    3. Entwicklung
    4. Adapter: jeelink
    Adapter: jeelink
      photographix last edited by
      Hallo foxthefox,
      ich habe mit dem Jeelink Adapter das selbe Problem wie simpixo. Ich bekomme lediglich die States angelegt - ohne Werte. Im Jeelink (vorher an der CCU2) laufen auch die ganzen Lacrosse auf.
      Hast du auch hier eine Idee? Jeelink 0.0.3, Admin 1.6.12, js-controller 0.16.1, Windows2016Srv
      jeelink.0 2017-03-02 19:54:48.783 info data received: H004800450144
      jeelink.0 2017-03-02 19:54:47.596 info data received: H001800740150
      jeelink.0 2017-03-02 19:54:45.596 info data received: H00801650000
      jeelink.0 2017-03-02 19:54:45.330 info data received: H003500120242
      jeelink.0 2017-03-02 19:54:44.596 info data received: H001900720153
      jeelink.0 2017-03-02 19:54:44.393 info data received: H004800450144
      jeelink.0 2017-03-02 19:54:43.455 info data received: H001800740150
      jeelink.0 2017-03-02 19:54:43.237 info data received: H004200850146
      jeelink.0 2017-03-02 19:54:42.502 info data received: H003200190242
      jeelink.0 2017-03-02 19:54:41.518 info data received: H00801650000
      jeelink.0 2017-03-02 19:54:40.612 info data received: H004400050242
      jeelink.0 2017-03-02 19:54:40.018 info data received: H004800450144
      jeelink.0 2017-03-02 19:54:39.346 info data received: H001800730150
      jeelink.0 2017-03-02 19:54:38.924 info data received: H004200850146
      jeelink.0 2017-03-02 19:54:37.455 info data received: H00801650000
      jeelink.0 2017-03-02 19:54:36.893 info data received: H003500120242
      jeelink.0 2017-03-02 19:54:36.299 info data received: H001900720153
      jeelink.0 2017-03-02 19:54:35.174 info data received: H001800740150
      jeelink.0 2017-03-02 19:54:34.580 info data received: H004200850146
      jeelink.0 2017-03-02 19:54:34.002 info data received: H003200190242
      jeelink.0 2017-03-02 19:54:33.393 info data received: H00801650000
      jeelink.0 2017-03-02 19:54:31.924 info data received: H004400050242
      jeelink.0 2017-03-02 19:54:31.268 info data received: H004800450144
      jeelink.0 2017-03-02 19:54:30.268 info data received: H004200850147
      jeelink.0 2017-03-02 19:54:29.752 info data received: H003200190242
      jeelink.0 2017-03-02 19:54:29.330 info data received: H00801650000
      jeelink.0 2017-03-02 19:54:28.237 info data received: H003500120242
      jeelink.0 2017-03-02 19:54:28.018 info data received: H001900720153
      jeelink.0 2017-03-02 19:54:26.877 info data received: H001800740150
      jeelink.0 2017-03-02 19:54:25.487 info data received: H003200190242
      jeelink.0 2017-03-02 19:54:25.268 info data received: H00801650000
      jeelink.0 2017-03-02 19:54:23.221 info data received: H004400050242
      jeelink.0 2017-03-02 19:54:22.533 info data received: H004800450144
      jeelink.0 2017-03-02 19:54:21.924 info data received: H00801670000
      jeelink.0 2017-03-02 19:54:21.596 info data received: H004200850146
      jeelink.0 2017-03-02 19:54:21.424 info data received: [LaCrosseITPlusReader.10.1g_HMS_mod3 (RFM69CW) @17241 kbps / 868300 kHz]
      jeelink.0 2017-03-02 19:54:19.596 info open
      jeelink.0 2017-03-02 19:54:19.346 info RFM12B setting up object = LaCrosse 1
      jeelink.0 2017-03-02 19:54:19.346 info RFM12B setting up object = LaCrosse 2
      jeelink.0 2017-03-02 19:54:19.346 info entered ready
      jeelink.0 2017-03-02 19:54:19.346 info starting. Version 0.0.3 in C:/ioBroker/node_modules/iobroker.jeelink, node: v4.5.0
      [1443_bildschirmfoto_2017-03-02_um_19.59.05.png](/assets/uploads/files/1443_bildschirmfoto_2017-03-02_um_19.59.05.png)
      [1443_bildschirmfoto_2017-03-02_um_20.02.41.png](/assets/uploads/files/1443_bildschirmfoto_2017-03-02_um_20.02.41.png)
        simpixo last edited by
        Hallo photographix,
        Du musst die ID's konfigurieren ansonsten wird nix angelegt
        Im Log müssten die zu finden sein! Und genau diese müsstest du im Admin des Adapters konfigurieren!
