    5. MAX! Cube Blockly Abwesenheit
    • mickym
      mickym Most Active @Marko1974 last edited by
      @marko1974 wie hast Du es genau geschrieben?
      Marko1974 2 Replies Last reply Reply Quote 0
      • Marko1974
        Marko1974 @mickym last edited by Marko1974
        @mickym ECO
          "common": {
            "name": "ECO",
            "desc": "Manuell erzeugt",
            "role": "state",
            "type": "number",
            "read": true,
            "write": true,
            "def": 0
          "type": "state",
          "user": "system.user.admin",
          "ts": 1636847431239,
          "_id": "0_userdata.0.Heizung.Kinderzimmer.ECO",
          "acl": {
            "object": 1636,
            "state": 1636,
            "owner": "system.user.admin",
        • Marko1974
          @mickym kann ich nochwas tun?
          • mickym
            mickym Most Active @Marko1974 last edited by mickym
            @marko1974 So der Hauptflow ist fertig - nun musst Du noch bissi Feinarbeiten machen:
            Hier der Import:
                   "id": "c2c0c34f.6e2ed",
                   "type": "subflow",
                   "name": "MAX Auto Badezimmer",
                   "info": "# MAX Wochenprofil erstellen",
                   "category": "MAX Auto Profil",
                   "in": [
                           "x": 40,
                           "y": 260,
                           "wires": [
                                   "id": "adc559a.6d1fea8"
                   "out": [
                           "x": 1240,
                           "y": 260,
                           "wires": [
                                   "id": "78e83c34.8e26f4",
                                   "port": 0
                                   "id": "b43a5b2f.5ba228",
                                   "port": 0
                                   "id": "c381b0fb.0c407",
                                   "port": 0
                                   "id": "d7602741.e08ec8",
                                   "port": 0
                                   "id": "67e1f0e6.98f84",
                                   "port": 0
                                   "id": "324ef3e0.d9ac1c",
                                   "port": 0
                                   "id": "2c0b8bd8.778e14",
                                   "port": 0
                                   "id": "5b0e8515.b3b32c",
                                   "port": 0
                                   "id": "50a57933.3a77b8",
                                   "port": 0
                                   "id": "92ee1669.329f78",
                                   "port": 0
                   "env": [],
                   "meta": {},
                   "color": "#FFAAAA",
                   "outputLabels": [
                       "AUTO Temperatur"
                   "icon": "font-awesome/fa-thermometer-2"
                   "id": "2961f12d.901f7e",
                   "type": "switch",
                   "z": "c2c0c34f.6e2ed",
                   "name": "Automatik <Template>- Zeitprofil Mo - Fr",
                   "property": "payload.time",
                   "propertyType": "msg",
                   "rules": [
                           "t": "btwn",
                           "v": "00:00",
                           "vt": "str",
                           "v2": "08:00",
                           "v2t": "str"
                           "t": "btwn",
                           "v": "08:00",
                           "vt": "str",
                           "v2": "09:00",
                           "v2t": "str"
                           "t": "btwn",
                           "v": "09:00",
                           "vt": "str",
                           "v2": "22:00",
                           "v2t": "str"
                           "t": "btwn",
                           "v": "22:00",
                           "vt": "str",
                           "v2": "23:00",
                           "v2t": "str"
                           "t": "btwn",
                           "v": "23:00",
                           "vt": "str",
                           "v2": "24:00",
                           "v2t": "str"
                   "checkall": "false",
                   "repair": false,
                   "outputs": 5,
                   "x": 780,
                   "y": 160,
                   "wires": [
                           "78e83c34.8e26f4"
                           "b43a5b2f.5ba228"
                           "c381b0fb.0c407"
                           "d7602741.e08ec8"
                           "67e1f0e6.98f84"
                   "id": "adc559a.6d1fea8",
                   "type": "change",
                   "name": "Change $moment",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "{\"weekday\":\"\",\"time\":\"\"}",
                           "tot": "json"
                           "t": "set",
                           "p": "payload.weekday",
                           "pt": "msg",
                           "to": "$moment().locale(\"de\").tz('Europe/Berlin').format('dddd')",
                           "tot": "jsonata"
                           "t": "set",
                           "p": "payload.time",
                           "pt": "msg",
                           "to": "$moment().locale(\"de\").tz('Europe/Berlin').format('HH:mm')",
                           "tot": "jsonata"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 190,
                   "y": 260,
                   "wires": [
                           "fd8206e3.66bbf8"
                   "type": "change",
                   "name": "22 °C",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "22",
                           "tot": "num"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1070,
                   "y": 120,
                   "wires": [
                   "type": "change",
                   "name": "17°C",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "17",
                           "tot": "num"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1070,
                   "y": 160,
                   "wires": [
                   "type": "change",
                   "name": "22 °C",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "22",
                           "tot": "num"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1070,
                   "y": 200,
                   "wires": [
                   "type": "change",
                   "name": "17 °C",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "17",
                           "tot": "num"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1070,
                   "y": 240,
                   "wires": [
                   "id": "a03bd421.d47bd8",
                   "type": "switch",
                   "name": "Automatik <Template> - Zeitprofil Sa + So",
                   "rules": [
                           "t": "btwn",
                           "v": "00:00",
                           "vt": "str",
                           "v2": "08:00",
                           "v2t": "str"
                           "t": "btwn",
                           "v": "08:00",
                           "vt": "str",
                           "v2": "09:00",
                           "v2t": "str"
                           "t": "btwn",
                           "v": "09:00",
                           "vt": "str",
                           "v2": "22:00",
                           "v2t": "str"
                           "t": "btwn",
                           "v": "22:00",
                           "vt": "str",
                           "v2": "23:00",
                           "v2t": "str"
                           "t": "btwn",
                           "v": "23:00",
                           "vt": "str",
                           "v2": "24:00",
                           "v2t": "str"
                   "repair": false,
                   "outputs": 5,
                   "x": 780,
                   "y": 380,
                   "wires": [
                           "324ef3e0.d9ac1c"
                           "2c0b8bd8.778e14"
                           "5b0e8515.b3b32c"
                           "92ee1669.329f78"
                           "50a57933.3a77b8"
                   "type": "change",
                   "name": "22 °C",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "22",
                           "tot": "num"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1070,
                   "y": 340,
                   "wires": [
                   "id": "fd8206e3.66bbf8",
                   "type": "switch",
                   "name": "Selektiere Wochentage",
                   "property": "payload.weekday",
                   "rules": [
                           "t": "regex",
                           "v": "Montag|Dienstag|Mittwoch|Donnerstag|Freitag",
                           "vt": "str",
                           "case": true
                           "t": "regex",
                           "v": "Samstag|Sonntag",
                           "vt": "str",
                           "case": true
                   "checkall": "true",
                   "repair": false,
                   "outputs": 2,
                   "x": 430,
                   "y": 260,
                   "wires": [
                           "2961f12d.901f7e"
                           "a03bd421.d47bd8"
                   "type": "change",
                   "name": "17 °C",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "17",
                           "tot": "num"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1070,
                   "y": 380,
                   "wires": [
                   "type": "change",
                   "name": "22 °C",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "22",
                           "tot": "num"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1070,
                   "y": 420,
                   "wires": [
                   "type": "change",
                   "name": "17 °C",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "17",
                           "tot": "num"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1070,
                   "y": 460,
                   "wires": [
                   "type": "change",
