    4. [Neuer Adapter] Homepilot20
      Melle110 @homecineplexx last edited by
      @homecineplexx
      Natürlich... Danke
      VG Sven
      {"error_description":"OK","error_code":0,"payload":{"device":{"capabilities":[{"name":"WIND_STOP_CMD","read_only":false,"timestamp":-1},{"name":"INC_CMD","read_only":false,"timestamp":-1},{"name":"PROD_CODE_DEVICE_LOC","value":"23782076","read_only":false,"timestamp":-1},{"name":"GOTO_VENTIL_POS_CMD","read_only":false,"timestamp":-1},{"name":"REACHABILITY_EVT","value":"true","read_only":true,"timestamp":1627797694},{"name":"NAME_DEVICE_LOC","value":"Markise","read_only":false,"timestamp":-1},{"name":"INTF_ID_DEVICE_LOC","value":"3","read_only":false,"timestamp":-1},{"name":"GOTO_DAWN_POS_CMD","read_only":false,"timestamp":-1},{"name":"WIND_PROG_ACTIVE_EVT","value":"false","read_only":true,"timestamp":1627797694},{"name":"RAIN_START_CMD","read_only":false,"timestamp":-1},{"name":"REQ_STATUS_CMD","read_only":false,"timestamp":-1},{"name":"AUTO_MODE_CFG","value":"true","read_only":false,"timestamp":1627797694},{"name":"DAWN_AUTO_CFG","value":"false","read_only":false,"timestamp":1627797694},{"name":"ID_DEVICE_LOC","value":"1010045","read_only":false,"timestamp":-1},{"name":"PROTOCOL_ID_CFG","value":"49a2f9","read_only":false,"timestamp":-1},{"name":"WIND_DIR_CFG","value":"true","read_only":false,"timestamp":1627797694},{"name":"GOTO_POS_CMD","min_value":"0","max_value":"100","step_size":"1","read_only":false,"timestamp":-1},{"name":"SUN_STOP_CMD","read_only":false,"timestamp":-1},{"name":"SUN_AUTO_CFG","value":"false","read_only":false,"timestamp":1627797694},{"name":"STOP_CMD","value":"false","read_only":false,"timestamp":-1},{"name":"VIS_DEVICE_LOC","value":"true","read_only":false,"timestamp":-1},{"name":"WIND_AUTO_CFG","value":"true","read_only":false,"timestamp":1627797694},{"name":"OBSTACLE_DET_EVT","value":"false","read_only":true,"timestamp":1627797694},{"name":"BLOCK_DET_CFG","value":"true","read_only":false,"timestamp":1627797694},{"name":"WIND_START_CMD","read_only":false,"timestamp":-1},{"name":"OBSTACLE_DET_CFG","value":"true","read_only":false,"timestamp":1627797694},{"name":"BLOCK_DET_EVT","value":"false","read_only":true,"timestamp":1627797694},{"name":"POS_DOWN_CMD","read_only":false,"timestamp":-1},{"name":"DESCR_DEVICE_LOC","value":"Markise","read_only":false,"timestamp":-1},{"name":"CLOTH_TIGHT_CFG","value":"true","read_only":false,"timestamp":1627797694},{"name":"CURR_POS_CFG","value":"0","min_value":"0","max_value":"100","step_size":"1","read_only":false,"timestamp":1627797694},{"name":"POS_UP_CMD","read_only":false,"timestamp":-1},{"name":"VERSION_CFG","value":"1.1-1","read_only":false,"timestamp":1627797694},{"name":"RESET_WO_PAIR_CMD","read_only":false,"timestamp":-1},{"name":"PROT_ID_DEVICE_LOC","value":"49a2f9_1","read_only":false,"timestamp":-1},{"name":"VENTIL_POS_MODE_CFG","value":"false","read_only":false,"timestamp":1627797694},{"name":"ICONSET_LOC","value":"iconset7","read_only":false,"timestamp":-1},{"name":"OBSTACLE_DET_REVERSING_CFG","value":"true","read_only":false,"timestamp":1627797694},{"name":"DEVICE_TYPE_LOC","value":"2","read_only":false,"timestamp":-1},{"name":"ICONSET_INV_LOC","value":"false","read_only":false,"timestamp":-1},{"name":"ROTATE_DIR_CFG","value":"true