    4. Test Adapter homeconnect (BSH Home-Connect) v0.0.x
      JohnnyBahama last edited by
      @tombox hast du meinen Log bekommen?
        sigi234 Forum Testing Most Active @tombox last edited by sigi234
        @dna909
        Hallo, ich glaube die haben die Api umgestellt?
        homeconnect.0
        2021-11-16 08:22:19.621	info	Undefined Error from Homeconnect this happens sometimes.
        homeconnect.0
        2021-11-16 08:22:19.620	error	EventSource error: {"type":"error"}
        homeconnect.0
        2021-11-16 08:22:19.620	error	Homeconnect API are not available please try again later
        homeconnect.0
        2021-11-16 08:22:19.620	error	Error: {"type":"error","status":500,"message":"Internal Server Error"}
        homeconnect.0
        2021-11-16 08:22:19.620	error	Error: 500
        homeconnect.0
        2021-11-16 08:22:19.620	error	Error (401010522278007458)
        homeconnect.0
        2021-11-16 08:22:19.620	error	500 Internal Server Error
        homeconnect.0
        2021-11-16 08:22:19.620	error	EventSource error: {"type":"error","status":500,"message":"Internal Server Error"}
        homeconnect.0
        2021-11-16 08:22:18.476	info	Undefined Error from Homeconnect this happens sometimes.
        homeconnect.0
        2021-11-16 08:22:18.475	error	EventSource error: {"type":"error"}
        homeconnect.0
        homeconnect.0
        2021-11-16 08:22:18.475	error	Homeconnect API are not available please try again later
        homeconnect.0
        2021-11-16 08:22:18.475	error	Error: {"type":"error","status":500,"message":"Internal Server Error"}
        homeconnect.0
        2021-11-16 08:22:18.475	error	Error: 500
        homeconnect.0
        2021-11-16 08:22:18.475	error	Error (401010522278007458)
        homeconnect.0
        2021-11-16 08:22:18.475	error	500 Internal Server Error
        homeconnect.0
        2021-11-16 08:22:18.475	error	EventSource error: {"type":"error","status":500,"message":"Internal Server Error"}
        Aha:
        Wartungsarbeiten am 16. November 2021
        Home Connect wird am 16. November 2021, von 12:00 Uhr bis 17:00 Uhr nicht verfügbar sein. Außerdem kann es auch am 17. November noch zu kleineren Störungen kommen. Hintergrund ist die Durchführung eines umfangreichen Upgrades unserer Infrastruktur. Dies wird zu einer verbesserten Netzwerkstabilität und einer besseren Performance der gesamten App führen.
        Bitte entschuldige diese Unannehmlichkeit,
        Dein Home Connect Team
          Michi_Pi @sigi234 last edited by Michi_Pi
          @sigi234 hab das gleiche Problem. Komme aber auch über die App nicht mehr drauf.
          Ahja, man sollte bis zum Ende lesen 😛
          oberfragger 1 Reply Last reply Reply Quote 0
          • oberfragger
            oberfragger @Michi_Pi last edited by
            @michi_pi @sigi234 Ah. Sehr interessant und danke für den heinweis.
            War heute früh m.E. bereits so. Jedenfalls wurde mir der Kaffee nicht angesagt...
              GrillSgt last edited by GrillSgt
              bin zur Zeit etwas ratlos.
              Habe einen HomeConnect fähigen Trockner sowie eine Kaffeemaschine.
              Aber augenscheinlich würde ich sagen, dass keine Stati angelegt werden um etwa die Kaffeemaschine anzuschalten. Ich denke auch nicht, dass es was mit dem Adapter selbst zu tun hat. Das Homebridge Plug-In für HomeConnect sagt auch nur, dass keine Steuerung möglich wäre / sei.
              Interessant ist auch, dass die Geräte angeblich im State "Connected" immer auf "false" stehen. Über die HomeConnect App aber lassen sich die Geräte problemlos steuern.
              Anbei mal exemplarisch die States für die Kaffeemaschine. Sieht für den Trockner ähnlich aus:
              Habe auch schon neue Client IDs auf der Developer Seite neu angelegt. Hat alles nichts gebracht. Jmd noch ne Idee?
              Adapterversion ist 0.0.36.
