    5. MAX! Cube Blockly Abwesenheit
    • mickym
      mickym Most Active @Marko1974 last edited by mickym
      @marko1974 So ich hoffe, Du hast die NodeRed Adapter Einstellungen übernommen.
      Dann bitte den folgenden Flow importieren:
             "id": "373f7aff.2abbb6",
             "type": "ioBroker in",
             "z": "6f3801b9.ba4b6",
             "name": "Gewünschte Temperatur = setpoint",
             "topic": "0_userdata.0.testType",
             "payloadType": "value",
             "onlyack": "",
             "func": "all",
             "gap": "",
             "fireOnStart": "false",
             "x": 300,
             "y": 120,
             "wires": [
                     "55298037.55ff3"
             "id": "81cdbb78.cc3408",
             "name": "Aktuelle Temperatur = temp",
             "onlyack": "",
             "func": "all",
             "gap": "",
             "x": 320,
             "y": 160,
             "wires": [
                     "74467d6b.3311e4"
             "id": "39620337.5bd16c",
             "name": "Modus = mode",
             "onlyack": "",
             "func": "all",
             "gap": "",
             "x": 360,
             "y": 240,
             "wires": [
                     "c8152df3.210ff"
             "id": "74467d6b.3311e4",
             "type": "change",
             "name": "setze aktuelle Temperatur",
             "rules": [
                     "t": "move",
                     "p": "payload",
                     "pt": "msg",
                     "to": "payload.temperature",
                     "tot": "msg"
                     "t": "set",
                     "p": "payload.scale",
                     "pt": "msg",
                     "to": "CELSIUS",
                     "tot": "str"
                     "t": "set",
                     "p": "payload.source",
                     "pt": "msg",
                     "to": "device",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 870,
             "y": 160,
             "wires": [
                     "f472b14d.0e6eb"
             "id": "55298037.55ff3",
             "type": "change",
             "name": "setze Wunsch-Temperatur",
             "rules": [
                     "t": "move",
                     "p": "payload",
                     "pt": "msg",
                     "to": "payload.targetTemperature",
                     "tot": "msg"
                     "t": "set",
                     "p": "payload.targetscale",
                     "pt": "msg",
                     "to": "CELSIUS",
                     "tot": "str"
                     "t": "set",
                     "pt": "msg",
                     "to": "device",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 870,
             "y": 120,
             "wires": [
                     "f472b14d.0e6eb"
             "id": "a607a56b.e990f8",
             "type": "change",
             "name": "Modus = AUTO",
             "rules": [
                     "t": "move",
                     "p": "payload",
                     "pt": "msg",
                     "to": "payload.thermostatMode",
                     "tot": "msg"
                     "t": "set",
                     "p": "payload.thermostatMode",
                     "pt": "msg",
                     "to": "AUTO",
                     "tot": "str"
                     "t": "set",
                     "pt": "msg",
                     "to": "device",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 900,
             "y": 220,
             "wires": [
                     "f472b14d.0e6eb"
             "id": "c8152df3.210ff",
             "type": "switch",
             "name": "Modus NUR Auto oder Manuell",
             "property": "payload",
             "propertyType": "msg",
             "rules": [
                     "t": "eq",
                     "v": "0",
                     "vt": "num"
                     "t": "gt",
                     "v": "0",
                     "vt": "num"
             "checkall": "true",
             "repair": false,
             "outputs": 2,
             "x": 650,
             "y": 240,
             "wires": [
                     "a607a56b.e990f8"
                     "18db62a2.db2ced"
             "id": "f472b14d.0e6eb",
             "type": "debug",
             "name": "dazwischen Alex Node",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "complete": "true",
             "targetType": "full",
             "statusVal": "",
             "statusType": "auto",
             "x": 1200,
             "y": 160,
             "wires": []
             "id": "18db62a2.db2ced",
             "type": "change",
             "name": "Modus = HEAT",
             "rules": [
                     "t": "move",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "msg"
                     "t": "set",
                     "pt": "msg",
                     "to": "HEAT",
                     "tot": "str"
                     "t": "set",
                     "pt": "msg",
                     "to": "device",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 900,
             "y": 260,
             "wires": [
                     "f472b14d.0e6eb"
      Dann wie in der Abb. beschrieben in den iobroker In Nodes die nach dem Namen die entsprechenden Datenpunkte einbinden.
      Vor der grünen Debug Node die Alexa Node einbinden. Die ganzen Change NOdes mit der Alexa Node verbinden - die Debug Node an den Ausgang der Alexa Node.
      Die rechte Seite sollte dann so aussehen:
      Es ist nun so konfiguriert, dass die MAX - Modi:
      AUTO auf AUTO gemappt werden
      alle anderen Modi wie BOOST und MANU werden auf HEAT gemappt.
