    4. [Anleitung] WireGuard mit WireGuard-UI auf Proxmox
    • Negalein
      Negalein Global Moderator @CrunkFX last edited by
      @crunkfx sagte in [Anleitung] WireGuard mit WireGuard-UI auf Proxmox:
      wget https://raw.githubusercontent.com/KleSecGmbH/ioBroker/main/wireguard/installer-pve.sh -O installer-pve.sh && bash installer-pve.sh
      das passt so?
      WireGuard is already installed.
      Select an option:
         1) Add a new client
         2) Remove an existing client
         3) Remove WireGuard
         4) Exit
      Option: 4
      und dann
      root@Wireguard-VPN:~# cd /root/wireguard-ui
      root@Wireguard-VPN:~/wireguard-ui# docker-compose up
      Creating wgui ... error
      ERROR: for wgui  Cannot create container for service wg: Conflict. The container name "/wgui" is already in use by container "e0fec4ebac7cc702789c13850ce574d71ac7641eef0822170a0ef8e640fdd36d". You have to remove (or rename) that container to be able to reuse that name.
      ERROR: for wg  Cannot create container for service wg: Conflict. The container name "/wgui" is already in use by container "e0fec4ebac7cc702789c13850ce574d71ac7641eef0822170a0ef8e640fdd36d". You have to remove (or rename) that container to be able to reuse that name.
      ERROR: Encountered errors while bringing up the project.
      root@Wireguard-VPN:~/wireguard-ui# docker stop e0fec4ebac7cc702789c13850ce574d71ac7641eef0822170a0ef8e640fdd36d
      root@Wireguard-VPN:~/wireguard-ui# docker system prune -a
      WARNING! This will remove:
        - all stopped containers
        - all networks not used by at least one container
        - all images without at least one container associated to them
        - all build cache
      Are you sure you want to continue? [y/N] y
      Deleted Containers:
      Deleted Networks:
      root_default
      Deleted Images:
      untagged: ngoduykhanh/wireguard-ui:latest
      untagged: ngoduykhanh/wireguard-ui@sha256:6f9a448d59a8d1caa73d3f4285ed8d257e1e55e179167e8ed630aea57592ad33
      deleted: sha256:4db588911bec98259b309558c77f106992814e6c2025d3ef4f7651a93e124008
      deleted: sha256:ce0601e1deda628bdbd314b66f98988398e206859d36237e10b9086cfaa31d3d
      deleted: sha256:6e4d16753cb5c6debe89482b1dd5f60eb3c8b4f09ffadb39b9a0a69e99b0cd25
      deleted: sha256:a364fcb7bc7d58162843c941803d87acc3571b038c1faef7431e6055741511bb
      deleted: sha256:4d93b92cf1a9a6f74075fe749df60271bd6b71fe991b6df6ca22e984a9244d5a
      deleted: sha256:14d0173ae5d18cffb7f01aab806a6edfbdf7b22a75b8a77f68db0ca6e84d4d23
      deleted: sha256:7e630ca8e05efa3aeae00e8fd435735fa62e8992d8ee3d2ca793468e2f36fd28
      deleted: sha256:9a5d14f9f5503e55088666beef7e85a8d9625d4fa7418e2fe269e9c54bcb853c
      Total reclaimed space: 48.83MB
      root@Wireguard-VPN:~/wireguard-ui# docker-compose up -d
      Pulling wg (ngoduykhanh/wireguard-ui:latest)...
      latest: Pulling from ngoduykhanh/wireguard-ui
      ddad3d7c1e96: Pull complete
      6469142f90ff: Pull complete
      700aafca4b83: Pull complete
      6849e6313309: Pull complete
      11e88fa8b517: Pull complete
      0353d820a55a: Pull complete
      3af261a56413: Pull complete
      Digest: sha256:6f9a448d59a8d1caa73d3f4285ed8d257e1e55e179167e8ed630aea57592ad33
      Status: Downloaded newer image for ngoduykhanh/wireguard-ui:latest
      Creating wgui ... done
      CrunkFX 2 Replies Last reply Reply Quote 0
      • CrunkFX
        CrunkFX Forum Testing @Negalein last edited by
        @negalein Jawoll
        • CrunkFX
          @negalein Dann müsste bei connected peers was drin stehen f605fe0a-5c63-4902-a61b-0b9f1b02e39e-image.png
          • Negalein
            Negalein Global Moderator @Negalein last edited by
            @CrunkFX
            @negalein sagte in [Anleitung] WireGuard mit WireGuard-UI auf Proxmox:
            @CrunkFX
            beim Import am Handy (oder auch QR-Scan) schreibt er ungültiger Name.
            Wäre hier IP 10.0.1.1/24 richtig?
            10.0.1.x ist mein internes Netz.
            Ist aber bis auf Name & IP (hier soll der gesamte IP-Bereich gelten) alles gleich.
