    4. Test Coronavirus Statistics for ioBroker
      jlssmt @ChrisNett last edited by
      @christian-sandkaulen
      Puuuuuuuuuhhhhhh.
      Ne sollte eigentlich funktionieren...
      Restarte mal den Adapter und schau in die Logs ob du irgendwelche Warnings bekommst.
      Sonst weiß ich grad nicht weiter. Vllt mal Adapter löschen und neu installieren.
      ChrisNett 1 Reply Last reply Reply Quote 0
      • ChrisNett
        ChrisNett @jlssmt last edited by
        @jlssmt sagte in Test Coronavirus Statistics for ioBroker:
        Puuuuuuuuuhhhhhh.
        coronavirus-statistics.0	2021-10-27 11:01:13.046	info	(5130) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
        coronavirus-statistics.0	2021-10-27 11:00:32.943	warn	(5130) [germanyBundesland] Unable to contact api.corona-zahlen.org : Error: Request failed with status code 502
        coronavirus-statistics.0	2021-10-27 11:00:04.576	info	(5130) starting. Version 0.8.3 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.5, js-controller: 3.3.18
        coronavirus-statistics.0	2021-10-27 10:59:58.408	info	(4962) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
        coronavirus-statistics.0	2021-10-27 10:59:21.227	warn	(4962) [germanyBundesland] Unable to contact api.corona-zahlen.org : Error: Request failed with status code 502
        coronavirus-statistics.0	2021-10-27 10:59:03.250	info	(4962) starting. Version 0.8.3 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.5, js-controller: 3.3.18
        coronavirus-statistics.0	2021-10-27 10:45:19.929	info	(1225) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
        coronavirus-statistics.0	2021-10-27 10:45:10.604	info	(1016) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
        mal ein log, ich habe mal eine 2. Instanz installiert mal sehen was die macht.
        • ChrisNett
          ChrisNett @ChrisNett last edited by
          b35866b9-139f-4683-b990-e1c5aa8adf1c-image.png @christian-sandkaulen
          die Impfungen habe ich jetzt schon mal...
            Die zwei Warnings bekommen wir hoffentlich mit der 0.8.4 raus.
            Aber sonst sieht es bei dir eigentlich gut aus.
            Mir fällt da ehrlich gesagt nichts ein, außer Adapter zu löschen und die Stable heute Nachmittag zu installieren.
            Vllt weiß @Dutchman noch was, was im ioBroker falsch sein könnte, da bin ich nicht so tief drin. Der Adapter selbst sollte eigentlich funktionieren.
            Zu deinem zweiten Screenshot:
            Die Impfungen sind jetzt aus der zweiten Instanz? Installier mal bitte die 0.8.4
            Aber eigentlich sollten auch in der 0.8.3 die Krankenhausdaten da sein.
            Hier mein Screenshot mit 0.8.4
            • Dutchman
              Dutchman Developer Most Active Administrators @jlssmt last edited by Dutchman
              nein, die waren erst ab der 0.8.4-0 dabei (wobei -0 bzw -X Nummer die alpha Versionen sind)
              Changelog
              0.8.4 (2021-10-26)
              (DutchmanNL) Bugfix: New DNS entry for COVID api
              (jlssmt) Hospital data for Germany added
              (jlssmt) fix umlauts in hospital service
              (jlssmt) extend api timer to fix 502 errors
              0.8.3 (2021-08-20)
              (jlssmt) Code refactoring
              (DutchmanNL) Bugfix: Unwanted deletion of data points for Germany solved
              ChrisNett 1 Reply Last reply Reply Quote 1
              • ChrisNett
                ChrisNett @Dutchman last edited by
                @dutchman sagte in Test Coronavirus Statistics for ioBroker:
                Changelog
                0.8.4 (2021-10-26)
                0.8.3 (2021-08-20)
                danke dann warte ich mal bis heute abend. über github geht es bei mir gerade irgtnwie nicht
                  Ah sorry. Zu viele releases und zu lange her 😄
                    sigi234 Forum Testing Most Active @Dutchman last edited by sigi234
                    @dutchman
                    Hallo, die Warn kommt immer
                    2021-11-17 10:14:42.439	warn	State attribute definition missing for daily_people_vaccinated_per_hundred
                    2021-11-17 10:14:42.439	debug	Create_state called for : United_Kingdom.Vaccination.daily_people_vaccinated_per_hundred with value : 0.067
                    2021-11-17 10:14:42.383	debug	Write value : false
                    2021-11-17 10:14:42.383	warn	State attribute definition missing for daily_people_vaccinated
                    2021-11-17 10:14:42.383	debug	Create_state called for : United_Kingdom.Vaccination.daily_people_vaccinated with value : 45681
