      MCU @Johannes Bauerstatter last edited by
      @johannes-bauerstatter
      Hält der Videostream dann nach 100 Sekunden an?
      Johannes Bauerstatter 1 Reply Last reply Reply Quote 0
        SchuetzeSchulz @MCU last edited by
        @mcu sagte in jarvis v2.2.0 - just another remarkable vis:
        <!DOCTYPE HTML> <html> <head> <title> </title> <style> #container {text-align: center; height: 100%;} .button { color: #333; background-color: #fff; border-color: #ccc; font-size: 14px; font-weight: 400; border: 1px solid black; border-radius: 4px; cursor: pointer; line-height: 1.42857143; text-align: center; white-space: nowrap; vertical-align: middle; padding: 6px 12px;} </style> <script> setTimeout(function(){ var button = document.querySelector('#container .button'); button.addEventListener('click', fullscreen); document.addEventListener('webkitfullscreenchange', fullscreenChange); document.addEventListener('mozfullscreenchange', fullscreenChange); document.addEventListener('fullscreenchange', fullscreenChange); document.addEventListener('MSFullscreenChange', fullscreenChange); },1000); function fullscreen() { // check if fullscreen mode is available if (document.fullscreenEnabled || document.webkitFullscreenEnabled || document.mozFullScreenEnabled || document.msFullscreenEnabled) { // which element will be fullscreen var iframe = document.querySelector('#container iframe'); // Do fullscreen if (iframe.requestFullscreen) { iframe.requestFullscreen(); } else if (iframe.webkitRequestFullscreen) { iframe.webkitRequestFullscreen(); } else if (iframe.mozRequestFullScreen) { iframe.mozRequestFullScreen(); } else if (iframe.msRequestFullscreen) { iframe.msRequestFullscreen(); } } else { document.querySelector('.error').innerHTML = 'Your browser is not supported'; } } function fullscreenChange() { if (document.fullscreenEnabled || document.webkitIsFullScreen || document.mozFullScreen || document.msFullscreenElement) { console.log('enter fullscreen'); } else { console.log('exit fullscreen'); } // force to reload iframe once to prevent the iframe source didn't care about trying to resize the window // comment this line and you will see var iframe = document.querySelector('iframe'); iframe.src = iframe.src; } function onKlick(elem) { elem.requestFullscreen(); } </script> </head> <body style="text-align: center;" id="video1body"> <div id="container"> <iFrame width="320px" height="150px" src="URL" onclick="onKlick(this);" frameborder="2" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen> </iFrame> <div> <button class="button">FullScreen</button> </div> <div class="error"></div> </div> </body> </html>
        Damit funktioniert das mit dem Button. Also klicke ich auf den Button kommt Vollbild.
          MCU @SchuetzeSchulz last edited by
          @schuetzeschulz Zufrieden, oder muss ich noch weiterschauen?
            @mcu Naja, ich würde es "besser" finden, wenn das Vollbild kommt wenn ich auf das Kamerabild drücke/klicke. Also quasi ohne den Button...
              @schuetzeschulz Dafür habe ich keinen Ansatz mehr. Das scheint an der Software für die Anzeige der Kamera zu liegen. Welche Kamera ist das?
              • Johannes Bauerstatter
                Johannes Bauerstatter @MCU last edited by
                @mcu Ja, funktioniert auch. War gewollt zum Testen.
                  @mcu Habe 3 Wansview W3 Kameras im Einsatz.
                    RkcCorian last edited by
                    Kenn jemand die CSS um die "Headings" (Überschriften) der Widgets anzupassen? Also Symbolgröße, Transparenz, sowie Schriftgröße? Vielen Dank!
                      MCU @RkcCorian last edited by MCU
                      @rkccorian
                      https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/besonderheiten-v3/styles/statelist-1/.q-item__section--main
                        RkcCorian @MCU last edited by
                        @mcu Für .q-item__section--main .q-item__label.text-h6 gibt es (noch) kein jarvis-wasAuchImmerEigenesCss?!
                          @rkccorian Nein. Es gibt jarvis-header, hat aber die Überschrift nicht mit drin? Bin mir grade nicht sicher.
                          .jarvis-widget-header
                            sicadrip last edited by
                            @Zefau
                            Ich vermisse in der aktuellen alpha.125 beim DateTime Modul die Einstellung "Style des Textes (JSON Format)". Kommt das wieder dazu?
                            v3.0.0-alpha.125
                            v2.3.3
                              MCU @sicadrip last edited by
                              @sicadrip CSS Eintrag
                              https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/besonderheiten-v3/styles/datetime
                              -cs- 1 Reply Last reply Reply Quote 0
                              • -cs-
                                -cs- @MCU last edited by -cs-
                                wenn ich in Jarvis (mobiles Ansicht auf Samsung Note10 / Chrome) scrollen möchte kommt neuerdings die Fehletmeldung:
                                Sorry, aber ich verstehe hier nur Bahnhof.
                                Solange ich nicht scrolle funktioniert alles.
                                  MCU @MCU last edited by
                                  @lustig29 Es hat sich beim Adapter etwas getan. Schau es dir mal an.
                                  https://github.com/Pix---/ioBroker.homepilot/issues/26
                                  https://github.com/Pix---/ioBroker.homepilot/tree/1.2.0a
                                  mcuiobroker created this issue in Pix---/ioBroker.homepilot
                                  closed Make homepilot jarvis compatible #26
                                    MCU @-cs- last edited by
                                    @csr Welche Version ist das? v2 oder v3?
                                    • -cs-
                                      @mcu sorry, dachte das steht dort.
                                      Erst 2.2.1 (2.2.2 sorry war erst Tippfehler) nach dem Fehler las ich irgendwo man soll auf 3.0 Updaten, wusste aber nicht wie.
                                      Somit habe ich Beta 2.2.3 getestet und ist das gleiche.
                                      Admin 5.1.25
                                      Node.js v12.22.7
                                      NPM 6.14.15
                                      Auf NUC i5 / Proxmox / VM Debian
                                        @csr https://mcuiobroker.gitbook.io/jarvis-infos/v3-fuer-einsteiger/installation-jarvis-v3
                                        • -cs-
                                          @mcu
                                          Schaut gut aus, danke.
                                          Ich frag mich bloß warum ich das nicht fand? 🤔
                                          • U
                                            UncleB last edited by UncleB
                                            Abend zusammen,
                                            Ich hab gestern den E-Chart Adapter installiert, wirklich genialer Adapter den ich bis Dato nicht kannte.
                                            Und würde das Diagramm gerne als I-Frame einbinden.
                                            Kann die Url ohne Probleme im Browser öffnen und alles wird perfekt dargestellt.
                                            Binde ich die Url als iFrame in Jarvis ein erhalte ich ne Fehlermeldung "Verbindung abgelehnt"
                                            Jemand ne Idee woran das liegen könnte?
                                            P.S Wusste nicht welcher der richtige Thread für mein Problem ist, dieser hier oder vom E-Chart Adapter
                                            316
                                            6126
                                            4116910
