    4. Frage zum BackItUp-Adapter: Fehler nach Update auf 2.2.2.
      Thomas Braun Most Active @invidianer last edited by
      @invidianer
      Schau halt jetzt das Log an und mach ein manuelles Backup.
      iobroker logs --watch
      I 1 Reply Last reply Reply Quote 2
      • I
        invidianer @Thomas Braun last edited by invidianer
        Okay, habe wieder auf 2.2.2 upgedated und dann manuell die Sicherung angestoßen. Bei "Packed 0MB so far ..." bleibt er hängen:
        Started iobroker ...
        [DEBUG] [mount] - mount activ... umount is started before mount!!
        [DEBUG] [mount] - umount successfully completed
        [DEBUG] [mount] - noserverino option: false
        [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=ioBroker_backup,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.2.1/fritzdg/ioBroker_backup /opt/iobroker/backups"
        [DEBUG] [mount] - mount successfully completed
        [DEBUG] [mount] - done
        [DEBUG] [iobroker] - host.raspberrypi 2468 states saved
        [DEBUG] [iobroker] - host.raspberrypi 2832 objects saved
        [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_11_18-08_32_28_backupiobroker.tar.gz
        [DEBUG] [iobroker] - done
        [DEBUG] [javascripts] - Try deleting the old javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
        [DEBUG] [javascripts] - old javascript_tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
        [DEBUG] [javascripts] - Created javascript_tmp directory
        [DEBUG] [javascripts] - found Script: Telegram_-_Stehlampe
        [DEBUG] [javascripts] - found Script: Telegram_-_Licht_Heizungskeller
        [DEBUG] [javascripts] - found Script: Waschmaschine_Stromversorgung
        [DEBUG] [javascripts] - found Script: Telegram_-_Waschmaschine_Stromversorgung
        [DEBUG] [javascripts] - found Script: Telegram_-_Geschirrspülmaschine_fertig
        [DEBUG] [javascripts] - found Script: Hifi_ausschalten
        [DEBUG] [javascripts] - found Script: Telegram_-_Anruf
        [DEBUG] [javascripts] - found Script: Telegram_-_TV
        [DEBUG] [javascripts] - found Script: Telegram_-_Tauchpumpe
        [DEBUG] [javascripts] - found Script: Telegram_-_Heizung
        [DEBUG] [javascripts] - found Script: Telegram_-_Kühlschrank
        [DEBUG] [javascripts] - found Script: Kaffeemaschine_ausschalten
        [DEBUG] [javascripts] - found Script: Telegram_-_Waschmaschine_fertig
        [DEBUG] [javascripts] - Packed 0MB so far...
        Thomas Braun J 2 Replies Last reply Reply Quote 0
          @invidianer
          Ist das eine Fritzbox, auf die da gesichert wird?
          Dann muss noserverino auf true gesetzt sein.
            Jan1 @invidianer last edited by Jan1
            @invidianer
            Macht er bei mir auch und der Ordner Scripte wird nicht angelegt.
            Allerdings klappt das wohl wenn er es nachts automatisch macht. Muss ich mal schauen, ob morgen alles wie gewünscht im Ordner liegt, wenn nicht, hast ein Bug gefunden 😉
            @Thomas-Braun
            so ist es, nur seit wann ist das und hats dazu ne Info gegeben?
            • I
              @thomas-braun sagte in Frage zum BackItUp-Adapter: Fehler nach Update auf 2.2.2.:
              @invidianer
              Das war es!! Danke!! Jetzt funktioniert es! Diese Option "Mount mit Option noserverinfo" gab es bei 2.1.17 noch nicht, oder? Zumindest hatte ich da nichts aktiviert und es ging ja.
              J Thomas Braun 2 Replies Last reply Reply Quote 0
                @invidianer
                Scheint so, da ich das ebenfalls so hatte und mir die Info zu dieser Option auch gefehlt hat.
                • I
                  invidianer @Jan1 last edited by
                  @jan1 sagte in Frage zum BackItUp-Adapter: Fehler nach Update auf 2.2.2.:
                  @invidianer
                  Danke für Bestätigung!
                    Thomas Braun Most Active @invidianer last edited by Thomas Braun
                    @invidianer @Jan1
                    Die Option gibt es seit dem Update des samba-Servers in der FritzBox.
                    Ist glaube ich mit FritzOS 7.2x eingeführt worden.