        Erst wenn die angelegt sind werden die Objekte angelegt und auch befüllt
        Adrian
          foxthefox Developer last edited by
          @photographix:
          Hallo foxthefox,
          Hast du auch hier eine Idee? Jeelink 0.0.3, Admin 1.6.12, js-controller 0.16.1, Windows2016Srv `
          Also bei simpixio war es dann ok.
          Könntest du mal den Adapter in den debug-Modus versetzen und dann nochmal das log schicken. Was mich grad ein bisschen wundert ist das die Sensoren mit "H" beginnen.
          Klaus
            Hallo simpixo,
            die IDs sind bei mir konfiguriert. Wie bei dir damals auch nur zwei zum starten.
            Eindeutige Sensor ID = von mir gewählt
            empfangene ID = aus dem LOG die ersten vier bzw zwei Zeichen
              Wo sieht das Log aus, am besten du schaltest den Adapter in den debug Modus! Kommen da Daten rein von den Sensoren rein!?
                Auf Debug bekomme ich keine Werte mehr rein
                Ist das Level wieder auf Info gehen auch wieder Werte
                  Scheinbar läuft dein Jeelink doppelt!
                  Kannst du mal schauen ob das der Fall ist!? Müssten zwei Prozesse sein!
                  Bei mir ist das auch mal passiert! Oh habe dann den Adapter beendet und habe den prozess der noch gelaufen ist beendet und erst dann den Adapter wieder gestartet
                  Adrian
                    Guten morgen,
                    auch nach einem Neustart von Iobroker (net stop / net start iobroker) habe ich weder Debug Ausgaben noch dekodierte Werte im Jeelink.
                    Was aber wieder auf Anhieb geht ist der Empfang aller DTHs von Lacrosse. Habe dazu keine Idee.
                    jeelink.0 2017-03-03 05:57:40.485 info data received: H001800640148
                    jeelink.0 2017-03-03 05:57:40.298 info data received: H003500880142
                    jeelink.0 2017-03-03 05:57:40.032 info data received: H004400320239
                    jeelink.0 2017-03-03 05:57:39.157 info data received: H00801270000
                    jeelink.0 2017-03-03 05:57:38.845 info data received: H003200850143
                    jeelink.0 2017-03-03 05:57:38.501 info data received: H00801190000
                    jeelink.0 2017-03-03 05:57:36.345 info data received: H001800650148
                    jeelink.0 2017-03-03 05:57:36.016 info data received: H003500880142
                    jeelink.0 2017-03-03 05:57:34.876 info data received: H001900700153
                    jeelink.0 2017-03-03 05:57:34.454 info data received: H00801190000
                    jeelink.0 2017-03-03 05:57:33.673 info data received: H004200850145
                    jeelink.0 2017-03-03 05:57:32.704 info data received: H004800430148
                    jeelink.0 2017-03-03 05:57:32.188 info data received: H001800640148
                    jeelink.0 2017-03-03 05:57:31.266 info data received: H004400320239
                    jeelink.0 2017-03-03 05:57:30.345 info data received: H003200850143
                    jeelink.0 2017-03-03 05:57:28.345 info data received: H004800430148
                    jeelink.0 2017-03-03 05:57:27.470 info data received: H003500880141
                    jeelink.0 2017-03-03 05:57:26.501 info data received: H001900700153
                    jeelink.0 2017-03-03 05:57:26.313 info data received: H00801190000
                    jeelink.0 2017-03-03 05:57:25.016 info data received: H004200850145
                    jeelink.0 2017-03-03 05:57:23.923 info data received: H001800640148
                    jeelink.0 2017-03-03 05:57:22.923 info data received: H00801270000
                    jeelink.0 2017-03-03 05:57:22.579 info data received: H004400320239
                    jeelink.0 2017-03-03 05:57:22.251 info data received: H00801190000
                    jeelink.0 2017-03-03 05:57:21.845 info data received: H003200850143
                    jeelink.0 2017-03-03 05:57:19.766 info data received: H001800640148
                    jeelink.0 2017-03-03 05:57:19.579 info data received: H004800440148
                    jeelink.0 2017-03-03 05:57:18.188 info data received: H00801190000
                    jeelink.0 2017-03-03 05:57:16.360 info data received: H004200850145
                    jeelink.0 2017-03-03 05:57:15.641 info data received: H001800640148
                    jeelink.0 2017-03-03 05:57:15.220 info data received: H004800430148
