      MCU @SchuetzeSchulz last edited by
      @schuetzeschulz
      Next one:
      <!DOCTYPE HTML>
      <html>
      <head>
          <title> </title>
          <style> #container {text-align: center; height: 100%;} .button { color: #333; background-color: #fff; border-color: #ccc;  font-size: 14px; font-weight: 400; border: 1px solid black; border-radius: 4px;  cursor: pointer;  line-height: 1.42857143; text-align: center; white-space: nowrap; vertical-align: middle; padding: 6px 12px;}
          </style>
          <script>
      	setTimeout(function(){
      	        var button = document.querySelector('#container .button');
              	button.addEventListener('click', fullscreen);
              	document.addEventListener('webkitfullscreenchange', fullscreenChange);
              	document.addEventListener('mozfullscreenchange', fullscreenChange);
              	document.addEventListener('fullscreenchange', fullscreenChange);
              	document.addEventListener('MSFullscreenChange', fullscreenChange);
      	},1000);
              function fullscreen() {
                  // check if fullscreen mode is available
                  if (document.fullscreenEnabled ||
                      document.webkitFullscreenEnabled ||
                      document.mozFullScreenEnabled ||
                      document.msFullscreenEnabled) {
                      // which element will be fullscreen
                      var iframe = document.querySelector('#container iframe');
                      // Do fullscreen
                      if (iframe.requestFullscreen) {
                          iframe.requestFullscreen();
                      } else if (iframe.webkitRequestFullscreen) {
                          iframe.webkitRequestFullscreen();
                      } else if (iframe.mozRequestFullScreen) {
                          iframe.mozRequestFullScreen();
                      } else if (iframe.msRequestFullscreen) {
                          iframe.msRequestFullscreen();
                  else {
                      document.querySelector('.error').innerHTML = 'Your browser is not supported';
              function fullscreenChange() {
                      document.webkitIsFullScreen ||
                      document.mozFullScreen ||
                      document.msFullscreenElement) {
                          console.log('enter fullscreen');
                  else {
                      console.log('exit fullscreen');
                  // force to reload iframe once to prevent the iframe source didn't care about trying to resize the window
                  // comment this line and you will see
                  var iframe = document.querySelector('iframe');
                  iframe.src = iframe.src;
              function onKlick(elem) { elem.requestFullscreen(); }
          </script>
      </head>
      <body style="text-align: center;" id="video1body">
          <div id="container">
              <iFrame width="320px" height="150px" src="URL" onclick="onKlick(this);" frameborder="2"
                  allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture"
                  allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen>
              </iFrame>
              <div>
                  <button class="button">FullScreen</button>
              </div>
              <div class="error"></div>
          </div>
      </body>
      </html>
      • Johannes Bauerstatter
        Johannes Bauerstatter @SchuetzeSchulz last edited by
        Ich glaub ich bin zu dämlich.
        Hab das Script laufen lassen und die IP´s eingetragen:
        In Jarvis folgendes:
        Geräte:
        Widget:
        Was mach ich falsch?
          MCU @Johannes Bauerstatter last edited by MCU
          @johannes-bauerstatter Wie lautet denn der Link zur Kamera?
          In die Server-Ip kommt nur die IP 192.168.188.205, aber nur dann, wenn man die vis.0 in objData hat. Dann würde automatisch der Link erstellt mit http://SERVER-IP:8082/ + objData.
          Johannes Bauerstatter 1 Reply Last reply Reply Quote 0
            Johannes Bauerstatter @MCU last edited by
            @mcu Ja genau. Wenn ich das in den Browser eingebe, läuft der Stream.
              @johannes-bauerstatter Stell mal bitte die objHTML rein.
              Du musst schon einmal makeHTML auf true setzen, damit eine objHTML erstellt wird.
              Und in jarvis müsste man auch die objHTML nutzen und nicht die objDataID.
                Johannes Bauerstatter @MCU last edited by Johannes Bauerstatter
                @mcu Muss das Script immer laufen oder nur 1x malig? Hab den Datenpunkt auf true gestellt und auch das Script wieder gestartet. Keine Änderung:
                  "common": {
                    "read": true,
                    "write": true,
                    "name": "HTML zum Objekt",
                    "type": "string",
                    "role": "text",
                    "def": ""
                  "native": {},
                  "type": "state",
                  "user": "system.user.admin",
                  "ts": 1636524251378,
                  "_id": "0_userdata.0.jarvis.stream.objHTML",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                    "owner": "system.user.admin",
                  Das Script nutzt man um die objHTML zu erstellen.