                    Steht in der ReadMe zum Backitup-Adapter aber auch drin:
                    Wenn eine Fritzbox als NAS mit einer Firmware >= 7.21 verwendet wird, sollten in Backitup die SMB-Einstellungen auf "3.1.1" eingestellt und die Option "noserverino" aktiviert werden.
                    • I
                      Hmm, komisch. Gestern (vor Update auf 2.2.2) hatte es noch funktioniert.
                      Wenn die Option bei 2.1.17 schon vorhanden war, ging es entweder auch mit nicht aktivierter oder sie war aktiviert und ist beim Update auf 2.2.2 rausgeflogen.
                        @invidianer sagte in Frage zum BackItUp-Adapter: Fehler nach Update auf 2.2.2.:
                        Es ging, aber nicht korrekt.
                        • I
                          Eine Fehlermeldung kam allerdings nie (es gab nur "positiv"-Meldungen per Telegram).
                            @invidianer
                            Ich meine, da müsste auch im Log irgendwas gestanden haben.
                            Ich hab das 'damals' mit @simatec jedenfalls ausbaldowert, kann mich aber nicht mehr erinnern was die Meldungen waren.
                            • I
                              Nochmal zu dem "Log": Es gibt doch nur das eine, welches im ioBroker-Frontend unter "Protokolle" einzusehen ist, oder?
                                @invidianer
                                Ja, das meine ich.
                                Wobei das besser in der Konsole angeschaut wird, die Darstellung unter 'Protokolle' ist suboptimal.
                                I J 2 Replies Last reply Reply Quote 1
                                • I
                                  Ok, danke!
                                  Darin stehen jedoch für die Sicherungen unter 2.1.17 tatsächlich keine Fehler. Diese wären mir sonst definitiv aufgefallen und zusätzlich kommt jede Nacht um 2:00 Uhr die Telegram-Meldung, daß die Sicherung erfolgreich war.
                                    Jan1 @Thomas Braun last edited by
                                    Mir ist es auch nur aufgefallen, weil ich eben mal ein Backup manuell gestartet hatte und dann einfach das Fenster nicht schließt, allerdings auch keine Fehlermeldung erscheint. Die Backups wurden aber schön auf der Fritz angelegt, somit ist das etwas verwirrend.
                                    OK, wenn es in der readme drin steht, könnte man das dort nachlesen, nur wenn ich vermeintlich kein Problem habe, lese ich die nicht aus reiner Neugier oder Langeweile 😉
                                    Aber auch egal, Problem erkannt und gelöst 🙂
                                    Thomas Braun I 2 Replies Last reply Reply Quote 1
                                      Thomas Braun Most Active @Jan1 last edited by
                                      @jan1 @invidianer
                                      Kann auch sein, dass es Meldungen seitens eines parallelen Backups auf Google Drive gab. Das greift ja auch auf das gemountete smb/cifs-Share zu.
                                      Ich weiß es aber nicht mehr.
                                      • I
                                        Ich habe es gemerkt, weil keine Telegram-Meldung zur Sicherung kam. Warum dies so war, weiß ich bisher nicht, aber da nun alles wieder funktioniert …
                                        • simatec
                                          simatec Developer Most Active @invidianer last edited by
                                          @invidianer @Jan1 @Thomas-Braun
                                          Für die Fritzbox mit aktueller Firmware ist definitiv die noserverino Option erforderlich. Andernfalls kann der tmp Ordner für einzelne Backuptypen nicht ordnungsgemäß angelegt werden.
                                          Dies ist auch mit 2.1.17 bereits so gewesen.
                                          Allerdings wurden durch Umstellungen in der Javascriptsicherung hier noch ein paar mehr Logs eingebaut.
                                          Ich gehe davon aus, dass in Version 2.1.17 hier ebenfalls ein Fehler auftrat, aber dieser nicht sauber gemeldet wurde.
                                            Jan1 @simatec last edited by Jan1
                                            @simatec
                                            Das ist gut möglich, da ich im Backup Ordner vorhin zwei Ordner drin hatte, die mir neu waren. Da ich die gelöscht habe ohne weiter drüber nachzudenken (es waren auch noch recht alte Backups da, die eigentlich auch hätten weg sein sollen), kann ich die nur aus dem Gedächtnis brennen.
                                            Müsste ein Script und ein temp.Script Ordner gewesen sein 😉
                                            Die sind nur nach dem gesetzten Haken und erneut ausgeführten Backup mit dem Adapter nicht mehr vorhanden.
                                            So sieht das nun wieder aus und so kenne ich das auch:
                                            simatec 1 Reply Last reply Reply Quote 1
                                            530
