    4. JavaScript
    5. [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten
      ticaki @sigi234 last edited by ticaki
      @sigi234
      Recht hast du:
      in zeile 116 muß
      const DWD2 = 8; // only for request
      eingefügt werden, das sieht dann so aus:
      const DWD = 1;
      const UWZ = 2;
      const NINA = 4;
      hatte ich vergessen.
        sigi234 Forum Testing Most Active @ticaki last edited by sigi234
        @ticaki
        Sieht schon besser aus.
        javascript.0
        2021-11-05 23:35:59.418	info	script.js.Sigi.UWZ_DWD_NINA9: registered 7 subscriptions and 1 schedule
        javascript.0
        2021-11-05 23:35:59.136	info	script.js.Sigi.UWZ_DWD_NINA9: Add UWZ/DWD warning to database. id: dwd.0.warning.object headline: Amtliche WARNUNG vor FROST
        javascript.0
        2021-11-05 23:35:59.073	info	script.js.Sigi.UWZ_DWD_NINA9: Skripts gestartet: ID:8153.694522928418
        javascript.0
        2021-11-05 23:35:59.069	info	Start javascript script.js.Sigi.UWZ_DWD_NINA9
        javascript.0
        2021-11-05 23:35:58.513	info	script.js.Sigi.UWZ_DWD_NINA9: Skripts gestoppt: ID:7213.070693352865
        javascript.0
        2021-11-05 23:35:58.513	info	Stop script script.js.Sigi.UWZ_DWD_NINA9
        javascript.0
        2021-11-05 23:35:58.423	info	script.js.Sigi.UWZ_DWD_NINA9: Neustart durch Skripts wird ausgeführt!
        javascript.0
        2021-11-05 23:35:58.134	info	script.js.Sigi.UWZ_DWD_NINA9: registered 7 subscriptions and 1 schedule
        javascript.0
        2021-11-05 23:35:57.840	info	script.js.Sigi.UWZ_DWD_NINA9: Add UWZ/DWD warning to database. id: dwd.0.warning.object headline: Amtliche WARNUNG vor FROST
        javascript.0
        2021-11-05 23:35:57.677	info	script.js.Sigi.UWZ_DWD_NINA9: Skripts gestartet: ID:7213.070693352865
        javascript.0
        2021-11-05 23:35:57.669	info	Start javascript script.js.Sigi.UWZ_DWD_NINA9
        javascript.0
        2021-11-05 23:35:55.671	info	script.js.Sigi.UWZ_DWD_NINA9: Skripts gestoppt: ID:4056.6884127745693
        javascript.0
        2021-11-05 23:35:55.670	info	Stop script script.js.Sigi.UWZ_DWD_NINA9
        javascript.0
        2021-11-05 23:35:55.313	warn	at processImmediate (internal/timers.js:463:21)
        javascript.0
        2021-11-05 23:35:55.313	warn	at Immediate._onImmediate (C:\Program Files\iobroker\Home\node_modules\iobroker.javascript\lib\sandbox.js:1967:33)
        javascript.0
        2021-11-05 23:35:55.312	warn	State "javascript.0.wetterwarnung.data.uwz.warning4.object" not found
        javascript.0
        2021-11-05 23:35:55.310	warn	at processImmediate (internal/timers.js:463:21)
        javascript.0
        2021-11-05 23:35:55.310	warn	at Immediate._onImmediate (C:\Program Files\iobroker\Home\node_modules\iobroker.javascript\lib\sandbox.js:1967:33)
        javascript.0
        2021-11-05 23:35:55.298	warn	State "javascript.0.wetterwarnung.data.dwd.warning4.object" not found
        javascript.0
        2021-11-05 23:35:55.005	info	script.js.Sigi.UWZ_DWD_NINA9: Neustart durch Skripts wird ausgeführt!