                   "name": "17 °C",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "17",
                           "tot": "num"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1070,
                   "y": 300,
                   "wires": [
                   "type": "change",
                   "name": "17 °C",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "17",
                           "tot": "num"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1070,
                   "y": 80,
                   "wires": [
                   "id": "1965b6bc.47ee19",
                   "type": "inject",
                   "z": "6f3801b9.ba4b6",
                   "name": "Trigger alle Minuten",
                   "props": [
                           "p": "ts",
                           "v": "",
                           "vt": "date"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "topic": "",
                   "x": 490,
                   "y": 1940,
                   "wires": [
                           "4ad77e6.fb2298"
                   "id": "f5d5a81d.0d79c8",
                   "type": "change",
                   "name": "Wohnzimmer",
                   "rules": [
                           "t": "set",
                           "p": "room",
                           "pt": "msg",
                           "to": "Wohnzimmer",
                           "tot": "str"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 910,
                   "y": 1920,
                   "wires": [
                           "9d89290d.3f4f48"
                   "id": "5715f8a9.9e36d8",
                   "type": "change",
                   "name": "Schlafzimmer",
                   "rules": [
                           "t": "set",
                           "p": "room",
                           "pt": "msg",
                           "to": "Schlafzimmer",
                           "tot": "str"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 900,
                   "y": 1880,
                   "wires": [
                           "9d89290d.3f4f48"
                   "id": "27e3cf0b.1fb9c",
                   "type": "change",
                   "name": "Kinderzimmer",
                   "rules": [
                           "t": "set",
                           "p": "room",
                           "pt": "msg",
                           "to": "Kinderzimmer",
                           "tot": "str"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 900,
                   "y": 1840,
                   "wires": [
                           "9d89290d.3f4f48"
                   "id": "30c3ea81.3b06b6",
                   "type": "change",
                   "name": "Flur",
                   "rules": [
                           "t": "set",
                           "p": "room",
                           "pt": "msg",
                           "to": "Flur",
                           "tot": "str"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 930,
                   "y": 1960,
                   "wires": [
                           "9d89290d.3f4f48"
                   "id": "b87ebd5f.04a7d",
                   "type": "change",
                   "name": "Küche",
                   "rules": [
                           "t": "set",
                           "p": "room",
                           "pt": "msg",
                           "to": "Küche",
                           "tot": "str"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 930,
                   "y": 2000,
                   "wires": [
                           "9d89290d.3f4f48"
                   "id": "4e2c598d.d467e8",
                   "type": "change",
                   "name": "Badezimmer",
                   "rules": [
                           "t": "set",
                           "p": "room",
                           "pt": "msg",
                           "to": "Badezimmer",
                           "tot": "str"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 910,
                   "y": 2040,
                   "wires": [
                           "9d89290d.3f4f48"
                   "id": "4ad77e6.fb2298",
                   "type": "switch",
                   "name": "Ein / Aus",
                   "property": "gHeizungssteuerung",
                   "propertyType": "global",
                   "rules": [
                           "t": "true"
                   "checkall": "true",
                   "repair": false,
                   "outputs": 1,
                   "x": 680,
                   "y": 1940,
                   "wires": [
                           "27e3cf0b.1fb9c",
                           "5715f8a9.9e36d8",
                           "f5d5a81d.0d79c8",
                           "30c3ea81.3b06b6",
                           "b87ebd5f.04a7d",
                           "4e2c598d.d467e8"
                   "id": "f62fe74f.2ea798",
                   "type": "inject",
                   "name": "Aktiviere Heizungssteuerung",
                   "props": [
                           "p": "payload"
                   "repeat": "",
                   "crontab": "",
                   "once": true,
                   "onceDelay": 0.1,
                   "topic": "",
                   "payload": "true",
                   "payloadType": "bool",
                   "x": 560,
                   "y": 1380,
                   "wires": [
                           "a06e7e01.fa763"
                   "id": "a06e7e01.fa763",
                   "type": "change",
                   "name": "",
                   "rules": [
                           "t": "set",
                           "p": "gHeizungssteuerung",
                           "pt": "global",
                           "to": "payload",
                           "tot": "msg"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 870,
                   "y": 1380,
                   "wires": [
                   "id": "9d89290d.3f4f48",
                   "type": "change",
                   "name": "",
                   "rules": [
                           "t": "set",
                           "p": "topic",
                           "pt": "msg",
                           "to": "\"0_userdata.0.Heizung.\" & room & \".mode\"",
                           "tot": "jsonata"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1200,
                   "y": 1840,
                   "wires": [
                           "f07d0a47.5ea388"
                   "id": "1940726b.23d83e",
                   "type": "debug",
                   "name": "",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "complete": "true",
                   "targetType": "full",
                   "statusVal": "",
                   "statusType": "auto",
                   "x": 1670,
                   "y": 2000,
                   "wires": []
                   "id": "f07d0a47.5ea388",
                   "type": "ioBroker get",
                   "name": "get mode",
                   "topic": "",
                   "attrname": "mode",
                   "payloadType": "value",
                   "x": 1370,
                   "y": 1840,
                   "wires": [
                           "31374dbc.8ee562"
                   "id": "863eaba3.56b088",
                   "name": "get desiredTemperature",
                   "topic": "",
                   "attrname": "desiredTemperature",
                   "x": 1410,
                   "y": 1920,
                   "wires": [
                           "6b0d1558.1cdc8c"
                   "id": "31374dbc.8ee562",
                   "type": "change",
                   "name": "",
                   "rules": [
                           "t": "set",
                           "p": "topic",
                           "pt": "msg",
                           "to": "\"0_userdata.0.Heizung.\" & room & \".setpoint\"",
                           "tot": "jsonata"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1200,
                   "y": 1920,
                   "wires": [
                           "863eaba3.56b088"
                   "id": "b1a9ca76.52ad48",
                   "type": "switch",
                   "name": "Heizungen",
                   "property": "room",
                   "rules": [
                           "t": "eq",
                           "v": "Kinderzimmer",
                           "vt": "str"
                           "t": "eq",
                           "v": "Schlafzimmer",
                           "vt": "str"
                           "t": "eq",
                           "v": "Wohnzimmer",
                           "vt": "str"
                           "t": "eq",
                           "v": "Flur",
                           "vt": "str"
                           "t": "eq",
                           "v": "Küche",
                           "vt": "str"
                           "t": "eq",
                           "v": "Badezimmer",
                           "vt": "str"
                   "checkall": "true",
                   "repair": false,
                   "outputs": 6,
                   "x": 1690,
                   "y": 1920,
                   "wires": [
                           "58a0f8f3.c56118"
                           "e21babd2.9960c8"
                           "c28be01e.ad1f"
                           "cfe521df.1b0fb"
                           "be5cdd66.a5d76"
                           "d95d6d51.eff4c"
                   "id": "58a0f8f3.c56118",
                   "type": "switch",
                   "property": "mode",
                   "rules": [
                           "t": "eq",
                           "v": "AUTO",
                           "vt": "str"
                           "t": "eq",
                           "v": "HEAT",
                           "vt": "str"
                           "t": "eq",
                           "v": "OFF",
                           "vt": "str"
                           "t": "eq",
                           "v": "ECO",
                           "vt": "str"
                   "checkall": "true",
                   "repair": false,
                   "outputs": 4,
                   "x": 1940,
                   "y": 1480,
                   "wires": [
                           "581dbaad.9c9f34"
                           "d912a77.1dadd58"
