    4. ioBroker.admin 5.1.25. Blockly nur mit alter GUI.
    • N
      nitrox9 @Thomas Braun last edited by
      @thomas-braun said in ioBroker.admin 5.1.25. Blockly nur mit alter GUI.:
      iobroker list adapters
      iobroker list instances
      iobroker update -i
      iobroker update all
      iobroker update -i
      iobroker update all
      system.adapter.admin                   : admin          - v5.1.25
      system.adapter.discovery               : discovery      - v2.7.0
      system.adapter.fhem                    : fhem           - v1.6.3
      system.adapter.info                    : info           - v1.9.8
      system.adapter.javascript              : javascript     - v5.2.8
      system.adapter.mqtt                    : mqtt           - v2.4.0
      system.adapter.vis                     : vis            - v1.4.4
      system.adapter.web                     : web            - v3.4.9
      + system.adapter.admin.0                  : admin                 : fhem                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.discovery.0              : discovery             : fhem                                     -  enabled
      + system.adapter.fhem.0                   : fhem                  : fhem                                     -  enabled, port: 7072
        system.adapter.info.0                   : info                  : fhem                                     - disabled
      + system.adapter.javascript.1             : javascript            : fhem                                     -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : fhem                                     -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.vis.0                    : vis                   : fhem                                     -  enabled
      + system.adapter.web.0                    : web                   : fhem                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      Used repository: default
      hash unchanged, use cached sources
      update done
      Adapter    "admin"         : 5.1.25   , installed 5.1.25
      Adapter    "backitup"      : 2.1.17   , installed 2.2.2
      Adapter    "discovery"     : 2.7.3    , installed 2.7.0 [Updateable]
      Adapter    "fhem"          : 1.6.3    , installed 1.6.3
      Adapter    "info"          : 1.9.8    , installed 1.9.8
      Adapter    "javascript"    : 5.2.8    , installed 5.2.8
      Controller "js-controller" : 3.3.18   , installed 3.3.18
      Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
      Adapter    "simple-api"    : 2.6.1    , installed 2.6.2
      Adapter    "socketio"      : 3.1.4    , installed 3.1.5
      Adapter    "vis"           : 1.4.4    , installed 1.4.4
      Adapter    "web"           : 3.4.9    , installed 3.4.9
      Used repository: all
      failed to download new sources, use cached sources
      update done
      Meine Neuinstallation:
      • iobroker stop
      • mv /opt/iobroker /opt/iobroker.old
      • curl -sL https://iobroker.net/install.sh | bash -
      • alle Einstellungen, Adapter, Instanzen und Passworte waren weg
      javascript.0 / JavaScript Rules war automatisch vorhanden (aber nicht gestartet) und musste gelöscht werden, um Skripte starten zu können.
      Homoran crunchip 3 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @nitrox9 last edited by Homoran
        @nitrox9 sagte in ioBroker.admin 5.1.25. Blockly nur mit alter GUI.:
        Ja, natürlich!
        die hast du ja verschoben und eine flammneue Installation aufgesetzt
        aber nur enn du die installiert hat. Wahrscheilich über discovery
          crunchip Forum Testing Most Active @nitrox9 last edited by crunchip
          @nitrox9 bei dir stimmt doch etws mit dem Repo nicht, daher auch bei einigen Adapter die falsche Version
          bzw bist du scheinbar im latest unterwegs
          • N
            nitrox9 @crunchip last edited by
            @crunchip said in ioBroker.admin 5.1.25. Blockly nur mit alter GUI.:
            Betriebssystem? Eigentlich nicht:
            sources.list:
            deb http://deb.debian.org/debian bullseye main contrib non-free
            deb http://deb.debian.org/debian bullseye-updates main contrib non-free
            deb http://security.debian.org/debian-security bullseye-security main contrib non-free
            Ist Bullseye 11.1, sollte die aktuellste stable sein.
            Das ganze System wurde mit apt dist-upgrade eigentlich sauber von Buster hochgezogen. Altlasten im System?
              @nitrox9 iobroker war damit gemeint Systemeinstellung(Schraubenschlüssel) standard repository
              Homoran N 2 Replies Last reply Reply Quote 0
                Homoran Global Moderator Administrators @crunchip last edited by
                @crunchip sagte in ioBroker.admin 5.1.25. Blockly nur mit alter GUI.:
                nicht nur dort:
                was soll das sein?
                • N
                    Thomas Braun Most Active @nitrox9 last edited by
                    @nitrox9
                    iobroker repo list
                      crunchip Forum Testing Most Active @Homoran last edited by
                      @homoran deswegen schrieb ich ja oben
                      • N
                        nitrox9 @Thomas Braun last edited by nitrox9
                        iobroker repo list
                        # iobroker repo list
                        default     : http://download.iobroker.net/sources-dist.json
                        latest      : http://download.iobroker.net/sources-dist-latest.json
                        Active repo: default
                          kann es sein das keine verbindung besteht?
                          dann wäre besser
                          live-default   http://iobroker.live/repo/sources-dist.json
                            Aber das ist doch eine neue Installation, oder?
                            wo kommt denn da der alte Mist her?
                              @homoran und wie kommt er dann zu
                                @crunchip ich sag ja, da ist irgendetwas grundlegend faul
                                @nitrox9
                                bitte immer auch die Eingabe und die vollständige Ausgabe posten
                                • N
                                  Adapter "simple-api" : 2.6.1 , installed 2.6.2 Adapter "socketio" : 3.1.4 , installed 3.1.5
                                  Altlasten im System von der ersten Installation?
                                  Bei der ersten Installation (die nach /opt/iobroker.old verschoben wurde) hatte ich alle Geräte angeklickt, die mir interessant vorkamen.
                                  Sollte nach meinem Verständnis aber nach
                                  erledigt sein.
                                  Thomas Braun Homoran crunchip 3 Replies Last reply Reply Quote 0
                                    erledigt sein.
                                    Da könnte aber noch Zeug im npm cache hängen und von dort wiederherstellt werden. Hatte so ein Phänomen die Tage (allerdings in einem leicht anderen Zusammenhang).
                                      das hatte ich vermutet / Zwei parallele Installationen
                                      @thomas-braun sagte in ioBroker.admin 5.1.25. Blockly nur mit alter GUI.:
                                      aber doch nicht die Pfade zum Repo?
                                      Ansonsten hilft ein
                                      cd/opt/iobroker
                                      npm cache clean --force
                                        @nitrox9 nein, es ist verwunderlich, das du versionen aus dem latest hast, dein repo auf default steht und zu gleich keine Ausgabe hergibt.
                                        ich persönlich würde den discover adapter aussen vor lassen und deine Geräte manuell nach und nach einrichten, bzw wenn du discover verwenden möchtet, dann Stück für Stück und nicht alles was dir angezeigt wird, gleich aktivieren. Da passieren nämlich hier und da, blöde Dinge, w.z.b. Geräte/Instanzen doppelt angelegt werden.
                                          Das wäre auch mein nächster Vorschlag, wenn wir eine saubere Basis haben
                                          • N
                                            nitrox9 @Homoran last edited by
                                            @homoran said in ioBroker.admin 5.1.25. Blockly nur mit alter GUI.:
                                            Vielen Dank für all den Support.
                                            Werde dann alles nochmal ganz neu als Minimalkonfig aufsetzen. Nur MQTT, FHEM, VIS und Blockly wird benötigt.
                                            Mir ging es hier in dieser Rubrik auch darum einen Fehler zwecks Verbesserung aufzuzeigen. Aber offensichtlich ist hier kein Bug im engen Sinne vorhanden.
                                            Grüße!
                                            2220