        javascript.0
        2021-11-05 23:35:54.783	info	script.js.Sigi.UWZ_DWD_NINA9: registered 7 subscriptions and 1 schedule
        javascript.0
        2021-11-05 23:35:54.412	info	script.js.Sigi.UWZ_DWD_NINA9: Add UWZ/DWD warning to database. id: dwd.0.warning.object headline: Amtliche WARNUNG vor FROST
        javascript.0
        2021-11-05 23:35:53.687	info	script.js.Sigi.UWZ_DWD_NINA9: Skripts gestartet: ID:4056.6884127745693
        javascript.0
        2021-11-05 23:35:53.646	info	Start javascript script.js.Sigi.UWZ_DWD_NINA9
        javascript.0
        2021-11-05 23:35:53.593	info	Stop script script.js.Sigi.UWZ_DWD_NINA9
        1. Skriptstart:
        23:38:28.014	info	javascript.0 (7748) Stop script script.js.Sigi.UWZ_DWD_NINA9
        23:38:28.015	info	javascript.0 (7748) script.js.Sigi.UWZ_DWD_NINA9: Skripts gestoppt: ID:8153.694522928418
        23:38:28.126	info	javascript.0 (7748) Start javascript script.js.Sigi.UWZ_DWD_NINA9
        23:38:28.138	info	javascript.0 (7748) script.js.Sigi.UWZ_DWD_NINA9: Skripts gestartet: ID:5654.143748022449
        23:38:28.481	info	javascript.0 (7748) script.js.Sigi.UWZ_DWD_NINA9: Add UWZ/DWD warning to database. id: dwd.0.warning.object headline: Amtliche WARNUNG vor FROST
        23:38:29.420	info	javascript.0 (7748) script.js.Sigi.UWZ_DWD_NINA9: registered 7 subscriptions and 1 schedule
          @sigi234
          Ich werde das demnächst auf async umstellen, aktuell dauert das beenden des Skript so lange das es noch zeit hat Fehler wegen States auszulösen.
            Alpha 4
            -CreateStateAsync() eingefügt
            -AlertStates sollten gehen.
              @ticaki
              Ganzes Skript ändern, oder ab 123456?
                @sigi234 12345
                  Thomas Braun Most Active @ticaki last edited by
                  @ticaki
                  Was soll ich denn hier machen:
                  2021-11-06 21:41:02.990  - error: javascript.0 (1880) script.js.common.dwd_uwz_nina_warnungen: Alexa - Serial HIER_SERIENNUMMER ist fehlerhaft. Überpüfen! Object ID:alexa2.0.Echo-Devices.HIER_SERIENNUMMER.Commands.announcement
                  Ich find da keinen Fehler. Die HIER_SERIENNUMMER ist jedenfalls richtig.
                    ticaki @Thomas Braun last edited by ticaki
                    @thomas-braun sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
                    Die Fehlermeldung bedeutet das er den State
                    nicht finden kann. gibts vielleicht kein announcement unter der id oder ist dein Alexa nicht alexa2.0 ?
                    Am einfachsten kopierst du den State aus der Fehlermeldung in der Objekte-Ansicht oben in das Suchfeld für States.
                      Thomas Braun Most Active @ticaki last edited by Thomas Braun
                      @ticaki
                      Aus dem Log:
                      javascript.0 (1880) script.js.common.dwd_uwz_nina_warnungen: Alexa - Serial G090LF1072420LXG ist fehlerhaft. Überpüfen! Object ID:
                      alexa2.0.Echo-Devices.G090LF1272420LXG.Commands.announcement
                      Aus der Objekt-Übersicht:
                      Stimmt für mich...
                        @ticaki
                        Ich habe jetzt nur noch ein Echo-Device drin, zuvor zwei. Jetzt wird der zwar nicht mehr angemeckert, aber dafür wird das skript nun im Sekundentakt neugestartet.
                        [Edit: Typo gehabt, läuft jetzt]
                          Gut 🙂
                            Hab beim letzten Update scheinbar den Push vergessen.
                            Bis auf eventuelle Fehler ist der Einbau jetzt Fertig.