                           "1afe73e2.fdb6ac"
                           "14999008.d8eab"
                   "id": "e21babd2.9960c8",
                   "type": "switch",
                   "property": "mode",
                   "rules": [
                           "t": "eq",
                           "v": "AUTO",
                           "vt": "str"
                           "t": "eq",
                           "v": "HEAT",
                           "vt": "str"
                           "t": "eq",
                           "v": "OFF",
                           "vt": "str"
                           "t": "eq",
                           "v": "ECO",
                           "vt": "str"
                   "checkall": "true",
                   "repair": false,
                   "outputs": 4,
                   "x": 1940,
                   "y": 1660,
                   "wires": [
                           "e66376fc.0697e8"
                           "a1a54233.2e25"
                           "4b729ec6.a7567"
                           "d0e7d874.8ffc18"
                   "id": "c28be01e.ad1f",
                   "type": "switch",
                   "property": "mode",
                   "rules": [
                           "t": "eq",
                           "v": "AUTO",
                           "vt": "str"
                           "t": "eq",
                           "v": "HEAT",
                           "vt": "str"
                           "t": "eq",
                           "v": "OFF",
                           "vt": "str"
                           "t": "eq",
                           "v": "ECO",
                           "vt": "str"
                   "checkall": "true",
                   "repair": false,
                   "outputs": 4,
                   "x": 1930,
                   "y": 1820,
                   "wires": [
                           "882eac91.a4c63"
                           "22fe10a1.4179a"
                           "f054e171.d9388"
                           "30ec57c5.5cb298"
                   "id": "cfe521df.1b0fb",
                   "type": "switch",
                   "name": "Flur",
                   "property": "mode",
                   "rules": [
                           "t": "eq",
                           "v": "AUTO",
                           "vt": "str"
                           "t": "eq",
                           "v": "HEAT",
                           "vt": "str"
                           "t": "eq",
                           "v": "OFF",
                           "vt": "str"
                           "t": "eq",
                           "v": "ECO",
                           "vt": "str"
                   "checkall": "true",
                   "repair": false,
                   "outputs": 4,
                   "x": 1910,
                   "y": 1980,
                   "wires": [
                           "6a4e1335.624edc"
                           "696a4cf4.0926f4"
                           "e8aa246e.263ee8"
                           "18820133.6bd0df"
                   "id": "be5cdd66.a5d76",
                   "type": "switch",
                   "name": "Küche",
                   "property": "mode",
                   "rules": [
                           "t": "eq",
                           "v": "AUTO",
                           "vt": "str"
                           "t": "eq",
                           "v": "HEAT",
                           "vt": "str"
                           "t": "eq",
                           "v": "OFF",
                           "vt": "str"
                           "t": "eq",
                           "v": "ECO",
                           "vt": "str"
                   "checkall": "true",
                   "repair": false,
                   "outputs": 4,
                   "x": 1930,
                   "y": 2160,
                   "wires": [
                           "220c1f0.70a44e2"
                           "6e94704e.ff4bc"
                           "d6ca8495.917f78"
                           "23535d36.f89882"
                   "id": "d95d6d51.eff4c",
                   "type": "switch",
                   "property": "mode",
                   "rules": [
                           "t": "eq",
                           "v": "AUTO",
                           "vt": "str"
                           "t": "eq",
                           "v": "HEAT",
                           "vt": "str"
                           "t": "eq",
                           "v": "OFF",
                           "vt": "str"
                           "t": "eq",
                           "v": "ECO",
                           "vt": "str"
                   "checkall": "true",
                   "repair": false,
                   "outputs": 4,
                   "x": 1930,
                   "y": 2340,
                   "wires": [
                           "8f1b3f56.520fe"
                           "5cd3bef0.e41f8"
                           "9703563a.10fbe8"
                           "d0ae36e3.0d6d68"
                   "id": "8f1b3f56.520fe",
                   "type": "subflow:c2c0c34f.6e2ed",
                   "name": "",
                   "x": 2190,
                   "y": 2280,
                   "wires": [
                           "8c12a45.58c5958"
                   "id": "5cd3bef0.e41f8",
                   "type": "change",
                   "name": "HEAT = setpoint",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "desiredTemperature",
                           "tot": "msg"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 2160,
                   "y": 2320,
                   "wires": [
                           "8c12a45.58c5958"
                   "id": "9703563a.10fbe8",
                   "type": "change",
                   "name": "OFF = 4.5",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "4.5",
                           "tot": "num"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 2140,
                   "y": 2360,
                   "wires": [
                           "8c12a45.58c5958"
                   "id": "6b0d1558.1cdc8c",
                   "type": "change",
                   "name": "",
                   "rules": [
                           "t": "set",
                           "p": "topic",
                           "pt": "msg",
                           "to": "\"0_userdata.0.Heizung.\" & room & \".ECO\"",
                           "tot": "jsonata"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1200,
                   "y": 2000,
                   "wires": [
                           "cad52ae9.b3a468"
                   "id": "cad52ae9.b3a468",
                   "name": "get ecoTemperature",
                   "topic": "",
                   "attrname": "ecoTemperature",
                   "x": 1400,
                   "y": 2000,
                   "wires": [
                           "b1a9ca76.52ad48",
                           "1940726b.23d83e"
                   "id": "d0ae36e3.0d6d68",
                   "type": "change",
                   "name": "ECO = ECO",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "ecoTemperature",
                           "tot": "msg"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 2150,
                   "y": 2400,
                   "wires": [
                           "8c12a45.58c5958"
                   "id": "6e94704e.ff4bc",
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "tot": "msg"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 2160,
                   "y": 2140,
                   "wires": [
                           "420c8f3.1d09f7"
                   "id": "d6ca8495.917f78",
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "4.5",
                           "tot": "num"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 2140,
                   "y": 2180,
                   "wires": [
                           "420c8f3.1d09f7"
                   "id": "23535d36.f89882",
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "tot": "msg"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 2150,
                   "y": 2220,
                   "wires": [
                           "420c8f3.1d09f7"
                   "id": "220c1f0.70a44e2",
                   "name": "",
                   "x": 2190,
                   "y": 2100,
                   "wires": [
                           "420c8f3.1d09f7"
                   "id": "696a4cf4.0926f4",
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "tot": "msg"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 2160,
                   "y": 1960,
                   "wires": [
                           "cab0fe28.59eef"
                   "id": "e8aa246e.263ee8",
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "4.5",
                           "tot": "num"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 2140,
                   "y": 2000,
                   "wires": [
                           "cab0fe28.59eef"
                   "id": "18820133.6bd0df",
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "tot": "msg"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 2150,
                   "y": 2040,
                   "wires": [
                           "cab0fe28.59eef"
                   "id": "6a4e1335.624edc",
                   "name": "",
                   "x": 2190,
                   "y": 1920,
                   "wires": [
                           "cab0fe28.59eef"
                   "id": "22fe10a1.4179a",
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "tot": "msg"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 2160,
                   "y": 1800,
                   "wires": [
                           "195630dc.b07aff"
                   "id": "f054e171.d9388",
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "4.5",
                           "tot": "num"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 2140,
                   "y": 1840,
                   "wires": [
                           "195630dc.b07aff"
                   "id": "30ec57c5.5cb298",
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "tot": "msg"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 2150,
                   "y": 1880,
                   "wires": [
                           "195630dc.b07aff"
