    • simatec
      simatec Developer Most Active @Guest last edited by simatec
      @noah3112 Ich kann deinen Fehler leider nicht nachvollziehen ... Der Fensterkontakt mit genau deiner Config genau das, was er soll.
      ? 2 Replies Last reply Reply Quote 0
        A Former User @simatec last edited by Negalein
        @simatec
        2021-11-09 16:25:32.804 - debug: shuttercontrol.0 (12762) TriggerID changed: zigbee.0.00158d0002370a0c.opened Value: true
        2021-11-09 16:25:32.817 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein - shutter conversion is:false
        2021-11-09 16:25:32.866 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein - shutter trigger drive-up is:35
        2021-11-09 16:25:32.867 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein - shutter trigger change is:upDown
        2021-11-09 16:25:32.867 - debug: shuttercontrol.0 (12762) #1 save trigger height: 0% for device Wohnzimmer Klein
        2021-11-09 16:25:32.868 - debug: shuttercontrol.0 (12762) #1 save trigger action: Manu_Mode for device Wohnzimmer Klein
        2021-11-09 16:25:32.869 - info: shuttercontrol.0 (12762) #1 Set ID: Wohnzimmer Klein value: 35%
        2021-11-09 16:25:32.918 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein - window is still open -> driving now to :35
        2021-11-09 16:25:32.940 - debug: shuttercontrol.0 (12762) Shutter state changed: Wohnzimmer Klein old value = 0 new value = 35
        2021-11-09 16:25:32.941 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein Old value = 0. New value = 35. automatic is active
        2021-11-09 16:25:33.305 - debug: shuttercontrol.0 (12762) Brightness sensor value: 721
        2021-11-09 16:25:33.306 - debug: shuttercontrol.0 (12762) Lightsensor changed: zigbee.0.04cf8cdf3c7cc445.illuminance Value: 721
        2021-11-09 16:25:33.329 - debug: shuttercontrol.0 (12762) Brightness sensor value: 721
        2021-11-09 16:25:33.329 - debug: shuttercontrol.0 (12762) Lightsensor changed: zigbee.0.04cf8cdf3c7cc445.illuminance Value: 721
        2021-11-09 16:25:33.983 - debug: shuttercontrol.0 (12762) save current height after State Check: 0% from Wohnzimmer Klein
        2021-11-09 16:25:33.984 - debug: shuttercontrol.0 (12762) Shutter Wohnzimmer Klein was moved manually to: 0% while window was open - prevent trigger from driving back
        2021-11-09 16:25:39.846 - debug: shuttercontrol.0 (12762) Shutter state changed: Wohnzimmer Klein old value = 0 new value = 35
        2021-11-09 16:25:39.847 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein drived manually to 35. Old value = 0. New value = 35
        2021-11-09 16:25:39.848 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein Updated trigger action to Manu_Mode to prevent moving after window close
        2021-11-09 16:25:40.853 - debug: shuttercontrol.0 (12762) save current height after State Check: 35% from Wohnzimmer Klein
        2021-11-09 16:25:40.854 - debug: shuttercontrol.0 (12762) Shutter Wohnzimmer Klein was moved manually to: 35% while window was open - prevent trigger from driving back
        2021-11-09 16:25:46.078 - debug: shuttercontrol.0 (12762) TriggerID changed: zigbee.0.00158d0002370a0c.opened Value: false
        2021-11-09 16:25:46.085 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein - shutter conversion is:false
        2021-11-09 16:25:46.131 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein - shutter current state.val is:35
        2021-11-09 16:25:46.132 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein - shutter current Height is:35
        2021-11-09 16:25:46.133 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein - shutter trigger Height is:35
        2021-11-09 16:25:46.133 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein - shutter trigger Action is:Manu_Mode
        2021-11-09 16:25:46.134 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein - shutter trigger Change is:upDown
        2021-11-09 16:25:46.135 - debug: shuttercontrol.0 (12762) #1 shutter trigger released Wohnzimmer Klein already in place: 35%
        2021-11-09 16:25:46.135 - debug: shuttercontrol.0 (12762) save back trigger action: Manu_Mode for device Wohnzimmer Klein
        Mod-Edit: Code in </> Code-Tag gepackt!