                            • DWD/DWD2 erhalten einen Datenpunkt EC_II bei DWD2 (Gemeindedatenbank) gibt es deutlich mehr Typen.
                            • hab Alexa + Telegram getestet mit DWD2 das geht und bis jetzt keine Fehler.
                            • die Warncellid für DWD2 Flensburg z.B. ist 801001000
                            • Schon länger drin, wenn ich es nicht vergesse wie bei DWD2 wird ein vorgezogener Test durchgeführt, ob neue Variablen auch in euren lokalen Skripts vorhanden sind und wenn nicht eine brauchbare Warnung ausgegeben. So einfach von 123456 kopieren und wenns ne Warnung gibt, die benannte Variable auf Github suchen und rüber kopieren.
                              @ticaki
                              Wichtig: ab wann muss das Skript UWZ angepasst werden?
                                @sigi234
                                Die Frage verstehe ich nicht. Das Extrascript UWZ sollte jetzt überflüssig sein.
                                sigi234 J 2 Replies Last reply Reply Quote 0
                                  @ticaki sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
                                  @sigi234
                                  Jupp, Denkfehler.
                                    jwerlsdf @ticaki last edited by
                                    @ticaki
                                    bei mir gibt es ein Kompilierungsfehler
                                    javascript.0 (25956) script.js.DWD compile failed: at script.js.DWD:2796
                                    Folgende Zeile ist es:
                                    const TELEGRAM = konstanten[0].value;
                                    Ich benutze Telegram.
                                    Weiterhin folgende Frage:
                                    Du hast gesagt, man benötigt das UWZ-Skript nicht mehr. In dem Skript wird aber weiterhin auf einen Datenpunkt javascript.0.uwz verwiesen. Ist dieser überflüssig geworden oder wie kann ich das verstehen?
                                    Benutze die Version 0.97.99.6 Alpha 4.
                                    Vielen Dank.
                                      ticaki @jwerlsdf last edited by ticaki
                                      @jwerlsdf
                                      Ich benutze ebenfalls telegram und hab keine Kompilierungsfehler. Vergleiche mal die paar Zeilen darüber mit der Version von Github(nicht die Kommentare). Hab gerade das Skript von Github unkonfiguriert gestart und bis auf meine Fehlermeldungen, wegen fehlenden Daten ist da nix.
                                      Du kannst das Skript mit einem externen UWZ Skript benutzen oder die interne Version. Sobald du
                                      var uwzWarncellId = '';
                                      mit etwas befüllst, wird der Teil des Codes der auf Datenpunkte zugreift um die UWZ Daten zu bekommen deaktiviert und die interne Version wird benutzt.
                                        @ticaki
                                        so sieht es bei mir aus:
                                        var konstanten = [
                                            {'name':'telegram','value':1,count:0, delay:200, maxChar: 4000 },
                                            {"name":'pushover',"value":2, count:0, delay:1000, maxChar: 1000},
                                            {"name":'email',"value":4},
                                            {"name":'sayit',"value":8, count:0, delay:0, maxChar: 940},
                                            {"name":'home24',"value":16, count:0, delay:0},
                                            {"name":'alexa',"value":32, count:0, delay:0, maxChar: 940},
                                            {"name":'state',"value":64},
                                            {"name":'iogo',"value":128, maxChar: 940, count: 0, delay: 300},
                                            {"name":'state_html',"value":256}
                                        const PUSHOVER = konstanten[1].value;
                                        const EMAIL = konstanten[2].value;
                                        const SAYIT = konstanten[3].value;
                                        const HOMETWO = konstanten[4].value;
                                        const ALEXA = konstanten[5].value;
                                        Den Code habe ich direkt von Github benutzt,.
                                          @jwerlsdf
                                          var mainStatePath = 'javascript.0.wetterwarnung_test.';
                                          und hier?
                                          So Fehlermeldungen gibts in der Regel wegen fehlenden } oder ' oder zuvielen davon.
                                            @ticaki
                                            var mainStatePath = '0_userdata.0.Wetterwarnung.';
                                            1521
                                            568030