              Zu den Meldungen vorher:
              Das mit den Wartungsarbeiten heute wusste ich. Es kam eine E-Mail.
                tombox @GrillSgt last edited by
                @grillsgt gib der api noch zwei Tage und probiere es dann nochmal
                  GrillSgt @tombox last edited by GrillSgt
                  @tombox Alles klar, danke 🙂
                  Allerdings, habe ich den Adapter schon vor einigen Tagen installiert. Hatte bisher nur selbst geschaut ob ich das in den Griff bekomme. Aber ich warte mal ab.
                  Hatte den Adapter auch mal zwei Tage deaktiviert um nicht die max. Anzahl von Anfragen zu erreichen.
                    holgerwolf last edited by
                    Seit der API Änderungen auf BSH-Seite laufe ich in das Request Limit:
                    homeconnect.0
                    	2021-11-19 08:43:58.958	warn	Retry Refresh Token in 5min
                    homeconnect.0
                    	2021-11-19 08:43:58.958	error	Error Refresh-Token: 429 undefined
                    homeconnect.0
                    	2021-11-19 08:43:58.953	warn	Restart the Adapter to get all devices correctly.
                    homeconnect.0
                    	2021-11-19 08:43:58.953	error	Error getting Aplliances with existing Token: 429 The rate limit "1000 calls in 1 day" was reached. Requests are blocked during the remaining period of 17:13:24
                    homeconnect.0
                    	2021-11-19 08:43:58.813	info	starting. Version 0.0.36 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v12.21.0, js-controller: 3.3.14
                    Habe nur zwei Geräte dran. Kann man das Abfrage-Intervall irgendwo einstellen?
                      holgerwolf @holgerwolf last edited by
                      @holgerwolf Gerade oben gelesen, dass es eien Github Version mit der Option gibt.
                      Hab ich mal nachinstalliert und jetzt heißt es warten bis morgen...
                        derdominik @holgerwolf last edited by
                        @holgerwolf im DEBUG mode siehst du auch, wie oft so ein restart bzw reload der Programme statt findet.
                        Hatte ich kürzlich auch, die Logs waren voll mit RECONNECT Meldungen und @tombox hat daraufhin netterweise diese Option eingebaut, dass die Programme nicht mehr geladen werden.
                        Bevor ich die neue Version installieren konnte habe ich allerdings meinen Geschirrspüler per Strom AUS/AN neu gestartet. Seit dem hatte ich keine RECONNECTs mehr...
                        • oberfragger
                          oberfragger @derdominik last edited by
                          @tombox Hi, diese Option scheint was gebracht zu haben. Der Adapter läuft nun fehlerfrei seit ca. 4 Tagen.
                            Bei mir läuft der Adapter jetzt auch seit Samstag wieder.
                              Bei mir läuft der Adapter grundsätzlich auch. Steuern lässt sich aber nix. Angeblich sind meine Geräte offline und entsprechend werden auch die Stati nicht angelegt. Habe auch keine Idee mehr was ich dagegen noch machen soll.
                              M T 2 Replies Last reply Reply Quote 0
                                MarcJ @GrillSgt last edited by
                                @grillsgt So auch bei mir. Gibts was neues?
                                  @grillsgt @MarcJ Bräuchte davon ein debug log vom starten und setzen eines Befehls
                                    homecineplexx @tombox last edited by
                                    @tombox Nur mal so zu dem Thema.
                                    Ich hab gestern den Adapter installiert und meinen neuen Bosch Backofen mittels HomeConnect App in Betrieb genommen, allerdings seh ich im ioBroker in den Objekten von HomeConnect nicht mal einen Datenpunkt was mit einem Device zu tun haben könnte!
                                    Funktioniert das Teil überhaut noch?
                                    danke
                                      holgerwolf @homecineplexx last edited by
                                      @homecineplexx Doch, doch, klappt gut:
                                      Steht denn was in dem Log? Ich hatte mal das Problem, dass zuviele Abfragen kamen und von Bosch die API für nen Tag gesperrt war.
                                        homecineplexx @holgerwolf last edited by
                                        @holgerwolf also eigentlich seh ich wirklich gar nichts ausser dass er den token renewed hat. aber ich hab nichts unter homeconnect.0 ausser dev
                                        ich verwende die homeconnect bosch app, ist das eh richtig?
                                          @homecineplexx Hast du denn der App auch erlaubt, die Geräte über die API auszulesen?
                                            @holgerwolf sorry wo seh ich das in der App?
                                            bsh bsh home connect home connect homeconnect adapter
                                            195
                                            1373
                                            499384