        Homoran simatec 2 Replies Last reply Reply Quote 0
          A Former User @simatec last edited by A Former User
          @simatec Das passiert beim öffnen bzw schließen...
          So richtig schlau werde ich nicht daraus. Vielleicht kannst du etwas damit anfangen.
            A Former User @Homoran last edited by
            @homoran Ups ich sehe gerade das ich den Log falsch adressiert habe.
              Homoran Global Moderator Administrators @Guest last edited by
              @noah3112 sagte in Test Adapter shuttercontrol v1.3.x:
              hier wird das zurückrollen unterbunden.
              Du hast keine Zeit eingestellt, nach der der Status überprüft werden soll?
              Hier wird das Fenster geschlossen:
              und hier der Status überprüft:
              gerade mal 100msec. dazwischen.
              Was hast du für Aktoren?
              Kann es sein, dass da etwas später erst die Endposition erreicht wird, was dann als manuelle Veränderung interpretiert wird?
              neee, ist schon gut so. @simatec muss sich das ansehen
              • simatec
                @noah3112
                Und wo ist der Log für das schließen?
                  Homoran Global Moderator Administrators @simatec last edited by Homoran
                  @simatec sagte in Test Adapter shuttercontrol v1.3.x:
                  ist es nicht das?
                  opened=false
                    @homoran Sorry aber ich kann nicht mehr folgen. Alles mal ganz langsam und zum verstehen. Mit den Einstellungen und den gleichen Sensoren bin ich von der Version 1.2.1 auf die Version 1.3.2 bzw jetzt auf 1.3.3. Was hat sich den grundsätzlich geändert das ich jetzt einen Fehler in meiner Einstellung bzw Sensorik suchen muss? Wie gesagt das gleiche Verhalten bei weiteren 12 Rollos. Die Aktoren sind übrigens Shellys 2.5. Bin nur Anwender und ganz leicht überfordert.
                      @homoran Bin gerade nochmal zurück auf Version 1.2.1 und es funzt wieder alles. Ist mir echt zu hoch...
                        das nutzt uns aber nichts wenn wir den "Bug" finden wollen
                        war auch nicht für dich sondern für @simatec
                          @homoran Bin gerade mal dran einen Log von der Version 1.2.1 zu erstellen. Uno momento...
                            das brauchen wir nicht - der "Bug" soll doch in der neuen Version drin sein
                              @homoran Aber vielleicht hilft es ja....
                              2021-11-09 18:23:52.550 - debug: shuttercontrol.0 (22409) TriggerID changed: zigbee.0.00158d0002370a0c.opened Value: true
                              2021-11-09 18:23:52.557 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter conversion is:false
                              2021-11-09 18:23:52.607 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter trigger drive-up is:35
                              2021-11-09 18:23:52.608 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter trigger change is:upDown
                              2021-11-09 18:23:52.608 - debug: shuttercontrol.0 (22409) #1 save trigger height: 0% for device Wohnzimmer Klein
                              2021-11-09 18:23:52.608 - debug: shuttercontrol.0 (22409) #1 save trigger action: down for device Wohnzimmer Klein
                              2021-11-09 18:23:52.609 - info: shuttercontrol.0 (22409) #1 Set ID: Wohnzimmer Klein value: 35%
                              2021-11-09 18:23:52.657 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - window is still open -> driving now to :35
                              2021-11-09 18:23:52.674 - debug: shuttercontrol.0 (22409) Shutter state changed: Wohnzimmer Klein old value = 0 new value = 35
                              2021-11-09 18:23:52.675 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein Old value = 0. New value = 35. automatic is active
                              2021-11-09 18:23:59.731 - debug: shuttercontrol.0 (22409) Shutter state changed: Wohnzimmer Klein old value = 0 new value = 35
                              2021-11-09 18:23:59.732 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein Old value = 0. New value = 35. automatic is active
                              2021-11-09 18:24:07.162 - debug: shuttercontrol.0 (22409) TriggerID changed: zigbee.0.00158d0002370a0c.opened Value: false
                              2021-11-09 18:24:07.164 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter conversion is:false
                              2021-11-09 18:24:07.211 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter current state.val is:35
