    4. [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen
    • opossum
      opossum @Dutchman last edited by
      Hallo, @dutchman
      wen ein Proces hängt, hat man keine andere Wahl 😉
      ein Neustart hat es gebraucht, Mäusekino an der Garage läuft wieder O-Ton meiner Frau :-). Danke Dir.
      opossum 1 Reply Last reply Reply Quote 1
      • opossum
        opossum @opossum last edited by opossum
        @Dutchman ,
        leider wieder ein Problem. Musste meinen iobroker wegen einiger Änderungen durchstarten. Bekomme nun folgende Meldungen im Log:
        2021-09-25 05:49:12.071	error	Cannot read property 'error' of undefined
        wled.0 2021-09-25 05:49:12.071	error	TypeError: Cannot read property 'error' of undefined at Wled.onUnload (/opt/iobroker/node_modules/iobroker.wled/main.js:130:13) at Wled.emit (events.js:314:20) at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8747:22) at Object.onceWrapper (events.js:421:26) at process.emit (events.js:314:20) at process.exit (internal/process/per_thread.js:168:15) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:352:25) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        wled.0 2021-09-25 05:49:12.068	error	unhandled promise rejection: Cannot read property 'error' of undefined
        wled.0 2021-09-25 05:49:12.067	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        wled.0 2021-09-25 05:49:10.971	error	wled.0 already running
        wled.0 2021-09-25 05:48:40.609	error	Cannot read property 'error' of undefined
        wled.0 2021-09-25 05:48:40.608	error	TypeError: Cannot read property 'error' of undefined at Wled.onUnload (/opt/iobroker/node_modules/iobroker.wled/main.js:130:13) at Wled.emit (events.js:314:20) at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8747:22) at Object.onceWrapper (events.js:421:26) at process.emit (events.js:314:20) at process.exit (internal/process/per_thread.js:168:15) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:352:25) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        wled.0 2021-09-25 05:48:40.605	error	unhandled promise rejection: Cannot read property 'error' of undefined
        wled.0 2021-09-25 05:48:40.604	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        wled.0 2021-09-25 05:48:39.694	error	wled.0 already running
        Hier hilft nun auch kein Neustart mehr. Wenn man den Adapter neustartet, gibt es ebenfalls diese Meldungen. Es scheint, als wenn der Prozess nicht sauber beendet wird.
        Habe mal die VM kontrolliert:
        debian@iobroker:/opt/iobroker$ ps auxww|grep wled
        iobroker  2004  0.0  0.6 611448 52288 ?        Sl   Sep24   0:06 /usr/bin/node /opt/iobroker/node_modules/iobroker.wled/main.js 0 info
        iobroker  3799  0.0  0.6 611180 52084 ?        Sl   05:48   0:01 /usr/bin/node /opt/iobroker/node_modules/iobroker.wled/main.js 0 info
        iobroker  3832  0.0  0.6 611444 51880 ?        Sl   05:49   0:01 /usr/bin/node /opt/iobroker/node_modules/iobroker.wled/main.js 0 info
        iobroker  5091  0.6  0.6 611240 50004 ?        Sl   06:15   0:01 /usr/bin/node /opt/iobroker/node_modules/iobroker.wled/main.js 0 info
        debian    5293  0.0  0.0   6088   888 pts/0    S+   06:19   0:00 grep wled
        Nachdem ich den Adapter beendet habe (im Admin), habe ich alle Prozesse mit WLED gekillt. Sind das eventuell noch Fragmente meines Scriptes für das Garagentor?
        debian@iobroker:/opt/iobroker$ sudo kill 2004
        debian@iobroker:/opt/iobroker$ sudo kill 3799
        debian@iobroker:/opt/iobroker$ sudo kill 3832
        debian@iobroker:/opt/iobroker$ sudo kill 5091
        Dann konnte ich den Adapter WLED neu starten.
        iobroker  5381  0.9  0.6 632400 57076 ?        Sl   06:20   0:03 io.wled.0
        Nach dem ich die o.g. Prozesse gekillt habe, kann ich auch den WLED-Adapter sauber beenden und starten. Scheint wirklich mein Garagenscript zu sein. Sorry.
        • Dutchman
          Dutchman Developer Most Active Administrators @opossum last edited by
          @opossum sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
          Eh LOL was macht dein Script den das es den Word Processing strapaziert 😳
          opossum 1 Reply Last reply Reply Quote 0
          • opossum
            opossum @Dutchman last edited by opossum
            Hallo, @dutchman, danke für die Rückantwort.
            Sind eigentlich drei. Die steuern, je nach dem, wie der Zustand des Garagentors steht, die Presets des LED-Stripes an.
            Muss mal schauen, wie ich die sauber beende. Denke, wenn das Tor schneller fährt, als die Verzögerung eingestellt ist, bleibt das jeweilige Script noch im Speicher.
            • Dutchman
              Ich würde empfehlen „löschen wen läuft“ zu setzen 😉
                Cino last edited by Cino
                Ich habe gerade einen ESP mit 0.13.0-b4 geflashed. Ist auch im Netzwerk erreichbar und ich kann über die GUI auch alles steuern. Nur der Adapter findet diesen nicht. Gebe ich die IP ein passiert auch nichts weiter.
                EDIT: Ein Neustart des Servers hat geholfen. Die Geräte werden im Adapter Offline angezeigt, aber über die DP steuerbar. Der neue Geräte wurde auch gefunden.
                  warp735 @Cino last edited by
                  Hi zusammen...
                  wer hat denn noch einen SK6812 im Einsatz und wie steuert ihr den WW Kanal? Muss man das kompliziert über den DP [255,255,255,0] machen?
                    hartwigm @crunchip last edited by
                    Irgendwie steht mir einer auf dem Schlauch!
                    Ich habe eine Stripe mit der WLED Arduino am laufen. Auch die Anbindung an den iobroker über den WLED Adapter geht perfekt.
                    Nun wollte ich einen 2ten Stripe mit auf dem gleichen Weg einbinden.
                    Das Ding bekommt seine IP, ich kann die Weboberfläche aufrufen. Ich habe wie beim Stripe zuvor Segmente definiert. Über die Weböberfläche geht das super
                    Im Adapter wird das Device auch angezeigt. Auch wenn ich übers Webinterface schalte, sehe ich den Status im iobroker unter Objekte.
                    Wenn ich aber bei dem Stripe via iobroker das Segment
                    seg/<nr>/on auf true setzte passiert nichts.
                    Beim ersten Stripe ist das der Weg um das definierte Segment an- /auszuschalten.
                    Habt ihr mir da einen Tipp. Das kann ja nur eine Kleinigkeit sein, aber irgendwie finde ich den Fehler nicht.
                    • Dutchman
                      Dutchman Developer Most Active Administrators @hartwigm last edited by
                      @hartwigm sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
                      Kannst du den kompletten Streifen an/aus schalten ? Ergo geht es algemein nicht oder nur Segmente?
                        hartwigm @Dutchman last edited by
                        @dutchman
                        so jetzt eine Menge weiterer Tests gemacht.
                        1.) Wenn ich den Objektbaum komplett löschen und anschließend bei Devices die IP des WLED wieder angebe, werden die Stripedaten eingelesen und alles ist OK, Ich kann die Segmente schalten und Dimmen.
                        Nun kommt aber das Problem.
                        Wenn ich die Stromversorgung für den Controller abstecke oder das WLAN mal kurz ausschalte, funktioniert die WEB Oberfläche des WLED weiterhin (IP Adresse ist die Selbe wie zuvor) aber der Adapter funktioniert nicht mehr schreibend! Auch wenn ich den Adapter neu starte ändert sich daran nichts mehr. Es hilft nur noch die Rückkehr zu Punkt 1
                        Ich habe auch mal testweise eine 2te WLED Instanz angelegt, auch hier ist das Ergebnis gleich.
                        Auch wenn ich mal eine Stunde warte, hilft das nicht weiter,
                        Wenn ich den ON Parameter bei SEG setzt bleibt diese rot und kann scheinbar nicht übermittelt werden.
                        • Dutchman
                          @dutchman
                          Daan wurde mich jetzt interessieren ws im log kommt wen diese Situation auftritt.
                          Ich bekomme öfter signalen das ein verlorenen ESP den weck nicht zurück findet außer das man ioBroker komplett neu startet und glaube genau das passiert auch. gerade bei dir.
                          ~ Dutch
                            Auch ein Neustart am iobroker hilft hier nicht.
                            Die IP .134 geht immer
                            Die 2te WLED hat die IP x.x.x.95 diese geht immer übers Webinterface taucht hier aber im Logfile um 12:01. mit Fehlermeldung auf
                            H Dutchman 2 Replies Last reply Reply Quote 0
                              hartwigm @hartwigm last edited by
                              @hartwigm
                              und hier noch ein DEBUG Logfile beim Starten
                              Das WLED mit .....bb ist das Problem.