                    jeelink.0 2017-03-03 05:57:14.657 info data received: H003500880141
                    jeelink.0 2017-03-03 05:57:14.126 info data received: H00801190000
                    jeelink.0 2017-03-03 05:57:13.376 info data received: H003200850143
                    jeelink.0 2017-03-03 05:57:11.501 info data received: H001800650148
                    jeelink.0 2017-03-03 05:57:10.376 info data received: H003500880141
                    jeelink.0 2017-03-03 05:57:10.063 info data received: H00801190000
                    jeelink.0 2017-03-03 05:57:09.907 info data received: H001900700153
                    jeelink.0 2017-03-03 05:57:07.720 info data received: H004200850145
                    jeelink.0 2017-03-03 05:57:07.360 info data received: H001800640148
                    jeelink.0 2017-03-03 05:57:06.673 info data received: H00801270000
                    jeelink.0 2017-03-03 05:57:06.454 info data received: H004800440148
                    jeelink.0 2017-03-03 05:57:06.001 info data received: H00801190000
                    jeelink.0 2017-03-03 05:57:05.220 info data received: H004400320239
                    jeelink.0 2017-03-03 05:57:04.845 info data received: H003200850143
                    jeelink.0 2017-03-03 05:57:02.110 info data received: H004800430148
                    jeelink.0 2017-03-03 05:57:01.938 info data received: H00801190000
                    jeelink.0 2017-03-03 05:57:01.610 info data received: H001900700153
                    jeelink.0 2017-03-03 05:56:59.079 info data received: H004200850145
                    jeelink.0 2017-03-03 05:56:58.532 info data received: H00801270000
                    jeelink.0 2017-03-03 05:56:57.876 info data received: H00801190000
                    jeelink.0 2017-03-03 05:56:57.704 info data received: H004800440148
                    jeelink.0 2017-03-03 05:56:57.563 info data received: H003500880141
                    jeelink.0 2017-03-03 05:56:56.516 info data received: H004400320239
                    jeelink.0 2017-03-03 05:56:56.329 info data received: H003200850143
                    jeelink.0 2017-03-03 05:56:54.470 info data received: H00801270000
                    jeelink.0 2017-03-03 05:56:53.813 info data received: H00801190000
                    jeelink.0 2017-03-03 05:56:53.298 info data received: H001900700153
                    jeelink.0 2017-03-03 05:56:50.798 info data received: H001800640148
                    jeelink.0 2017-03-03 05:56:50.407 info data received: H004200850145
                    jeelink.0 2017-03-03 05:56:49.751 info data received: H00801190000
                    jeelink.0 2017-03-03 05:56:48.970 info data received: H004800440148
                    jeelink.0 2017-03-03 05:56:47.829 info data received: H004400320239
                    jeelink.0 2017-03-03 05:56:45.689 info data received: H00801190000
                    jeelink.0 2017-03-03 05:56:44.735 info data received: H003500880141
                    jeelink.0 2017-03-03 05:56:44.579 info data received: H004800430148
                    jeelink.0 2017-03-03 05:56:42.516 info data received: H001800640148
                    jeelink.0 2017-03-03 05:56:41.626 info data received: H00801190000
                    jeelink.0 2017-03-03 05:56:40.470 info data received: H003500880141
                    jeelink.0 2017-03-03 05:56:39.344 info data received: H003200850143
                    jeelink.0 2017-03-03 05:56:39.173 info data received: H004400320239
                    jeelink.0 2017-03-03 05:56:38.219 info data received: H00801270000
                    jeelink.0 2017-03-03 05:56:37.564 info data received: H00801190000
                    jeelink.0 2017-03-03 05:56:36.719 info data received: H001900700153
                    jeelink.0 2017-03-03 05:56:36.188 info data received: H003500880142
                    jeelink.0 2017-03-03 05:56:35.845 info data received: H004800440148
                    jeelink.0 2017-03-03 05:56:34.173 info data received: H00801270000
                    jeelink.0 2017-03-03 05:56:33.501 info data received: H00801190000
                    jeelink.0 2017-03-03 05:56:33.079 info data received: H004200850145
                    jeelink.0 2017-03-03 05:56:31.923 info data received: H003500880141
                    jeelink.0 2017-03-03 05:56:31.454 info data received: H004800440148