                   "id": "882eac91.a4c63",
                   "name": "",
                   "x": 2190,
                   "y": 1760,
                   "wires": [
                           "195630dc.b07aff"
                   "id": "a1a54233.2e25",
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "tot": "msg"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 2160,
                   "y": 1640,
                   "wires": [
                           "7cb96adf.df8ef4"
                   "id": "4b729ec6.a7567",
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "4.5",
                           "tot": "num"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 2140,
                   "y": 1680,
                   "wires": [
                           "7cb96adf.df8ef4"
                   "id": "d0e7d874.8ffc18",
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "tot": "msg"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 2150,
                   "y": 1720,
                   "wires": [
                           "7cb96adf.df8ef4"
                   "id": "e66376fc.0697e8",
                   "name": "",
                   "x": 2190,
                   "y": 1600,
                   "wires": [
                           "7cb96adf.df8ef4"
                   "id": "d912a77.1dadd58",
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "tot": "msg"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 2160,
                   "y": 1460,
                   "wires": [
                           "7da482f0.8e833c"
                   "id": "1afe73e2.fdb6ac",
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "4.5",
                           "tot": "num"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 2140,
                   "y": 1500,
                   "wires": [
                           "7da482f0.8e833c"
                   "id": "14999008.d8eab",
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "tot": "msg"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 2150,
                   "y": 1540,
                   "wires": [
                           "7da482f0.8e833c"
                   "id": "581dbaad.9c9f34",
                   "name": "",
                   "x": 2190,
                   "y": 1420,
                   "wires": [
                           "7da482f0.8e833c"
                   "id": "544cd832.3d5cb8",
                   "type": "debug",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "complete": "payload",
                   "targetType": "msg",
                   "statusVal": "",
                   "x": 2610,
                   "y": 2380,
                   "wires": []
                   "id": "8c12a45.58c5958",
                   "type": "rbe",
                   "name": "",
                   "func": "rbe",
                   "gap": "",
                   "start": "",
                   "inout": "out",
                   "septopics": true,
                   "property": "payload",
                   "x": 2440,
                   "y": 2360,
                   "wires": [
                           "6ce146dd.f3bdd8",
                           "544cd832.3d5cb8"
                   "id": "6ce146dd.f3bdd8",
                   "type": "ioBroker out",
                   "d": true,
                   "topic": "",
                   "ack": "false",
                   "autoCreate": "false",
                   "stateName": "",
                   "role": "",
                   "payloadType": "",
                   "readonly": "",
                   "stateUnit": "",
                   "stateMin": "",
                   "stateMax": "",
                   "x": 2610,
                   "y": 2340,
                   "wires": []
                   "id": "ef09f468.27d118",
                   "type": "debug",
                   "name": "Küche",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 2590,
                   "y": 2180,
                   "wires": []
                   "id": "420c8f3.1d09f7",
                   "type": "rbe",
                   "name": "",
                   "func": "rbe",
                   "gap": "",
                   "start": "",
                   "inout": "out",
                   "septopics": true,
                   "x": 2440,
                   "y": 2160,
                   "wires": [
                           "66692b1b.1a5af4",
                           "ef09f468.27d118"
                   "id": "66692b1b.1a5af4",
                   "d": true,
                   "name": "Küche",
                   "topic": "",
                   "ack": "false",
                   "stateName": "",
                   "role": "",
                   "payloadType": "",
                   "readonly": "",
                   "stateUnit": "",
                   "stateMin": "",
                   "stateMax": "",
                   "x": 2590,
                   "y": 2140,
                   "wires": []
                   "id": "b8cbf5b5.4b82c8",
                   "type": "debug",
                   "name": "Flur",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 2590,
                   "y": 2000,
                   "wires": []
                   "id": "cab0fe28.59eef",
                   "type": "rbe",
                   "name": "",
                   "func": "rbe",
                   "gap": "",
                   "start": "",
                   "inout": "out",
                   "septopics": true,
                   "x": 2440,
                   "y": 1980,
                   "wires": [
                           "d749214a.8cde9",
                           "b8cbf5b5.4b82c8"
                   "id": "d749214a.8cde9",
                   "d": true,
                   "name": "Flur",
                   "topic": "",
                   "ack": "false",
                   "stateName": "",
                   "role": "",
                   "payloadType": "",
                   "readonly": "",
                   "stateUnit": "",
                   "stateMin": "",
                   "stateMax": "",
                   "x": 2590,
                   "y": 1960,
                   "wires": []
                   "id": "a3fbc37c.6029e",
                   "type": "debug",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 2610,
                   "y": 1840,
                   "wires": []
                   "id": "195630dc.b07aff",
                   "type": "rbe",
                   "name": "",
                   "func": "rbe",
                   "gap": "",
                   "start": "",
                   "inout": "out",
                   "septopics": true,
                   "x": 2440,
                   "y": 1820,
                   "wires": [
                           "f46f75.b28e9088",
                           "a3fbc37c.6029e"
                   "id": "f46f75.b28e9088",
                   "d": true,
                   "topic": "",
                   "ack": "false",
                   "stateName": "",
                   "role": "",
                   "payloadType": "",
                   "readonly": "",
                   "stateUnit": "",
                   "stateMin": "",
                   "stateMax": "",
                   "x": 2610,
                   "y": 1800,
                   "wires": []
                   "id": "13e32815.6f13a8",
                   "type": "debug",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 2620,
                   "y": 1700,
                   "wires": []
                   "id": "7cb96adf.df8ef4",
                   "type": "rbe",
                   "name": "",
                   "func": "rbe",
                   "gap": "",
                   "start": "",
                   "inout": "out",
                   "septopics": true,
                   "x": 2440,
                   "y": 1680,
                   "wires": [
                           "ea6ed90a.7eea08",
                           "13e32815.6f13a8"
                   "id": "ea6ed90a.7eea08",
                   "d": true,
                   "topic": "",
                   "ack": "false",
                   "stateName": "",
                   "role": "",
                   "payloadType": "",
                   "readonly": "",
                   "stateUnit": "",
                   "stateMin": "",
                   "stateMax": "",
                   "x": 2620,
                   "y": 1660,
                   "wires": []
                   "id": "efcc4af2.479898",
                   "type": "debug",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 2620,
                   "y": 1500,
                   "wires": []
                   "id": "7da482f0.8e833c",
                   "type": "rbe",
                   "name": "",
                   "func": "rbe",
                   "gap": "",
                   "start": "",
                   "inout": "out",
                   "septopics": true,
                   "x": 2440,
                   "y": 1480,
                   "wires": [
                           "c1f9faa7.60fd18",
                           "efcc4af2.479898"
                   "id": "c1f9faa7.60fd18",
                   "d": true,
                   "topic": "",
                   "ack": "false",
                   "stateName": "",
                   "role": "",
                   "payloadType": "",
                   "readonly": "",
                   "stateUnit": "",
                   "stateMin": "",
                   "stateMax": "",
                   "x": 2620,
                   "y": 1460,
                   "wires": []
            So und keine Angst es läuft nach dem Deploy noch nichts los.
            Marko1974 1 Reply Last reply Reply Quote 0
            • Marko1974
              @mickym Wahnsinn.... Das hätte ich natürlich viel schneller hinbekommen 🙂
              Ich hab ja jetzt sogar AUS und ECO .... also den jetzt als neuen flow?
              • mickym
                @marko1974 Ob als neuen Flow - oder auf der gleichen Seite ist egal. Auf der gleichen Seite hat es ja auch noch Platz. Vielleicht nutzt Du Node Red ja noch für was anderes.
                • Marko1974
                  @mickym Type error: J_def is undefined
                  • mickym
                    @marko1974 sagte in MAX! Cube Blockly Abwesenheit:
                    So dann musst Du noch die AUTO Nodes gegen die korrekten aus dem Zimmern zuordnen - ich habe nur eine genommen, sonst hättest Du lauter Duplicate drin.
