    4. Frage wegen Warnings in Blockly Prg
      Homoran Global Moderator Administrators @hg6806 last edited by
      @hg6806 Kein Screenshot!
      ich kann da nichts zitieren!
      • hg6806
        hg6806 Most Active last edited by
        OK, hier das Javascript:
        var Boost_Soll_T_Raum, timeout, timeout;
        on({id: 'smartmeter.0.1-0:16_7_0__255.value', change: "ne"}, async function (obj) {
          var value = obj.state.val;
          if (getState("javascript.0.PV.Heizung-Boost").val && !timeout) {
            if ((obj.state ? obj.state.val : "") < -500) {
              if (Boost_Soll_T_Raum < 30) {
                Boost_Soll_T_Raum = (typeof Boost_Soll_T_Raum == 'number' ? Boost_Soll_T_Raum : 0) + 0.5;
          } else if ((obj.state ? obj.state.val : "") < -50 && Boost_Soll_T_Raum > getState("javascript.0.PV.Raumtemp-Soll_alt").val) {
            Boost_Soll_T_Raum = (typeof Boost_Soll_T_Raum == 'number' ? Boost_Soll_T_Raum : 0) + -0.5;
          if (getState("smartmeter.0.1-0:16_7_0__255.value").val != Boost_Soll_T_Raum) {
            setState("fhem.0.myHPSU.HPSU~Soll_T_Raum_1"/*myHPSU HPSU.Soll_T_Raum_1*/, Boost_Soll_T_Raum);
            timeout = setTimeout(async function () {
              timeout = null;
            }, 60000);
        setState("javascript.0.PV.Heizung-Boost"/*Heizung-Boost*/, false);
        on({id: 'javascript.0.PV.Heizung-Boost', change: "ne"}, async function (obj) {
          if ((obj.state ? obj.state.val : "")) {
            Boost_Soll_T_Raum = getState("fhem.0.myHPSU.HPSU~Soll_T_Raum_1").val;
            setState("javascript.0.PV.Raumtemp-Soll_alt"/*Raumtemp-Soll_alt*/, Boost_Soll_T_Raum, true);
          } else {
            setState("fhem.0.myHPSU.HPSU~Soll_T_Raum_1"/*myHPSU HPSU.Soll_T_Raum_1*/, getState("javascript.0.PV.Raumtemp-Soll_alt").val);
          Homoran Global Moderator Administrators @hg6806 last edited by Homoran
          @hg6806 sagte in Frage wegen Warnings in Blockly Prg:
          setState("fhem.0.myHPSU.HPSU~Soll_T_Raum_1"/myHPSU HPSU.Soll_T_Raum_1/, Boost_Soll_T_Raum)
          was macht die Tilde da?
          Heisst deine ID wirklich so?
          • hg6806
            Ja, die wilde Tilde ist leider Bestandteil des Datenpunktes.
            Der kommt von FHEM.
            • dslraser
              dslraser Forum Testing Most Active @hg6806 last edited by
              @hg6806
              hast Du mal probiert dafür einen Alias zu erstellen und dann den im Blockly zu verwenden ?
              Da kannst Du dann wenigstens „vernünftige“ Namen und ID vergeben (ohne wilde Tilde)
              • hg6806
                Habe ein Alias für den Wert erstellt.
                Alias-Namen ohne Tilde. Steht auch so im Alias-Manager drin.
                Wenn ich den Alias dann auswähle steht wieder eine Tilde drin?????
                Nach dem Fix von Wert des Objekt ID in nur Objekt ID geht es, zählt jedoch alle 5-10 Sek hoch und nicht jede Minute.
                Ich schätze da stimmt was mit Timeout nicht.
                Ist auch komisch dass es in der Variablendeklaration 2x auftaucht.
                Wie schon geschrieben hatte ich "timeout" als Variable neu angelegt, da ich es sonst im Blockly nicht hätte auswählen können
                  paul53 @hg6806 last edited by paul53
                  @hg6806 sagte: Wie schon geschrieben hatte ich "timeout" als Variable neu angelegt, da ich es sonst im Blockly nicht hätte auswählen können
                  Dann wähle die andere (echte) Variable timeout aus und kontrolliere in der Javascript-Ansicht, dass nur noch eine Variable timeout existiert.
