    4. (Gelöst) Tr-064 keine Verbindung seit Update
    • chucky666
      chucky666 @Ahnungsbefreit last edited by
      @ahnungsbefreit
      Danke 🙏 neu eingeben und jetzt klappt es
        el_malto last edited by el_malto
        Hab Leider das gleiche Problem. PW usw. schon neu eingegeben, FB neugestartet aber ohne Erfolg.
        Mit den anderen Error kann ich leider nichts anfangen.
        host.ioBrokerHost	2021-11-11 18:45:26.797	info	Restart adapter system.adapter.tr-064.0 because enabled
        host.ioBrokerHost	2021-11-11 18:45:26.797	error	instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        tr-064.0	2021-11-11 18:45:26.057	warn	(42120) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
        tr-064.0	2021-11-11 18:45:26.057	error	(42120) ~
        tr-064.0	2021-11-11 18:45:26.056	error	(42120) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
        tr-064.0	2021-11-11 18:45:26.056	error	(42120) ~~ Fatal error. Can not connect to your FritzBox.
        tr-064.0	2021-11-11 18:45:26.055	error	(42120) Error: sendSOAPActionRequest Error action=GetInfo serviceType=urn:dslforum-org:service:WLANConfiguration:1: 401 - {"code":401}
        tr-064.0	2021-11-11 18:45:24.102	info	(42120) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v12.22.1, js-controller: 3.2.16
        host.ioBrokerHost	2021-11-11 18:45:20.119	info	instance system.adapter.tr-064.0 started with pid 42120
        host.ioBrokerHost	2021-11-11 18:45:18.839	info	Restart adapter system.adapter.tr-064.0 because enabled
        host.ioBrokerHost	2021-11-11 18:45:18.838	error	instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        tr-064.0	2021-11-11 18:45:18.098	warn	(42103) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
        tr-064.0	2021-11-11 18:45:18.095	error	(42103) ~
        tr-064.0	2021-11-11 18:45:18.094	error	(42103) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
        tr-064.0	2021-11-11 18:45:18.094	error	(42103) ~~ Fatal error. Can not connect to your FritzBox.
        tr-064.0	2021-11-11 18:45:18.093	error	(42103) ~
        tr-064.0	2021-11-11 18:45:18.090	error	(42103) Error: sendSOAPActionRequest Error action=GetInfo serviceType=urn:dslforum-org:service:WLANConfiguration:1: 401 - {"code":401}
        tr-064.0	2021-11-11 18:45:15.819	info	(42103) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v12.22.1, js-controller: 3.2.16
        host.ioBrokerHost	2021-11-11 18:45:10.095	info	instance system.adapter.tr-064.0 started with pid 42103
        host.ioBrokerHost	2021-11-11 18:45:09.041	info	Restart adapter system.adapter.tr-064.0 because enabled
        • haselchen
          haselchen Most Active @el_malto last edited by haselchen
          @el_malto
          In der Box mal nen neuen User angelegt und den dann im Adapter benutzt/eingegeben?
          Callmonitor eingeschaltet? # 96 *5 * aber hintereinander eingeben, hier geht es nicht anders zu schreiben wegen der Sternchen
            el_malto @haselchen last edited by el_malto
            Der Tipp hier hat gepasst:
            https://forum.iobroker.net/topic/47358/fritzbox-adapter-tr-064-probleme/7?_=1636655442998
            Einfach unter Benutzer gucken wie der Default Benutzername jetzt heißt und den nehmen.
              Thomas Braun Most Active @el_malto last edited by
              @el_malto
              Der Tip war von mir.
              Der nächste Tip ist:
              System aktuell halten.
                el_malto @Thomas Braun last edited by
                Ich checke immer vorher wenn ich Adapter Updates mache ob die noce und js-controller Version dafür noch ausreicht. Habe mir schon mal böse meine ioBroker installation verschossen als ich die Versionen anheben wollte. Zum Glück hatte ich die VM vorher gesichert und konnte einfach zurück. Bei ioBroker habe ich nun schon des öfteren die Erfahrung gemacht "never change a running system".
                Aber dennoch danke für den Tipp.
                  @el_malto sagte in (Gelöst) Tr-064 keine Verbindung seit Update:
                  Grundfalsch. "Halt die Kiste aktuell" ist angesagt. Bevorzugt aus dem stable-Zweig.
                    Das kannst du ja gern so machen😉
                      Thomas Braun Most Active @el_malto last edited by Thomas Braun
                      @el_malto
                      Nee, ich fahre Beta-Versionen. Mein "System changes" also permanent.
                      Lies hier mal rein, da ist viel wahres dabei:
                      https://de.linkedin.com/pulse/never-change-running-system-warum-diese-weisheit-im-zeitalter-welsch-1e
                      https://clouderp.blog/2018/05/07/never-change-a-running-system/
                        Tolle Links, aber die beschreiben ja eher Unternehmensstrukturen die ganze Prozesse usw. digitalisieren oder optimieren. Da bin ich ja auch bei dir, gerade auch wenn es um Sicherheitsrelevante Systeme geht. Aber wenn der ioBroker bei mir im internen Netzwerk dümpelt und ein paar maginale Aufgaben erledigt, will ich da nicht ständig dran rum fummeln müssen. Da fahre ich nur Updates wenn diese auch notwendig sind.
                        Aber egal, jeder so wie er mag😉
                          @el_malto
                          Das ist unabhängig von professionellem oder heimeinsatz gültig.
                          Halt nicht wundern wenn es in veralteten Versionen Fehler und Lücken gibt, die in aktuellen Versionen längst beseitigt wurden. Die wenigsten neuen Versionen werden released weil die neue Versionsnummer hübscher aussieht als die alte, da musste also irgendwas 'repariert' werden.
                          592