                    jeelink.0 2017-03-03 05:56:30.829 info data received: H003200850143
                    jeelink.0 2017-03-03 05:56:30.454 info data received: H004400320239
                    jeelink.0 2017-03-03 05:56:30.313 info [LaCrosseITPlusReader.10.1g_HMS_mod3 (RFM69CW) @17241 kbps / 868300 kHz]
                    jeelink.0 2017-03-03 05:56:30.313 info data received:
                    jeelink.0 2017-03-03 05:56:28.518 info open
                    jeelink.0 2017-03-03 05:56:28.329 info RFM12B setting up object = LaCrosse 1
                    jeelink.0 2017-03-03 05:56:28.329 info RFM12B setting up object = LaCrosse 2
                    jeelink.0 2017-03-03 05:56:28.329 info entered ready
                    jeelink.0 2017-03-03 05:56:28.313 info starting. Version 0.0.3 in C:/ioBroker/node_modules/iobroker.jeelink, node: v4.5.0
                    jeelink.0 2017-03-03 05:56:28.266 debug statesDB connected
                    jeelink.0 2017-03-03 05:56:28.219 debug objectDB connected
                      @photographix:
                      Guten morgen,
                      Was aber wieder auf Anhieb geht ist der Empfang aller DTHs von Lacrosse. Habe dazu keine Idee. `
                      Guten Morgen,
                      Evtl. Meinte simpixio nicht die net-Befehle, sondern eher die Befehle im iobroker Verzeichnis:
                      iobroker list instances
                      iobroker stop jeelink
                      iobroker start jeelink
                      Könntest du auch einmal oben links "alles" auswählen und nicht nur den jeelink.0? Da hatte ich öfters mal Unterschiede, manchmal hilft auch zwischen den tabs zu wechseln.
                      Ohne debug-log siehts schwierig aus.
                      Klaus
                        Irgendwie geht der Debug Modus beim Jeelink nicht, scheint mir. Bis auf die Meldung mit der States DB kommt nichts mehr.
                        Habe auch nur eine Instanz laufen.
                        Der RFlink Adapter (Bild) ist gesprächiger im Debug Modus.
                        c:\ioBroker>iobroker list instances
                        c:\ioBroker>node node_modules/iobroker.js-controller/iobroker.js list instances
                        system.adapter.admin.0 : admin - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                        system.adapter.cloud.0 : cloud - disabled
                        system.adapter.dwd.0 : dwd - enabled
                        system.adapter.history.0 : history - enabled
                        system.adapter.hm-rega.0 : hm-rega - enabled
                        system.adapter.hm-rpc.0 : hm-rpc - enabled, port: 0
                        system.adapter.hm-rpc.1 : hm-rpc - enabled, port: 0
                        system.adapter.hm-rpc.2 : hm-rpc - enabled, port: 0
                        system.adapter.ical.0 : ical - enabled
                        system.adapter.icons-material-svg.0 : icons-material-svg - enabled
                        system.adapter.icons-mfd-svg.0 : icons-mfd-svg - enabled
                        system.adapter.javascript.0 : javascript - enabled
                        system.adapter.jeelink.0 : jeelink - enabled
                        system.adapter.mobile.0 : mobile - disabled
                        system.adapter.node-red.0 : node-red - disabled, port: 1880
                        system.adapter.parser.0 : parser - disabled
                        system.adapter.ping.0 : ping - enabled
                        system.adapter.rflink.0 : rflink - enabled
                        system.adapter.rickshaw.0 : rickshaw - enabled
                        system.adapter.sayit.0 : sayit - disabled, port: 0
                        system.adapter.scenes.0 : scenes - enabled
                        system.adapter.socketio.0 : socketio - enabled, port: 8084, bind: 0.0.0.0 (SSL), run as: admin
                        system.adapter.tr-064.0 : tr-064 - enabled
                        system.adapter.upnp.0 : upnp - disabled
                        system.adapter.vis.0 : vis - enabled
                        system.adapter.web.0 : web - enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
                        system.adapter.yr.0 : yr - enabled
                        ! c:\ioBroker>iobroker stop jeelink
                        ! c:\ioBroker>node node_modules/iobroker.js-controller/iobroker.js stop jeelink
                        Adapter "jeelink.0 stopped.