                    In den deaktivierten iobroker Out Nodes kommen die setpoints zu den Thermostaten im MaxCube Adapter.
                    Dann probierst Du erst mal aus, ob die richtige Temperatur rauskommt, wenn Du den Trigger benutzt.
                    • mickym
                      @marko1974 OK - dann bekommst den Flow als Datei - Augenblick:
                      MAXCubeSteuerung.json
                      • Marko1974
                        @mickym gleiche fehlermeldung
                        • mickym
                          @marko1974 Nein - das muss gehen - über Datei funktioniert es. Du darfst nicht über den Text importieren - sondern musst die Seite wieder im Dateisystem abspeichern und dann die DAtei im Import angeben.
                          Das Problem ist wenn Du den Flow als Text in das rosa Fenster kopierst.
                          • Marko1974
                            @mickym Leider nein....Auf import und dann aus Datei importieren.
                            • mickym
                              Sorry ich hab das bei mir gerade 2 mal gemacht
                              • Marko1974
                                @mickym Ich habe keine Text da reinkopiert. Bin auf neuen Flow erstelllen, Importieren, Aus Datei....Datei ausgewählt....Fehlermeldung
                                • Marko1974
                                  @mickym said in MAX! Cube Blockly Abwesenheit:
                                  So mache ich das schon die ganze Zeit....
                                  • mickym
                                    @marko1974 Hmmm -
                                    • Marko1974
                                      @mickym Ja ich sehe das schon....aber eine Datei importieren kann ich eigentlich schon 🙂 ... Oder fehlt was bei mir??
                                      • mickym
                                        @marko1974 Ich hab vielleicht noch eine Idee - wobei es als Datei wenn Du ohne markieren - den Text einfach mit Speichern unter als Datei kopiert hättest. Wie speicherst Du denn die Datei im lokalen Dateisystem?
                                        • Marko1974
                                          @mickym Na rechte Maustaste, Ziel speichern unter - und dann habe ich sie als Json gespeichert.
                                          Hab auch schon die Datei aufgemacht und reinkopiert....
                                          • mickym
                                            @marko1974 Ich versuche gerade mal ein Kopie ohne 3 Nodes zur Verfügung zu stellen - Augenblick
                                                   "type": "subflow",
                                                   "in": [
                                                           "x": 40,
                                                           "y": 260,
                                                           "wires": [
                                                   "out": [
                                                           "x": 1240,
                                                           "y": 260,
                                                           "wires": [
        "port": 0
        "port": 0
        "port": 0
        "port": 0
        "port": 0
        "port": 0
        "port": 0
        "port": 0
        "port": 0
        "port": 0
                                                   "env": [],
                                                   "meta": {},
                                                   "color": "#FFAAAA",
                                                   "outputLabels": [
                                                       "AUTO Temperatur"
                                                   "type": "switch",
                                                   "rules": [
                                                           "t": "btwn",
                                                           "v": "00:00",
                                                           "vt": "str",
                                                           "v2": "08:00",
                                                           "v2t": "str"
                                                           "t": "btwn",
                                                           "v": "08:00",
                                                           "vt": "str",
                                                           "v2": "09:00",
                                                           "v2t": "str"
                                                           "t": "btwn",
                                                           "v": "09:00",
                                                           "vt": "str",
                                                           "v2": "22:00",
                                                           "v2t": "str"
                                                           "t": "btwn",
                                                           "v": "22:00",
                                                           "vt": "str",
                                                           "v2": "23:00",
                                                           "v2t": "str"
                                                           "t": "btwn",
                                                           "v": "23:00",
                                                           "vt": "str",
                                                           "v2": "24:00",
                                                           "v2t": "str"
                                                   "repair": false,
                                                   "outputs": 5,
                                                   "x": 780,
                                                   "y": 160,
                                                   "wires": [
                                                           "78e83c34.8e26f4"
                                                           "b43a5b2f.5ba228"
                                                           "c381b0fb.0c407"
                                                           "d7602741.e08ec8"
                                                           "67e1f0e6.98f84"
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "tot": "json"
                                                           "t": "set",
                                                           "pt": "msg",
                                                           "tot": "jsonata"
                                                           "t": "set",
                                                           "pt": "msg",
                                                           "tot": "jsonata"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 190,
                                                   "y": 260,
                                                   "wires": [
                                                           "fd8206e3.66bbf8"
                                                   "type": "change",
                                                   "name": "22 °C",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "to": "22",
                                                           "tot": "num"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1070,
                                                   "y": 120,
                                                   "wires": [
                                                   "type": "change",
                                                   "name": "17°C",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "to": "17",
                                                           "tot": "num"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1070,
                                                   "y": 160,
                                                   "wires": [
                                                   "type": "change",
                                                   "name": "22 °C",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "to": "22",
                                                           "tot": "num"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1070,
                                                   "y": 200,
                                                   "wires": [
                                                   "type": "change",
                                                   "name": "17 °C",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "to": "17",
                                                           "tot": "num"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1070,
                                                   "y": 240,
                                                   "wires": [
                                                   "type": "switch",
                                                   "rules": [
                                                           "t": "btwn",
                                                           "v": "00:00",
                                                           "vt": "str",
                                                           "v2": "08:00",
                                                           "v2t": "str"
                                                           "t": "btwn",
                                                           "v": "08:00",
                                                           "vt": "str",
                                                           "v2": "09:00",
                                                           "v2t": "str"
                                                           "t": "btwn",
                                                           "v": "09:00",
                                                           "vt": "str",
                                                           "v2": "22:00",
                                                           "v2t": "str"
                                                           "t": "btwn",
                                                           "v": "22:00",
                                                           "vt": "str",
                                                           "v2": "23:00",
                                                           "v2t": "str"
                                                           "t": "btwn",
                                                           "v": "23:00",
                                                           "vt": "str",
                                                           "v2": "24:00",
                                                           "v2t": "str"
                                                   "repair": false,
                                                   "outputs": 5,
                                                   "x": 780,
                                                   "y": 380,
                                                   "wires": [
                                                           "324ef3e0.d9ac1c"
                                                           "2c0b8bd8.778e14"
                                                           "5b0e8515.b3b32c"
                                                           "92ee1669.329f78"
                                                           "50a57933.3a77b8"
                                                   "type": "change",
                                                   "name": "22 °C",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "to": "22",
                                                           "tot": "num"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1070,
                                                   "y": 340,
                                                   "wires": [
                                                   "type": "switch",
                                                   "rules": [
                                                           "t": "regex",
                                                           "vt": "str",
                                                           "case": true
                                                           "t": "regex",
                                                           "vt": "str",
                                                           "case": true
                                                   "checkall": "true",
                                                   "repair": false,
                                                   "outputs": 2,
                                                   "x": 430,
                                                   "y": 260,
                                                   "wires": [
                                                           "2961f12d.901f7e"
                                                           "a03bd421.d47bd8"
                                                   "type": "change",
                                                   "name": "17 °C",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "to": "17",
                                                           "tot": "num"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1070,
                                                   "y": 380,
                                                   "wires": [
                                                   "type": "change",
                                                   "name": "22 °C",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "to": "22",
                                                           "tot": "num"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1070,
                                                   "y": 420,
                                                   "wires": [
                                                   "type": "change",
                                                   "name": "17 °C",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "to": "17",
                                                           "tot": "num"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1070,
                                                   "y": 460,
                                                   "wires": [
                                                   "type": "change",
                                                   "name": "17 °C",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "to": "17",
                                                           "tot": "num"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1070,
                                                   "y": 300,
                                                   "wires": [
                                                   "type": "change",
                                                   "name": "17 °C",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "to": "17",
                                                           "tot": "num"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1070,
                                                   "y": 80,
                                                   "wires": [
                                                   "id": "8d07f0f.462691",
                                                   "type": "inject",
                                                   "z": "2fbfe79e.7af108",
                                                   "props": [
                                                           "p": "ts",
                                                           "v": "",
