    4. IO ERROR states.json
      papper371 @Thomas Braun last edited by Homoran
      Ausgabe ist:
      [Sun Nov  7 19:24:10 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:640x480M@60 smsc95xx.macaddr=DC:A6:32:2E:7E:4F vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=97709164-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Sun Nov  7 19:24:11 2021] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [Sun Nov  7 19:24:11 2021] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Sun Nov  7 19:24:13 2021] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      Habe jetzt laut der kleinen Werkzeugkiste die nodejs nochmal richtig gerückt. Lag alles in /usr/local/bin/.. stimmt jetzt wieder.
      Weiterhin habe ich aber den Fehler den ich schon beschrieben habe. Hier mal das Log der Node-Red instanz, welche auch den beschriebenen IO Fehler zeigt.
      node-red.0
      2021-11-07 20:46:27.648	error	7 Nov 20:46:27 - [error] Error: EPERM: operation not permitted, copyfile '/media/hdd/iobroker/iobroker-data/node-red/.config.nodes.json' -> '/media/hdd/iobroker/iobroker-data/node-red/.config.nodes.json.backup'
      node-red.0
      2021-11-07 20:46:27.646	error	7 Nov 20:46:27 - [error] Failed to start server:
      node-red.0
      2021-11-07 20:46:09.423	info	Starting node-red: --max-old-space-size=128 /media/hdd/iobroker/node_modules/node-red/red.js -v --settings /media/hdd/iobroker/iobroker-data/node-red/settings.js
      node-red.0
      2021-11-07 20:46:08.401	error	install: [""]
      node-red.0
      2021-11-07 20:46:08.260	info	starting. Version 2.4.0 in /media/hdd/iobroker/node_modules/iobroker.node-red, node: v14.18.1, js-controller: 3.2.16
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      MOD EDIT: Code in code-tagsgesetzt!
        Thomas Braun Most Active @papper371 last edited by
        @papper371
        Les ich nicht. CodeTags verwenden.
          @thomas-braun Was sind CodeTags?
            @papper371
            Konsolentext markieren, </> Icon anklicken. Dann wird die Buchstabensuppe lesbar.
              @thomas-braun Danke
                Thomas Braun Most Active @papper371 last edited by Thomas Braun
                @papper371
                Wo kommt das merkwürdige Installationsverzeichnis her? Iobroker liegt eigentlich in /opt/iobroker , nicht im mountpunkt für Wechselmedien.
                ls -la /usr/bin/iob
                Und mal
                mount | sort | grep ^/dev
                Den höchstwahrscheinlich mitlaufenden Desktop knipst du auch aus. Das hat auf einem Server nix verloren.
                Schaut für mich insgesamt nach einer komplett verpfuschten Installation aus.
                  Wie ich den iobroker auf der HDD installiert habe (Anleitung dazu finde ich nicht mehr, ist schon was länger her) sollte ein statischer Link vom Speicherort /opt/iobroker auf den HDD Speicherort installiert werden. Wie das genau war kann ich nicht mehr nachvollziehen. Bisher hat das auch immer vernünftig funktioniert.
                  lrwxrwxrwx 1 root root 22 Nov  6 19:58 /usr/bin/iob -> /opt/iobroker/iobroker
                  Wie gesagt habe ich auch nur das Problem mit dieser einen Datei. Selbst im Explorer auf dem Raspy lässt sich die Datei nicht öffnen. Sie wird als corrupt angezeigt.
                  pi@HomeMaster:~ $ mount | sort | grep ^/dev
                  /dev/mmcblk0p1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
                  /dev/mmcblk0p2 on / type ext4 (rw,noatime)
                  /dev/sda1 on /media/hdd type fuseblk (rw,noatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096)
                    @papper371
                    Ist kompletter Quark. Auf der Festplatte ist NTFS als Dateisystem, da installiert man nix unixoides drauf.
                      @thomas-braun was kann ich den machen um meinen iobroker noch zu retten. Hatte dies ja nach Anleitung gemacht und hat bisher super funktioniert.
                        Thomas Braun Most Active last edited by
                        @papper371
                        Es sind halt auch leider ziemlich viele Schwachsinns-Anleitungen zu finden.
                          Ich denke, dass ich den iobroker komplett neu aufsetze. Welche Anleitung sollte man den benutzen um diesen auf die hdd zu bringen?
                            @papper371
                            Ich hab sowas nicht im Einsatz. Aber gemeinhin wird die SSD mit ext4 formatiert und dann via fstab und blkid auf / eingehängt. Dann kann man da ganz normal ohne irgendwelche Links auf NTFS-Filesysteme den ioBroker installieren.
                            Ich glaube neuere Raspberry Pi können auch direkt von USB booten.
                            Such dir eine Anleitung die entweder so oder so vorgeht.
                            Und nimm ein Raspberry OS Lite (ohne Desktop-Oberfläche).
                            709