      Falls Du nicht weißt wie man den Flow importiert:
      1. Über Select All den Code markieren mit Strg+C in die Zwischenablage
      2. Dann das Hauptmenü im NodeRed öffnen und auf Import:
      3. Dann in das rote Fenster den Code aus der Zwischenablage einfügen und mit Import auf DEinem Flow plazieren:
      Noch eine Ergänzung:
      Wenn Du die Datenpunkte in den iobroker In Nodes setzt dann stell noch die folgende Option ein (habe ich nicht gemacht)
      Damit wird er Datenpunkte des iobroker Datenpunktes bei Start des Node-Red Adapters bzw. des Flows sofort eingelesen und nicht erst wenn er getriggert wird.
      Marko1974 2 Replies Last reply Reply Quote 0
      • Marko1974
        Marko1974 @mickym last edited by
        @mickym Ja super klasse....das werde ich morgen mal in Angriff nehmen, da hab ich mehr Ruhe und werde dann berichten. Vielen Dank dafür.
        Momentan habe ich eher das Problem, dass mein MaxCube Adapter immer abstürzt. Entweder habe ich zuviel daran rumgefummelt und der muss sich wieder beruhigen.... oder es ist was anderes.
        Das blöde Blockly wollte auch nicht so recht. Ist wohl nicht so toll, wenn plötzlich 6 Befehle auf einmal kommen. Hab das jetzt mit einer verzögerung entzerrt und auch mal den Wert als Mathematik Wert eingesetzt und nicht als Text. Da war er auch am meckern.
        Das mit dem Flow setze ich morgen direkt ein. Da bin ich richtig HEISS drauf.
        • Marko1974
          @mickym In meinem Adapter steht eher was von Zeichenkette...aber nichts mit Strings. Ist es das?
          • mickym
            @marko1974 Doch genau das ist die Einstellung - die musst Du deaktivieren. Also iobroker Werte in Zeichenkette konvertieren darf nicht angehakt sein.
            Marko1974 1 Reply Last reply Reply Quote 0
            • Marko1974
              @mickym Dann funktioniert aber mein anderer flow mit den steckdosen noch und der den wir gestern gemacht haben auch?
              • mickym
                @marko1974 Jo funktioniert noch - weil diese Werte ja über die Alexa Node und nicht über iobroker reingekommen sind.
                • mickym
                  @marko1974 sagte in MAX! Cube Blockly Abwesenheit:
                  Das Blockly können wir auch in Node Red umsetzen - wenn Du willst.
                  Im NodeRed gibts die Möglichkeiten die Nachrichten / Befehle verzögert zu schicken:
                  oder Du musst den DutyCycle checken. Vielleicht hat der Adapter dafür einen Datenpunkt - musst halt schauen.
                  • Marko1974
                    @mickym Ja vielleicht liegt es am dutycycle. Auch bei deinem Flow kommt wie vorhin die Ansage: Es ist ausgestellt. Aber ich hab ihn schonmal importiert und eingerichtet.
                    12.11.2021, 00:54:10node: dazwischen Alex Node
                    msg : Object
                    { topic: "", payload: object, _msgid: "4aa724a2.1b226c" }
                    12.11.2021, 00:54:23node: dazwischen Alex Node
                    msg : Object
                    { topic: "", payload: object, _msgid: "bb78cede.28eca" }
                    • mickym
                      @marko1974
                      msg : Object
                      msg : Object
                      Hab noch eine Ergänzung unten geschrieben - stell die iobroker In Nodes so ein, dass die Werte sofort eingelesen werden und nicht getriggert werden müssen.
                      Dann wäre es mir lieber - auch wenn es sonst icht so gerne gesehen wird, wenn Du wirklich ein Screenshot vom Debug Fenster machst und die Objekte alle aufmachst (also Pfeile nach unten)
                      • Marko1974
                        @mickym ```
                        12.11.2021, 01:06:34node: dazwischen Alex Node
                        msg : Object
                        object
                        topic: ""
                        payload: object
                        temperature: 0
                        scale: "CELSIUS"
                        targetTemperature: 20
                        targetScale: "CELSIUS"
                        thermostatMode: "OFF"
                        powerState: "ON"
                        source: "alexa"
                        directive: "SetTargetTemperature"
                        type: "THERMOSTAT"
                        rawDirective: object
                        directive: object
                        header: object
                        namespace: "Alexa.ThermostatController"
                        correlationToken: "xxxxxxxnYxw/T5PRpP2Bxn7XZeKRzj2aPCvs0IlvfoiG8nsrZLrjm0cldbNH3jCCmluxOYQ6LZQh9yBsDo5OnWpvPg/60Z8VMZt6LP91HvL4kaYz4l7B+pcOAGDJ8zQCdTZctfc5icdsdcsdcsdcsdcsdcscd"
                        endpoint: object
                        endpointId: "vshd-6c9dea9fb111e4"
                        payload: object
                        targetSetpoint: object
                        _msgid: "268d308.e7231d"
                        • mickym
                          @marko1974 Ach und nochwas - das Topic war leer - Da kannst Du mal selbst ein Topic in der Alexa Node definieren:
                          Das ist ggf- für später wichtig um unterscheiden zu können von welcher Alexa Node die Nachricht stammt. Du kannst auch als Topic den Namen des Thermostats rein schreiben:
                          thermostat_0d1718
                          • mickym
                            @marko1974 Wie gesagt die Screenshots aus dem Debug Fenster sind mir lieber, so wie ich das gepostet habe.
