter" address="2/0/9"><groupaddress name="Licht WohnzimmerLEDs" address="2/0/10"><groupaddress name="Licht Sophie" address="2/0/11"><groupaddress name="Licht Mara" address="2/0/12"><groupaddress name="Licht Bad OG" address="2/0/13"></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></grouprange>
      <grouprange name="Jalousiesteuerung" rangestart="4352" rangeend="4607"><groupaddress name="Jalousie Wohnzimmer links" address="2/1/0"><groupaddress name="Jalousie Wohnzimmer rechts" address="2/1/1"><groupaddress name="Jalousie Küche" address="2/1/2"><groupaddress name="Jalousie Bad Erdgeschoss" address="2/1/3"><groupaddress name="Jalousie Flur Erdgeschoss" address="2/1/4"><groupaddress name="Jalousie Wohzimmer links verstellen" address="2/1/5"><groupaddress name="Jalousie Wohzimmer rechts verstellen" address="2/1/6"><groupaddress name="Jalousie Küche verstellen" address="2/1/7"><groupaddress name="Jalousie Bad verstellen" address="2/1/8"><groupaddress name="Jalousie Flur verstellen" address="2/1/9"><groupaddress name="Jalousie Alle Jalousien schließen" address="2/1/10"><groupaddress name="Jalousie Kinder ins Bett" address="2/1/11"><groupaddress name="Jalousie Kind 2 Mara" address="2/1/12"><groupaddress name="Jalousie Kind 2 Mara verstellen" address="2/1/13"><groupaddress name="Jalousien ET1 alle Fahren" address="2/1/14"><groupaddress name="Jalousie Kind 1 Sophie" address="2/1/15"><groupaddress name="Jalousie Kind 1 Sophie verstellen" address="2/1/16"><groupaddress name="Jalousie Flur OG" address="2/1/17"><groupaddress name="Jalousie Flur OG verstellen" address="2/1/18"><groupaddress name="Jalousie Bad OG" address="2/1/19"><groupaddress name="Jalousie Bad OG verstellen" address="2/1/20"><groupaddress name="Jalousie Alle EG" address="2/1/21"><groupaddress name="Jalousie wohnzimmer links Stop" address="2/1/22"><groupaddress name="Jalousie Alle EG verstellen" address="2/1/23"><groupaddress name="Jalousie Alle Jalousien verschliessen" address="2/1/24"><groupaddress name="Jalousie Kinder ins Bett verstellen" address="2/1/25"><groupaddress name="Jalousie Alle OG verstellen" address="2/1/26"></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></groupaddress></grouprange>
      Ich schicke Dir die Projektdatei als PN zu.
      Gruß Sven</grouprange></grouprange>
        KNXbroker last edited by
        Hi Chefkoch,
        hattest Du bereits Gelegenheit DPT13 zu prüfen? Sind dir Probleme bekannt oder liegt es an mir…? Ich habe schon alles möglich probiert, aber krieg es nicht zum laufen.
        Danke für eine kurze Rückmeldung. Über DPT13 läuft bei mir die komplette Eigenverbrauchssteuerung.
        Viele Grüße, KNX Broker
        • cvidal
          So ich habe es jetzt soweit auch am laufen allerdings mit dem KNX Adapter 0.7.3 mit dem Aktuellem Adapter bekomme ich es auch nicht hin da werden dann die Rollen falsch angegeben, habe in der ETS5 alles auf Schalten eingestellt auch die Rollladen diese lassen sich nur mit An/Aus Steuern. Jemand eine Idee wie ich bspw. Eine Prozent Angabe für die Rollis hinbekomme? Wie gesagt Aktueller Adapter funkt nicht. Chefkoch hast du eine Idee? Gruß cvidal
            edo last edited by
            Hi Chefkoch,
            ich habe auch Probleme. Im Log "stateChange: not ready" und ich kann nicht auf den Bus schreiben. In der Objektliste werden zumindest geänderte Zustände angezeigt, ausgelesen werden die Zustände beim Start aber nicht.
            In meinen Augen ist es unwahrscheinlich, dass es am KNX-IP-Adapter liegt, da ich zwei verschiedene ausprobiert habe (Loxone und Siemens 350).