                  Falsch nachgebaut. Hier ein Export, bei dem nur noch sämtliche Datenpunkt-IDs zugewiesen werden müssen:
                   <variables>
                     <variable id="Z$dQ(fbDb]yEVd;|nC}-">sollwert</variable>
                   </variables>
                   <block type="on_ext" id="WS2pki!+Wa]B9pOoH1EE" x="37" y="212">
                     <value name="OID0">
                       <shadow type="field_oid" id="Y^gX`@%S7?]9pdzDbqEn">
                         <field name="oid">0_userdata.0.Blockly.Power</field>
                       <block type="controls_if" id="-o8O7GRQ_+OWlJ(^s1h%">
                           <block type="logic_operation" id="eT!,1v1_jt8)-5XX@;?2" inline="false">
                             <field name="OP">AND</field>
                               <block type="get_value" id="v/tyE{%;^.:%%orWc8:=">
                                 <field name="OID">0_userdata.0.Blockly.Freigabe_Ventil</field>
                               <block type="logic_negate" id="MXXJdcO#s]zQ-JxKx[Bh">
                                 <value name="BOOL">
                                   <block type="variables_get" id="x9+r_-8A*dc4*7wR}1KX">
                                     <field name="VAR" id="timeout" variabletype="timeout">timeout</field>
                           <block type="controls_if" id="$+Tz0_$:o%:gB#ZPeD:C">
                               <block type="logic_compare" id="pZ-=;Pw4Q#KOu7F|A6r%">
                                 <field name="OP">LT</field>
                                   <block type="on_source" id="7r5wceo=h`FgR(eUAPjg">
                                   <block type="math_number" id="n|s4N_SYXa:14gT]--M8">
                                     <field name="NUM">-500</field>
                               <block type="controls_if" id="-vmvsiA04M-QQ{q+;2=S">
                                   <block type="logic_compare" id="r!}hW3Jx;};jGqVq7(,*">
                                       <block type="variables_get" id=";)|KKMwc}q?9GgFXDRJB">
                                         <field name="VAR" id="Z$dQ(fbDb]yEVd;|nC}-">sollwert</field>
                                       <block type="math_number" id="cF!GbW/0|^ptc@N7QwxT">
                                         <field name="NUM">30</field>
                                   <block type="math_change" id=",tB,NxYBtB.os9gwcwKF">
                                     <value name="DELTA">
                                       <shadow type="math_number" id="6.SMWS.JZ7n.%iWwSIYY">
                                         <field name="NUM">0.5</field>
                             <value name="IF1">
                               <block type="logic_operation" id="?S~%I*Xg2:{~A+]VD?P`" inline="false">
                                   <block type="logic_compare" id="!|lzv#rfsRB[uRR-?8$y">
                                     <field name="OP">GT</field>
                                       <block type="on_source" id="k1M{WSL7Jhz.(NG+OzPq">
                                       <block type="math_number" id="-d#_*f;t]C(]]/Ai.1%f">
                                         <field name="NUM">-50</field>
                                   <block type="logic_compare" id="cz6_7CvYs=$+Sm6EE:gb">
                                       <block type="variables_get" id="9`#BZ6DDn/2xOix%G}4D">
                                       <block type="get_value" id=";)%YZm}v`Zgyl_5nzjoc">
                                         <field name="OID">ID auswählen</field>
                             <statement name="DO1">
                               <block type="math_change" id="cD[rF.$wvhyc9A~lPgHD">
                                   <shadow type="math_number" id="tgK{*FKsZ*.aVs|?/9kR">
                                     <field name="NUM">-0.5</field>
                               <block type="controls_if" id="(L0@;g9L{HUsVe)wksD9">
                                   <block type="logic_compare" id="qp1YjeoR-#T`*b)T-s/2">
                                     <field name="OP">NEQ</field>
                                       <block type="variables_get" id="Y`5.KpcfrW`AxI:SDz#(">
                                       <block type="get_value" id="ZX_bR1a[SnhgVmw|Q*9n">
                                         <field name="OID">0_userdata.0.Blockly.Soll_Temperatur</field>
                                   <block type="control" id="X]wVtN]L1~B?Hf+3=o5V">
                                       <block type="variables_get" id="E=D1Jm-$N-SVHnI7!YsQ">
                                   <block type="timeouts_settimeout" id="!Mx#av5+R*@g#]jARsK.">
                                     <field name="DELAY">1</field>
                                       <block type="variables_set" id="4ym+oZsroTg8TRrd$*lv">
                                           <block type="logic_null" id="M6m?`rO-O1Ip)vX*cLw5"></block>
                   <block type="on_ext" id="V!I|JBF1eXs(=1C?2MrO" x="512" y="213">
                     <value name="OID0">
                       <shadow type="field_oid" id="=f[=Yy}F]CQ@$O/r1k{V">
                         <field name="oid">0_userdata.0.Blockly.Freigabe_Ventil</field>
                       <block type="controls_if" id="S_.jdk|=zJG7scL4a!C@">
                           <block type="on_source" id=")mc%Hr$aEpk.r2gF#`Zw">
                           <block type="variables_set" id="j!fW@36IZ4+v~%`cE}.?">
                               <block type="get_value" id="6L4QjxCw`a/4,tc%*MYr">
                               <block type="update" id="M=0-F6W4M+$c3p(9Br11">
                                   <block type="variables_get" id="M*ss*L*Amq{|pG|K0_^F">
                         <statement name="ELSE">
                           <block type="control" id="11t{niAfqS9bH9?UXEf{">
                               <block type="get_value" id="-6|)NTE*4+N[YhQF;%;,">
                  • hg6806
                    hg6806 Most Active @paul53 last edited by
                    Danke, aber Ziel ist es, dass ich es alleine auf die Beine stelle.