                    Version 0.8.6 in C:/Program Files/iobroker/Home/node_modules/iobroker.coronavirus-statistics, node: v12.22.7, js-controller: 3.3.18
                    • Dutchman
                      Dutchman Developer Most Active Administrators @sigi234 last edited by
                      @sigi234 sagte in Test Coronavirus Statistics for ioBroker:
                      @dutchman
                      machste mir bitte n issue ? wohl was neues in der API
                        @dutchman
                        https://github.com/DrozmotiX/ioBroker.coronavirus-statistics/issues/331
                        sigi2345 created this issue in DrozmotiX/ioBroker.coronavirus-statistics
                        closed Warmmeldungen State attribute definition missing #331
                        • Dutchman
                          @dutchman
                          thank, habe neue version auf git geschoben please try 🙂
                            Warnung ist weg. 👍
                            • Dutchman
                              Warnung ist weg. 👍
                              Danke fürs schnelle testen, fix geht Direkt heute nach stable
                              blue231181 1 Reply Last reply Reply Quote 0
                              • blue231181
                                blue231181 @Dutchman last edited by
                                @dutchman
                                Hallo zusammen, wird der Hospitalisierungs Index auch als DP ausgegeben? (Aus aktuellen Anlass….)
                                Beste Grüße
                                  jlssmt @blue231181 last edited by
                                  @blue231181
                                  Haben sich die Bundesländer mittlerweile auf eine deutschlandweite Regelung geeinigt? (Ich weiß es wirklich nicht)
                                  Bis das nicht passiert ist, nein.
                                  • blue231181
                                    blue231181 @jlssmt last edited by
                                    @jlssmt
                                    Ja soweit ich die Medien verfolgt habe ist der Hospitalisierungs Index unsere neue Richtlinie (korrigiert mich bitte falls ich falsch liege)
                                      @blue231181
                                      Ist das die 7-Tage-Inzidenz für Krankenhauseinlieferungen?
                                      Wie berechnet der sich denn?
                                      Gilt der dann pro Bundesland?
                                      blue231181 1 Reply Last reply Reply Quote 1
                                      • blue231181
                                        @jlssmt
                                        Ja der gilt pro Bundesland
                                        Die Hospitalisierungsrate oder auch Hospitalisierungsinzidenz gibt an, wie viele der mit COVID-19 Erkrankten pro 100.000 Einwohnern ins Krankenhaus eingewiesen wurden. Als Grundlage dienen die Krankenhauseinweisungen der letzten sieben Tage.
                                        Eventuell gibt es ja diesen DP?
                                          @blue231181
                                          Ne. Den gibts nicht. Und um den zu berechnen müssten wir eine Historie für die letzten sieben Tage mit den Einlieferungen aufbauen.
                                          Für die Einlieferungen habe ich jedoch keine Datenquelle...
                                          Wenn du mir eine API zeigst, können wir das gerne einpflegen. Ich denke aber nicht, dass das so schnell geht. Die Mühlen mahlen sehr langsam...
                                          blue231181 Homoran 2 Replies Last reply Reply Quote 1
                                          • blue231181
                                            @jlssmt
                                            Ach du bist mit an der Entwicklung beteiligt?
                                            Dann mal ein Riesen großes Kompliment an die Zeit und Mühe die Ihr Investiert.
                                            Ich nutz den Adapter seit 1,5 Jahren täglich und finde es einen sinnvollsten überhaupt
                                            Also vielen Dank und allen Respekt 😃
                                            J Chaot 2 Replies Last reply Reply Quote 0
                                            adapter installation adapterentwicklung testen
                                            120
                                            1177
                                            328504