            Wie sensibel ist der Import des ETS Projekte? In meinem ETS-Projekt habe ich nur einige DPT eingetragen – sollte das dann für diese Aktoren funktionieren? Oder führt eine unvollständige Angabe der DPT sofort dazu, dass gar nichts funktioniert? Meine Installation hat 270 Datenpunkte und bei einigen wird es echt schwierig, einen Status zu erhalten (z.B. uralte Dimmaktoren) – daher wäre ein toleranter Umgang mit dem Import wünschenswert 😛
            Was ist mit Sensoren, wie Temperatur? Werden die schon erkannt?
            Kann ich dir meine Projektdatei mal schicken?
            Gruß Jörg
            • chefkoch009
              chefkoch009 Developer last edited by
              Hallo edo,
              Das ist das Problem bei sehr alten Komponenten. Dabei hat man mitunter die Status- auf die Schaltenadresse gelegt und kein KO für die Rückmeldung.
              Ich würde mich freuen, wenn Du mir deinen ETS4/5 Export zur Verfügung stellen würdest.
              VG
              chefkoch009
              • chefkoch009
                Hallo KNXbroker,
                sry, das ich mich erst jetzt melde.
                Ja es gibt Probleme mit den Datenpunkten.
                Primär behandele ich erst mal Probleme beim Import und beim Adapterstart. Dabei bin ich auf jede Rückmeldung angewiesen und versuche diese Zeitnah zu beheben.
                Das soll nicht heissen, das ich bei den Datenpunkten nicht weitermache…..es geht halt nur nicht so schnell.
                Dafür bitte ich um Verständnis.
                Demnächst wird es wieder eine neue Version geben.
                VG
                chefkoch009
                  edo last edited by
                  @chefkoch009:
                  Hallo edo,
                  VG
                  chefkoch009 `
                  leider bin ich noch nicht berechtigt für PMs – schickst du mir kurz deine E-Mail-Adresse? Alternativ gerne Twitter.
                  • chefkoch009
                    Hallo edo,
                    Schalte dich für PM frei.
                    VG
                    Chefkoch009
                      edo last edited by
                      @chefkoch009:
                      Hallo edo,
                      VG
                      Chefkoch009 `
                      "Leider bist du nicht berechtigt, diese Funktion zu nutzen. Du hast dich vermutlich erst vor kurzem registriert und musst dich noch mehr im Board beteiligen, damit du diese Funktion nutzen kannst." …
                      • chefkoch009
                        An Alle Tester und Antwortschreiber,
                        ich habe soeben die Version 0.8.2 veröffentlicht.
                        Nach dem Update ist ein erneuter Import der knxproj Datei zwingend notwendig. Es werden dabei nur die zum Adapter gehörenden Parameter geändert / aktualisiert. Die Parameter für
                        Aleksa sollten erhalten bleiben.
                        Viel Spass beim Testen. Ich freue mich auf reges Feedback
                        VG
                        chefkoch009
                          Boergi last edited by
                          Hallo Chefkoch,
                          erstmal vielen Dank für deinen Adapter, ich habe ihn heute installiert und leider ein Problem bei der Inbetriebnahme.
                          Die Kommunikation mit dem Bus scheint zu funktioniert, ich bekomme zumindest die Status Rückmeldungen 0/1 der einzelnen Objekte. Will ich sie aber über Alexa steuern bekomme ich als Status nur false angezeigt. Außerdem kann er laut Log die Gruppenadressen nicht zuordnen, aber der Wert wird wie gesagt in der Objektliste dann doch angezeigt.
                          Ich verwende noch ETS 4 und habe damit auch das Projekt exportiert.
                          Vielleicht fällt dir ja was ein.
                          Danke,
                          Sebastian
                            my-knx-shop last edited by
                            Hallo Chefkoch,
                            danke für deine erneute fleissige Arbeit. Ich werde mich am WE mal ransetzen und es versuchen.
                            Aktuell funktioniert alles so schön, dass ich jetzt nicht sofort was anpassen will und dann keine Zeit habe ggf. etwas zu korrigieren.
                            Wie ist dass dann mit der neuen Version ?
                            Kann ich damit dann auch per Alexa schon dass dimmen und das Jalousie fahren realisieren oder ist das von dem anderen Adapter abhängig ?