            CrunkFX 1 Reply Last reply Reply Quote 0
            • Negalein
              kann ich morgen sagen. Komm gerade nicht auf die Fritz zwecks Weiterleitung
              • CrunkFX
                @negalein Nicht ganz
                cc106bc5-b492-4032-8295-1f17ad5c62b1-image.png so z.B. hat der Client nur Zugriff auf die IP´s 192.168.1.1-192.168.1.254
                Also
                x.x.x.0/24 für alle
                x.x.x.0/32 für 1
                • Negalein
                  ah, gecheckt
                  und was bedeutet 0.0.0.0/0
                  das finde ich bei Tante Goggerle nicht
                  • CrunkFX
                    @negalein AllowedIPs = 0.0.0.0/0
                    dadurch weist du den Wireguard-Client an, sämtlichen Verkehr über die VPN-Verbindung zu schicken. Wenn du nur den Zugriff zu einem Gerät zulassen möchtest, dann musst du dort nur die jeweiligen IP-Adressen eintragen, die über die Verbindung getunnelt werden sollen.
                    Möglich ich m.E auch 192.168.1.2/32, das sollte auch gehen. Da beim 32er Subnet ohnehin nur ein Gerät angesprochen werden kann.
                    • Negalein
                      ok, aber mit 0.0.0.0/0 hat er immer "schreibt er ungültiger Name" beim Import der .conf oder dem QR geschrieben.
                      Erst mit 10.0.1.0/24 gings.
                      Oder ist das mit "sämtlichen Verkehr über die VPN-Verbindung zu schicken" anders gemeint?
                      • CrunkFX
                        @negalein Ne eig. nicht, ich kann den Fehler auch nicht nachstellen
                          crunchip Forum Testing Most Active @CrunkFX last edited by
                          docker-compose up
                          nachdem ich nun nochmals ab da probiert habe, kam nur noch error Meldung bzw hat ewig geladen.
                          Letztendlich habe ich nun den LXC neu aufgesetzt, mit der neuen Version, habe den CT wie beschrieben neu gestartet, trotzdem habe ich wieder einen leeren Status.
                          • CrunkFX
                            CrunkFX Forum Testing @crunchip last edited by
                            @crunchip Was sagt der Befehl
                            wg
                              @crunkfx
                              interface: wg0
                                public key: kPKZIn5yubBiweatmmNo5mWhVhBFIVrA3Ko2ZQUY0Fk=
                                private key: (hidden)
                                listening port: 51820
                              • CrunkFX
                                @crunchip OK sehr gut. Zeig mal bitte den Output von
                                nano /root/wireguard-ui/docker-compose.yml
                                  @crunkfx ich bekomm aktuell aber auch keine Verbindung mehr zu stand, am Handy baut sich keine Seite mehr auf
                                  version: '3'
                                  services:
                                    wg:
                                      image: ngoduykhanh/wireguard-ui:latest
                                      container_name: wgui
                                      ports:
                                        - 5000:5000
                                      logging:
                                        driver: json-file
                                        options:
                                          max-size: 50m
                                      volumes:
                                        - ./db:/app/db
                                        - /etc/wireguard:/etc/wireguard
                                      restart: always
                                      cap_add:
                                          - NET_ADMIN
                                      network_mode: host
                                  • CrunkFX
                                    @crunchip Hast du daran gedacht?
                                    Dazu im Fenster WireGuard Server unter dem Punkt Post Up Script folgendes eintragen:
                                    iptables -A FORWARD -i %i -j ACCEPT; iptables -A FORWARD -o %i -j ACCEPT; iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
                                    und um Feld Post Down Script folgendes eintragen:
                                    iptables -D FORWARD -i %i -j ACCEPT; iptables -D FORWARD -o %i -j ACCEPT; iptables -t nat -D POSTROUTING -o eth0 -j MASQUERADE
                                      @crunkfx ja die sind eingetragen
                                      • CrunkFX
                                        @crunchip
                                        Nach der neuinstallation rebootet?
                                        Neuen Client angelegt und Apply Config gedrückt?
                                        Wenn ja zeig mal bitte
                                        ip a
                                          crunchip Forum Testing Most Active @CrunkFX last edited by crunchip
                                          @crunkfx ja hatte ich
                                          1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
                                              link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                                              inet 127.0.0.1/8 scope host lo
                                                 valid_lft forever preferred_lft forever
                                              inet6 ::1/128 scope host
                                          2: eth0@if43: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
                                              link/ether fe:8b:dc:86:6e:51 brd ff:ff:ff:ff:ff:ff link-netnsid 0
                                              inet 10.1.1.21/24 brd 10.1.1.255 scope global eth0
                                              inet6 fe80::fc8b:dcff:fe86:6e51/64 scope link
                                          3: wg0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1450 qdisc mq state UNKNOWN group default qlen 500
                                              link/none
                                              inet 10.252.1.0/24 scope global wg0
                                              inet6 fe80::e128:9915:e0b1:325d/64 scope link stable-privacy
                                          4: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
                                              link/ether 02:42:e4:53:d0:58 brd ff:ff:ff:ff:ff:ff
                                              inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
                                          ich setz ihn einfach nochmal neu auf
                                          edit, hab ein zweites handy hinzugefügt, CT nochmal neu gestartet, Verbindung funktioniert wieder, Status bleibt aber dennoch leer
                                          • CrunkFX
                                            @crunchip Denk an Nesting und keyctl für Docker. Bevor du neuinstalliert versuch nochmal
                                            wg-quick down wg0 && wg-quick up wg0
                                            portforwarding portfreigabe portfreischaltung proxmox vpn wireguard wireguard ios app
                                            64
                                            603
                                            162528