                              Danke für deine Unterstützung
                              wled.0
                              2021-11-11 13:59:01.106	debug	Create_state called for : b4e62d6986bb.seg.0.mi with value : false
                              wled.0
                              2021-11-11 13:59:01.105	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:01.104	debug	Create_state called for : b4e62d6986bb.seg.0.rev with value : false
                              wled.0
                              2021-11-11 13:59:01.103	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:01.101	debug	Create_state called for : b4e62d6986bb.seg.0.sel with value : true
                              wled.0
                              2021-11-11 13:59:01.101	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:01.099	debug	Create_state called for : b4e62d6986bb.seg.0.pal with value : 0
                              wled.0
                              2021-11-11 13:59:01.098	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:01.096	debug	Create_state called for : b4e62d6986bb.seg.0.ix with value : 128
                              wled.0
                              2021-11-11 13:59:01.096	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:01.094	debug	Create_state called for : b4e62d6986bb.seg.0.sx with value : 128
                              wled.0
                              2021-11-11 13:59:01.093	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:01.091	debug	Create_state called for : b4e62d6986bb.seg.0.fx with value : 0
                              wled.0
                              2021-11-11 13:59:01.091	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:01.089	debug	Create_state called for : b4e62d6986bb.seg.0.col.2_HEX with value : #000000
                              wled.0
                              2021-11-11 13:59:01.088	debug	Create_state called for : b4e62d6986bb.seg.0.col.2 with value : 0,0,0
                              wled.0
                              2021-11-11 13:59:01.086	debug	Create_state called for : b4e62d6986bb.seg.0.col.1_HEX with value : #000000
                              wled.0
                              2021-11-11 13:59:01.084	debug	Create_state called for : b4e62d6986bb.seg.0.col.1 with value : 0,0,0
                              wled.0
                              2021-11-11 13:59:01.083	debug	Create_state called for : b4e62d6986bb.seg.0.col.0_HEX with value : #ffa000
                              wled.0
                              2021-11-11 13:59:01.080	debug	Create_state called for : b4e62d6986bb.seg.0.col.0 with value : 255,160,0
                              wled.0
                              2021-11-11 13:59:01.080	debug	Naming : col with content : [255,160,0]
                              wled.0
                              2021-11-11 13:59:01.080	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:01.077	debug	Create_state called for : b4e62d6986bb.seg.0.bri with value : 255
                              wled.0
                              2021-11-11 13:59:01.077	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:01.075	debug	Create_state called for : b4e62d6986bb.seg.0.on with value : true
                              wled.0
                              2021-11-11 13:59:01.074	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:01.072	debug	Create_state called for : b4e62d6986bb.seg.0.of with value : 0
                              wled.0
                              2021-11-11 13:59:01.071	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:01.070	debug	Create_state called for : b4e62d6986bb.seg.0.spc with value : 0
                              wled.0
                              2021-11-11 13:59:01.069	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:01.067	debug	Create_state called for : b4e62d6986bb.seg.0.grp with value : 1
                              wled.0
                              2021-11-11 13:59:01.067	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:01.065	debug	Create_state called for : b4e62d6986bb.seg.0.len with value : 77
                              wled.0
                              2021-11-11 13:59:01.064	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:01.058	debug	Create_state called for : b4e62d6986bb.seg.0.stop with value : 77
                              wled.0
                              2021-11-11 13:59:01.058	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:01.056	debug	Create_state called for : b4e62d6986bb.seg.0.start with value : 0
                              wled.0
                              2021-11-11 13:59:01.055	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:01.052	debug	Create_state called for : b4e62d6986bb.seg.0.id with value : 0
                              wled.0
                              2021-11-11 13:59:01.052	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:01.052	debug	Segment Array : [{"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}]
                              wled.0
                              2021-11-11 13:59:01.051	debug	Datatype : object
                              wled.0
                              2021-11-11 13:59:01.048	debug	Create_state called for : b4e62d6986bb.mainseg with value : 0
                              wled.0
                              2021-11-11 13:59:01.047	debug	Default state created : mainseg : 0
                              wled.0
                              2021-11-11 13:59:01.047	debug	Datatype : number
                              wled.0
                              2021-11-11 13:59:01.045	debug	Create_state called for : b4e62d6986bb.lor with value : 0
                              wled.0
                              2021-11-11 13:59:01.044	debug	Default state created : lor : 0
                              wled.0
                              2021-11-11 13:59:01.044	debug	Datatype : number
                              wled.0
                              2021-11-11 13:59:01.042	debug	Create_state called for : b4e62d6986bb.udpn.recv with value : true
                              wled.0
                              2021-11-11 13:59:01.041	debug	Object states created for channel udpn with parameter : recv : true
                              wled.0
                              2021-11-11 13:59:01.039	debug	Create_state called for : b4e62d6986bb.udpn.send with value : false
                              wled.0
                              2021-11-11 13:59:01.039	debug	Object states created for channel udpn with parameter : send : false
                              wled.0
                              2021-11-11 13:59:01.037	debug	Datatype : object
                              wled.0
                              2021-11-11 13:59:01.036	debug	Create_state called for : b4e62d6986bb.nl.rem with value : -1
                              wled.0
                              2021-11-11 13:59:01.035	debug	Object states created for channel nl with parameter : rem : -1
                              wled.0
                              2021-11-11 13:59:01.032	debug	Create_state called for : b4e62d6986bb.nl.tbri with value : 0
                              wled.0
                              2021-11-11 13:59:01.031	debug	Object states created for channel nl with parameter : tbri : 0
                              wled.0
                              2021-11-11 13:59:01.030	debug	Create_state called for : b4e62d6986bb.nl.mode with value : 1
                              wled.0
                              2021-11-11 13:59:01.029	debug	Object states created for channel nl with parameter : mode : 1
                              wled.0
                              2021-11-11 13:59:01.027	debug	Create_state called for : b4e62d6986bb.nl.dur with value : 60
                              wled.0
                              2021-11-11 13:59:01.026	debug	Object states created for channel nl with parameter : dur : 60
                              wled.0
                              2021-11-11 13:59:01.024	debug	Create_state called for : b4e62d6986bb.nl.on with value : false
                              wled.0
                              2021-11-11 13:59:01.024	debug	Object states created for channel nl with parameter : on : false
                              wled.0
                              2021-11-11 13:59:01.023	debug	Datatype : object
                              wled.0
                              2021-11-11 13:59:01.020	debug	Create_state called for : b4e62d6986bb.pl with value : -1
                              wled.0
                              2021-11-11 13:59:01.020	debug	Default state created : pl : -1
                              wled.0
                              2021-11-11 13:59:01.020	debug	Datatype : number
                              wled.0
                              2021-11-11 13:59:01.015	debug	Create_state called for : b4e62d6986bb.ps with value : -1
                              wled.0
                              2021-11-11 13:59:01.015	debug	Default state created : ps : -1
                              wled.0
                              2021-11-11 13:59:01.014	debug	Datatype : number
                              wled.0
                              2021-11-11 13:59:00.972	debug	Create_state called for : b4e62d6986bb.transition with value : 7
                              wled.0
                              2021-11-11 13:59:00.971	debug	Default state created : transition : 7
                              wled.0
                              2021-11-11 13:59:00.971	debug	Datatype : number
                              wled.0
                              2021-11-11 13:59:00.967	debug	Create_state called for : b4e62d6986bb.bri with value : 128
                              wled.0
                              2021-11-11 13:59:00.967	debug	Default state created : bri : 128
                              wled.0
                              2021-11-11 13:59:00.966	debug	Datatype : number
                              wled.0
                              2021-11-11 13:59:00.963	debug	Create_state called for : b4e62d6986bb.on with value : false
                              wled.0
                              2021-11-11 13:59:00.963	debug	Default state created : on : false
                              wled.0
                              2021-11-11 13:59:00.962	debug	Datatype : boolean
                              wled.0
                              2021-11-11 13:59:00.960	debug	Create_state called for : b4e62d6986bb._info.ip with value : 192.168.133.95
                              wled.0
                              2021-11-11 13:59:00.959	debug	State created : ip : "192.168.133.95"
                              wled.0
                              2021-11-11 13:59:00.957	debug	Create_state called for : b4e62d6986bb._info.mac with value : b4e62d6986bb
                              wled.0
                              2021-11-11 13:59:00.956	debug	State created : mac : "b4e62d6986bb"
                              wled.0
                              2021-11-11 13:59:00.954	debug	Create_state called for : b4e62d6986bb._info.product with value : FOSS
                              wled.0
                              2021-11-11 13:59:00.953	debug	State created : product : "FOSS"
                              wled.0
                              2021-11-11 13:59:00.951	debug	Create_state called for : b4e62d6986bb._info.brand with value : WLED
                              wled.0
                              2021-11-11 13:59:00.950	debug	State created : brand : "WLED"
                              wled.0
                              2021-11-11 13:59:00.948	debug	Create_state called for : b4e62d6986bb._info.opt with value : 127
                              wled.0
                              2021-11-11 13:59:00.947	debug	State created : opt : 127
                              wled.0
                              2021-11-11 13:59:00.900	debug	Devices array from bonjour scan : {"192.168.133.134":{"ip":"192.168.133.134","mac":"b4e62d693a50","connected":true,"initialized":true,"name":"WLED","wsConnected":true,"wsPingSupported":true,"wsPong":true},"192.168.133.93":{"ip":"192.168.133.93","mac":"b4e62d6983ab","connected":false,"initialized":false},"192.168.133.95":{"ip":"192.168.133.95","mac":"b4e62d6986bb","connected":true,"initialized":true,"name":"WLED-Post","wsConnected":true,"wsPingSupported":true,"wsPong":true}}
