    4. Test Adapter BMW/Mini v2.0.0
      manny4566 @Jogi19 last edited by
      @jogi19 said in Test Adapter BMW v2.0.0:
      myBMW APP
      An dem mit der myBMW APP könnte was dran sein.
      Hab das gleiche auch erst vor paar Tagen gemacht. Mich dort angemeldet und die Bedingungen akzeptiert.
        fwT26 @Jogi19 last edited by
        @jogi19 Habe stable 3.3.18 und bis heute morgen hat 2.4.1 funktioniert
        2021-11-17 19:07:06.046 - info: host.iobroker instance system.adapter.bmw.0 started with pid 25021
        2021-11-17 19:07:06.868 - info: bmw.0 (25021) starting. Version 2.4.1 in /opt/iobroker/node_modules/iobroker.bmw, node: v12.22.2, js-controller: 3.3.18
        2021-11-17 19:07:07.176 - error: bmw.0 (25021) {"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
        2021-11-17 19:07:07.283 - error: bmw.0 (25021) Error: Request failed with status code 400
        2021-11-17 19:07:07.284 - error: bmw.0 (25021) {"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
        • bahnuhr
          bahnuhr Forum Testing Most Active last edited by bahnuhr
          Ha, das ist der Hammer.
          Habe eben mal den bmw Adapter neu gestartet. Und jetzt kommt der Fehler bei mir auch:
          bmw.0
          2021-11-17 21:16:15.669	error	{"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
          bmw.0
          2021-11-17 21:16:15.668	error	Error: Request failed with status code 400
          bmw.0
          2021-11-17 21:16:15.551	error	{"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
          Äußerst ärgerlich das ganze nun.
          Bitte prüfen.
          Nachtrag:
          Und der Adpater bleibt gelb.
          F bahnuhr M 3 Replies Last reply Reply Quote 0
            fwT26 @bahnuhr last edited by
            @bahnuhr Ja genau, bei mir nach restart auch gelb
            • bahnuhr
              bahnuhr Forum Testing Most Active @bahnuhr last edited by
              Im debug kommt noch:
              bmw.0
              2021-11-17 21:25:27.234	error	{"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
              bmw.0
              2021-11-17 21:25:27.233	error	Error: Request failed with status code 400
              bmw.0
              2021-11-17 21:25:27.188	error	{"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
              bmw.0
              2021-11-17 21:25:27.119	debug	{"redirect_to":"redirect_uri=com.bmw.connected://oauth?client_id=31c357a0-7a1d-4590-aa99-33xxxxxx&response_type=code&scope=openid profile email offline_access smacc vehicle_data perseus dlm svds cesim vsapi remote_services fupo authenticate_user&state=cEG9eLAIi6Nv-aaCAniziE_B6FPoobva3qr5gukilYw&authorization=fX7MypPgrL_FKrljWXPvAQrJNUE.*AAJTSQACMDIAAlNLABxjQjRxd2RoQWkxRzRIWEkvxxxxxxxxxxxxxxxxxxIwMQ..*"}
              (debug code hab ich teilweise x eingefügt)
                manny4566 @bahnuhr last edited by
                @bahnuhr
                Jo, hab es heute auch nach dem Neustart bemerkt. Da passt etwas nicht mehr. Meine VIS hat jetzt keine BMW Infos mehr -.- ... Weltuntergang 😄
                  tombox @manny4566 last edited by
                  @manny4566
                  Mit v2.5.0 wurde der neue Loginprozess übernommen.
                  Einfach via github installieren oder auf das Update warten
                  M F bahnuhr M S 6 Replies Last reply Reply Quote 7
                    Magoo @tombox last edited by
                    @tombox
                    Perfekt mit 2.5.0 läuft es wieder!!!
                    Danke an alle für den schnellen Fix.
                      fwT26 @tombox last edited by
                      @tombox
                      Vielen Dank für das schnelle Update, mit 2.5.0 alles wieder OK !
                      • bahnuhr
                        bahnuhr Forum Testing Most Active @tombox last edited by
                        @tombox
                        Auch Bestätigung von mir. Läuft wieder.
                        Danke schön.
                        Jetzt kann ich die Standheizung wieder über VIS starten.