                              edo last edited by
                              Hallo Chefkoch,
                              sorry für die späte Rückmeldung … danke – bei mir lassen sich jetzt zumindest die Verbraucher schalten. Was noch nicht funktioniert, ist der Rückmeldung, sodass ich Alexa nicht fragen kann: „ist die Deckenleuchte an?“. Heisst das, dass die GA nicht erfolgreich verknüpft wurde?
                              Jörg
                              • chefkoch009
                                Hallo
                                @Boergi:
                                Grundsätzlich werden Datenpunkte erzeugt, wenn der Datenpunkttyp eindeutig klar ist also:
                                1. Diese in der ETS zugeordnet wurden
                                2. Diese sich eindeutig aus der KNX-Geräte Konfigurationsdatei bestimmen lassen
                                Gruppenadressen werden immer entsprechend deiner Gruppenadressstruktur erzeugt, deshalb sind sie immer sichtbar.
                                Konnte nun aus o.g. Punkten kein DP erzeugt werden, so ist die GA trotzdem sichtbar, aber es erscheint die von Dir beschriebene Meldung. Solltest Du Punkt 1) korrekt vergeben haben,
                                würde ich mich freuen, wenn Du mir gestattest einen Blick in Deine export-Datei zu werfen.
                                @my-knx-shop:
                                Zu Aleksa kann ich nichts sagen, weil ich keins besitze. Dimmen mit DPT5 funktioniert. An der Jalousie bin ich am Testen
                                @edo:
                                Hast Du wie besprochen die Rückmeldungen in Deinen Geräten freigeschaltet und diese Verknüpft (Programmieren der Komponenten nicht vergessen 😉 ) ? Wie oben schon erwähnt, kann ich
                                zu Alexsa nicht viel / nichts sagen.
                                VG
                                chefkoch009
                                  Abend 😃
                                  Meiner Meinung nach müssten beide Punkte erfüllt sein, wenn du wirklich magst würde ich dir gerne mein KNX Projekt mal zukommen lassen, wie klappt das am besten?
                                  Gruß,
                                  Sebastian
                                    Ich kann dir leider noch keine PN schicken, vielleicht magst du mir einfach deine eMail Adresse per PN schicken dann geb ich dir die Teamviewer Zugangsdaten, danke.
                                    • chefkoch009
                                      das Problem bei Boergi ist der eibPort. Dazu hatte ich weiter oben schon was geschrieben.
                                      VG
                                      chefkoch009
                                        Vielen Dank nochmal für deine Hilfe. Ich hab mir heute eine neue IP Schnittstelle bestellt und hoffe dann deinen Adapter dann testen zu können.
                                          Ich muss jetzt nach dem Update mal fragen, da ich mich mit dem dimmen noch nicht im ioBroker beschäftigt hatte.
                                          Wenn ich im KNX Adapter nun einen Datenpunkt habe ( Wohnzimmer Esstisch dimmen ) der "DPST-5-1" hat und nun dort den Smartname hinzufüge um den Datenpunkt per Alexa ansteuern zu wollen, dann bekomme ich leider nicht im Cloud Adapter die das an aus % hoch runter angezeigt sondern weiterhin nur das an aus, obwohl beide Datenpunkte ( also schalten und dimmen ) drin sind.
                                          Wie macht Ihr das ?
                                            Ichhabe den Fehler selbst gefunden.
                                            Ich darf halt nicht den Schaltwert und den Dimmwert mit dem gleichen Namen belegen. Es reciht aus wenn man nur den Dimmwert nimmt und diesen dann für alles nutzt. schalten und dimmen.
                                            Ich dachte ich müsste zum dimmen einen Wert nehmen und zum dimmen einen Wert nehmen und dieses dann als Gruppe nutzen.
                                            Dimmen geht somit schonmal.
                                            Hat jemand einen Tipp wie ich Werte abfragen kann ?
                                            Also zum Beispiel.
                                            Alexa, ist Aussenbeleuchtung eingeschaltet ? Antwort: ja / nein
                                            Alexa, wie hoch ist der Wasserstand Zisterne ? Antwort: Der Wasserstand Zisterne ist xy Liter
                                            Alexa, wie hoch ist die Aussentemperatur ? Antwort: Die Aussentemperatur ist 15 Grad
                                            Danke Euch vorab
                                            1043
                                            345642