                                                           "vt": "date"
                                                   "repeat": "",
                                                   "crontab": "",
                                                   "once": false,
                                                   "onceDelay": 0.1,
                                                   "topic": "",
                                                   "x": 230,
                                                   "y": 640,
                                                   "wires": [
                                                           "ba9950a5.49288"
                                                   "id": "7cb2eeb8.3e183",
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "room",
                                                           "pt": "msg",
                                                           "to": "Wohnzimmer",
                                                           "tot": "str"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 650,
                                                   "y": 620,
                                                   "wires": [
                                                   "id": "a8d50db9.c6774",
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "room",
                                                           "pt": "msg",
                                                           "tot": "str"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 640,
                                                   "y": 580,
                                                   "wires": [
                                                   "id": "bf4c2ed6.98035",
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "room",
                                                           "pt": "msg",
                                                           "tot": "str"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 640,
                                                   "y": 540,
                                                   "wires": [
                                                   "id": "c4e28fa7.326bc",
                                                   "type": "change",
                                                   "name": "Flur",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "room",
                                                           "pt": "msg",
                                                           "to": "Flur",
                                                           "tot": "str"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 670,
                                                   "y": 660,
                                                   "wires": [
                                                   "id": "658a283c.e3df28",
                                                   "type": "change",
                                                   "name": "Küche",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "room",
                                                           "pt": "msg",
                                                           "to": "Küche",
                                                           "tot": "str"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 670,
                                                   "y": 700,
                                                   "wires": [
                                                   "id": "8d92ec5a.66a3e",
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "room",
                                                           "pt": "msg",
                                                           "to": "Badezimmer",
                                                           "tot": "str"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 650,
                                                   "y": 740,
                                                   "wires": [
                                                   "id": "ba9950a5.49288",
                                                   "type": "switch",
                                                   "rules": [
                                                           "t": "true"
                                                   "checkall": "true",
                                                   "repair": false,
                                                   "outputs": 1,
                                                   "x": 420,
                                                   "y": 640,
                                                   "wires": [
                                                           "bf4c2ed6.98035",
                                                           "a8d50db9.c6774",
                                                           "7cb2eeb8.3e183",
                                                           "c4e28fa7.326bc",
                                                           "658a283c.e3df28",
                                                           "8d92ec5a.66a3e"
                                                   "id": "a6332322.cad5c",
                                                   "type": "inject",
                                                   "props": [
                                                           "p": "payload"
                                                   "repeat": "",
                                                   "crontab": "",
                                                   "once": true,
                                                   "onceDelay": 0.1,
                                                   "topic": "",
                                                   "payload": "true",
                                                   "x": 300,
                                                   "y": 80,
                                                   "wires": [
                                                           "e64a03f5.dab21"
                                                   "id": "e64a03f5.dab21",
                                                   "type": "change",
                                                   "name": "",
                                                   "rules": [
                                                           "t": "set",
                                                           "pt": "global",
                                                           "to": "payload",
                                                           "tot": "msg"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 610,
                                                   "y": 80,
                                                   "wires": [
                                                   "id": "62b671f6.c2aaf",
                                                   "type": "debug",
                                                   "name": "",
                                                   "active": true,
                                                   "tosidebar": true,
                                                   "console": false,
                                                   "tostatus": false,
                                                   "complete": "true",
                                                   "statusVal": "",
                                                   "x": 1410,
                                                   "y": 700,
                                                   "wires": []
                                                   "id": "29540e68.f0aa92",
                                                   "name": "get mode",
                                                   "topic": "",
                                                   "attrname": "mode",
                                                   "x": 1110,
                                                   "y": 540,
                                                   "wires": [
                                                   "id": "c51fcd1e.360f2",
                                                   "topic": "",
                                                   "x": 1150,
                                                   "y": 620,
                                                   "wires": [
                                                   "id": "cb21ff74.eb4a9",
                                                   "type": "switch",
                                                   "property": "room",
                                                   "rules": [
                                                           "t": "eq",
                                                           "vt": "str"
                                                           "t": "eq",
                                                           "vt": "str"
                                                           "t": "eq",
                                                           "v": "Wohnzimmer",
                                                           "vt": "str"
                                                           "t": "eq",
                                                           "v": "Flur",
                                                           "vt": "str"
                                                           "t": "eq",
                                                           "v": "Küche",
                                                           "vt": "str"
                                                           "t": "eq",
                                                           "v": "Badezimmer",
                                                           "vt": "str"
                                                   "checkall": "true",
                                                   "repair": false,
                                                   "outputs": 6,
                                                   "x": 1430,
                                                   "y": 620,
                                                   "wires": [
                                                           "e5a3e935.e886d8"
                                                           "972d9173.c7f3"
                                                           "ed377f3f.8544b"
                                                           "5d6d4c4f.91d114"
                                                           "38ccb111.f4e7fe"
                                                           "21e8fc89.707d14"
                                                   "id": "e5a3e935.e886d8",
                                                   "type": "switch",
                                                   "property": "mode",
                                                   "rules": [
                                                           "t": "eq",
                                                           "v": "AUTO",
                                                           "vt": "str"
                                                           "t": "eq",
                                                           "v": "HEAT",
                                                           "vt": "str"
                                                           "t": "eq",
                                                           "v": "OFF",
                                                           "vt": "str"
                                                           "t": "eq",
                                                           "v": "ECO",
                                                           "vt": "str"
                                                   "checkall": "true",
                                                   "repair": false,
                                                   "outputs": 4,
                                                   "x": 1680,
                                                   "y": 180,
                                                   "wires": [
                                                           "d54c49bb.c74768"
                                                           "c184fb01.ebcca8"
                                                           "6529e1ae.5cd9"
                                                           "6dabe592.9faefc"
                                                   "id": "972d9173.c7f3",
                                                   "type": "switch",
                                                   "property": "mode",
                                                   "rules": [
                                                           "t": "eq",
                                                           "v": "AUTO",
                                                           "vt": "str"
                                                           "t": "eq",
                                                           "v": "HEAT",
                                                           "vt": "str"
                                                           "t": "eq",
                                                           "v": "OFF",
                                                           "vt": "str"
                                                           "t": "eq",
                                                           "v": "ECO",
                                                           "vt": "str"
                                                   "checkall": "true",
                                                   "repair": false,
                                                   "outputs": 4,
                                                   "x": 1680,
                                                   "y": 360,
                                                   "wires": [
                                                           "724c420d.7bb4dc"
                                                           "c03eaf47.47cf8"
                                                           "472549e6.0d4678"
                                                           "331e3168.d80a6e"
                                                   "id": "ed377f3f.8544b",
                                                   "type": "switch",
                                                   "property": "mode",
                                                   "rules": [
                                                           "t": "eq",
                                                           "v": "AUTO",
                                                           "vt": "str"
                                                           "t": "eq",
                                                           "v": "HEAT",
                                                           "vt": "str"
                                                           "t": "eq",
                                                           "v": "OFF",
                                                           "vt": "str"
                                                           "t": "eq",
                                                           "v": "ECO",
                                                           "vt": "str"
                                                   "checkall": "true",
                                                   "repair": false,
                                                   "outputs": 4,
                                                   "x": 1670,
                                                   "y": 520,
                                                   "wires": [
