    5. Telegram Anruf
    Telegram Anruf
      liv-in-sky @ghifunk last edited by
      @ghifunk
      dann bitte auch auf github einen 'daumen hoch' geben
        liv-in-sky last edited by
        bei mir funktioniert der anruf so:
        <block xmlns="https://developers.google.com/blockly/xml" type="request" id="2Bs`~72,]CB_AWuNZ=5W" x="1038" y="538">
         <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
         <field name="WITH_STATEMENT">TRUE</field>
         <field name="LOG"></field>
         <value name="URL">
           <shadow type="text">
             <field name="TEXT">http://api.callmebot.com/start.php?source=auth&amp;user=@Liv_in_sky&amp;text=This%20is%20a%20test%20from%20Callmebot&amp;lang=en-US-Standard-B</field>
           <block type="text_join" id="}i0rsU~z-|Op[BKF_iZs">
             <mutation items="5"></mutation>
             <value name="ADD0">
               <block type="text" id="l,667sh=U(R;FM=Sov!F">
                 <field name="TEXT">http://api.callmebot.com/start.php?source=auth&amp;user=</field>
             <value name="ADD1">
               <block type="text" id="@W6q15%YP}k^@rJ!2^F!">
                 <field name="TEXT">@name</field>
             <value name="ADD2">
               <block type="text" id="LZl(C-nJ5Tz+N]T/{JB+">
                 <field name="TEXT">&amp;text=</field>
             <value name="ADD3">
               <block type="text" id="IFX_(qkHt3Q6N,L=_G??">
                 <field name="TEXT">probier mal das</field>
             <value name="ADD4">
               <block type="text" id="+I^Cly[PbO.AhVy$9+0R">
                 <field name="TEXT">&amp;lang=de-DE-Standard-A</field>
           <block type="comment" id="|0.xm_XOM!LS!rSs)X6r">
             <field name="COMMENT">wertet anruf aus</field>
               <block type="comment" id="-F4qcF^_|lV81npxr3!|">
                 <field name="COMMENT">und setzt vari's für wiederholung</field>
                   <block type="debug" id="3#?6#v)FD47te_G/lNQ6">
                     <value name="TEXT">
                       <block type="variables_get" id="Id*/E$)`#z8X/PUo246A">
                         <field name="VAR" id="i2LQ+=xJVh:3^NtkAcE$">result</field>
                       <block type="comment" id="vL9[UfJaj1*6=#}39LN8">
                         <field name="COMMENT">hier anzahl der call-versuche</field>
                           <block type="controls_if" id="MrLDm/V9@-4J)cHR-tiA">
                               <block type="logic_operation" id="nMJ^%6TeLOmg,Y}Bs+*A" inline="false">
                                 <field name="OP">AND</field>
                                   <block type="logic_compare" id="z]ru/*L1H.(%I^=`?JJ^">
                                     <field name="OP">GT</field>
                                       <block type="text_indexOf" id="?Yr;KVQ4_fF}0oPS%=~h">
                                         <field name="END">FIRST</field>
                                           <block type="variables_get" id="^V,I_zJlxC#x8?!RU*)e">
                                         <value name="FIND">
                                             <field name="TEXT">abc</field>
                                           <block type="text" id="2=z1oHJVC%#-:fWT_e*w">
                                             <field name="TEXT">Missed Call</field>
                                       <block type="math_number" id="L`$),6jgM?joBAuv/+;t">
                                         <field name="NUM">0</field>
                                   <block type="logic_compare" id="qpo9~)rwFS}qO@O-0zl#">
                                     <field name="OP">LT</field>
                                       <block type="variables_get" id="Tyt+g;zShM-e6RN;1}K-">
                                         <field name="VAR" id="m6C(]?IK|wH{|pGVVx@F">countCalls</field>
                                       <block type="math_number" id="v3EAx)P,KTuqMESCu4Zk">
                                         <field name="NUM">10</field>
                               <block type="debug" id="ip`zCMcLZK]yGG3irApZ">
                                 <value name="TEXT">
                                     <field name="TEXT">Missed Call detected !!!</field>
                                   <block type="text_join" id=";5N?ll2OGwgi)gNa#qfU">
                                     <value name="ADD0">
                                       <block type="text" id="1r2${t@9SVx~T7DLJCYY">
                                         <field name="TEXT">Missed Call detected !!! ( </field>
                                     <value name="ADD1">
                                       <block type="variables_get" id="l,stwS-l;,F,R@p(E*4W">
                                     <value name="ADD2">
                                       <block type="text" id="8dIBT^xqNQ~`M`MYw*Ja">
                                         <field name="TEXT"> Versuch(e) )</field>
                                   <block type="variables_set" id="j}1t`EL,MPN_**1IGMmz">
                                     <field name="VAR" id="29eNbdg;U(3)s_]JhfG2">Misse4dCallsVar</field>
                                       <block type="logic_boolean" id="YUsIwKn.m!B6l|eglGEW">
                             <statement name="ELSE">
                               <block type="variables_set" id="Pi55sPX+yG6,:Wa1V8j:">
                                   <block type="logic_boolean" id="pL2ftE@oe~!)HZfPZiyR">
                                   <block type="variables_set" id="c,#~f*wm]2lwY!C^`G16">
                                       <block type="math_number" id="9z5px)}#.eTw=k-ReTy.">
          fastfoot @liv-in-sky last edited by
          in der main.js des Adapters wird der Konstanten axios ein Wert zugewiesen, woraufhin der Anruf fehlschlägt. Einfach Zeile 1262 auskommentieren bzw. natürlich im issue erwähnen, habe gerade wenig Zeit dafür
          //axios = axios || require('axios'); <=== ist unnötig und erzeugt Fehler durch Zuweisung an die Konstante axios (definiert in Zeile 27)
          liv-in-sky 1 Reply Last reply Reply Quote 2
            liv-in-sky @fastfoot last edited by
            @fastfoot
            super - danke funktioniert
            alle telegrm instanzen stoppen
            /opt/iobroker/node_modules/iobroker.telegram/main.js
            mit blockly getestet !