                              wled.0
                              2021-11-11 13:59:00.896	debug	Create_state called for : b4e62d6986bb._info.uptime with value : 12060
                              wled.0
                              2021-11-11 13:59:00.895	debug	State created : uptime : 12060
                              wled.0
                              2021-11-11 13:59:00.843	debug	Create_state called for : b4e62d6986bb._info.freeheap with value : 21240
                              wled.0
                              2021-11-11 13:59:00.841	debug	State created : freeheap : 21240
                              wled.0
                              2021-11-11 13:59:00.838	debug	Create_state called for : b4e62d6986bb._info.lwip with value : 1
                              wled.0
                              2021-11-11 13:59:00.837	debug	State created : lwip : 1
                              wled.0
                              2021-11-11 13:59:00.836	debug	Create_state called for : b4e62d6986bb._info.core with value : 2_7_4_7
                              wled.0
                              2021-11-11 13:59:00.835	debug	State created : core : "2_7_4_7"
                              wled.0
                              2021-11-11 13:59:00.834	debug	Create_state called for : b4e62d6986bb._info.arch with value : esp8266
                              wled.0
                              2021-11-11 13:59:00.833	debug	State created : arch : "esp8266"
                              wled.0
                              2021-11-11 13:59:00.832	debug	Create_state called for : b4e62d6986bb._info.ndc with value : -1
                              wled.0
                              2021-11-11 13:59:00.831	debug	State created : ndc : -1
                              wled.0
                              2021-11-11 13:59:00.829	debug	Create_state called for : b4e62d6986bb._info.fs.pmt with value : 0
                              wled.0
                              2021-11-11 13:59:00.829	debug	State created : pmt : 0
                              wled.0
                              2021-11-11 13:59:00.827	debug	Create_state called for : b4e62d6986bb._info.fs.t with value : 1024
                              wled.0
                              2021-11-11 13:59:00.827	debug	State created : t : 1024
                              wled.0
                              2021-11-11 13:59:00.825	debug	Create_state called for : b4e62d6986bb._info.fs.u with value : 49
                              wled.0
                              2021-11-11 13:59:00.824	debug	State created : u : 49
                              wled.0
                              2021-11-11 13:59:00.822	debug	Create_state called for : b4e62d6986bb._info.wifi.channel with value : 11
                              wled.0
                              2021-11-11 13:59:00.821	debug	State created : channel : 11
                              wled.0
                              2021-11-11 13:59:00.819	debug	Create_state called for : b4e62d6986bb._info.wifi.signal with value : 50
                              wled.0
                              2021-11-11 13:59:00.819	debug	State created : signal : 50
                              wled.0
                              2021-11-11 13:59:00.817	debug	Create_state called for : b4e62d6986bb._info.wifi.rssi with value : -75
                              wled.0
                              2021-11-11 13:59:00.817	debug	State created : rssi : -75
                              wled.0
                              2021-11-11 13:59:00.815	debug	Create_state called for : b4e62d6986bb._info.wifi.bssid with value : 4A:D9:E7:FA:E1:26
                              wled.0
                              2021-11-11 13:59:00.815	debug	State created : bssid : "4A:D9:E7:FA:E1:26"
                              wled.0
                              2021-11-11 13:59:00.813	debug	Create_state called for : b4e62d6986bb._info.palcount with value : 71
                              wled.0
                              2021-11-11 13:59:00.813	debug	State created : palcount : 71
                              wled.0
                              2021-11-11 13:59:00.811	debug	Create_state called for : b4e62d6986bb._info.fxcount with value : 118
                              wled.0
                              2021-11-11 13:59:00.810	debug	State created : fxcount : 118
                              wled.0
                              2021-11-11 13:59:00.763	debug	Create_state called for : b4e62d6986bb._info.ws with value : 1
                              wled.0
                              2021-11-11 13:59:00.763	debug	State created : ws : 1
                              wled.0
                              2021-11-11 13:59:00.759	debug	Create_state called for : b4e62d6986bb._info.lip with value :
                              wled.0
                              2021-11-11 13:59:00.759	debug	State created : lip : ""
                              wled.0
                              2021-11-11 13:59:00.757	debug	Create_state called for : b4e62d6986bb._info.lm with value :
                              wled.0
                              2021-11-11 13:59:00.757	debug	State created : lm : ""
                              wled.0
                              2021-11-11 13:59:00.753	debug	Create_state called for : b4e62d6986bb._info.live with value : false
                              wled.0
                              2021-11-11 13:59:00.748	debug	State created : live : false
                              wled.0
                              2021-11-11 13:59:00.744	debug	Create_state called for : b4e62d6986bb._info.udpport with value : 21324
                              wled.0
                              2021-11-11 13:59:00.740	debug	State created : udpport : 21324
                              wled.0
                              2021-11-11 13:59:00.713	debug	Create_state called for : b4e62d6986bb._info.name with value : WLED-Post
                              wled.0
                              2021-11-11 13:59:00.712	debug	State created : name : "WLED-Post"
                              wled.0
                              2021-11-11 13:59:00.711	debug	Create_state called for : b4e62d6986bb._info.str with value : false
                              wled.0
                              2021-11-11 13:59:00.711	debug	State created : str : false
                              wled.0
                              2021-11-11 13:59:00.709	debug	Create_state called for : b4e62d6986bb._info.leds.seglock with value : false
                              wled.0
                              2021-11-11 13:59:00.708	debug	State created : seglock : false
                              wled.0
                              2021-11-11 13:59:00.707	debug	Create_state called for : b4e62d6986bb._info.leds.maxseg with value : 16
                              wled.0
                              2021-11-11 13:59:00.707	debug	State created : maxseg : 16
                              wled.0
                              2021-11-11 13:59:00.705	debug	Create_state called for : b4e62d6986bb._info.leds.maxpwr with value : 600
                              wled.0
                              2021-11-11 13:59:00.704	debug	State created : maxpwr : 600
                              wled.0
                              2021-11-11 13:59:00.703	debug	Create_state called for : b4e62d6986bb._info.leds.fps with value : 0
                              wled.0
                              2021-11-11 13:59:00.702	debug	State created : fps : 0
                              wled.0
                              2021-11-11 13:59:00.701	debug	Create_state called for : b4e62d6986bb._info.leds.pwr with value : 177
                              wled.0
                              2021-11-11 13:59:00.700	debug	State created : pwr : 177
                              wled.0
                              2021-11-11 13:59:00.699	debug	Create_state called for : b4e62d6986bb._info.leds.wv with value : false
                              wled.0
                              2021-11-11 13:59:00.698	debug	State created : wv : false
                              wled.0
                              2021-11-11 13:59:00.656	debug	Create_state called for : b4e62d6986bb._info.leds.rgbw with value : false
                              wled.0
                              2021-11-11 13:59:00.655	debug	State created : rgbw : false
                              wled.0
                              2021-11-11 13:59:00.654	debug	Pong received by websocket
                              wled.0
                              2021-11-11 13:59:00.654	debug	Websocket WLED message received for 192.168.133.95 : pong
                              wled.0
                              2021-11-11 13:59:00.627	debug	Create_state called for : b4e62d6986bb._info.leds.count with value : 77
                              wled.0
                              2021-11-11 13:59:00.627	debug	State created : count : 77
                              wled.0
                              2021-11-11 13:59:00.625	debug	Create_state called for : b4e62d6986bb._info.vid with value : 2109220
                              wled.0
                              2021-11-11 13:59:00.625	debug	State created : vid : 2109220
                              wled.0
                              2021-11-11 13:59:00.616	debug	Create_state called for : b4e62d6986bb._info.ver with value : 0.13.0-b3
                              wled.0
                              2021-11-11 13:59:00.615	debug	State created : ver : "0.13.0-b3"
                              wled.0
                              2021-11-11 13:59:00.613	debug	Websocket WLED message received for 192.168.133.95 : {"state":{"on":false,"bri":128,"transition":7,"ps":-1,"pl":-1,"nl":{"on":false,"dur":60,"mode":1,"tbri":0,"rem":-1},"udpn":{"send":false,"recv":true},"lor":0,"mainseg":0,"seg":[{"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}]},"info":{"ver":"0.13.0-b3","vid":2109220,"leds":{"count":77,"rgbw":false,"wv":false,"pwr":177,"fps":0,"maxpwr":600,"maxseg":16,"seglock":false},"str":false,"name":"WLED-Post","udpport":21324,"live":false,"lm":"","lip":"","ws":1,"fxcount":118,"palcount":71,"wifi":{"bssid":"4A:D9:E7:FA:E1:26","rssi":-75,"signal":50,"channel":11},"fs":{"u":49,"t":1024,"pmt":0},"ndc":-1,"arch":"esp8266","core":"2_7_4_7","lwip":1,"freeheap":21240,"uptime":12060,"opt":127,"brand":"WLED","product":"FOSS","mac":"b4e62d6986bb","ip":"192.168.133.95"}}
                              wled.0
                              2021-11-11 13:59:00.597	info	WLED-Post connected
                              wled.0
                              2021-11-11 13:59:00.583	debug	Devices array from bonjour scan : {"192.168.133.134":{"ip":"192.168.133.134","mac":"b4e62d693a50","connected":true,"initialized":true,"name":"WLED","wsConnected":true,"wsPingSupported":true,"wsPong":true},"192.168.133.93":{"ip":"192.168.133.93","mac":"b4e62d6983ab","connected":false,"initialized":false},"192.168.133.95":{"ip":"192.168.133.95","mac":"b4e62d6986bb","connected":true,"initialized":true,"name":"WLED-Post"}}
                              wled.0
                              2021-11-11 13:59:00.569	info	Bonjour service started, new devices will be detected automatically
                              wled.0
                              2021-11-11 13:59:00.499	debug	An attribute has changed : b4e62d6986bb.seg.0.mi | old undefined | new {"name":"Mirrors the segment (available since 0.10.2)","type":"boolean","role":"state","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:59:00.499	debug	Create_state called for : b4e62d6986bb.seg.0.mi with value : false
                              wled.0
                              2021-11-11 13:59:00.498	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:00.439	debug	An attribute has changed : b4e62d6986bb.seg.0.rev | old undefined | new {"name":"Flips the segment, causing animations to change direction","type":"boolean","role":"switch","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:59:00.439	debug	Create_state called for : b4e62d6986bb.seg.0.rev with value : false
                              wled.0
                              2021-11-11 13:59:00.439	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:00.390	debug	An attribute has changed : b4e62d6986bb.seg.0.sel | old undefined | new {"name":"Selected segments will have their state (color/FX) updated ","type":"boolean","role":"switch","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:59:00.390	debug	Create_state called for : b4e62d6986bb.seg.0.sel with value : true
