    4. Test Adapter BMW/Mini v2.0.0
      Thomas Braun Most Active @Magoo last edited by
      @magoo sagte in Test Adapter BMW v2.0.0:
      aufgrund Faulheitsgründen
      Das ist kein Grund.
        manny4566 @tombox last edited by
        @tombox
        Hier nochmal mein Logfile.
        Sieht bestimmt ähnlich aus:
        bmw.0
        	2021-11-17 20:55:02.935	error	{"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
        bmw.0
        	2021-11-17 20:55:02.934	error	Error: Request failed with status code 400
        bmw.0
        	2021-11-17 20:55:02.785	error	{"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
        bmw.0
        	2021-11-17 20:55:02.620	debug	{"redirect_to":"redirect_uri=com.bmw.connected://oauth?client_id=31c357a0-7a1d-4590-aa99-33b97244d048&response_type=code&scope=openid profile email offline_access smacc vehicle_data perseus dlm svds cesim vsapi remote_services fupo authenticate_user&state=cEG9eLAIi6Nv-aaCAniziE_B6FPoobva3qr5gukilYw&authorization=zNW8ddy_ui_7u99INO08nvR54VA.*AAJTSQACMDIAAlNLABx2OW14NkdWWnlDNnpWUUNJNmFmUzdZVnVmdW89AAR0eXBlAANDVFMAAlMxAAIwMQ..*"}
        bmw.0
        	2021-11-17 20:55:01.833	info	starting. Version 2.4.1 in /opt/iobroker/node_modules/iobroker.bmw, node: v12.22.7, js-controller: 3.3.18
        bmw.0
        	2021-11-17 20:55:01.750	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        bmw.0
        	2021-11-17 20:55:01.718	debug	Plugin sentry Initialize Plugin (enabled=true)
        bmw.0
        bmw.0
        	2021-11-17 20:55:00.853	debug	statesDB connected
        bmw.0
        	2021-11-17 20:55:00.851	debug	States connected to redis: 127.0.0.1:9000
        bmw.0
        	2021-11-17 20:55:00.818	debug	States create User PubSub Client
        bmw.0
        	2021-11-17 20:55:00.816	debug	States create System PubSub Client
        bmw.0
        	2021-11-17 20:55:00.785	debug	Redis States: Use Redis connection: 127.0.0.1:9000
        bmw.0
        	2021-11-17 20:55:00.782	debug	objectDB connected
        bmw.0
        	2021-11-17 20:55:00.771	debug	Objects connected to redis: 127.0.0.1:9001
        bmw.0
        	2021-11-17 20:55:00.727	debug	Objects client initialize lua scripts
        bmw.0
        	2021-11-17 20:55:00.726	debug	Objects create User PubSub Client
        bmw.0
        	2021-11-17 20:55:00.724	debug	Objects create System PubSub Client
        bmw.0
        	2021-11-17 20:55:00.720	debug	Objects client ready ... initialize now
        bmw.0
        	2021-11-17 20:55:00.660	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
          manny4566 @Jogi19 last edited by
          @jogi19 said in Test Adapter BMW v2.0.0:
          myBMW APP
          An dem mit der myBMW APP könnte was dran sein.
          Hab das gleiche auch erst vor paar Tagen gemacht. Mich dort angemeldet und die Bedingungen akzeptiert.
            fwT26 @Jogi19 last edited by
            @jogi19 Habe stable 3.3.18 und bis heute morgen hat 2.4.1 funktioniert
            2021-11-17 19:07:06.046 - info: host.iobroker instance system.adapter.bmw.0 started with pid 25021
            2021-11-17 19:07:06.868 - info: bmw.0 (25021) starting. Version 2.4.1 in /opt/iobroker/node_modules/iobroker.bmw, node: v12.22.2, js-controller: 3.3.18
            2021-11-17 19:07:07.176 - error: bmw.0 (25021) {"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
            2021-11-17 19:07:07.283 - error: bmw.0 (25021) Error: Request failed with status code 400
            2021-11-17 19:07:07.284 - error: bmw.0 (25021) {"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
            • bahnuhr
              bahnuhr Forum Testing Most Active last edited by bahnuhr
              Ha, das ist der Hammer.
