    4. web.0 fehler im log (alias)
      liv-in-sky last edited by liv-in-sky
      habe diese fehler von web-adapter, bei denen ein problem mit einem alias sein soll - das alias funktioniert
      hat jmd eine idee dazu ?
      web.1
      	2021-11-16 18:39:00.928	error	Alias subscription error. Please check your alias definitions: sourceId=fritzdect.0.DECT_119610651024.battery, sourceObj={"type":"state","common":{"name":"battery status","type":"number","min":0,"max":100,"unit":"%","read":true,"write":false,"role":"value","desc":"battery status"},"native":{},"from":"system.adapter.fritzdect.0","user":"system.user.admin","ts":1611662566145,"_id":"fritzdect.0.DECT_119610651024.battery","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      web.1
      	2021-11-16 18:39:00.927	error	Alias subscription error. Please check your alias definitions: sourceId=fritzdect.0.DECT_119610651024.tist, sourceObj={"type":"state","common":{"name":"Actual temperature","type":"number","min":0,"max":32,"unit":"°C","read":true,"write":false,"role":"value","desc":"Actual temperature"},"native":{},"from":"system.adapter.fritzdect.0","user":"system.user.admin","ts":1611662566136,"_id":"fritzdect.0.DECT_119610651024.tist","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      web.1
      	2021-11-16 18:39:00.915	error	Alias subscription error. Please check your alias definitions: sourceId=fritzdect.0.DECT_119610651024.tsoll, sourceObj={"type":"state","common":{"name":"Setpoint Temperature","type":"number","min":0,"max":32,"unit":"°C","read":true,"write":true,"role":"value.temperature","desc":"Setpoint Temperature"},"native":{},"from":"system.adapter.fritzdect.0","user":"system.user.admin","ts":1611662566136,"_id":"fritzdect.0.DECT_119610651024.tsoll","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
        crunchip Forum Testing Most Active @liv-in-sky last edited by crunchip
        @liv-in-sky so eine Meldung hatte ich gester auch bemerkt, jedoch nicht weiter verfolgt, trat bisher erst einmal auf und weiss auch gerade nicht mehr was ich da gemacht hatte, glaube zu meinen, es kam nach einem Adapter Update, welcher mit alias jedoch nichts zu tun hat
        War auch nur ein alias betroffen in dieser Meldung, den ich mal mit dem Adapter Geräte verwalten angelegt hatte.
          habe das mal auf git gepostet
          https://github.com/ioBroker/ioBroker.web/issues/159
          liv-in-sky created this issue in ioBroker/ioBroker.web
          closed alias error in log #159