                  Das Programm muss laufen, bevor man den Schalter auf true setzt. Du musst jetzt einmal wieder auf false setzen und dann auf true.
                  Benötigt man nur einmalig, ausser man hat verändernde Inhalte, dann müsste das Programm sowieso angepasst werden.
                    @mcu Danke. Funktioniert jetzt
                      Hält der Videostream dann nach 100 Sekunden an?
                        SchuetzeSchulz @MCU last edited by
                        @mcu sagte in jarvis v2.2.0 - just another remarkable vis:
                        <!DOCTYPE HTML> <html> <head> <title> </title> <style> #container {text-align: center; height: 100%;} .button { color: #333; background-color: #fff; border-color: #ccc; font-size: 14px; font-weight: 400; border: 1px solid black; border-radius: 4px; cursor: pointer; line-height: 1.42857143; text-align: center; white-space: nowrap; vertical-align: middle; padding: 6px 12px;} </style> <script> setTimeout(function(){ var button = document.querySelector('#container .button'); button.addEventListener('click', fullscreen); document.addEventListener('webkitfullscreenchange', fullscreenChange); document.addEventListener('mozfullscreenchange', fullscreenChange); document.addEventListener('fullscreenchange', fullscreenChange); document.addEventListener('MSFullscreenChange', fullscreenChange); },1000); function fullscreen() { // check if fullscreen mode is available if (document.fullscreenEnabled || document.webkitFullscreenEnabled || document.mozFullScreenEnabled || document.msFullscreenEnabled) { // which element will be fullscreen var iframe = document.querySelector('#container iframe'); // Do fullscreen if (iframe.requestFullscreen) { iframe.requestFullscreen(); } else if (iframe.webkitRequestFullscreen) { iframe.webkitRequestFullscreen(); } else if (iframe.mozRequestFullScreen) { iframe.mozRequestFullScreen(); } else if (iframe.msRequestFullscreen) { iframe.msRequestFullscreen(); } } else { document.querySelector('.error').innerHTML = 'Your browser is not supported'; } } function fullscreenChange() { if (document.fullscreenEnabled || document.webkitIsFullScreen || document.mozFullScreen || document.msFullscreenElement) { console.log('enter fullscreen'); } else { console.log('exit fullscreen'); } // force to reload iframe once to prevent the iframe source didn't care about trying to resize the window // comment this line and you will see var iframe = document.querySelector('iframe'); iframe.src = iframe.src; } function onKlick(elem) { elem.requestFullscreen(); } </script> </head> <body style="text-align: center;" id="video1body"> <div id="container"> <iFrame width="320px" height="150px" src="URL" onclick="onKlick(this);" frameborder="2" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen> </iFrame> <div> <button class="button">FullScreen</button> </div> <div class="error"></div> </div> </body> </html>
                        Damit funktioniert das mit dem Button. Also klicke ich auf den Button kommt Vollbild.
                          @schuetzeschulz Zufrieden, oder muss ich noch weiterschauen?
                            @mcu Naja, ich würde es "besser" finden, wenn das Vollbild kommt wenn ich auf das Kamerabild drücke/klicke. Also quasi ohne den Button...
                              @schuetzeschulz Dafür habe ich keinen Ansatz mehr. Das scheint an der Software für die Anzeige der Kamera zu liegen. Welche Kamera ist das?
                                @mcu Ja, funktioniert auch. War gewollt zum Testen.
                                  @mcu Habe 3 Wansview W3 Kameras im Einsatz.
                                    RkcCorian last edited by
                                    Kenn jemand die CSS um die "Headings" (Überschriften) der Widgets anzupassen? Also Symbolgröße, Transparenz, sowie Schriftgröße? Vielen Dank!
                                      MCU @RkcCorian last edited by MCU
                                      @rkccorian
                                      https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/besonderheiten-v3/styles/statelist-1/.q-item__section--main
                                        RkcCorian @MCU last edited by
                                        @mcu Für .q-item__section--main .q-item__label.text-h6 gibt es (noch) kein jarvis-wasAuchImmerEigenesCss?!
                                          @rkccorian Nein. Es gibt jarvis-header, hat aber die Überschrift nicht mit drin? Bin mir grade nicht sicher.
                                          .jarvis-widget-header
                                            sicadrip last edited by
                                            @Zefau
                                            Ich vermisse in der aktuellen alpha.125 beim DateTime Modul die Einstellung "Style des Textes (JSON Format)". Kommt das wieder dazu?
                                            v3.0.0-alpha.125
                                            v2.3.3
                                            316
                                            6126
                                            4116918