                        ! c:\ioBroker>iobroker start jeelink
                        ! c:\ioBroker>node node_modules/iobroker.js-controller/iobroker.js start jeelink
                        Adapter "jeelink.0 started.
                        Drücke Strg+A und danach Strg+C, um den Inhalt in die Zwischenablage zu kopieren. Klicke irgendwo, um das Fenster zu schliessen.
                        jeelink.0	2017-03-03 20:19:22.904	info	data received: H00801770000
                        jeelink.0	2017-03-03 20:19:22.310	info	data received: H00801740000
                        jeelink.0	2017-03-03 20:19:21.091	info	data received: H004800530148
                        jeelink.0	2017-03-03 20:19:20.794	info	data received: H003500050242
                        jeelink.0	2017-03-03 20:19:19.654	info	data received: H004400000237
                        jeelink.0	2017-03-03 20:19:18.904	info	data received: H00801770000
                        jeelink.0	2017-03-03 20:19:18.263	info	data received: H00801740000
                        jeelink.0	2017-03-03 20:19:17.888	info	data received: H004200850147
                        jeelink.0	2017-03-03 20:19:16.701	info	data received: H004800530148
                        jeelink.0	2017-03-03 20:19:16.529	info	data received: H003500050242
                        jeelink.0	2017-03-03 20:19:16.325	info	data received: H003200180241
                        jeelink.0	2017-03-03 20:19:14.200	info	data received: H00801740000
                        jeelink.0	2017-03-03 20:19:12.247	info	data received: H003500050242
                        jeelink.0	2017-03-03 20:19:10.966	info	data received: H004400990137
                        jeelink.0	2017-03-03 20:19:10.716	info	data received: H00801770000
                        jeelink.0	2017-03-03 20:19:10.122	info	data received: H00801740000
                        jeelink.0	2017-03-03 20:19:09.450	info	data received: [LaCrosseITPlusReader.10.1g_HMS_mod3 (RFM69CW) @17241 kbps / 868300 kHz]
                        jeelink.0	2017-03-03 20:19:07.638	info	open
                        jeelink.0	2017-03-03 20:19:07.325	info	RFM12B setting up object = LaCrosse 1
                        jeelink.0	2017-03-03 20:19:07.325	info	RFM12B setting up object = LaCrosse 2
                        jeelink.0	2017-03-03 20:19:07.325	info	entered ready
                        jeelink.0	2017-03-03 20:19:07.325	info	starting. Version 0.0.3 in C:/ioBroker/node_modules/iobroker.jeelink, node: v4.5.0
                        host.Smarthub	2017-03-03 20:19:05.795	info	instance system.adapter.jeelink.0 started with pid 3380
                        host.Smarthub	2017-03-03 20:19:05.795	info	'system.adapter.jeelink.0' enabled
                        host.Smarthub	2017-03-03 20:19:05.795	info	object change system.adapter.jeelink.0
                        rflink.0	2017-03-03 20:19:03.888	warn	Wrong serial data: ;
                        host.Smarthub	2017-03-03 20:18:49.873	info	instance system.adapter.jeelink.0 terminated with code null ()
                        host.Smarthub	2017-03-03 20:18:49.873	warn	instance system.adapter.jeelink.0 terminated due to SIGTERM
                        host.Smarthub	2017-03-03 20:18:49.732	info	stopInstance system.adapter.jeelink.0 killing pid 1608
                        host.Smarthub	2017-03-03 20:18:49.732	info	'system.adapter.jeelink.0' disabled
                        host.Smarthub	2017-03-03 20:18:49.732	info	object change system.adapter.jeelink.0
                        jeelink.0	2017-03-03 20:18:46.607	info	data received: H003500050242
                        host.Smarthub	2017-03-03 20:18:46.545	error	WARNING: cannot find logs with id = 86695495