                              wled.0
                              2021-11-11 13:59:00.389	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:00.332	debug	An attribute has changed : b4e62d6986bb.seg.0.pal | old undefined | new {"name":"ID of the color palette","type":"number","role":"state","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:59:00.331	debug	Create_state called for : b4e62d6986bb.seg.0.pal with value : 0
                              wled.0
                              2021-11-11 13:59:00.331	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:00.316	debug	An attribute has changed : b4e62d6986bb.seg.0.ix | old undefined | new {"name":"Effect intensity","type":"number","role":"state","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:59:00.316	debug	Create_state called for : b4e62d6986bb.seg.0.ix with value : 128
                              wled.0
                              2021-11-11 13:59:00.315	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:00.308	debug	An attribute has changed : b4e62d6986bb.seg.0.sx | old undefined | new {"name":"Relative effect speed","type":"number","role":"state","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:59:00.307	debug	Create_state called for : b4e62d6986bb.seg.0.sx with value : 128
                              wled.0
                              2021-11-11 13:59:00.307	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:00.299	debug	Create special drop down state with value {"b4e62d693a50":{"0":"Solid","1":"Blink","2":"Breathe","3":"Wipe","4":"Wipe Random","5":"Random Colors","6":"Sweep","7":"Dynamic","8":"Colorloop","9":"Rainbow","10":"Scan","11":"Scan Dual","12":"Fade","13":"Theater","14":"Theater Rainbow","15":"Running","16":"Saw","17":"Twinkle","18":"Dissolve","19":"Dissolve Rnd","20":"Sparkle","21":"Sparkle Dark","22":"Sparkle+","23":"Strobe","24":"Strobe Rainbow","25":"Strobe Mega","26":"Blink Rainbow","27":"Android","28":"Chase","29":"Chase Random","30":"Chase Rainbow","31":"Chase Flash","32":"Chase Flash Rnd","33":"Rainbow Runner","34":"Colorful","35":"Traffic Light","36":"Sweep Random","37":"Running 2","38":"Aurora","39":"Stream","40":"Scanner","41":"Lighthouse","42":"Fireworks","43":"Rain","44":"Tetrix","45":"Fire Flicker","46":"Gradient","47":"Loading","48":"Police","49":"Police All","50":"Two Dots","51":"Two Areas","52":"Running Dual","53":"Halloween","54":"Tri Chase","55":"Tri Wipe","56":"Tri Fade","57":"Lightning","58":"ICU","59":"Multi Comet","60":"Scanner Dual","61":"Stream 2","62":"Oscillate","63":"Pride 2015","64":"Juggle","65":"Palette","66":"Fire 2012","67":"Colorwaves","68":"Bpm","69":"Fill Noise","70":"Noise 1","71":"Noise 2","72":"Noise 3","73":"Noise 4","74":"Colortwinkles","75":"Lake","76":"Meteor","77":"Meteor Smooth","78":"Railway","79":"Ripple","80":"Twinklefox","81":"Twinklecat","82":"Halloween Eyes","83":"Solid Pattern","84":"Solid Pattern Tri","85":"Spots","86":"Spots Fade","87":"Glitter","88":"Candle","89":"Fireworks Starburst","90":"Fireworks 1D","91":"Bouncing Balls","92":"Sinelon","93":"Sinelon Dual","94":"Sinelon Rainbow","95":"Popcorn","96":"Drip","97":"Plasma","98":"Percent","99":"Ripple Rainbow","100":"Heartbeat","101":"Pacifica","102":"Candle Multi","103":"Solid Glitter","104":"Sunrise","105":"Phased","106":"Twinkleup","107":"Noise Pal","108":"Sine","109":"Phased Noise","110":"Flow","111":"Chunchun","112":"Dancing Shadows","113":"Washing Machine","114":"Candy Cane","115":"Blends","116":"TV Simulator","117":"Dynamic Smooth"},"b4e62d6986bb":{"0":"Solid","1":"Blink","2":"Breathe","3":"Wipe","4":"Wipe Random","5":"Random Colors","6":"Sweep","7":"Dynamic","8":"Colorloop","9":"Rainbow","10":"Scan","11":"Scan Dual","12":"Fade","13":"Theater","14":"Theater Rainbow","15":"Running","16":"Saw","17":"Twinkle","18":"Dissolve","19":"Dissolve Rnd","20":"Sparkle","21":"Sparkle Dark","22":"Sparkle+","23":"Strobe","24":"Strobe Rainbow","25":"Strobe Mega","26":"Blink Rainbow","27":"Android","28":"Chase","29":"Chase Random","30":"Chase Rainbow","31":"Chase Flash","32":"Chase Flash Rnd","33":"Rainbow Runner","34":"Colorful","35":"Traffic Light","36":"Sweep Random","37":"Running 2","38":"Aurora","39":"Stream","40":"Scanner","41":"Lighthouse","42":"Fireworks","43":"Rain","44":"Tetrix","45":"Fire Flicker","46":"Gradient","47":"Loading","48":"Police","49":"Police All","50":"Two Dots","51":"Two Areas","52":"Running Dual","53":"Halloween","54":"Tri Chase","55":"Tri Wipe","56":"Tri Fade","57":"Lightning","58":"ICU","59":"Multi Comet","60":"Scanner Dual","61":"Stream 2","62":"Oscillate","63":"Pride 2015","64":"Juggle","65":"Palette","66":"Fire 2012","67":"Colorwaves","68":"Bpm","69":"Fill Noise","70":"Noise 1","71":"Noise 2","72":"Noise 3","73":"Noise 4","74":"Colortwinkles","75":"Lake","76":"Meteor","77":"Meteor Smooth","78":"Railway","79":"Ripple","80":"Twinklefox","81":"Twinklecat","82":"Halloween Eyes","83":"Solid Pattern","84":"Solid Pattern Tri","85":"Spots","86":"Spots Fade","87":"Glitter","88":"Candle","89":"Fireworks Starburst","90":"Fireworks 1D","91":"Bouncing Balls","92":"Sinelon","93":"Sinelon Dual","94":"Sinelon Rainbow","95":"Popcorn","96":"Drip","97":"Plasma","98":"Percent","99":"Ripple Rainbow","100":"Heartbeat","101":"Pacifica","102":"Candle Multi","103":"Solid Glitter","104":"Sunrise","105":"Phased","106":"Twinkleup","107":"Noise Pal","108":"Sine","109":"Phased Noise","110":"Flow","111":"Chunchun","112":"Dancing Shadows","113":"Washing Machine","114":"Candy Cane","115":"Blends","116":"TV Simulator","117":"Dynamic Smooth"}}
                              wled.0
                              2021-11-11 13:59:00.290	debug	An attribute has changed : b4e62d6986bb.seg.0.fx | old undefined | new {"name":"ID of the effect ","type":"number","role":"state","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:59:00.290	debug	Create_state called for : b4e62d6986bb.seg.0.fx with value : 0
                              wled.0
                              2021-11-11 13:59:00.289	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:00.282	debug	An attribute has changed : b4e62d6986bb.seg.0.col.2_HEX | old undefined | new {"name":"Tertiary Color HEX","type":"mixed","role":"level.color.hex","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:59:00.282	debug	Create_state called for : b4e62d6986bb.seg.0.col.2_HEX with value : #000000
                              wled.0
                              2021-11-11 13:59:00.271	debug	An attribute has changed : b4e62d6986bb.seg.0.col.2 | old undefined | new {"name":"Tertiary Color RGB","type":"mixed","role":"level.color.rgb","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:59:00.271	debug	Create_state called for : b4e62d6986bb.seg.0.col.2 with value : 0,0,0
                              wled.0
                              2021-11-11 13:59:00.253	debug	An attribute has changed : b4e62d6986bb.seg.0.col.1_HEX | old undefined | new {"name":"Secondary Color HEX (background)","type":"mixed","role":"level.color.hex","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:59:00.252	debug	Create_state called for : b4e62d6986bb.seg.0.col.1_HEX with value : #000000
                              wled.0
                              2021-11-11 13:59:00.245	debug	An attribute has changed : b4e62d6986bb.seg.0.col.1 | old undefined | new {"name":"Secondary Color RGB (background)","type":"mixed","role":"level.color.rgb","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:59:00.244	debug	Create_state called for : b4e62d6986bb.seg.0.col.1 with value : 0,0,0
                              wled.0
                              2021-11-11 13:59:00.237	debug	An attribute has changed : b4e62d6986bb.seg.0.col.0_HEX | old undefined | new {"name":"Primary Color HEX","type":"mixed","role":"level.color.hex","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:59:00.237	debug	Create_state called for : b4e62d6986bb.seg.0.col.0_HEX with value : #ffa000
                              wled.0
                              2021-11-11 13:59:00.228	debug	An attribute has changed : b4e62d6986bb.seg.0.col.0 | old undefined | new {"name":"Primary Color RGB","type":"mixed","role":"level.color.rgb","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:59:00.228	debug	Create_state called for : b4e62d6986bb.seg.0.col.0 with value : 255,160,0
                              wled.0
                              2021-11-11 13:59:00.228	debug	Naming : col with content : [255,160,0]
                              wled.0
                              2021-11-11 13:59:00.227	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:00.218	debug	An attribute has changed : b4e62d6986bb.seg.0.bri | old undefined | new {"min":0,"max":255,"name":"Brightness of the light","type":"number","role":"value.brightness","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:59:00.218	debug	Create_state called for : b4e62d6986bb.seg.0.bri with value : 255
                              wled.0
                              2021-11-11 13:59:00.218	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:00.210	debug	An attribute has changed : b4e62d6986bb.seg.0.on | old undefined | new {"name":"On / Off","type":"boolean","role":"switch","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:59:00.210	debug	Create_state called for : b4e62d6986bb.seg.0.on with value : true
                              wled.0
                              2021-11-11 13:59:00.209	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:00.202	debug	An attribute has changed : b4e62d6986bb.seg.0.of | old undefined | new {"name":"Offset (how many LEDs to rotate the virtual start of the segments, available since 0.13.0)","type":"number","role":"state","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:59:00.202	debug	Create_state called for : b4e62d6986bb.seg.0.of with value : 0
                              wled.0
                              2021-11-11 13:59:00.201	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:00.194	debug	An attribute has changed : b4e62d6986bb.seg.0.spc | old undefined | new {"min":0,"max":255,"name":"Spacing (how many LEDs are turned off and skipped between each group)","type":"number","role":"state","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:59:00.194	debug	Create_state called for : b4e62d6986bb.seg.0.spc with value : 0
                              wled.0
                              2021-11-11 13:59:00.194	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:00.185	debug	An attribute has changed : b4e62d6986bb.seg.0.grp | old undefined | new {"name":"grp","type":"number","role":"state","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:59:00.185	debug	Create_state called for : b4e62d6986bb.seg.0.grp with value : 1
                              wled.0
                              2021-11-11 13:59:00.185	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:00.176	debug	An attribute has changed : b4e62d6986bb.seg.0.len | old undefined | new {"name":"Length of the segment (stop - start). stop has preference","type":"number","role":"state","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:59:00.175	debug	Create_state called for : b4e62d6986bb.seg.0.len with value : 77
                              wled.0
                              2021-11-11 13:59:00.171	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:00.118	debug	An attribute has changed : b4e62d6986bb.seg.0.stop | old undefined | new {"name":"LED the segment stops at, not included in range","type":"number","role":"state","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:59:00.118	debug	Create_state called for : b4e62d6986bb.seg.0.stop with value : 77
                              wled.0
                              2021-11-11 13:59:00.116	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:00.107	debug	An attribute has changed : b4e62d6986bb.seg.0.start | old undefined | new {"name":"LED the segment starts at.","type":"number","role":"state","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:59:00.106	debug	Create_state called for : b4e62d6986bb.seg.0.start with value : 0
                              wled.0
                              2021-11-11 13:59:00.106	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:00.096	debug	An attribute has changed : b4e62d6986bb.seg.0.id | old undefined | new {"name":"Zero-indexed ID of the segment","type":"number","role":"state","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:59:00.096	debug	Create_state called for : b4e62d6986bb.seg.0.id with value : 0