","read_only":false,"timestamp":1627797694},{"name":"SUN_POS_CFG","value":"50","min_value":"0","max_value":"100","step_size":"1","read_only":false,"timestamp":1627797694},{"name":"RAIN_STOP_CMD","read_only":false,"timestamp":-1},{"name":"RMT_STOP_PAIR_CMD","read_only":false,"timestamp":-1},{"name":"VOICE_CONTROLLED_LOC","value":"Alexa","read_only":false,"timestamp":-1},{"name":"DUSK_AUTO_CFG","value":"false","read_only":false,"timestamp":1627797694},{"name":"CLOTH_RELIEVE_CFG","value":"true","read_only":false,"timestamp":1627797694},{"name":"VENTIL_POS_CFG","value":"80","min_value":"0","max_value":"100","step_size":"1","read_only":false,"timestamp":1627797694},{"name":"RESET_FULL_CMD","read_only":false,"timestamp":-1},{"name":"PUSH_CMD","read_only":false,"timestamp":-1},{"name":"PAIRING_CONFIRMED_LOC","value":"true","read_only":false,"timestamp":-1},{"name":"RMT_START_PAIR_CMD","read_only":false,"timestamp":-1},{"name":"SUN_PROG_ACTIVE_EVT","value":"false","read_only":true,"timestamp":1627797694},{"name":"GOTO_DUSK_POS_CMD","read_only":false,"timestamp":-1},{"name":"SUN_START_CMD","read_only":false,"timestamp":-1},{"name":"RAIN_PROG_ACTIVE_EVT","value":"false","read_only":true,"timestamp":1627797694},{"name":"RAIN_AUTO_CFG","value":"true","read_only":false,"timestamp":1627797694},{"name":"BLOCK_DET_REVERSING_CFG","value":"true","read_only":false,"timestamp":1627797694},{"name":"RMT_START_UNPAIR_CMD","read_only":false,"timestamp":-1},{"name":"RAIN_DIR_CFG","value":"true","read_only":false,"timestamp":1627797694},{"name":"TIME_AUTO_CFG","value":"false","read_only":false,"timestamp":1627797694},{"name":"PING_CMD","read_only":false,"timestamp":-1},{"name":"DEC_CMD","read_only":false,"timestamp":-1}],"scenes":[{"id":5500,"name":"Rauchmelder öffnet alle Rollos","description":"Rauchmelderalarm öffnet alle Rollos"}]}}}
        @homecineplexx
        vielen Dank... funktioniert...
        Sven
          @melle110 bitteschön, super das freut mich!!!
          viel spaß damit
            pk68 @homecineplexx last edited by
            Hallo @homecineplexx,
            wäre es möglich bei deinem Adapter auf Git in der Changlog neben der Version auch einen Timespamp mit einzutragen? Damit könnte man einfacher erkennen, ob ein Update verfügbar ist. Danke.
              @pk68 versteh nicht ganz was du damit meinst. du siehst ja welche version du hast und du siehst ja welche version auf git ist und damit weißt ja, dass du updaten könntest
              P TheBam 2 Replies Last reply Reply Quote 0
                @homecineplexx
                Ja das stimmt. Ich meinte so etwas. Hier ein Beispiel vom Zigbee-Adapter:
                Man könnte den Link zu Git im Browser öffnen, um zu schauen, ob es was Neues gibt. Die Version der Adapter habe ich nicht im Kopf. Das Datum würde da helfen. Ist jammern auf hohem Niveau.
                  luft-post last edited by
                  Moin zusammen,
                  genauso wie bei einigen Post weiter oben wird mein Log durch zwei Sonnen Sensoren durch
                  omepilot20.0
                  2021-10-27 08:27:16.405	warn	State value to set for "homepilot20.0.Sensor.1010004-16234511.timestamp" has value "-1" less than min "0"
                  Vollgeschrieben 😞
                  Gab es hierzu schon eine Lösung?
