    4. Test Adapter BMW/Mini v2.0.0
      Jogi19 @Thomas Braun last edited by
      @thomas-braun hier ist mal der komplette Start.
      wie bekommt man das mit den CodeTags hin?
      2021-11-17 19:39:55.469 error {"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
      bmw.0
      2021-11-17 19:39:55.469 error Error: Request failed with status code 400
      bmw.0
      2021-11-17 19:39:55.369 error {"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
      bmw.0
      2021-11-17 19:39:55.275 debug {"redirect_to":"redirect_uri=com.bmw.connected://oauth?client_id=31c357a0-7a1d-4590-aa99-33b97244d048&response_type=code&scope=openid profile email offline_access smacc vehicle_data perseus dlm svds cesim vsapi remote_services fupo authenticate_user&state=cEG9eLAIi6Nv-aaCAniziE_B6FPoobva3qr5gukilYw&authorization=hsHv0G6SWObZiUAfnVqfBiso6JA.AAJTSQACMDIAAlNLABxmRmJkUWVwNWx3S2lzQUJkZDRQbWtlbnlDUnc9AAR0eXBlAANDVFMAAlMxAAIwMQ.."}
      bmw.0
      2021-11-17 19:39:55.068 info starting. Version 2.4.1 in /opt/iobroker/node_modules/iobroker.bmw, node: v12.22.7, js-controller: 3.3.19
      bmw.0
      2021-11-17 19:39:54.958 debug Plugin sentry Initialize Plugin (enabled=true)
      bmw.0
      2021-11-17 19:39:54.902 debug statesDB connected
      bmw.0
      2021-11-17 19:39:54.902 debug States connected to redis: 127.0.0.1:6379
      bmw.0
      2021-11-17 19:39:54.900 debug States create User PubSub Client
      bmw.0
      2021-11-17 19:39:54.899 debug States create System PubSub Client
      bmw.0
      2021-11-17 19:39:54.897 debug Redis States: Use Redis connection: 127.0.0.1:6379
      bmw.0
      2021-11-17 19:39:54.896 debug objectDB connected
      bmw.0
      2021-11-17 19:39:54.893 debug Objects connected to redis: 127.0.0.1:6379
      bmw.0
      2021-11-17 19:39:54.885 debug Objects client initialize lua scripts
      bmw.0
      2021-11-17 19:39:54.885 debug Objects create User PubSub Client
      bmw.0
      2021-11-17 19:39:54.884 debug Objects create System PubSub Client
      bmw.0
      2021-11-17 19:39:54.884 debug Objects client ready ... initialize now
      bmw.0
      2021-11-17 19:39:54.873 debug Redis Objects: Use Redis connection: 127.0.0.1:6379
        Thomas Braun Most Active @Jogi19 last edited by
        @jogi19
        </> Icon anklicken, Text zwischen die Steuerzeichen kopieren.
          bmw.0
          bmw.0
          bmw.0
          2021-11-17 19:39:55.275	debug	{"redirect_to":"redirect_uri=com.bmw.connected://oauth?client_id=31c357a0-7a1d-4590-aa99-33b97244d048&response_type=code&scope=openid profile email offline_access smacc vehicle_data perseus dlm svds cesim vsapi remote_services fupo authenticate_user&state=cEG9eLAIi6Nv-aaCAniziE_B6FPoobva3qr5gukilYw&authorization=hsHv0G6SWObZiUAfnVqfBiso6JA.*AAJTSQACMDIAAlNLABxmRmJkUWVwNWx3S2lzQUJkZDRQbWtlbnlDUnc9AAR0eXBlAANDVFMAAlMxAAIwMQ..*"}
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          bmw.0
            tombox @Jogi19 last edited by
            @jogi19 hast du dich bei der bmw App mal ausgeloggt und wieder eingeloggt ?
            J M 2 Replies Last reply Reply Quote 0
              Jogi19 @tombox last edited by
              @tombox
              bei mir ist das Problem aufgetreten, nachdem ich das js Update auf 3.3.19 durchgeführt hatte und ioBroker wieder gestartet ist. Ich bin dann in die myBMW APP gegangen und muste dort wieder alle Haken bei den Datenschutzbedingungen setzen. Ich glaube es gab ein neues Update der APP. Ich habe mich gerade nochmal in der APP neu angemeldet. Das funktioniert, der Adapter bringt aber noch den gleichen Fehler.