                              wled.0
                              2021-11-11 13:59:00.095	debug	Object states created for channel seg with parameter : 0 : {"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}
                              wled.0
                              2021-11-11 13:59:00.091	debug	Segment Array : [{"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}]
                              wled.0
                              2021-11-11 13:59:00.090	debug	Datatype : object
                              wled.0
                              2021-11-11 13:59:00.081	debug	An attribute has changed : b4e62d6986bb.mainseg | old undefined | new {"name":"Main Segment","type":"number","role":"state","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:59:00.081	debug	Create_state called for : b4e62d6986bb.mainseg with value : 0
                              wled.0
                              2021-11-11 13:59:00.080	debug	Default state created : mainseg : 0
                              wled.0
                              2021-11-11 13:59:00.080	debug	Datatype : number
                              wled.0
                              2021-11-11 13:59:00.069	debug	An attribute has changed : b4e62d6986bb.lor | old undefined | new {"name":"Live data override. 0 is off, 1 is override until live data ends, 2 is override until ESP reboot (available since 0.10.0)","type":"number","role":"state","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:59:00.069	debug	Create_state called for : b4e62d6986bb.lor with value : 0
                              wled.0
                              2021-11-11 13:59:00.069	debug	Default state created : lor : 0
                              wled.0
                              2021-11-11 13:59:00.068	debug	Datatype : number
                              wled.0
                              2021-11-11 13:59:00.059	debug	An attribute has changed : b4e62d6986bb.udpn.recv | old undefined | new {"name":"Receive broadcast packets","type":"boolean","role":"switch","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:59:00.059	debug	Create_state called for : b4e62d6986bb.udpn.recv with value : true
                              wled.0
                              2021-11-11 13:59:00.058	debug	Object states created for channel udpn with parameter : recv : true
                              wled.0
                              2021-11-11 13:59:00.049	debug	An attribute has changed : b4e62d6986bb.udpn.send | old undefined | new {"name":"Send WLED broadcast (UDP sync) packet on state change","type":"boolean","role":"switch","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:59:00.049	debug	Create_state called for : b4e62d6986bb.udpn.send with value : false
                              wled.0
                              2021-11-11 13:59:00.048	debug	Object states created for channel udpn with parameter : send : false
                              wled.0
                              2021-11-11 13:59:00.046	debug	Datatype : object
                              wled.0
                              2021-11-11 13:59:00.038	debug	An attribute has changed : b4e62d6986bb.nl.rem | old undefined | new {"name":"Remaining nightlight in seconds","type":"number","role":"state","read":true,"unit":"s","write":false}
                              wled.0
                              2021-11-11 13:59:00.038	debug	Create_state called for : b4e62d6986bb.nl.rem with value : -1
                              wled.0
                              2021-11-11 13:59:00.037	debug	Object states created for channel nl with parameter : rem : -1
                              wled.0
                              2021-11-11 13:59:00.027	debug	An attribute has changed : b4e62d6986bb.nl.tbri | old undefined | new {"name":"Target brightness of nightlight feature","type":"number","role":"value.brightness","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:59:00.027	debug	Create_state called for : b4e62d6986bb.nl.tbri with value : 0
                              wled.0
                              2021-11-11 13:59:00.026	debug	Object states created for channel nl with parameter : tbri : 0
                              wled.0
                              2021-11-11 13:58:59.947	debug	An attribute has changed : b4e62d6986bb.nl.mode | old undefined | new {"name":"Nightlight mode","type":"number","role":"state","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:59.947	debug	Create_state called for : b4e62d6986bb.nl.mode with value : 1
                              wled.0
                              2021-11-11 13:58:59.946	debug	Object states created for channel nl with parameter : mode : 1
                              wled.0
                              2021-11-11 13:58:59.888	debug	An attribute has changed : b4e62d6986bb.nl.dur | old undefined | new {"name":"Duration of nightlight in minutes","type":"number","role":"state","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:58:59.887	debug	Create_state called for : b4e62d6986bb.nl.dur with value : 60
                              wled.0
                              2021-11-11 13:58:59.886	debug	Object states created for channel nl with parameter : dur : 60
                              wled.0
                              2021-11-11 13:58:59.834	debug	An attribute has changed : b4e62d6986bb.nl.on | old undefined | new {"name":"On / Off","type":"boolean","role":"switch","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:58:59.834	debug	Create_state called for : b4e62d6986bb.nl.on with value : false
                              wled.0
                              2021-11-11 13:58:59.834	debug	Object states created for channel nl with parameter : on : false
                              wled.0
                              2021-11-11 13:58:59.831	debug	Datatype : object
                              wled.0
                              2021-11-11 13:58:59.740	debug	An attribute has changed : b4e62d6986bb.pl | old undefined | new {"name":"ID of currently set playlist","type":"number","role":"state","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:58:59.740	debug	Create_state called for : b4e62d6986bb.pl with value : -1
                              wled.0
                              2021-11-11 13:58:59.731	debug	Default state created : pl : -1
                              wled.0
                              2021-11-11 13:58:59.731	debug	Datatype : number
                              wled.0
                              2021-11-11 13:58:59.647	debug	An attribute has changed : b4e62d6986bb.ps | old undefined | new {"name":"ID of currently set preset","type":"number","role":"state","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:58:59.647	debug	Create_state called for : b4e62d6986bb.ps with value : -1
                              wled.0
                              2021-11-11 13:58:59.647	debug	Default state created : ps : -1
                              wled.0
                              2021-11-11 13:58:59.646	debug	Datatype : number
                              wled.0
                              2021-11-11 13:58:59.592	debug	An attribute has changed : b4e62d6986bb.transition | old undefined | new {"name":"Duration of the crossfade between different colors/brightness levels.","type":"number","role":"value.transition","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:58:59.592	debug	Create_state called for : b4e62d6986bb.transition with value : 7
                              wled.0
                              2021-11-11 13:58:59.591	debug	Default state created : transition : 7
                              wled.0
                              2021-11-11 13:58:59.591	debug	Datatype : number
                              wled.0
                              2021-11-11 13:58:59.528	debug	An attribute has changed : b4e62d6986bb.bri | old undefined | new {"min":0,"max":255,"name":"Brightness of the light","type":"number","role":"value.brightness","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:58:59.527	debug	Create_state called for : b4e62d6986bb.bri with value : 128
                              wled.0
                              2021-11-11 13:58:59.527	debug	Default state created : bri : 128
                              wled.0
                              2021-11-11 13:58:59.526	debug	Datatype : number
                              wled.0
                              2021-11-11 13:58:59.517	debug	An attribute has changed : b4e62d6986bb.on | old undefined | new {"name":"On / Off","type":"boolean","role":"switch","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:58:59.517	debug	Create_state called for : b4e62d6986bb.on with value : false
                              wled.0
                              2021-11-11 13:58:59.516	debug	Default state created : on : false
                              wled.0
                              2021-11-11 13:58:59.516	debug	Datatype : boolean
                              wled.0
                              2021-11-11 13:58:59.506	debug	An attribute has changed : b4e62d6986bb._info.ip | old undefined | new {"name":"IP Address","type":"string","role":"state","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:59.506	debug	Create_state called for : b4e62d6986bb._info.ip with value : 192.168.133.95
                              wled.0
                              2021-11-11 13:58:59.505	debug	State created : ip : "192.168.133.95"
                              wled.0
                              2021-11-11 13:58:59.497	debug	An attribute has changed : b4e62d6986bb._info.mac | old undefined | new {"name":"The hexadecimal hardware MAC address of the light, lowercase and without colons","type":"string","role":"info.mac","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:59.496	debug	Create_state called for : b4e62d6986bb._info.mac with value : b4e62d6986bb
                              wled.0
                              2021-11-11 13:58:59.496	debug	State created : mac : "b4e62d6986bb"
                              wled.0
                              2021-11-11 13:58:59.489	debug	An attribute has changed : b4e62d6986bb._info.product | old undefined | new {"name":"The product name. Always DIY light for standard installations.","type":"mixed","role":"info.name","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:59.489	debug	Create_state called for : b4e62d6986bb._info.product with value : FOSS
                              wled.0
                              2021-11-11 13:58:59.488	debug	State created : product : "FOSS"
                              wled.0
                              2021-11-11 13:58:59.481	debug	An attribute has changed : b4e62d6986bb._info.brand | old undefined | new {"name":"The producer/vendor of the light. Always WLED for standard installations.","type":"mixed","role":"info.name ","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:59.480	debug	Create_state called for : b4e62d6986bb._info.brand with value : WLED
                              wled.0
                              2021-11-11 13:58:59.480	debug	State created : brand : "WLED"
                              wled.0
                              2021-11-11 13:58:59.473	debug	An attribute has changed : b4e62d6986bb._info.opt | old undefined | new {"name":"Used for debugging purposes only","type":"mixed","role":"state","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:59.472	debug	Create_state called for : b4e62d6986bb._info.opt with value : 127
                              wled.0
                              2021-11-11 13:58:59.472	debug	State created : opt : 127
                              wled.0
                              2021-11-11 13:58:59.461	debug	An attribute has changed : b4e62d6986bb._info.uptime | old undefined | new {"name":"Time since the last boot/reset in seconds","type":"number","role":"info.status","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:59.460	debug	Create_state called for : b4e62d6986bb._info.uptime with value : 12057
                              wled.0
                              2021-11-11 13:58:59.460	debug	State created : uptime : 12057
                              wled.0