                  Hier der betroffene Datenpunkt:
                  gruß
                  Matthias
                    homecineplexx @luft-post last edited by
                    @luft-post hallo
                    ohne zu wissen welche version du hast, wirds schwer eine Aussage zu treffen!!
                    hast schon im git repository nachgeschaut?
                      luft-post @homecineplexx last edited by
                      @homecineplexx
                      Moin,
                      der Fehler hat sich erledigt. Hatte noch eine sehr alte Version drauf, hatte nicht gewusst dass der Manuel geupdaten werden muss.
                      gruß
                      Matthias
                      • TheBam
                        TheBam @homecineplexx last edited by
                        @homecineplexx
                        Danke für den Adapter habe ihn gestern auch installiert und getestet. Ging sehr gut mit der Bridge und dem rollotron 1200.
                        Warum bringst du den Adapter denn nichts ins repro?
                          homecineplexx @TheBam last edited by
                          @thebam weil ich mir da ansehen müsste wie das geht 😉
                          TheBam 1 Reply Last reply Reply Quote 0
                          • TheBam
                            @homecineplexx
                            Eigentlich recht einfach
                            https://github.com/ioBroker/ioBroker.repositories
                            • Bommelpage
                              Bommelpage @aca_home last edited by
                              @aca_home sagte in [Neuer Adapter] Homepilot20:
                              Als erstes will ich mich für die tolle Arbeit von euch bedanken! Echt klasse Job!
                              Bin noch neu in dem Bereich, habe jedoch bis jetzt alle meine Homepilot Geräte anbinden können.
                              Wollte mich jetzt an die Szenen rantrauen die im Homepilot abgespeichert sind. Das klappt leider nur teolweise.
                              Es geht bei mir um Szenen die automatisch ausgeführt werden, z.B. bei Morgendämmerung.
                              Ich würde gerne bestimmte Szenen über Button aktivieren und deaktivieren können.
                              Leider verhält es sich so, dass wenn ich mit Checkbox oder Button die Szene auf 1 setzen will, diese kurz gesetzt wird und dann gleich wieder auf 0 überspring.
                              Ich verwende den Datenpunkt "active"
                              Mache ich da irgendwas falsch oder habe ich was nicht bedacht?
                              Hoffe ihr könnt mir helfen!
                              Servus,
                              hab das gleiche Problem das ich die Szenen nicht Aktivieren kann,
                              nur Kurz egal ob über Objekte oder JS,
                              hat einer eine Idee,
                              hompilot20.0 V0.0.31
                              sonst funktioniert der Adapter Top mit meinen Rademacher Geräten
                                homecineplexx @Bommelpage last edited by
                                @bommelpage versuch bitte mal die 0.0.32 Version!
                                danke
                                Bommelpage 1 Reply Last reply Reply Quote 0
                                • Bommelpage
                                  Bommelpage @homecineplexx last edited by
                                  @homecineplexx Servus,
                                  klasse, funktioniert mit Version0.0.32
                                  kann mit dem Datenpunkt active jetzt Szenen aktivieren und deaktivieren
                                  getestet manuell und auch mit Blockly script
                                  Vielen Vielen Dank
                                  Und Frohe Weihnachten noch
                                    Rolf 0 @homecineplexx last edited by
                                    @homecineplexx Danke, hat auch mir geholfen 🙂
                                      Jurist last edited by Jurist
                                      ich bin noch Neuling in Sachen iobroker und versuche gerade die Bridge über den Adapter homepilot20 einzubinden.
                                      NAch ewigem rumprobieren habe ich den adapter auch installiert bekommen. Mir wird aber bei Objekten nur der Admin Ordner angezeigt.
                                      Wo kann ich denn die IP für die bridge eingeben, damit diese auch gefunden wird? Bei den Instanzen wird mir der Adapter übrigens bisher nicht angezeigt.
                                      Habe nochmals installiert: Dies ist das InstallationsLOG:
                                      Immer noch nichts in den Instanzen....
                                      Vieleicht könnt Ihr mir ja weiterhelfen....
                                      Jetzt hat es geklappt!!!
                                      DANKE!!
                                        homecineplexx @Jurist last edited by
                                        @jurist hallo
                                        nur den Adapter zu installieren reicht nicht...du musst auch eine Instanz installieren, sonst klappt das nicht und dann bekommst du unter Instanzen auch ein Menü, wo du die IP eingeben kannst.
                                        Funktioniert eigentlich bei allen Adaptern gleich
                                        • Bommelpage
                                          Bommelpage last edited by Bommelpage
                                          Servus
                                          hab grad den Rademacher addZ-Stick für die Zigbee-Leuchten in meinen Homepilot eingesteckt
                                          und dazu eine addZ Wihte+Colour KerzeE14 angeschlossen.