                            Wie schauen die iobroker In Nodes aus - steht connected drunter oder der Wert des Datenpunktes - hast Du die auch richtig gemappt?
                            Wenn Du wie in Ergänzung beschrieben sofort ausliest stehen die Werte, die ausgelesen wurden darunter und nicht mehr Connected unter den Datenpunkten
                            • Marko1974
                              Marko1974 @mickym last edited by Marko1974
                              @mickym
                              Also das war wohl vorhin der DutyCycle.
                              Jetzt hat sie gesagt bei Stelle auf 20.
                              Die Wärme ist auf 20 Grad gestellt. Die aktuelle Temperatur wird angezeigt und der Modus steht auf Heizen.
                              Hier steht noch 5 ....wahrscheinlich nicht aktualisiert. in der app ja...im Datenpunkt steht auch 5
                              • mickym
                                @marko1974 Nee das passt schon - die 5 sind Dein letztes Kommando das Du im Kommando hast.
                                Die Apple HomeApp ist ja gar nicht an den MaxCube Adapter angebunden.
                                Insofern klappt das doch schon Wunderbar.
                                Du kannst mal das Debug fenster posten wenn Du Alexa sagst dass Du auf eine bestimmte Temperatur einstellen möchtest.
                                Wie gesagt poste die Objekte die aus der Alexa Node rauskommen, wenn Du Befehle gibst und zwar aufgeklappt - sowie ich das unten gemacht habe.
                                Marko1974 mickym 2 Replies Last reply Reply Quote 0
                                • Marko1974
                                  @mickym Das mit dem Aufklappen und Screenshot bekomme ich hier an meinem kleinen MacBookAir nicht hin. Da muss ich morgen an den grossen PC....
                                  Also .... die Werte werden alle in der Alexa App übernommen. Wieso Apple Home...das ist ein ganz anderes Thema.
                                  Ich rede hier von der Alexa App.
                                  Also: Alles wird richtig übermittelt, nur der DP verändert sich nicht.
                                  • mickym
                                    mickym Most Active @mickym last edited by
                                    @mickym
                                    OK habs schon gesehen - das unten was das was rauskommt und ich sehe - dass source auf Alexa steht - dann mach ich noch den rechten Teil - der die Kommandos dann wieder an dem MAX Cube Adapter schickt.
                                    • Marko1974
                                      @mickym hier nochmal der Debug mit ganz viel Mühe 🙂
                                      Lass Dir Zeit...Wir können da auch morgen weitermachen.
                                      Muss jetzt auch erstmal ins Bett. Wecker klingelt gleich schon wieder.
                                      Ich danke erstmal schon wieder bis hierhin. Denke aber auch mal dass es für viele nützlich sein wird.
                                      • mickym
                                        mickym Most Active @mickym last edited by mickym
                                        Super - Ok - Du kannst mir noch einen Gefallen tun - damit brauchst keine Screenshots schicken. Jo ich will Dich nicht wachhalten - aber bevor Du ins Bett gehst.
                                        Kannst Du auf die mittlere Schaltfläche klicken - dann wird ein JSON der payload in die Zwischenablage kopiert. Das kannst Du dann wieder hier in CodeTags packen und ich kann während Du schläfst den hinteren Teil des Flows machen.
                                        • Marko1974
                                          @mickym
                                          {"temperature":17.7,"scale":"CELSIUS","targetTemperature":19.5,"targetScale":"CELSIUS","thermostatMode":"HEAT","powerState":"ON","source":"alexa","directive":"SetTargetTemperature","name":"Testthermostat","type":"THERMOSTAT","rawDirective":{"directive":{"header":{"namespace":"Alexa.ThermostatController","name":"SetTargetTemperature","correlationToken":"xxxxxxxxxxxxtx2k2tXcnFAe8p32lAWluMvY5SuTi1idEQNC6RVBzVWSx/J7sUr6gpV+dmi+5tnxumaaKMGFjh5eddaYHSGDKFkpLw7v/IZ8xIwSMZt5MuTkdYM1ff15/Z6IPHvNh1cOktXYxxoKwVgfeQDMwqIydHD6EHZXX3LQ8TNJ9tf2Bs9C0fgsU6tq7bR4w0Gq538UXTN0gmHGJP/QJWxxxxxxxxxxxxxxxxACSaDYts0LKvz17x08XwRP5Y/kbZ6Lb9FaxGSAD5jUyF3Ygae/JhN+C5GTeiuQIb2sKpLJOj830roHVk6s"},"endpoint":{"endpointId":"vshd-6c9dea9fb111e4"},"payload":{"targetSetpoint":{"value":19.5,"scale":"CELSIUS"}}}}}```
                                          • Marko1974
                                            @mickym said in MAX! Cube Blockly Abwesenheit:
                                            Was für ein Service. Womit hab ich das verdient? 🙂
                                            162902