                              2021-11-11 13:58:59.448	debug	An attribute has changed : b4e62d6986bb._info.freeheap | old undefined | new {"name":"Bytes of heap memory (RAM) currently available. Problematic if <10k.","type":"number","role":"info.status","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:59.448	debug	Create_state called for : b4e62d6986bb._info.freeheap with value : 21280
                              wled.0
                              2021-11-11 13:58:59.447	debug	State created : freeheap : 21280
                              wled.0
                              2021-11-11 13:58:59.438	debug	An attribute has changed : b4e62d6986bb._info.lwip | old undefined | new {"name":"lwip","type":"number","role":"state","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:59.438	debug	Create_state called for : b4e62d6986bb._info.lwip with value : 1
                              wled.0
                              2021-11-11 13:58:59.437	debug	State created : lwip : 1
                              wled.0
                              2021-11-11 13:58:59.418	debug	An attribute has changed : b4e62d6986bb._info.core | old undefined | new {"name":"Version of the underlying (Arduino core) SDK","type":"mixed","role":"state","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:59.418	debug	Create_state called for : b4e62d6986bb._info.core with value : 2_7_4_7
                              wled.0
                              2021-11-11 13:58:59.417	debug	State created : core : "2_7_4_7"
                              wled.0
                              2021-11-11 13:58:59.405	debug	An attribute has changed : b4e62d6986bb._info.arch | old undefined | new {"name":"Name of the platform.","type":"mixed","role":"state","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:59.405	debug	Create_state called for : b4e62d6986bb._info.arch with value : esp8266
                              wled.0
                              2021-11-11 13:58:59.405	debug	State created : arch : "esp8266"
                              wled.0
                              2021-11-11 13:58:59.396	debug	An attribute has changed : b4e62d6986bb._info.ndc | old undefined | new {"name":"Number of other WLED devices discovered on the network. -1 if Node discovery disabled. (since 0.12.0)","type":"number","role":"state","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:59.395	debug	Create_state called for : b4e62d6986bb._info.ndc with value : -1
                              wled.0
                              2021-11-11 13:58:59.395	debug	State created : ndc : -1
                              wled.0
                              2021-11-11 13:58:59.386	debug	An attribute has changed : b4e62d6986bb._info.fs.pmt | old undefined | new {"name":"presetsModifiedTime","type":"number","role":"state","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:59.385	debug	Create_state called for : b4e62d6986bb._info.fs.pmt with value : 0
                              wled.0
                              2021-11-11 13:58:59.385	debug	State created : pmt : 0
                              wled.0
                              2021-11-11 13:58:59.375	debug	An attribute has changed : b4e62d6986bb._info.fs.t | old undefined | new {"name":"fsBytesTotal in kB","type":"number","role":"state","read":true,"unit":"kB","write":false}
                              wled.0
                              2021-11-11 13:58:59.375	debug	Create_state called for : b4e62d6986bb._info.fs.t with value : 1024
                              wled.0
                              2021-11-11 13:58:59.374	debug	State created : t : 1024
                              wled.0
                              2021-11-11 13:58:59.364	debug	An attribute has changed : b4e62d6986bb._info.fs.u | old undefined | new {"name":"fsBytesUsed in kB","type":"number","role":"state","read":true,"unit":"kB","write":false}
                              wled.0
                              2021-11-11 13:58:59.363	debug	Create_state called for : b4e62d6986bb._info.fs.u with value : 49
                              wled.0
                              2021-11-11 13:58:59.362	debug	State created : u : 49
                              wled.0
                              2021-11-11 13:58:59.314	debug	An attribute has changed : b4e62d6986bb._info.wifi.channel | old undefined | new {"name":"The current WiFi channel","type":"number","role":"info.address","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:59.314	debug	Create_state called for : b4e62d6986bb._info.wifi.channel with value : 11
                              wled.0
                              2021-11-11 13:58:59.313	debug	State created : channel : 11
                              wled.0
                              2021-11-11 13:58:59.305	debug	An attribute has changed : b4e62d6986bb._info.wifi.signal | old undefined | new {"name":"Relative signal quality of the current connection","type":"number","role":"info.status","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:59.304	debug	Create_state called for : b4e62d6986bb._info.wifi.signal with value : 50
                              wled.0
                              2021-11-11 13:58:59.304	debug	State created : signal : 50
                              wled.0
                              2021-11-11 13:58:59.296	debug	An attribute has changed : b4e62d6986bb._info.wifi.rssi | old undefined | new {"name":"rssi","type":"number","role":"state","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:59.295	debug	Create_state called for : b4e62d6986bb._info.wifi.rssi with value : -75
                              wled.0
                              2021-11-11 13:58:59.295	debug	State created : rssi : -75
                              wled.0
                              2021-11-11 13:58:59.289	debug	An attribute has changed : b4e62d6986bb._info.wifi.bssid | old undefined | new {"name":"The BSSID of the currently connected network","type":"mixed","role":"info.address","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:59.289	debug	Create_state called for : b4e62d6986bb._info.wifi.bssid with value : 4A:D9:E7:FA:E1:26
                              wled.0
                              2021-11-11 13:58:59.288	debug	State created : bssid : "4A:D9:E7:FA:E1:26"
                              wled.0
                              2021-11-11 13:58:59.282	debug	An attribute has changed : b4e62d6986bb._info.palcount | old undefined | new {"name":"Number of palettes configured","type":"mixed","role":"info.name","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:59.281	debug	Create_state called for : b4e62d6986bb._info.palcount with value : 71
                              wled.0
                              2021-11-11 13:58:59.281	debug	State created : palcount : 71
                              wled.0
                              2021-11-11 13:58:59.274	debug	An attribute has changed : b4e62d6986bb._info.fxcount | old undefined | new {"name":"Number of effects included","type":"mixed","role":"info.name","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:59.273	debug	Create_state called for : b4e62d6986bb._info.fxcount with value : 118
                              wled.0
                              2021-11-11 13:58:59.273	debug	State created : fxcount : 118
                              wled.0
                              2021-11-11 13:58:59.264	debug	An attribute has changed : b4e62d6986bb._info.ws | old undefined | new {"name":"Number of currently connected WebSockets clients. -1 indicates that WS is unsupported in this build.","type":"number","role":"state","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:59.264	debug	Create_state called for : b4e62d6986bb._info.ws with value : 0
                              wled.0
                              2021-11-11 13:58:59.264	debug	State created : ws : 0
                              wled.0
                              2021-11-11 13:58:59.259	debug	An attribute has changed : b4e62d6986bb._info.lip | old undefined | new {"name":"Realtime data source IP address","type":"string","role":"state","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:59.259	debug	Create_state called for : b4e62d6986bb._info.lip with value :
                              wled.0
                              2021-11-11 13:58:59.258	debug	State created : lip : ""
                              wled.0
                              2021-11-11 13:58:59.208	debug	An attribute has changed : b4e62d6986bb._info.lm | old undefined | new {"name":"Info about the realtime data source","type":"string","role":"state","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:59.208	debug	Create_state called for : b4e62d6986bb._info.lm with value :
                              wled.0
                              2021-11-11 13:58:59.207	debug	State created : lm : ""
                              wled.0
                              2021-11-11 13:58:59.159	debug	An attribute has changed : b4e62d6986bb._info.live | old undefined | new {"name":"If true, the software is currently receiving realtime data via UDP or E1.31","type":"boolean","role":"state","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:59.159	debug	Create_state called for : b4e62d6986bb._info.live with value : false
                              wled.0
                              2021-11-11 13:58:59.158	debug	State created : live : false
                              wled.0
                              2021-11-11 13:58:59.111	debug	An attribute has changed : b4e62d6986bb._info.udpport | old undefined | new {"name":"The UDP port for realtime packets and WLED broadcast","type":"number","role":"info.port","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:59.111	debug	Create_state called for : b4e62d6986bb._info.udpport with value : 21324
                              wled.0
                              2021-11-11 13:58:59.106	debug	State created : udpport : 21324
                              wled.0
                              2021-11-11 13:58:59.051	debug	An attribute has changed : b4e62d6986bb._info.name | old undefined | new {"name":"Friendly name of the light. Intended for display in lists and titles","type":"mixed","role":"info.name","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:59.051	debug	Create_state called for : b4e62d6986bb._info.name with value : WLED-Post
                              wled.0
                              2021-11-11 13:58:59.050	debug	State created : name : "WLED-Post"
                              wled.0
                              2021-11-11 13:58:58.999	debug	An attribute has changed : b4e62d6986bb._info.str | old undefined | new {"name":"str","type":"boolean","role":"state","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:58.999	debug	Create_state called for : b4e62d6986bb._info.str with value : false
                              wled.0
                              2021-11-11 13:58:58.998	debug	State created : str : false
                              wled.0
                              2021-11-11 13:58:58.947	debug	An attribute has changed : b4e62d6986bb._info.leds.seglock | old undefined | new {"name":"seglock","type":"boolean","role":"state","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:58.947	debug	Create_state called for : b4e62d6986bb._info.leds.seglock with value : false
                              wled.0
                              2021-11-11 13:58:58.946	debug	State created : seglock : false
                              wled.0
                              2021-11-11 13:58:58.895	debug	An attribute has changed : b4e62d6986bb._info.leds.maxseg | old undefined | new {"name":"Maximum number of segments supported by this version","type":"number","role":"state","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:58.895	debug	Create_state called for : b4e62d6986bb._info.leds.maxseg with value : 16
                              wled.0
                              2021-11-11 13:58:58.894	debug	State created : maxseg : 16
                              wled.0
                              2021-11-11 13:58:58.843	debug	An attribute has changed : b4e62d6986bb._info.leds.maxpwr | old undefined | new {"name":"Maximum power budget in milliamps for the ABL. 0 if ABL is disabled","type":"number","role":"value.power","read":true,"unit":"mA","write":false}
                              wled.0
                              2021-11-11 13:58:58.843	debug	Create_state called for : b4e62d6986bb._info.leds.maxpwr with value : 600
                              wled.0
                              2021-11-11 13:58:58.842	debug	State created : maxpwr : 600
                              wled.0