                              2021-11-09 18:24:07.212 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter current Height is:35
                              2021-11-09 18:24:07.212 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter trigger Height is:0
                              2021-11-09 18:24:07.212 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter trigger Action is:down
                              2021-11-09 18:24:07.213 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter trigger Change is:upDown
                              2021-11-09 18:24:07.213 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter trigger Action is:35
                              2021-11-09 18:24:07.261 - info: shuttercontrol.0 (22409) Window is still closed -> drive to last height: 0% for device: Wohnzimmer Klein
                              2021-11-09 18:24:07.262 - debug: shuttercontrol.0 (22409) save back trigger action: down for device: Wohnzimmer Klein
                              2021-11-09 18:24:07.312 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein Old value = 0. New value = 0. automatic is active
                              2021-11-09 18:24:07.314 - debug: shuttercontrol.0 (22409) Shutter state changed: Wohnzimmer Klein old value = 0 new value = 35
                              2021-11-09 18:24:07.315 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein drived manually to 35. Old value = 0. New value = 35
                              2021-11-09 18:24:07.315 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein Updated trigger action to Manu_Mode to prevent moving after window close
                              2021-11-09 18:24:14.151 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein Old value = 0. New value = 0. automatic is active
                              • simatec
                                Set ID
                                Aber auch hier sehe ich nicht, dass dein Rollladen wieder runterfährt.
                                Da müsste „ Set ID“ im Log dann zweimal sein.
                                Für die Config mit einem reinen Fensterkontakt ohne Kippstellung hat sich nix geändert.
                                Bitte poste doch mal deine komplette Config als json File.
                                Kannst du im Adapter Menü über die Pfeile runterladen.
                                So wie du in meinem Gif gesehen hast, habe ich nix anderes gemacht, als den Fensterkontakt von false auf true (Rollladen geht auf 35%) und danach wieder auf false (Rollladen schließt auf 0%).
                                Was geht denn bei dir nicht?
                                Ich hatte doch genau deine Config übernommen und die exakt identische Version getestet.
                                Kann es sein, dass deine shellys eventuell den Wert nochmal ändern und du nach x Sekunden eine erneute Statusabfrage in shuttercontrol aktivieren musst.
                                Wie gesagt, zeige mal die Config.
                                  @simatec Meinst du dieses Menü?
                                  Wenn ja wo finde ich die heruntergeladene Datei?
                                  Bin ich hier richtig?
                                  • Bostil
                                    Bostil last edited by Bostil
                                    Möchte es nicht mal bug nennen, hatte aber folgendes Problem: für das Herunterfahren per Lichtsensor bei Unterschreiten eines Schwellenwertes hatte ich schon länger einen Sensor definiert, der keine Daten mehr lieferte (disconnected). Jedes Mal wenn ich "auto_all" anwählte fuhren alle Rolladen herunter. Habe nun den Sensor entfernt und hoffe, dass dies die Problemlösung ist.
                                    Bostil 1 Reply Last reply Reply Quote 0
                                    • Jens16
                                      Jens16 last edited by
                                      Unter Instanzen Shuttercontrol rechts oben die Pfeile
                                        A Former User @Jens16 last edited by
                                        @jens16 Gefunden Danke 🙂
                                          @simatec system.adapter.shuttercontrol.0.json
                                          Ich hoffe das hilft weiter...
                                          • simatec
                                            @noah3112
                                            Jetzt mache mal das Fenster auf und schaue, was für ein Wert in dem shelly Objekt steht.
                                            332
                                            7408
                                            10565258