                                          Im Moment steuere ich sie über angelegte Szenen im Hompilot2 Ein/Aus/Farbwechsel und steuere diese Szenen im IOBroker indem ich sie über den Adapter.homepilot20 unter Scene und execute steuere.
                                          Das klappt soweit ganz gut.
                                          Unter Actuator werden die Leuchtmittel zwar erkannt aber mehr auch nicht.
                                          Steuern kann man sie nicht.
                                          Hab mal unter <homepilot-ip>/v4/devices?devtype=Actuator einige Einstellungen ausgelesen
                                          Falls jemand 😀 den Adapter anpassen will
                                          Gedimmt wir über "Position" und anscheinend auch ausgeschalten
                                          Der Farbmodus wir über "colormode" eingestellt rgb für Farbe und ct für warm-weiss
                                          Die Farbe wird über "rgb" eingestellt
                                          Und die Farbtemperatur über "colortemperature"
                                          Einstellung Color RGB Farbe Blau und Dimmer 100% :
                                          {"response":"get_visible_devices","devices":[{"description":"Lampe im Wohnzimmerschrank","deviceGroup":71,
                                          "did":1010053,"hasErrors":0,"iconSetInverted":0,"iconSet":{"k":"iconset40"},"messages":[],"name":"Schranklampe",
                                          "properties":{"closingContact":3,"dawn":3,"dusk":3,"motion":3,"rain":3,"smartphone":3,"smoke":3,"sun":3,
                                          "temperature":3,"time":3,"trigger":3,"warning":3,"wind":3},"statusValid":true,
                                          "statusesMap":{"Position":100,"colortemperature":500,"rgb":"0xFF361A","colormode":"rgb"},
                                          "visible":true,"deviceNumber":"35144001","uid":"ZIG_847127FFFE950574","voiceControlledBy":"Google","origin":"HomePilot"},
                                          Einstellung Color RGB Farbe Rot und Dimmer 50% :
                                          "statusesMap":{"Position":50,"colortemperature":500,"rgb":"0xFF361A","colormode":"rgb"},
                                          Einstellung Warm-Weiss Farbe Warm und Dimmer 50% :
                                          "statusesMap":{"Position":50,"colortemperature":483,"rgb":"0xFFAA39","colormode":"ct"},
                                          Einstellung Warm-Weiss Farbe Weiss und Dimmer 100% :
                                          "statusesMap":{"Position":100,"colortemperature":159,"rgb":"0xF8FFFB","colormode":"ct"},
                                          Einstellung Color RGB Lampe ausgeschalten :
                                          "statusesMap":{"Position":0,"colortemperature":153,"rgb":"0x001BFF","colormode":"rgb"},
                                          Abfrage /v4/devices/1010053 :
                                          {"response":"get_device","device":{"description":"Lampe im Wohnzimmerschrank","deviceGroup":71,"did":1010053,"hasErrors":0,"iconSetInverted":0,"iconSet":{"k":"iconset40"},"messages":[],"name":"Schranklampe","properties":{"closingContact":3,"dawn":3,"dusk":3,"motion":3,"rain":3,"smartphone":3,"smoke":3,"sun":3,"temperature":3,"time":3,"trigger":3,"warning":3,"wind":3},"statusValid":true,"statusesMap":{"Position":0,"colortemperature":153,"rgb":"0x001BFF","colormode":"rgb"},"visible":true,"deviceNumber":"35144001","uid":"ZIG_847127FFFE950574","voiceControlledBy":"Google","origin":"HomePilot","sceneConfig":["DIRECT_FUNCTION_CMD","TURN_ON_CMD","TURN_OFF_CMD","GOTO_POS_CMD","SET_COLOR_TEMP_CMD","SET_HUE_CMD","SET_RGB_CMD"]}}
                                            mwolle last edited by
                                            Moin zusammen,
                                            ich habe eine Bewegungssensor 9484 am Laufen. Der wird auch schön erkannt im iobroker und im Adapter. Mir fehlt aber z.B. eine Einstellung wie Automatik und manueller Betrieb. Oder ist es der Eintrag?
                                            BUTTON_MODE_CFG? Der gibt aber nur true und false zurück.
                                            adapter
                                            56
                                            261
                                            36587