                                                           "75b189b0.a21ce8"
                                                           "8699996.589d768"
                                                           "53fd717d.05821"
                                                           "7459aba.9b79754"
                                                   "id": "5d6d4c4f.91d114",
                                                   "type": "switch",
                                                   "name": "Flur",
                                                   "property": "mode",
                                                   "rules": [
                                                           "t": "eq",
                                                           "v": "AUTO",
                                                           "vt": "str"
                                                           "t": "eq",
                                                           "v": "HEAT",
                                                           "vt": "str"
                                                           "t": "eq",
                                                           "v": "OFF",
                                                           "vt": "str"
                                                           "t": "eq",
                                                           "v": "ECO",
                                                           "vt": "str"
                                                   "checkall": "true",
                                                   "repair": false,
                                                   "outputs": 4,
                                                   "x": 1650,
                                                   "y": 680,
                                                   "wires": [
                                                           "e5b821c6.408a"
                                                           "43795266.f0f97c"
                                                           "21ca5905.e8f226"
                                                           "27615a8c.7d6016"
                                                   "id": "38ccb111.f4e7fe",
                                                   "type": "switch",
                                                   "name": "Küche",
                                                   "property": "mode",
                                                   "rules": [
                                                           "t": "eq",
                                                           "v": "AUTO",
                                                           "vt": "str"
                                                           "t": "eq",
                                                           "v": "HEAT",
                                                           "vt": "str"
                                                           "t": "eq",
                                                           "v": "OFF",
                                                           "vt": "str"
                                                           "t": "eq",
                                                           "v": "ECO",
                                                           "vt": "str"
                                                   "checkall": "true",
                                                   "repair": false,
                                                   "outputs": 4,
                                                   "x": 1670,
                                                   "y": 860,
                                                   "wires": [
                                                           "e0360495.4282d8"
                                                           "6192c71e.e14868"
                                                           "3af25a08.425dd6"
                                                           "90555796.db7908"
                                                   "id": "21e8fc89.707d14",
                                                   "type": "switch",
                                                   "property": "mode",
                                                   "rules": [
                                                           "t": "eq",
                                                           "v": "AUTO",
                                                           "vt": "str"
                                                           "t": "eq",
                                                           "v": "HEAT",
                                                           "vt": "str"
                                                           "t": "eq",
                                                           "v": "OFF",
                                                           "vt": "str"
                                                           "t": "eq",
                                                           "v": "ECO",
                                                           "vt": "str"
                                                   "checkall": "true",
                                                   "repair": false,
                                                   "outputs": 4,
                                                   "x": 1670,
                                                   "y": 1040,
                                                   "wires": [
                                                           "855f7739.710cf8"
                                                           "f0fac0a8.a938"
                                                           "be472598.070aa8"
                                                           "58de29bc.e3d6c8"
                                                   "id": "855f7739.710cf8",
                                                   "name": "",
                                                   "x": 1930,
                                                   "y": 980,
                                                   "wires": [
                                                           "bb798b95.27ffe8"
                                                   "id": "f0fac0a8.a938",
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "tot": "msg"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1900,
                                                   "y": 1020,
                                                   "wires": [
                                                           "bb798b95.27ffe8"
                                                   "id": "be472598.070aa8",
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "to": "4.5",
                                                           "tot": "num"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1880,
                                                   "y": 1060,
                                                   "wires": [
                                                           "bb798b95.27ffe8"
                                                   "id": "b66df471.5836c8",
                                                   "topic": "",
                                                   "x": 1140,
                                                   "y": 700,
                                                   "wires": [
                                                           "cb21ff74.eb4a9",
                                                           "62b671f6.c2aaf"
                                                   "id": "58de29bc.e3d6c8",
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "tot": "msg"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1890,
                                                   "y": 1100,
                                                   "wires": [
                                                           "bb798b95.27ffe8"
                                                   "id": "6192c71e.e14868",
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "tot": "msg"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1900,
                                                   "y": 840,
                                                   "wires": [
                                                           "9be24893.3fb948"
                                                   "id": "3af25a08.425dd6",
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "to": "4.5",
                                                           "tot": "num"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1880,
                                                   "y": 880,
                                                   "wires": [
                                                           "9be24893.3fb948"
                                                   "id": "90555796.db7908",
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "tot": "msg"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1890,
                                                   "y": 920,
                                                   "wires": [
                                                           "9be24893.3fb948"
                                                   "id": "e0360495.4282d8",
                                                   "name": "",
                                                   "x": 1930,
                                                   "y": 800,
                                                   "wires": [
                                                           "9be24893.3fb948"
                                                   "id": "43795266.f0f97c",
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "tot": "msg"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1900,
                                                   "y": 660,
                                                   "wires": [
                                                           "fa3e96a8.7edc38"
                                                   "id": "21ca5905.e8f226",
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "to": "4.5",
                                                           "tot": "num"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1880,
                                                   "y": 700,
                                                   "wires": [
                                                           "fa3e96a8.7edc38"
                                                   "id": "27615a8c.7d6016",
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "tot": "msg"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1890,
                                                   "y": 740,
                                                   "wires": [
                                                           "fa3e96a8.7edc38"
                                                   "id": "e5b821c6.408a",
                                                   "name": "",
                                                   "x": 1930,
                                                   "y": 620,
                                                   "wires": [
                                                           "fa3e96a8.7edc38"
                                                   "id": "8699996.589d768",
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "tot": "msg"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1900,
                                                   "y": 500,
                                                   "wires": [
                                                           "43619702.eb9618"
                                                   "id": "53fd717d.05821",
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "to": "4.5",
                                                           "tot": "num"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1880,
                                                   "y": 540,
                                                   "wires": [
                                                           "43619702.eb9618"
                                                   "id": "7459aba.9b79754",
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "tot": "msg"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1890,
                                                   "y": 580,
                                                   "wires": [
                                                           "43619702.eb9618"
                                                   "id": "75b189b0.a21ce8",
                                                   "name": "",
                                                   "x": 1930,
                                                   "y": 460,
                                                   "wires": [
                                                           "43619702.eb9618"
                                                   "id": "c03eaf47.47cf8",
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "tot": "msg"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1900,
                                                   "y": 340,
                                                   "wires": [
                                                           "4d667db0.e6ae24"
                                                   "id": "472549e6.0d4678",
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "to": "4.5",
                                                           "tot": "num"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1880,
                                                   "y": 380,
                                                   "wires": [
                                                           "4d667db0.e6ae24"
                                                   "id": "331e3168.d80a6e",
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "tot": "msg"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1890,
                                                   "y": 420,
                                                   "wires": [
                                                           "4d667db0.e6ae24"
                                                   "id": "724c420d.7bb4dc",
                                                   "name": "",
                                                   "x": 1930,
                                                   "y": 300,
                                                   "wires": [
                                                           "4d667db0.e6ae24"
                                                   "id": "c184fb01.ebcca8",
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "tot": "msg"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1900,
                                                   "y": 160,
                                                   "wires": [
                                                           "bbbcbe24.a8ad3"
                                                   "id": "6529e1ae.5cd9",
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "to": "4.5",
                                                           "tot": "num"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1880,
                                                   "y": 200,
                                                   "wires": [
                                                           "bbbcbe24.a8ad3"
                                                   "id": "6dabe592.9faefc",
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "tot": "msg"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1890,