                    Das Blockly hatte ich nur zur Hälfte verstanden, bei deinem Javascript verstehe ich gar nichts. Das bringt mir nichts.
                    Ich muss erst einmal schauen, warum mir Alias wieder eine Tilde ausspuckt, obwohl ich ohne Tilde erstelle.
                      @hg6806 sagte: Ziel ist es, dass ich es alleine auf die Beine stelle.
                      Gut so. Vergleiche die Anordnung von "Ausführen timeout".
                      • hg6806
                        Stimmt!
                        So sollte es hoffentlich passen. Kann es erst morgen testen:
                          @hg6806 sagte: So sollte es hoffentlich passen.
                          Weshalb wird "Heizung-Boost" bei Skriptstart auf falsch gesetzt?
                          • hg6806
                            Weil ich es generell eben auf aus gestellt haben möchte, wenn der Pi mal gebootet wird Javascript neu gestartet, etc.
                            • hg6806
                              So, nachdem ich es richtig umgesetzt wurde läuft es endlich 🙂
                              Noch eine kurze Off Topic Frage.
                              Das Objekt myHPSU HPSU.Betriebsart..... gibt mir ab und zu ein "Abtauen" aus.
                              Jedoch funktioniert die Falls-Abfrage nicht.
                                wie sieht denn das RAW des Datenpunktes aus?
                                kann das eine Werteliste sein?
                                • hg6806
                                  Hier ist das Raw. Werteliste kann ich nicht beantworten.
                                    "_id": "fhem.0.myHPSU.HPSU~Aktive_Betriebsart",
                                    "type": "state",
                                    "common": {
                                      "name": "myHPSU HPSU.Aktive_Betriebsart",
                                      "type": "string",
                                      "role": "text",
                                      "read": true,
                                      "write": false,
                                      "custom": {
                                        "history.0": {
                                          "enabled": true,
                                          "aliasId": "",
                                          "changesOnly": true,
                                          "debounce": 0,
                                          "changesRelogInterval": "0",
                                          "changesMinDelta": 0,
                                          "maxLength": 10,
                                          "retention": "31536000"
                                    "native": {
                                      "Name": "myHPSU",
                                      "Attribute": "HPSU.Aktive_Betriebsart",
                                      "Readings": true,
                                      "type": "string",
                                      "role": "text"
                                    "value": {
                                      "val": "Standby"
                                    "acl": {
                                      "object": 1636,
                                      "state": 1636,
                                      "owner": "system.user.admin",
                                    "user": "system.user.admin",
                                    "ts": 1622098457713
                                    @hg6806
                                    Du triggerst auf "...Aktive_Betriebsart", vergleichst dann aber "...Betriebsart". Besser so für Beginn:
                                    und so für Ende Abtauen:
                                      "type": "string",
                                      nein, ist wirklich ein String
                                      dann schreib mal zusätzliche einen debug Baustein rein, der die den WERT ausgibt, damit man sieht was da wirklich ankommt, wenn da Abtauen steht,
                                      Wert ist ein Menüpunkt des Pulldownmenüs in dem Baustein aus der Gruppe Trigger
                                      • hg6806
                                        hg6806 Most Active @Homoran last edited by
                                        Welcher Baustein ist das?
                                          @hg6806 sagte: Welcher Baustein ist das?
                                          Wert? Es steht zuerst "Objekt ID" drin:
                                            System -> debug
                                            2054