            F P 2 Replies Last reply Reply Quote 1
              @liv-in-sky sagte in Telegram Anruf:
              gerne, habe auch gleich noch einen PR gemacht, dann sollte das vom Tisch sein
              liv-in-sky 1 Reply Last reply Reply Quote 1
                @fastfoot habe es auch in github hinterlegt
                  habe ich gesehen, mit PR meinte ich die fertige Lösung welche nur noch akzeptiert werden muss damit die Codebase geändert wird.
                  liv-in-sky G 2 Replies Last reply Reply Quote 0
                    @fastfoot ok
                    Das ist ja ein Service hier:-) nochmals danke
                    falke69 1 Reply Last reply Reply Quote 0
                    • falke69
                      falke69 @liv-in-sky last edited by
                      @liv-in-sky
                      ich wollte gerade Dein Blockly importieren, dabei scheint es aber einen Fehler zu geben.
                      Also habe ich es nachgebaut, aber leider bekomme ich bei Telegram keinen Anruf rein.
                      Die Stelle in der main.js habe ich bereits auskommentiert und den Adapter neu gestartet.
                      Muss ich ggf. im Bot noch etwas einstellen?
                        liv-in-sky @falke69 last edited by liv-in-sky
                        @falke69
                        du nimmst das standard blockly von telegram, wenn der adpter in main.js geändert ist (unter sendto)
                        oder als javascript:
                        sendTo('telegram.1', 'call', {
                           text: 'Some text',
                           user: ''
                        • falke69
                          @liv-in-sky
                          danke für die schnelle Rückmeldung.
                          das mit diesem Baustein habe ich auch schon versucht.
                          Da bekomme ich aber folgende Fehlermeldung:
                          	Cannot make a call to @Test: <head> <script data-ad-client="ca-pub-120411544941234" async src="https://pagead2.googlesyndication.com/pagead/js/adsbygoogle.js"></script> </head> <!-- Global site tag (gtag.js) - Google Analytics --> <script async src="https://www.googletagmanager.com/gtag/js?id=UA-170177679-1"></script> <script> window.dataLayer = window.dataLayer || []; function gtag(){dataLayer.push(arguments);} gtag("js", new Date()); gtag("config", "UA-170177679-1"); </script> <font face="Courier New,Digital, Arial, Helvetica, sans-serif"><p>User @Test is not in the whitelist. Checking Authorization...<br>Using bot: @CallMeBot_API<p>Authorization for user @Test is not received.<p><font color="red">Warning! User not authorized. Click <a href="https://api2.callmebot.com/txt/auth.php">here</a> to authorize CallMeBot to contact you.</font>
                          Den Benutzernamen und die Zahlengrupen habe ich ersetzt.
                            @falke69 lass mal den user weg
                              @falke69 ich meinte den empfänger
                              muss den user angeben: '@Liv_in_sky'
                              • falke69
                                falke69 @liv-in-sky last edited by falke69
                                @liv-in-sky
                                da bekomme ich das:
                                Cannot make a call, because no users stored in telegram.0.communicate.users
                                Edit:
                                das wäre die Meldung ohne Benutzer.
                                Und das hier die Meldung mit Benutzer:
                                Ansonsten sollten die Einstellungen im Adaper stimmen.
                                Ich habe es anstelle des Benutzernamens auch mit der ID versucht, aber auch ohne Erfolg.
                                Alle anderen Blocklys, wo Telegram verbaut ist, funktionieren.
                                • falke69
                                  falke69 @falke69 last edited by
                                  @falke69
                                  So habe den Fehler gefunden:-)
                                  Anrufe waren in der App gesperrt. 😥
                                    ghifunk @fastfoot last edited by ghifunk
                                    @fastfoot
                                    Danke für die schnelle Antwort! Nach dem Auskommentieren der Zeile 1262 kommen nun die Sprachnachrichten an!
                                    Allerdings bekomme ich nach dem Ablauf der Meldung trotzdem noch einen Fehler im Protokoll angezeigt:
                                    kann jemand daraus erkennen, was da noch falsch läuft?
                                    was sagt mir "User @myname is not in the whitelist"?
                                    Danke für die Hilfe
                                    Gerhard
                                    • Glasfaser
                                      Glasfaser @ghifunk last edited by
                                      @ghifunk
                                      lese ein Beitrag über dir , er hatte das gleich und auch gelöst
                                      G Vumer 3 Replies Last reply Reply Quote 0
                                        ghifunk @Glasfaser last edited by
                                        @glasfaser
                                        hallo,
                                        nicht ganz, - die Sprachnachricht funktioniert ja, allerdings kommt trotzdem die Fehlermeldung.
                                          ghifunk @Glasfaser last edited by ghifunk
                                          @glasfaser
                                          Die gleiche Fehlermeldung kommt auch wenn ich den Anruf als javascript auslöse!03-11-_2021_17-20-52.jpg
                                          Der Anruf mit der Durchsage auf mein Handy erfolgt ohne Probleme!
                                          • Vumer
                                            Vumer @Glasfaser last edited by Vumer
                                            @ghifunk
                                            bei mir ist es genauso
                                            @glasfaser sagte in Telegram Anruf:
                                            leider nicht, der Anruf funktioniert
                                            45
                                            4996