                        • bahnuhr
                          @Magoo
                          @fwT26
                          Gebt @tombox doch einen Daumen nach oben.
                          War doch super Arbeit.
                            manny4566 @tombox last edited by
                            @tombox
                            Klappt, super Danke
                              @tombox
                              auch von mir ein Dankeschön für die schnelle Problemlösung.
                                kkickingereder @bahnuhr last edited by
                                @bahnuhr triggerst du diese Datenpunkte?
                                Standheizung an dann einfach auf TRUE (1)
                                • bahnuhr
                                  bahnuhr Forum Testing Most Active @kkickingereder last edited by
                                  @kkickingereder
                                  ja, einfach auf true.
                                  setState('bmw.0.WBA5D11010G293605.remotev2.climate-now_START', true);
                                    jm3west last edited by jm3west
                                    Tach,
                                    wo kann ich sehen/auslesen ob das Fahrzeug verriegelt oder entriegelt ist?
                                    Mit dem doorGeneralState funktioniert dass nicht!
                                    Ich habe mal den Datenpunkt mittels Debug > Wert von Objekt-ID ausgelesen ...
                                    ... da steht ja "EntriegeltVerriegelt" drin
                                    Deshalb funktioniert auch meine Bedingung nicht
                                      Strobelix @jm3west last edited by
                                      @jm3west unter properties „aredoorslocked“
                                        stenmic @tombox last edited by
                                        @tombox hi,
                                        seit dem letzten Update der App wird bei mir der Reifendruck angezeigt.
                                        Kann der Adapter auch die Werte auslesen?
                                          MSPtrs @tombox last edited by MSPtrs
                                          @tombox
                                          Moin BMW Adapter Gemeinde, 😄
                                          ich würde gerne den Ladestatus meines iX3 abfragen - das funktionier auch über diesen Adapter echt gut👍
                                          Ich lasse den Adapter automatisiert auch nur laufen, wenn das Auto angesteckt ist, aber trotz dessen wird etwa 18 Stunden am Tag alle 5 Minuten einmal der Ladestand abgefragt...
                                          Wäre das vielleicht möglich, per Blocky einen Datenpunkt oder so zu steuern, welcher das Abfrageintervall des Adapters reguliert? Wenn diese Funktion integriert ist, wäre das echt nett, wenn mir jemand diese zeigen würde, sodass ich nicht unnötig die BMW API belaste und somit mein Beitrag zur Nachhaltigkeit des Adapters beitrage✊
                                          Denn dann würde das Intervall nur auf 5 Min. stehen, wenn das Auto auch wirklich lädt und nicht nur eingesteckt ist.
                                          Schönen Advent
                                            lxs @tombox last edited by lxs
                                            @tombox
                                            Ich komme mir jetzt leider wie ein Spielverderber vor, aber bei mir ist der Fehler auch mit der 2.5.0 noch vorhanden:
                                            2021-12-20 09:20:00.783  - info: bmw.0 (4608) starting. Version 2.5.0 in /opt/iobroker/node_modules/iobroker.bmw, node: v12.22.7, js-controller: 3.3.21
                                            2021-12-20 09:20:01.147  - debug: bmw.0 (4608) {"redirect_to":"redirect_uri=com.bmw.connected://oauth?client_id=XXXXX48&response_type=code&scope=openid profile email offline_access smacc vehicle_data perseus dlm svds cesim vsapi remote_services fupo authenticate_user&state=cwU-gIEXXXXXXUcL3KQ&authorization=EvXXXXXXnA.*AXXXXXXXXwMQ..*"}
                                            2021-12-20 09:20:05.359  - error: bmw.0 (4608) "400 Bad Request"
                                            2021-12-20 09:20:05.514  - error: bmw.0 (4608) Error: Request failed with status code 400
                                            2021-12-20 09:20:05.515  - error: bmw.0 (4608) {"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
                                            Ich habe ein paar XXX eingefügt.
                                            Habe den Adapter bereits einmal gelöscht und neu installiert, hat aber leider nicht geholfen 😧
                                            Viele Grüße,
                                            Alexander
                                            lobomau 1 Reply Last reply Reply Quote 0
                                            674
                                            151246
