    4. ioBroker.admin 5.1.25. Blockly nur mit alter GUI.
      Thomas Braun Most Active @nitrox9 last edited by
      @nitrox9
      iobroker list adapters
      iobroker list instances
      iobroker update -i
      iobroker update all
      • N
        nitrox9 @Thomas Braun last edited by
        @thomas-braun said in ioBroker.admin 5.1.25. Blockly nur mit alter GUI.:
        iobroker update -i
        iobroker update all
        iobroker update -i
        iobroker update all
        system.adapter.admin                   : admin          - v5.1.25
        system.adapter.discovery               : discovery      - v2.7.0
        system.adapter.fhem                    : fhem           - v1.6.3
        system.adapter.info                    : info           - v1.9.8
        system.adapter.javascript              : javascript     - v5.2.8
        system.adapter.mqtt                    : mqtt           - v2.4.0
        system.adapter.vis                     : vis            - v1.4.4
        system.adapter.web                     : web            - v3.4.9
        + system.adapter.admin.0                  : admin                 : fhem                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.discovery.0              : discovery             : fhem                                     -  enabled
        + system.adapter.fhem.0                   : fhem                  : fhem                                     -  enabled, port: 7072
          system.adapter.info.0                   : info                  : fhem                                     - disabled
        + system.adapter.javascript.1             : javascript            : fhem                                     -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : fhem                                     -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.vis.0                    : vis                   : fhem                                     -  enabled
        + system.adapter.web.0                    : web                   : fhem                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        Used repository: default
        hash unchanged, use cached sources
        update done
        Adapter    "admin"         : 5.1.25   , installed 5.1.25
        Adapter    "backitup"      : 2.1.17   , installed 2.2.2
        Adapter    "discovery"     : 2.7.3    , installed 2.7.0 [Updateable]
        Adapter    "fhem"          : 1.6.3    , installed 1.6.3
        Adapter    "info"          : 1.9.8    , installed 1.9.8
        Adapter    "javascript"    : 5.2.8    , installed 5.2.8
        Controller "js-controller" : 3.3.18   , installed 3.3.18
        Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
        Adapter    "simple-api"    : 2.6.1    , installed 2.6.2
        Adapter    "socketio"      : 3.1.4    , installed 3.1.5
        Adapter    "vis"           : 1.4.4    , installed 1.4.4
        Adapter    "web"           : 3.4.9    , installed 3.4.9
        Used repository: all
        failed to download new sources, use cached sources
        update done
        Meine Neuinstallation:
        • iobroker stop
        • mv /opt/iobroker /opt/iobroker.old
        • curl -sL https://iobroker.net/install.sh | bash -
        • alle Einstellungen, Adapter, Instanzen und Passworte waren weg
        javascript.0 / JavaScript Rules war automatisch vorhanden (aber nicht gestartet) und musste gelöscht werden, um Skripte starten zu können.
        Homoran crunchip 3 Replies Last reply Reply Quote 0
          Homoran Global Moderator Administrators @nitrox9 last edited by Homoran
          @nitrox9 sagte in ioBroker.admin 5.1.25. Blockly nur mit alter GUI.:
          Ja, natürlich!
          die hast du ja verschoben und eine flammneue Installation aufgesetzt
          aber nur enn du die installiert hat. Wahrscheilich über discovery
            crunchip Forum Testing Most Active @nitrox9 last edited by crunchip
            @nitrox9 bei dir stimmt doch etws mit dem Repo nicht, daher auch bei einigen Adapter die falsche Version
            bzw bist du scheinbar im latest unterwegs
            • N
              nitrox9 @crunchip last edited by
              @crunchip said in ioBroker.admin 5.1.25. Blockly nur mit alter GUI.:
              Betriebssystem? Eigentlich nicht:
              sources.list:
              deb http://deb.debian.org/debian bullseye main contrib non-free
              deb http://deb.debian.org/debian bullseye-updates main contrib non-free
              deb http://security.debian.org/debian-security bullseye-security main contrib non-free
              Ist Bullseye 11.1, sollte die aktuellste stable sein.
              Das ganze System wurde mit apt dist-upgrade eigentlich sauber von Buster hochgezogen. Altlasten im System?
                @nitrox9 iobroker war damit gemeint Systemeinstellung(Schraubenschlüssel) standard repository
                Homoran N 2 Replies Last reply Reply Quote 0
                  Homoran Global Moderator Administrators @crunchip last edited by
                  @crunchip sagte in ioBroker.admin 5.1.25. Blockly nur mit alter GUI.:
                  nicht nur dort:
                  was soll das sein?
                  • N
                      @nitrox9
                      iobroker repo list
                        crunchip Forum Testing Most Active @Homoran last edited by
                        @homoran deswegen schrieb ich ja oben
                        • N
                          nitrox9 @Thomas Braun last edited by nitrox9
                          iobroker repo list
                          # iobroker repo list
                          default     : http://download.iobroker.net/sources-dist.json
                          latest      : http://download.iobroker.net/sources-dist-latest.json
                          Active repo: default
                            kann es sein das keine verbindung besteht?
                            dann wäre besser
                            live-default   http://iobroker.live/repo/sources-dist.json
                              Aber das ist doch eine neue Installation, oder?
                              wo kommt denn da der alte Mist her?
                                @homoran und wie kommt er dann zu
                                  @crunchip ich sag ja, da ist irgendetwas grundlegend faul
                                  @nitrox9
                                  bitte immer auch die Eingabe und die vollständige Ausgabe posten
                                  • N
                                    Adapter "simple-api" : 2.6.1 , installed 2.6.2 Adapter "socketio" : 3.1.4 , installed 3.1.5
                                    Altlasten im System von der ersten Installation?
                                    Bei der ersten Installation (die nach /opt/iobroker.old verschoben wurde) hatte ich alle Geräte angeklickt, die mir interessant vorkamen.
                                    Sollte nach meinem Verständnis aber nach
                                    erledigt sein.
                                    Thomas Braun Homoran crunchip 3 Replies Last reply Reply Quote 0
                                      erledigt sein.
                                      Da könnte aber noch Zeug im npm cache hängen und von dort wiederherstellt werden. Hatte so ein Phänomen die Tage (allerdings in einem leicht anderen Zusammenhang).
                                        das hatte ich vermutet / Zwei parallele Installationen
                                        @thomas-braun sagte in ioBroker.admin 5.1.25. Blockly nur mit alter GUI.:
                                        aber doch nicht die Pfade zum Repo?
                                        Ansonsten hilft ein
                                        cd/opt/iobroker
                                        npm cache clean --force
                                          @nitrox9 nein, es ist verwunderlich, das du versionen aus dem latest hast, dein repo auf default steht und zu gleich keine Ausgabe hergibt.
                                          ich persönlich würde den discover adapter aussen vor lassen und deine Geräte manuell nach und nach einrichten, bzw wenn du discover verwenden möchtet, dann Stück für Stück und nicht alles was dir angezeigt wird, gleich aktivieren. Da passieren nämlich hier und da, blöde Dinge, w.z.b. Geräte/Instanzen doppelt angelegt werden.
                                            Das wäre auch mein nächster Vorschlag, wenn wir eine saubere Basis haben
                                            2222