                                                   "y": 240,
                                                   "wires": [
                                                           "bbbcbe24.a8ad3"
                                                   "id": "d54c49bb.c74768",
                                                   "name": "",
                                                   "x": 1930,
                                                   "y": 120,
                                                   "wires": [
                                                           "bbbcbe24.a8ad3"
                                                   "id": "a4444639.a32858",
                                                   "type": "debug",
                                                   "active": true,
                                                   "tosidebar": true,
                                                   "console": false,
                                                   "tostatus": false,
                                                   "statusVal": "",
                                                   "x": 2350,
                                                   "y": 1080,
                                                   "wires": []
                                                   "id": "bb798b95.27ffe8",
                                                   "type": "rbe",
                                                   "name": "",
                                                   "func": "rbe",
                                                   "gap": "",
                                                   "start": "",
                                                   "inout": "out",
                                                   "septopics": true,
                                                   "x": 2180,
                                                   "y": 1060,
                                                   "wires": [
                                                           "6d76bee5.29833",
                                                           "a4444639.a32858"
                                                   "id": "6d76bee5.29833",
                                                   "d": true,
                                                   "topic": "",
                                                   "ack": "false",
                                                   "stateName": "",
                                                   "role": "",
                                                   "payloadType": "",
                                                   "readonly": "",
                                                   "stateUnit": "",
                                                   "stateMin": "",
                                                   "stateMax": "",
                                                   "x": 2350,
                                                   "y": 1040,
                                                   "wires": []
                                                   "id": "bff952d4.2c202",
                                                   "type": "debug",
                                                   "name": "Küche",
                                                   "active": true,
                                                   "tosidebar": true,
                                                   "console": false,
                                                   "tostatus": false,
                                                   "statusVal": "",
                                                   "x": 2330,
                                                   "y": 880,
                                                   "wires": []
                                                   "id": "9be24893.3fb948",
                                                   "type": "rbe",
                                                   "name": "",
                                                   "func": "rbe",
                                                   "gap": "",
                                                   "start": "",
                                                   "inout": "out",
                                                   "septopics": true,
                                                   "x": 2180,
                                                   "y": 860,
                                                   "wires": [
                                                           "680cda98.c79904",
                                                           "bff952d4.2c202"
                                                   "id": "680cda98.c79904",
                                                   "d": true,
                                                   "name": "Küche",
                                                   "topic": "",
                                                   "ack": "false",
                                                   "stateName": "",
                                                   "role": "",
                                                   "payloadType": "",
                                                   "readonly": "",
                                                   "stateUnit": "",
                                                   "stateMin": "",
                                                   "stateMax": "",
                                                   "x": 2330,
                                                   "y": 840,
                                                   "wires": []
                                                   "id": "c60e966b.faec78",
                                                   "type": "debug",
                                                   "name": "Flur",
                                                   "active": true,
                                                   "tosidebar": true,
                                                   "console": false,
                                                   "tostatus": false,
                                                   "statusVal": "",
                                                   "x": 2330,
                                                   "y": 700,
                                                   "wires": []
                                                   "id": "fa3e96a8.7edc38",
                                                   "type": "rbe",
                                                   "name": "",
                                                   "func": "rbe",
                                                   "gap": "",
                                                   "start": "",
                                                   "inout": "out",
                                                   "septopics": true,
                                                   "x": 2180,
                                                   "y": 680,
                                                   "wires": [
                                                           "f0a0c599.311628",
                                                           "c60e966b.faec78"
                                                   "id": "f0a0c599.311628",
                                                   "d": true,
                                                   "name": "Flur",
                                                   "topic": "",
                                                   "ack": "false",
                                                   "stateName": "",
                                                   "role": "",
                                                   "payloadType": "",
                                                   "readonly": "",
                                                   "stateUnit": "",
                                                   "stateMin": "",
                                                   "stateMax": "",
                                                   "x": 2330,
                                                   "y": 660,
                                                   "wires": []
                                                   "id": "32d64871.5d6618",
                                                   "type": "debug",
                                                   "active": true,
                                                   "tosidebar": true,
                                                   "console": false,
                                                   "tostatus": false,
                                                   "statusVal": "",
                                                   "x": 2350,
                                                   "y": 540,
                                                   "wires": []
                                                   "id": "43619702.eb9618",
                                                   "type": "rbe",
                                                   "name": "",
                                                   "func": "rbe",
                                                   "gap": "",
                                                   "start": "",
                                                   "inout": "out",
                                                   "septopics": true,
                                                   "x": 2180,
                                                   "y": 520,
                                                   "wires": [
                                                           "18ba5ed3.02b871",
                                                           "32d64871.5d6618"
                                                   "id": "18ba5ed3.02b871",
                                                   "d": true,
                                                   "topic": "",
                                                   "ack": "false",
                                                   "stateName": "",
                                                   "role": "",
                                                   "payloadType": "",
                                                   "readonly": "",
                                                   "stateUnit": "",
                                                   "stateMin": "",
                                                   "stateMax": "",
                                                   "x": 2350,
                                                   "y": 500,
                                                   "wires": []
                                                   "id": "8dc663ac.ad48c",
                                                   "type": "debug",
                                                   "active": true,
                                                   "tosidebar": true,
                                                   "console": false,
                                                   "tostatus": false,
                                                   "statusVal": "",
                                                   "x": 2360,
                                                   "y": 400,
                                                   "wires": []
                                                   "id": "4d667db0.e6ae24",
                                                   "type": "rbe",
                                                   "name": "",
                                                   "func": "rbe",
                                                   "gap": "",
                                                   "start": "",
                                                   "inout": "out",
                                                   "septopics": true,
                                                   "x": 2180,
                                                   "y": 380,
                                                   "wires": [
                                                           "3b64abf8.4e46a4",
                                                           "8dc663ac.ad48c"
                                                   "id": "3b64abf8.4e46a4",
                                                   "d": true,
                                                   "topic": "",
                                                   "ack": "false",
                                                   "stateName": "",
                                                   "role": "",
                                                   "payloadType": "",
                                                   "readonly": "",
                                                   "stateUnit": "",
                                                   "stateMin": "",
                                                   "stateMax": "",
                                                   "x": 2360,
                                                   "y": 360,
                                                   "wires": []
                                                   "id": "92ea75ca.3e4688",
                                                   "type": "debug",
                                                   "active": true,
                                                   "tosidebar": true,
                                                   "console": false,
                                                   "tostatus": false,
                                                   "statusVal": "",
                                                   "x": 2360,
                                                   "y": 200,
                                                   "wires": []
                                                   "id": "bbbcbe24.a8ad3",
                                                   "type": "rbe",
                                                   "name": "",
                                                   "func": "rbe",
                                                   "gap": "",
                                                   "start": "",
                                                   "inout": "out",
                                                   "septopics": true,
                                                   "x": 2180,
                                                   "y": 180,
                                                   "wires": [
                                                           "45b23eda.84112",
                                                           "92ea75ca.3e4688"
                                                   "id": "45b23eda.84112",
                                                   "d": true,
                                                   "topic": "",
                                                   "ack": "false",
                                                   "stateName": "",
                                                   "role": "",
                                                   "payloadType": "",
                                                   "readonly": "",
                                                   "stateUnit": "",
                                                   "stateMin": "",
                                                   "stateMax": "",
                                                   "x": 2360,
                                                   "y": 160,
                                                   "wires": []
                                            Schau mal on das geht
                                            164276