                              2021-11-11 13:58:58.791	debug	An attribute has changed : b4e62d6986bb._info.leds.fps | old undefined | new {"name":"Frames per Second","type":"number","role":"state","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:58.791	debug	Create_state called for : b4e62d6986bb._info.leds.fps with value : 0
                              wled.0
                              2021-11-11 13:58:58.790	debug	State created : fps : 0
                              wled.0
                              2021-11-11 13:58:58.739	debug	An attribute has changed : b4e62d6986bb._info.leds.pwr | old undefined | new {"name":"Current LED power usage in milliamps as determined by the ABL. 0 if ABL is disabled","type":"number","role":"value.power","read":true,"unit":"mA","write":false}
                              wled.0
                              2021-11-11 13:58:58.739	debug	Create_state called for : b4e62d6986bb._info.leds.pwr with value : 177
                              wled.0
                              2021-11-11 13:58:58.739	debug	State created : pwr : 177
                              wled.0
                              2021-11-11 13:58:58.684	debug	An attribute has changed : b4e62d6986bb._info.leds.wv | old undefined | new {"name":"wv","type":"boolean","role":"state","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:58.684	debug	Create_state called for : b4e62d6986bb._info.leds.wv with value : false
                              wled.0
                              2021-11-11 13:58:58.684	debug	State created : wv : false
                              wled.0
                              2021-11-11 13:58:58.674	debug	An attribute has changed : b4e62d6986bb._info.leds.rgbw | old undefined | new {"name":"true if LEDs are 4-channel (RGBW)","type":"boolean","role":"state","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:58.674	debug	Create_state called for : b4e62d6986bb._info.leds.rgbw with value : false
                              wled.0
                              2021-11-11 13:58:58.673	debug	State created : rgbw : false
                              wled.0
                              2021-11-11 13:58:58.664	debug	An attribute has changed : b4e62d6986bb._info.leds.count | old undefined | new {"name":"Total LED count","type":"number","role":"value","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:58.664	debug	Create_state called for : b4e62d6986bb._info.leds.count with value : 77
                              wled.0
                              2021-11-11 13:58:58.663	debug	State created : count : 77
                              wled.0
                              2021-11-11 13:58:58.607	debug	An attribute has changed : b4e62d6986bb._info.vid | old undefined | new {"name":"Build ID (YYMMDDB, B = daily build index","type":"number","role":"state","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:58.607	debug	Create_state called for : b4e62d6986bb._info.vid with value : 2109220
                              wled.0
                              2021-11-11 13:58:58.606	debug	State created : vid : 2109220
                              wled.0
                              2021-11-11 13:58:58.551	debug	An attribute has changed : b4e62d6986bb._info.ver | old undefined | new {"name":"Version name","type":"string","role":"state","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:58.550	debug	Create_state called for : b4e62d6986bb._info.ver with value : 0.13.0-b3
                              wled.0
                              2021-11-11 13:58:58.550	debug	State created : ver : "0.13.0-b3"
                              wled.0
                              2021-11-11 13:58:58.547	debug	Create_state called for : b4e62d6986bb.time with value : null
                              wled.0
                              2021-11-11 13:58:58.527	debug	An attribute has changed : b4e62d6986bb.time | old undefined | new {"name":"Set module time to unix timestamp.","type":"mixed","role":"info.date","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:58.526	debug	Create_state called for : b4e62d6986bb.time with value : null
                              wled.0
                              2021-11-11 13:58:58.467	debug	An attribute has changed : b4e62d6986bb.udpn.nn | old undefined | new {"name":"Dont send a broadcast packet (applies to just the current API call)","type":"mixed","role":"state","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:58:58.467	debug	Create_state called for : b4e62d6986bb.udpn.nn with value :
                              wled.0
                              2021-11-11 13:58:58.415	debug	An attribute has changed : b4e62d6986bb.psave | old undefined | new {"name":"Save current light config to specified preset slot","type":"mixed","role":"state","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:58:58.415	debug	Create_state called for : b4e62d6986bb.psave with value :
                              wled.0
                              2021-11-11 13:58:58.362	debug	An attribute has changed : b4e62d6986bb.tt | old undefined | new {"name":"Similar to transition, but applies to just the current API call.","type":"mixed","role":"state","read":true,"unit":"","write":true}
                              wled.0
                              2021-11-11 13:58:58.362	debug	Create_state called for : b4e62d6986bb.tt with value :
                              wled.0
                              2021-11-11 13:58:58.361	debug	Expire time set for state : online with time in seconds : 120
                              wled.0
                              2021-11-11 13:58:58.237	debug	An attribute has changed : b4e62d6986bb._info._online | old undefined | new {"name":"Device connection state","type":"boolean","role":"indicator.connected","read":true,"unit":"","write":false}
                              wled.0
                              2021-11-11 13:58:58.236	debug	Create_state called for : b4e62d6986bb._info._online with value : true
                              wled.0
                              2021-11-11 13:58:57.854	info	Initialising : " WLED-Post" on IP : 192.168.133.95
                              wled.0
                              2021-11-11 13:58:57.853	debug	Info Data received from WLED device {"state":{"on":false,"bri":128,"transition":7,"ps":-1,"pl":-1,"nl":{"on":false,"dur":60,"mode":1,"tbri":0,"rem":-1},"udpn":{"send":false,"recv":true},"lor":0,"mainseg":0,"seg":[{"id":0,"start":0,"stop":77,"len":77,"grp":1,"spc":0,"of":0,"on":true,"bri":255,"col":[[255,160,0],[0,0,0],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":0,"sel":true,"rev":false,"mi":false}]},"info":{"ver":"0.13.0-b3","vid":2109220,"leds":{"count":77,"rgbw":false,"wv":false,"pwr":177,"fps":0,"maxpwr":600,"maxseg":16,"seglock":false},"str":false,"name":"WLED-Post","udpport":21324,"live":false,"lm":"","lip":"","ws":0,"fxcount":118,"palcount":71,"wifi":{"bssid":"4A:D9:E7:FA:E1:26","rssi":-75,"signal":50,"channel":11},"fs":{"u":49,"t":1024,"pmt":0},"ndc":-1,"arch":"esp8266","core":"2_7_4_7","lwip":1,"freeheap":21280,"uptime":12057,"opt":127,"brand":"WLED","product":"FOSS","mac":"b4e62d6986bb","ip":"192.168.133.95"},"effects":["Solid","Blink","Breathe","Wipe","Wipe Random","Random Colors","Sweep","Dynamic","Colorloop","Rainbow","Scan","Scan Dual","Fade","Theater","Theater Rainbow","Running","Saw","Twinkle","Dissolve","Dissolve Rnd","Sparkle","Sparkle Dark","Sparkle+","Strobe","Strobe Rainbow","Strobe Mega","Blink Rainbow","Android","Chase","Chase Random","Chase Rainbow","Chase Flash","Chase Flash Rnd","Rainbow Runner","Colorful","Traffic Light","Sweep Random","Running 2","Aurora","Stream","Scanner","Lighthouse","Fireworks","Rain","Tetrix","Fire Flicker","Gradient","Loading","Police","Police All","Two Dots","Two Areas","Running Dual","Halloween","Tri Chase","Tri Wipe","Tri Fade","Lightning","ICU","Multi Comet","Scanner Dual","Stream 2","Oscillate","Pride 2015","Juggle","Palette","Fire 2012","Colorwaves","Bpm","Fill Noise","Noise 1","Noise 2","Noise 3","Noise 4","Colortwinkles","Lake","Meteor","Meteor Smooth","Railway","Ripple","Twinklefox","Twinklecat","Halloween Eyes","Solid Pattern","Solid Pattern Tri","Spots","Spots Fade","Glitter","Candle","Fireworks Starburst","Fireworks 1D","Bouncing Balls","Sinelon","Sinelon Dual","Sinelon Rainbow","Popcorn","Drip","Plasma","Percent","Ripple Rainbow","Heartbeat","Pacifica","Candle Multi","Solid Glitter","Sunrise","Phased","Twinkleup","Noise Pal","Sine","Phased Noise","Flow","Chunchun","Dancing Shadows","Washing Machine","Candy Cane","Blends","TV Simulator","Dynamic Smooth"],"palettes":["Default","* Random Cycle","* Color 1","* Colors 1&2","* Color Gradient","* Colors Only","Party","Cloud","Lava","Ocean","Forest","Rainbow","Rainbow Bands","Sunset","Rivendell","Breeze","Red & Blue","Yellowout","Analogous","Splash","Pastel","Sunset 2","Beech","Vintage","Departure","Landscape","Beach","Sherbet","Hult","Hult 64","Drywet","Jul","Grintage","Rewhi","Tertiary","Fire","Icefire","Cyane","Light Pink","Autumn","Magenta","Magred","Yelmag","Yelblu","Orange & Teal","Tiamat","April Night","Orangery","C9","Sakura","Aurora","Atlantica","C9 2","C9 New","Temperature","Aurora 2","Retro Clown","Candy","Toxy Reaf","Fairy Reaf","Semi Blue","Pink Candy","Red Reaf","Aqua Flash","Yelblu Hot","Lite Light","Red Flash","Blink Red","Red Shift","Red Tide","Candy2"]}
                              wled.0
                              2021-11-11 13:58:57.852	debug	"API response data : [object Object]"
                              wled.0
                              • Dutchman
                                Dutchman Developer Most Active Administrators @hartwigm last edited by
                                @hartwigm sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
                                Auch ein Neustart am iobroker hilft hier nicht.
                                Die IP .134 geht immer
                                Die 2te WLED hat die IP x.x.x.95 diese geht immer übers Webinterface taucht hier aber im Logfile um 12:01. mit Fehlermeldung auf
                                Welche led Firmware Version hat du drauf?
                                  hartwigm @Dutchman last edited by
                                  @dutchman
                                  WLED version 0.13.0-b3
                                    hartwigm @hartwigm last edited by
                                    @hartwigm
                                    Entwarnung!
                                    ich habe nun die Version 0.13.0-B4 installiert und einen factory default gemacht.
                                    Warum auch immer, aber nun geht es, auch nach reset an der Stromversorgung.
                                    Danke für die Hilfe
                                    Dutchman 1 Reply Last reply Reply Quote 1
                                    • Dutchman
                                      @hartwigm
                                      Entwarnung!
                                      Danke für die Hilfe
                                      Ah Check, das war meine Vermutung.
                                      Mir ist von aircookie (wled Entwickler) bekannt das es in der Firmware Probleme gab aber konnte es nicht hieran relativieren
                                      • V
                                        Vocaris last edited by
                                        ich verzweifele, weil ich bei meiner Garagenfahrt den Fehler nicht finde.
                                        Ich nutze als Schaltpunkte 2 Xiaomi Fensterkontakte.
                                        Ist das Tor unten ist der untere Kontakt zu/(False) und der obere Kontakt offen/(True)
                                        Die Steuerung des WLED habe ich diesmal nicht mit Presets gemacht sondern ich steuere die Effekte direkt im Script an.
                                        Beim Rauffahren passt alles. Nur beim Runterfahren beginnt er mit dem roten Laufband. Aber nach kurzer Zeit springt er in das weiße Laufband gefolgt von den Spots. Wenn das Tor dann unten ist, geht das WLED aus.
                                        Ich verstehe null, warum er unterwegs springt. Die Kontakte geben unterwegs auch keine Zwischenstand ab (true/false). Zudem verstehe ich nicht warum er in der Routine direkt zum weiß springt. Wenn doch was wäre, müsste er doch auch das grün noch anzeigen...
                                        Ich packe Euch mal das Blockly rein. Ggf. findet einer von Euch das Problem.