              • bahnuhr
                bahnuhr Forum Testing Most Active @Jogi19 last edited by
                @jogi19 sagte in Test Adapter BMW v2.0.0:
                Update auf 3.3.19
                warum 3.3.19
                stable ist 3.3.18
                  Jogi19 @bahnuhr last edited by
                  @bahnuhr Du magst ja Recht haben, aber nun bin ich ja nicht der Einzige und nicht der Erste der den Fehler gemeldet hat. Nun wäre mal interessant, ob die anderen auch 3.3.19 installiert haben und der Fehler daran liegt, oder ob sich nach dem Update der myBMW APP und einem anschließenden Adapterstart bemerkbar macht. Wenn es an 3.3.19 liegt könnte ich einfach das Backup der Proxmox VM zurück spielen.
                  M M F 3 Replies Last reply Reply Quote 0
                    Magoo @Jogi19 last edited by
                    Ich nutze 3.3.15 als Version, aufgrund Faulheitsgründen 🙂
                    Mit der myBMW App habe ich schon ausprobiert, ohne Erfolg.
                      Thomas Braun Most Active @Magoo last edited by
                      @magoo sagte in Test Adapter BMW v2.0.0:
                      Das ist kein Grund.
                        manny4566 @tombox last edited by
                        @tombox
                        Hier nochmal mein Logfile.
                        Sieht bestimmt ähnlich aus:
                        bmw.0
                        	2021-11-17 20:55:02.935	error	{"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
                        bmw.0
                        	2021-11-17 20:55:02.934	error	Error: Request failed with status code 400
                        bmw.0
                        	2021-11-17 20:55:02.785	error	{"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
                        bmw.0
                        	2021-11-17 20:55:02.620	debug	{"redirect_to":"redirect_uri=com.bmw.connected://oauth?client_id=31c357a0-7a1d-4590-aa99-33b97244d048&response_type=code&scope=openid profile email offline_access smacc vehicle_data perseus dlm svds cesim vsapi remote_services fupo authenticate_user&state=cEG9eLAIi6Nv-aaCAniziE_B6FPoobva3qr5gukilYw&authorization=zNW8ddy_ui_7u99INO08nvR54VA.*AAJTSQACMDIAAlNLABx2OW14NkdWWnlDNnpWUUNJNmFmUzdZVnVmdW89AAR0eXBlAANDVFMAAlMxAAIwMQ..*"}
                        bmw.0
                        	2021-11-17 20:55:01.833	info	starting. Version 2.4.1 in /opt/iobroker/node_modules/iobroker.bmw, node: v12.22.7, js-controller: 3.3.18
                        bmw.0
                        	2021-11-17 20:55:01.750	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                        bmw.0
                        	2021-11-17 20:55:01.718	debug	Plugin sentry Initialize Plugin (enabled=true)
                        bmw.0
                        bmw.0
                        	2021-11-17 20:55:00.853	debug	statesDB connected
                        bmw.0
                        	2021-11-17 20:55:00.851	debug	States connected to redis: 127.0.0.1:9000
                        bmw.0
                        	2021-11-17 20:55:00.818	debug	States create User PubSub Client
                        bmw.0
                        	2021-11-17 20:55:00.816	debug	States create System PubSub Client
                        bmw.0
                        	2021-11-17 20:55:00.785	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                        bmw.0
                        	2021-11-17 20:55:00.782	debug	objectDB connected
                        bmw.0
                        	2021-11-17 20:55:00.771	debug	Objects connected to redis: 127.0.0.1:9001
                        bmw.0
                        	2021-11-17 20:55:00.727	debug	Objects client initialize lua scripts
                        bmw.0
                        	2021-11-17 20:55:00.726	debug	Objects create User PubSub Client
                        bmw.0
                        	2021-11-17 20:55:00.724	debug	Objects create System PubSub Client
                        bmw.0
                        	2021-11-17 20:55:00.720	debug	Objects client ready ... initialize now
                        bmw.0
                        	2021-11-17 20:55:00.660	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                          manny4566 @Jogi19 last edited by
                          @jogi19 said in Test Adapter BMW v2.0.0:
                          myBMW APP
                          An dem mit der myBMW APP könnte was dran sein.