              Habe eben mal den bmw Adapter neu gestartet. Und jetzt kommt der Fehler bei mir auch:
              bmw.0
              2021-11-17 21:16:15.669	error	{"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
              bmw.0
              2021-11-17 21:16:15.668	error	Error: Request failed with status code 400
              bmw.0
              2021-11-17 21:16:15.551	error	{"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
              Äußerst ärgerlich das ganze nun.
              Bitte prüfen.
              Nachtrag:
              Und der Adpater bleibt gelb.
              F bahnuhr M 3 Replies Last reply Reply Quote 0
                fwT26 @bahnuhr last edited by
                @bahnuhr Ja genau, bei mir nach restart auch gelb
                • bahnuhr
                  bahnuhr Forum Testing Most Active @bahnuhr last edited by
                  Im debug kommt noch:
                  bmw.0
                  2021-11-17 21:25:27.234	error	{"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
                  bmw.0
                  2021-11-17 21:25:27.233	error	Error: Request failed with status code 400
                  bmw.0
                  2021-11-17 21:25:27.188	error	{"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
                  bmw.0
                  2021-11-17 21:25:27.119	debug	{"redirect_to":"redirect_uri=com.bmw.connected://oauth?client_id=31c357a0-7a1d-4590-aa99-33xxxxxx&response_type=code&scope=openid profile email offline_access smacc vehicle_data perseus dlm svds cesim vsapi remote_services fupo authenticate_user&state=cEG9eLAIi6Nv-aaCAniziE_B6FPoobva3qr5gukilYw&authorization=fX7MypPgrL_FKrljWXPvAQrJNUE.*AAJTSQACMDIAAlNLABxjQjRxd2RoQWkxRzRIWEkvxxxxxxxxxxxxxxxxxxIwMQ..*"}
                  (debug code hab ich teilweise x eingefügt)
                    manny4566 @bahnuhr last edited by
                    @bahnuhr
                    Jo, hab es heute auch nach dem Neustart bemerkt. Da passt etwas nicht mehr. Meine VIS hat jetzt keine BMW Infos mehr -.- ... Weltuntergang 😄
                      tombox @manny4566 last edited by
                      @manny4566
                      Mit v2.5.0 wurde der neue Loginprozess übernommen.
                      Einfach via github installieren oder auf das Update warten
                      M F bahnuhr M S 6 Replies Last reply Reply Quote 7
                        Magoo @tombox last edited by
                        @tombox
                        Perfekt mit 2.5.0 läuft es wieder!!!
                        Danke an alle für den schnellen Fix.
                          fwT26 @tombox last edited by
                          @tombox
                          Vielen Dank für das schnelle Update, mit 2.5.0 alles wieder OK !
                          • bahnuhr
                            bahnuhr Forum Testing Most Active @tombox last edited by
                            @tombox
                            Auch Bestätigung von mir. Läuft wieder.
                            Danke schön.
                            Jetzt kann ich die Standheizung wieder über VIS starten.
                            • bahnuhr
                              @Magoo
                              @fwT26
                              Gebt @tombox doch einen Daumen nach oben.
                              War doch super Arbeit.
                                @tombox
                                Klappt, super Danke
                                  @tombox
                                  auch von mir ein Dankeschön für die schnelle Problemlösung.
                                    kkickingereder @bahnuhr last edited by
                                    @bahnuhr triggerst du diese Datenpunkte?
                                    Standheizung an dann einfach auf TRUE (1)
                                    • bahnuhr
                                      bahnuhr Forum Testing Most Active @kkickingereder last edited by
                                      @kkickingereder
                                      ja, einfach auf true.
                                      setState('bmw.0.WBA5D11010G293605.remotev2.climate-now_START', true);
                                        jm3west last edited by jm3west
                                        Tach,
                                        wo kann ich sehen/auslesen ob das Fahrzeug verriegelt oder entriegelt ist?
                                        Mit dem doorGeneralState funktioniert dass nicht!
                                        Ich habe mal den Datenpunkt mittels Debug > Wert von Objekt-ID ausgelesen ...
                                        ... da steht ja "EntriegeltVerriegelt" drin
                                        Deshalb funktioniert auch meine Bedingung nicht
                                          Strobelix @jm3west last edited by
                                          @jm3west unter properties „aredoorslocked“
                                            stenmic @tombox last edited by
                                            @tombox hi,
                                            seit dem letzten Update der App wird bei mir der Reifendruck angezeigt.
                                            Kann der Adapter auch die Werte auslesen?
                                            672
                                            147258