                                        Ausgewählte Blöcke exportieren
                                          <block type="on_ext" id="c9_Lh@FHI;poTY]d1N5m" x="-162" y="-212">
                                            <value name="OID0">
                                              <shadow type="field_oid" id="WjOXLVJGy[6y?6hjV-Mz">
                                                <field name="oid">deconz.0.sensors.00158d0003969b2a.open</field>
                                            <value name="OID1">
                                              <shadow type="field_oid" id="b9@2=+{!5/#107[ssnL{">
                                                <field name="oid">deconz.0.sensors.00158d00040ad900.open</field>
                                              <block type="control" id=",5Th~j85zjEul[hjL6f]">
                                                <field name="OID">wled.0.e09806861c93.seg.0.bri</field>
                                                  <block type="math_number" id="GaLez8j=$O]s[C2aM3UO">
                                                    <field name="NUM">255</field>
                                                  <block type="comment" id="[tb7whrZ%L^DL|QK]*qs">
                                                    <field name="COMMENT">Wenn sich das Tor bewegt, dann Lauflicht</field>
                                                      <block type="controls_if" id="m^?.SDbC2hIAR|TSjBzD">
                                                          <block type="logic_operation" id="%t?qGdKFJ,ok/p*!,WwA">
                                                            <field name="OP">AND</field>
                                                              <block type="logic_compare" id="Tbg:GyG|U6WplQ!Vgt+K">
        <field name="OP">EQ</field>
        <block type="get_value" id="UX%w2t;J{j+0Jg-Ndirh">
        <field name="OID">deconz.0.sensors.00158d0003969b2a.open</field>
        <block type="logic_boolean" id="9a2JO(|gnd#[gBd-u6qy">
                                                              <block type="logic_compare" id="cp}mtqpA*_:,/8k6Q(Mu">
        <block type="get_value" id="BT8Q_UV5=B2RR%#(aVei">
        <field name="OID">deconz.0.sensors.00158d00040ad900.open</field>
        <block type="logic_boolean" id="[^qB;PA6r`dYn0LRx2nk">
                                                          <block type="control" id="0FN@=:9[V:VMV(3q@]V8">
                                                            <field name="OID">wled.0.e09806861c93.seg.0.col.0_HEX</field>
                                                              <block type="colour_picker" id="~QqI`tU=2(JzdsOwJ?e]">
        <field name="COLOUR">#ff0000</field>
                                                              <block type="control" id="aNsgLKWr8d3d2pp:U$LX">
        <field name="OID">wled.0.e09806861c93.seg.0.sx</field>
        <block type="math_number" id="-|6`nbA6_~]_e:=S)HCX">
        <field name="NUM">130</field>
        <block type="control" id="TonY@DG~?)S+7x30]Dyr">
        <field name="OID">wled.0.e09806861c93.seg.0.fx</field>
        <block type="math_number" id="87RX20#eqAcjTAE_HP^$">
        <field name="NUM">60</field>
        <block type="control" id="tACF}f9#YI%kb)_^~#tK">
        <field name="OID">wled.0.e09806861c93.seg.0.ix</field>
        <block type="math_number" id="3)?eMSV_T6rr8vPxLDM`">
        <field name="NUM">240</field>
        <block type="comment" id="aDkbK}LE=t[LT/fD)jg1">
        <field name="COMMENT">Sollte das WLED aus sein, dann mach es an</field>
        <block type="controls_if" id="N1N[)/BO`pF[czQ93kCV">
        <block type="logic_compare" id="[bkQ6s.C~/t:(654{#zS">
        <block type="get_value" id="v#2OQsxo+_^wXxh90J#W">
        <field name="OID">wled.0.e09806861c93.on</field>
        <block type="logic_boolean" id="M%LNwyQa[pbyTaJ$)-}M">
        <block type="control" id="dq7,xCgtU:6,mwQ159$Z">
        <block type="logic_boolean" id=",f0aP;aZkZU=OfR-YPNv">
                                                          <block type="controls_if" id="-KCO)lpJDbWg@FqxvldF">
                                                              <block type="logic_operation" id="Ks1oQ~u3LtKuk@d_._V-">
        <block type="logic_compare" id="OkHl^O+G]YUc]1!TiL1:">
        <block type="get_value" id="`o2b[:4=mOqBqEW`tr8K">
        <block type="logic_boolean" id="5FS}cXZ#Z_tEMiV]2MrL">
        <block type="logic_compare" id="`j}wR;eN-L9JoJf`@c=G">
        <block type="get_value" id="~DI|e!um-.q{Yvl[x5{m">
        <block type="logic_boolean" id="V[Ju#.K=KRJ:n2!0;UbU">
                                                              <block type="comment" id="SYcsb!wFDuFU!%|q,UE[">
        <field name="COMMENT">Wenn Garage zu, dann mach das WLED aus</field>
        <block type="controls_if" id="hEuj~tM++bk7tuxOE4`J">
        <block type="logic_compare" id="|*4Gi=j)vOeg%.eT4g*{">
        <block type="get_value" id="i!7zoUbBe#R`D8wx{ADh">
        <block type="logic_boolean" id="e8-jE)XaO,t]HR@$7A2?">
        <block type="control" id="[a2x/8K;xOkD.afIs/p7">
        <block type="logic_boolean" id="LBtJv6l#u=;`Gk-W3[Z.">
                                                              <block type="controls_if" id="+mA^40o}yz6AO:6KZjiD">
        <block type="logic_operation" id="TohssJa+VdIz{!m^{]kU">
        <block type="logic_compare" id="k|ZhxV9B7c/-C{DAAVS@">
        <block type="get_value" id="kT|*c=akL2eL||OIUG*w">
        <block type="logic_boolean" id="!6V-Ur2|XYJ)lDH,iqEN">
        <block type="logic_compare" id="p!zr(eZdSfk4`72It|y-">
        <block type="get_value" id="f~{S:rR*qrh2Q1)4._Dp">
        <block type="logic_boolean" id="~+Ie.K%@;TZ9.*Jqz0uk">
        <block type="comment" id="}P@0+qGZd#8!c=9opW38">
        <field name="COMMENT">Wenn Garage auf, dann schalte auf grün</field>
        <block type="control" id="f_I;.`nF_*Y,keUX-sX2">
        <block type="colour_picker" id="7!?#)Qh||Ds,HgKqFs7.">
        <field name="COLOUR">#33ff33</field>
        <block type="control" id="M:I/},FhH-}xYMoza$sw">
        <block type="math_number" id="%tl!Tr|Y}JyWb_2B5Lu%">
        <field name="NUM">0</field>
        <block type="controls_if" id="cXTc:dK~jiqnXPOW{mXe">
        <block type="logic_compare" id="$8FWvHL`ALzdAf])Sp5R">
        <block type="get_value" id="gKAu^oX|@A^ZLjkb=wf.">
        <block type="logic_boolean" id="oBTm=X1%@]k-wcC(bsQj">
        <block type="control" id="$P~8xhYnUtR{;bD8_w5$">
        <block type="logic_boolean" id="NE[;nD[Uf^TBp.@s6:sS">
        <block type="timeouts_wait" id="GCb`Y8H!?N^rLk~@KVuo">
        <field name="DELAY">3</field>
        <block type="comment" id="xvpqfqlXEL8js:W~%`Zf">
        <field name="COMMENT">Nach drei Sek. grün schalten auf weißes Lauflicht</field>
        <block type="control" id="viL)Yw+_JR78%{Ei(L6u">
        <block type="colour_picker" id="QZM|eLB0U9tqK7`|{nfX">
        <field name="COLOUR">#ffffff</field>
        <block type="control" id="r=Y#M}%^7:Qd$Uq?(I`=">
        <block type="math_number" id="@lH3HROapgMKw/C]d3nQ">
        <field name="NUM">215</field>
        <block type="control" id="E7G*)C[COUSr?l4YMU14">
        <block type="math_number" id="UWfddRq)6DVMs7a,k.)N">
        <block type="controls_if" id="j+go^vPn.];!D?,0t.nN">
        <block type="logic_compare" id="eNp0nwk8dLEJgjVSqY0;">
        <block type="get_value" id="mGs9h@4yCa],U|K/t7o}">
        <block type="logic_boolean" id="Zcf_I}vE~?)O;;E8|/am">
        <block type="control" id="/%bg?bqlRPQf0bsYuvMW">
        <block type="logic_boolean" id="LVDUgEhXX.[Q^/D1FA9G">
        <block type="timeouts_wait" id="V_w:J!6QHz~s.Mov.wrw">
        <field name="DELAY">3000</field>
        <field name="UNIT">ms</field>
        <block type="comment" id="@)k^BTvK9OBJR-CAqJ^w">
        <field name="COMMENT">Schalte dann auf die Spots</field>
        <block type="control" id="i[/$u*#{wd/C%bNO,xt6">
        <block type="logic_boolean" id="}g!.2eE4p5q@|6B9{~f_">
        <block type="control" id="C{f1HunIEv3FS^)|U5Vp">
        <block type="math_number" id="(@P--X?MknBg=lGfIxDO">
        <field name="NUM">85</field>
        <block type="control" id="c%,?0B:5N=`7R=2AiTRo">
        <block type="math_number" id="^%dqsT:Z@-$K#Y^va5{2">
        <field name="NUM">45</field>
        <block type="controls_if" id="%0FB5~Ed`A.=M{5q~u-|">
        <block type="logic_compare" id="a9YV9!:f;_$Ba`i/()4P">
        <block type="get_value" id="g60u=H1WwrXni9~A+c8F">
        <block type="logic_boolean" id="BB4OdZOGc_-J:fP@g!A^">
        <block type="control" id="#G?:^DAAcmcO,-FtUC-B">
        <block type="logic_boolean" id=")IL(AVk)[[^_l@?FO|]X">
                                          <block type="timeouts_wait" id="R43lb1vG!PcSenMjz)O+" x="362" y="1363">
                                            <field name="DELAY">1100</field>
                                          <block type="control" id="DYLdpWUdRQ[J%U-4dxx#" x="237" y="1438">
                                              <block type="logic_boolean" id="lM6Q)sdGdY|DeFXzV_6]">
                                            <value name="OID0">
                                            <value name="OID1">
                                        opossum 1 Reply Last reply Reply Quote 0
                                        • opossum
                                          opossum @Vocaris last edited by
                                          Hallo, @vocaris,
                                          Du könntest in Dein Script nach jedem Schritt ein Debug output reintun.
                                          811f2cb3-4135-4f6c-a446-d1eab1316875-image.png .
                                          Dann kannst Du zumindest im Log sehen, was in Deinem Script wann passiert. Ich würde insbesondere die beiden Fensterkontakte mit Ihren Änderungen überwachen.
                                          Wenn Du die beiden Kontakte benutzt, um einen eigenen Datenpunkt zu füllen mit z.B. Tor_auf, Tor_zu und Tor_fährt, und Du dann diese Zustandsänderungen mitprotokollierst, kannst Du zumindest erst mal die Kontakte ausschließen.
                                          Das Steuerungsscript triggerst Du dann auf Deinen Datenpunkt.
                                          Ich mache das so:
                                          Vielleicht findest Du da etwas. Viel Erfolg.
                                          • V
                                            Vocaris @opossum last edited by
                                            @opossum Danke. Mit dem Debug einsetzen kenne ich mich leider nicht aus. Als was man da tun muss, welchen Wert man nimmt etc.
                                            Klar mit einem Datenpunkt kann man es auch machen. Wäre halt noch ein Schritt und ein Scripte mehr.
                                            Abe selbst wenn sich beim Runterfahren die Kontakte (warum auch immer) ändern würden. Warum springt er dann nicht wenn zuerst zu dem grün. Wieso direkt zu dem weiß..
                                            Berges01 1 Reply Last reply Reply Quote 0
                                            31.7k
                                            79.9k
                                            adapater adapter neu hier test testen tester wled
                                            73
                                            655
                                            141399
