    4. Test Coronavirus Statistics for ioBroker
    • Dutchman
      Dutchman Developer Most Active Administrators @jlssmt last edited by Dutchman
      @jlssmt sagte in Test Coronavirus Statistics for ioBroker:
      Aber eigentlich sollten auch in der 0.8.3 die Krankenhausdaten da sein.
      nein, die waren erst ab der 0.8.4-0 dabei (wobei -0 bzw -X Nummer die alpha Versionen sind)
      Changelog
      0.8.4 (2021-10-26)
      (DutchmanNL) Bugfix: New DNS entry for COVID api
      (jlssmt) Hospital data for Germany added
      (jlssmt) fix umlauts in hospital service
      (jlssmt) extend api timer to fix 502 errors
      0.8.3 (2021-08-20)
      (jlssmt) Code refactoring
      (DutchmanNL) Bugfix: Unwanted deletion of data points for Germany solved
      ChrisNett 1 Reply Last reply Reply Quote 1
      • ChrisNett
        ChrisNett @Dutchman last edited by
        @dutchman sagte in Test Coronavirus Statistics for ioBroker:
        Changelog
        0.8.4 (2021-10-26)
        0.8.3 (2021-08-20)
        danke dann warte ich mal bis heute abend. über github geht es bei mir gerade irgtnwie nicht
          jlssmt @ChrisNett last edited by
          Ah sorry. Zu viele releases und zu lange her 😄
            sigi234 Forum Testing Most Active @Dutchman last edited by sigi234
            @dutchman
            Hallo, die Warn kommt immer
            coronavirus-statistics.0
            2021-11-17 10:14:42.439	warn	State attribute definition missing for daily_people_vaccinated_per_hundred
            2021-11-17 10:14:42.439	debug	Create_state called for : United_Kingdom.Vaccination.daily_people_vaccinated_per_hundred with value : 0.067
            2021-11-17 10:14:42.383	debug	Write value : false
            2021-11-17 10:14:42.383	warn	State attribute definition missing for daily_people_vaccinated
            2021-11-17 10:14:42.383	debug	Create_state called for : United_Kingdom.Vaccination.daily_people_vaccinated with value : 45681
            Version 0.8.6 in C:/Program Files/iobroker/Home/node_modules/iobroker.coronavirus-statistics, node: v12.22.7, js-controller: 3.3.18
            • Dutchman
              Dutchman Developer Most Active Administrators @sigi234 last edited by
              @sigi234 sagte in Test Coronavirus Statistics for ioBroker:
              @dutchman
              machste mir bitte n issue ? wohl was neues in der API
                @dutchman
                https://github.com/DrozmotiX/ioBroker.coronavirus-statistics/issues/331
                sigi2345 created this issue in DrozmotiX/ioBroker.coronavirus-statistics
                closed Warmmeldungen State attribute definition missing #331
                • Dutchman
                  @dutchman
                  thank, habe neue version auf git geschoben please try 🙂
                    Warnung ist weg. 👍
                    • Dutchman
                      Warnung ist weg. 👍
                      Danke fürs schnelle testen, fix geht Direkt heute nach stable
                      blue231181 1 Reply Last reply Reply Quote 0
                      • blue231181
                        blue231181 @Dutchman last edited by
                        @dutchman
                        Hallo zusammen, wird der Hospitalisierungs Index auch als DP ausgegeben? (Aus aktuellen Anlass….)
                        Beste Grüße
                          jlssmt @blue231181 last edited by
                          @blue231181
                          Haben sich die Bundesländer mittlerweile auf eine deutschlandweite Regelung geeinigt? (Ich weiß es wirklich nicht)
                          Bis das nicht passiert ist, nein.
                          • blue231181
                            blue231181 @jlssmt last edited by
                            @jlssmt
                            Ja soweit ich die Medien verfolgt habe ist der Hospitalisierungs Index unsere neue Richtlinie (korrigiert mich bitte falls ich falsch liege)
                              @blue231181
                              Ist das die 7-Tage-Inzidenz für Krankenhauseinlieferungen?
                              Wie berechnet der sich denn?
                              Gilt der dann pro Bundesland?
                              blue231181 1 Reply Last reply Reply Quote 1
                              • blue231181
                                @jlssmt
                                Ja der gilt pro Bundesland
                                Die Hospitalisierungsrate oder auch Hospitalisierungsinzidenz gibt an, wie viele der mit COVID-19 Erkrankten pro 100.000 Einwohnern ins Krankenhaus eingewiesen wurden. Als Grundlage dienen die Krankenhauseinweisungen der letzten sieben Tage.
                                Eventuell gibt es ja diesen DP?
                                  @blue231181
                                  Ne. Den gibts nicht. Und um den zu berechnen müssten wir eine Historie für die letzten sieben Tage mit den Einlieferungen aufbauen.
                                  Für die Einlieferungen habe ich jedoch keine Datenquelle...
                                  Wenn du mir eine API zeigst, können wir das gerne einpflegen. Ich denke aber nicht, dass das so schnell geht. Die Mühlen mahlen sehr langsam...
                                  blue231181 Homoran 2 Replies Last reply Reply Quote 1
                                  • blue231181
                                    @jlssmt
                                    Ach du bist mit an der Entwicklung beteiligt?
                                    Dann mal ein Riesen großes Kompliment an die Zeit und Mühe die Ihr Investiert.
                                    Ich nutz den Adapter seit 1,5 Jahren täglich und finde es einen sinnvollsten überhaupt
                                    Also vielen Dank und allen Respekt 😃
                                    J Chaot 2 Replies Last reply Reply Quote 0
                                      @blue231181
                                      Kein Thema 😉
                                      Ich hab mich in den letzten Monaten ein bisschen reingeschmuggelt, ja.
                                      Für Bayern finde ich den Indexwert hier: https://www.lgl.bayern.de/gesundheit/infektionsschutz/infektionskrankheiten_a_z/coronavirus/karte_coronavirus/index.htm#kennzahlen
                                      Aber woher dort die Daten kommen, weiß keiner. Vmtl. aus einer Excel Tabelle, die per Fax vom Krankenhaus an das Ministerium geschickt wurde, welches dann wiederum alle Excel abtippen und zu einem Wert konsolidieren.
                                      Die Tabelle könnte ich verwenden, wollen wir aber nicht, weil wir das dann 16x machen müssten und bei jeder Änderung der Adapter nicht mehr funktioniert...
                                      • Chaot
                                        Chaot @blue231181 last edited by
                                        @blue231181 Ich orientiere mich an dem Prozentsatz der freien Betten. Das ist jetzt zwar nicht die offizielle Variante, aber aus früheren Zeiten weiß ich das ab 10% Restkapazität verschiedene Notfallpläne anlaufen. Ich denke mal das die hier vielleicht noch etwas verschoben haben, aber spätestens ab 5% brennt alles.
                                        Auch wenn auf Regierungsebene da vielleicht andere Zahlen konstruiert werden ist letztlich doch die verfügbare Kapazität das Maß der Dinge. Wenn 0% erreicht sind gibt es eben Tote auf der Straße (mal krass gesagt).
                                        • blue231181
                                          @jlssmt kann ich verstehen
                                          Dann einen schönen Gruß ans ganze Team und nochmal vielen Dank
                                          • blue231181
                                            blue231181 @Chaot last edited by
                                            @chaot danke, das wäre ne gute Alternative
                                            Ich teste das mal aus
                                            adapter installation adapterentwicklung testen
                                            120
                                            1177
                                            328555
