    4. Probleme TI Stick und Zigbee nach Neuinstallation
      toki1973 last edited by
      Hallo, ich habe eine neue VM parallel zur existierenden Proxmox VM aufgebaut und io broker installiert und die Backups iobroker und Zigbee eingespielt.
      Von den Objekten sieht alles soweit gut aus. Nur den TI-Stick bekomme ich nicht in Betrieb genommen. Ich habe in Proxmox wie hier abgebildet installiert:efe3fff7-70f5-4990-b9f0-fd269ec6223c-image.png
      Beim starten des Zigbee Adapter bekomme ich folgendes Log:
      zigbee.0
      2021-11-19 12:13:06.726	error	Error herdsman start
      zigbee.0
      2021-11-19 12:13:06.726	error	Failed to start Zigbee
      zigbee.0
      2021-11-19 12:13:06.725	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
      zigbee.0
      2021-11-19 12:13:06.604	info	Installed Version: iobroker.zigbee@1.6.6
      zigbee.0
      2021-11-19 12:13:06.584	debug	Starting zigbee-herdsman...
      zigbee.0
      2021-11-19 12:13:06.583	info	Starting Zigbee npm ...
      zigbee.0
      2021-11-19 12:13:06.582	info	Try to reconnect. 1 attempts left
      zigbee.0
      2021-11-19 12:12:56.580	error	Error herdsman start
      zigbee.0
      2021-11-19 12:12:56.580	error	Failed to start Zigbee
      zigbee.0
      2021-11-19 12:12:56.579	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
      zigbee.0
      2021-11-19 12:12:36.620	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2021_11_19-12_12_36.tar.gz success
      zigbee.0
      2021-11-19 12:12:36.613	info	Installed Version: iobroker.zigbee@1.6.6
      zigbee.0
      2021-11-19 12:12:36.072	debug	Starting zigbee-herdsman...
      zigbee.0
      2021-11-19 12:12:36.071	info	Starting Zigbee npm ...
      zigbee.0
      2021-11-19 12:12:36.028	debug	Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[15],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM1","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
      zigbee.0
      2021-11-19 12:12:35.995	info	starting. Version 1.6.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.7, js-controller: 3.3.19
      zigbee.0
      2021-11-19 12:12:35.986	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      zigbee.0
      2021-11-19 12:12:35.983	debug	Plugin sentry Initialize Plugin (enabled=true)
      Einstellungen im Adapter sind wie folgt:
      Die alte VM befindet sich im Pause Modus uns sollte somit den Port freigeben.
      Was kann ich denn noch prüfen?
      Danke!
        crunchip Forum Testing Most Active @toki1973 last edited by
        @toki1973 sagte in Probleme TI Stick und Zigbee nach Neuinstallation:
        mach es mit der Geräte ID und nicht per Port
          toki1973 @crunchip last edited by toki1973
          @crunchip Danke für die Rückmeldung. Du meinst in Proxmox mit der Vendor ID. Das hatte ich probiert.
          Ich habe gerade mal einen Cold-boot des NUCs durchgeführt. Nun läuft der Zigbee-Adapter. 🙂
          Noch eine Frage. Wie kann ich denn der neuen VM die IP der alten VM vergeben, damit ich meine mqqt Endpunkte und alles andere nicht ändern muss? Bei einem Container geht das glaube ich ganz einfach - ich habe aber eine VM.
            crunchip Forum Testing Most Active @toki1973 last edited by crunchip
            ja, denn der Port kann nach einem Reboot eventuell wechseln, daher immer per Geräte ID einbinden
            kannst/solltest du auf statisch stellen, mittels
            sudo nano /etc/network/interfaces
            auf deiner VM aufrufen
            sieht dann in etwa so aus
            anschliesend ein reboot deiner VM
              @crunchip
              Super und vielen Dank - das hat auch geklappt.
              Nur wenn ich die VIS starte bekomme ich nun diesen Fehler:
              URIError: Failed to decode param '%web_protocol%://192.168.0.193:%web_port%/vis/edit.html'
                  at decodeURIComponent (<anonymous>)
                  at decode_param (/opt/iobroker/node_modules/express/lib/router/layer.js:172:12)
                  at Layer.match (/opt/iobroker/node_modules/express/lib/router/layer.js:148:15)
                  at matchLayer (/opt/iobroker/node_modules/express/lib/router/index.js:574:18)
                  at next (/opt/iobroker/node_modules/express/lib/router/index.js:220:15)
                  at expressInit (/opt/iobroker/node_modules/express/lib/middleware/init.js:40:5)
                  at Layer.handle [as handle_request] (/opt/iobroker/node_modules/express/lib/router/layer.js:95:5)
                  at trim_prefix (/opt/iobroker/node_modules/express/lib/router/index.js:317:13)
                  at /opt/iobroker/node_modules/express/lib/router/index.js:284:7
                  at Function.process_params (/opt/iobroker/node_modules/express/lib/router/index.js:335:12)
                toki1973 @toki1973 last edited by
                Der WebServer hatte irgendwein Problem. Nach iobroker upload all läuft er nun wieder