                          Hab das gleiche auch erst vor paar Tagen gemacht. Mich dort angemeldet und die Bedingungen akzeptiert.
                            fwT26 @Jogi19 last edited by
                            @jogi19 Habe stable 3.3.18 und bis heute morgen hat 2.4.1 funktioniert
                            2021-11-17 19:07:06.046 - info: host.iobroker instance system.adapter.bmw.0 started with pid 25021
                            2021-11-17 19:07:06.868 - info: bmw.0 (25021) starting. Version 2.4.1 in /opt/iobroker/node_modules/iobroker.bmw, node: v12.22.2, js-controller: 3.3.18
                            2021-11-17 19:07:07.176 - error: bmw.0 (25021) {"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
                            2021-11-17 19:07:07.283 - error: bmw.0 (25021) Error: Request failed with status code 400
                            2021-11-17 19:07:07.284 - error: bmw.0 (25021) {"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
                            • bahnuhr
                              bahnuhr Forum Testing Most Active last edited by bahnuhr
                              Ha, das ist der Hammer.
                              Habe eben mal den bmw Adapter neu gestartet. Und jetzt kommt der Fehler bei mir auch:
                              bmw.0
                              2021-11-17 21:16:15.669	error	{"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
                              bmw.0
                              2021-11-17 21:16:15.668	error	Error: Request failed with status code 400
                              bmw.0
                              2021-11-17 21:16:15.551	error	{"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
                              Äußerst ärgerlich das ganze nun.
                              Bitte prüfen.
                              Nachtrag:
                              Und der Adpater bleibt gelb.
                              F bahnuhr M 3 Replies Last reply Reply Quote 0
                                fwT26 @bahnuhr last edited by
                                @bahnuhr Ja genau, bei mir nach restart auch gelb
                                • bahnuhr
                                  bahnuhr Forum Testing Most Active @bahnuhr last edited by
                                  Im debug kommt noch:
                                  bmw.0
                                  2021-11-17 21:25:27.234	error	{"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
                                  bmw.0
                                  2021-11-17 21:25:27.233	error	Error: Request failed with status code 400
                                  bmw.0
                                  2021-11-17 21:25:27.188	error	{"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
                                  bmw.0
                                  2021-11-17 21:25:27.119	debug	{"redirect_to":"redirect_uri=com.bmw.connected://oauth?client_id=31c357a0-7a1d-4590-aa99-33xxxxxx&response_type=code&scope=openid profile email offline_access smacc vehicle_data perseus dlm svds cesim vsapi remote_services fupo authenticate_user&state=cEG9eLAIi6Nv-aaCAniziE_B6FPoobva3qr5gukilYw&authorization=fX7MypPgrL_FKrljWXPvAQrJNUE.*AAJTSQACMDIAAlNLABxjQjRxd2RoQWkxRzRIWEkvxxxxxxxxxxxxxxxxxxIwMQ..*"}
                                  (debug code hab ich teilweise x eingefügt)
                                    manny4566 @bahnuhr last edited by
                                    @bahnuhr
                                    Jo, hab es heute auch nach dem Neustart bemerkt. Da passt etwas nicht mehr. Meine VIS hat jetzt keine BMW Infos mehr -.- ... Weltuntergang 😄
                                      tombox @manny4566 last edited by
                                      @manny4566
                                      Mit v2.5.0 wurde der neue Loginprozess übernommen.
                                      Einfach via github installieren oder auf das Update warten
                                      M F bahnuhr M S 6 Replies Last reply Reply Quote 7
                                        Magoo @tombox last edited by
                                        @tombox
                                        Perfekt mit 2.5.0 läuft es wieder!!!
                                        Danke an alle für den schnellen Fix.
                                          fwT26 @tombox last edited by
                                          @tombox
                                          Vielen Dank für das schnelle Update, mit 2.5.0 alles wieder OK !
                                          • bahnuhr
                                            bahnuhr Forum Testing Most Active @tombox last edited by
                                            @tombox
                                            Auch Bestätigung von mir. Läuft wieder.
                                            Danke schön.
                                            Jetzt kann ich die Standheizung wieder über VIS starten.
                                            674
                                            150702