                        jeelink.0	2017-03-03 20:18:46.076	info	data received: H004800530148
                        jeelink.0	2017-03-03 20:18:45.779	info	data received: H00801740000
                        jeelink.0	2017-03-03 20:18:45.045	info	data received: H004400990137
                        host.Smarthub	2017-03-03 20:18:44.998	error	WARNING: cannot find logs with id = 86693273
                        jeelink.0	2017-03-03 20:18:43.545	info	data received: H001900720151
                        jeelink.0	2017-03-03 20:18:43.280	info	data received: H004200850147
                        jeelink.0	2017-03-03 20:18:42.279	info	data received: H00801770000
                        jeelink.0	2017-03-03 20:18:41.716	info	data received: H00801740000
                        host.Smarthub	2017-03-03 20:18:41.701	error	WARNING: cannot find logs with id = 86693019
                        jeelink.0	2017-03-03 20:18:38.154	info	data received: H003500050242
                        jeelink.0	2017-03-03 20:18:37.951	info	data received: H00801740000
                        history.0	2017-03-03 20:18:41.201	info	init timed Relog: disable relog because state not set so far hm-rpc.0.NEQ0948175.0.AES_KEY: null
                        history.0	2017-03-03 20:18:40.888	info	init timed Relog: disable relog because state not set so far hm-rpc.0.NEQ0387055.0.AES_KEY: null
                        history.0	2017-03-03 20:18:40.888	info	init timed Relog: disable relog because state not set so far hm-rpc.0.NEQ0387055.1.INSTALL_TEST: null
                        [1443_bildschirmfoto_2017-03-03_um_20.29.24.png](/assets/uploads/files/1443_bildschirmfoto_2017-03-03_um_20.29.24.png)
                          Das ist sehr komisch, weil der debug Modus mir sehr beim programmieren geholfen hat. Arbeite grad an nem Update um die unbekannten Sensoren im Admin aufzulisten, aber das löst nicht das debug Problem. Werde evtl. Standardmäßig debug einstellen.
                            Also, nochmal drübergeschaut. Das Programm wertet nur empfangene Telegramme aus, die mit OK beginnen und DTH Sensoren sollten mit 9 standardmäßig beginnen. Weil es nicht mit OK beginnt, gibt es auch keine debug Meldungen, weil kein weiteres Programm durchlaufen wird.
                            Was für Sensoren sind es (Typ und Hersteller)?
                            Welche Firmware wird auf dem Stick verwendet?
                            Unter Umständen muss ich den Adapter erweitern, um neue Sensoren zu unterstützen.
                            Klaus
                              Marcolotti last edited by
                              ich habe jetzt ein paar Stunden zugebracht den original Jeelink v3c zum laufen zu bringen. Vielleicht hilft es ja weiter.
                              <u>Flashen:</u>
                              Für mich, Lacrosse Sketch Hex 10.1q herunterladen.
                              Avrdude installieren
                              avrdude -p atmega328P -c arduino -P /dev/ttyUSB1 -D -U flash:w:./JeeLink_LaCrosse.hex 2>./JeeLinkFlash.log
                              Was unbedingt noch automatisiert werden muss ist der Modus, sonst empfängt man nichts.
                              Im Terminal:````
                              echo "3m 30t v" > /dev/ttyUSB1
                              Dann wechselt er alle 30 Sekunden zwischen den beiden Datenraten 17.241 kbps (TX29) und 9.579 kbps (TX35).
                               ![721_jeelink.jpg](/assets/uploads/files/721_jeelink.jpg)
                              Gruß Marco
                                ` > Was für Sensoren sind es (Typ und Hersteller)?
                                Welche Firmware wird auf dem Stick verwendet? `
                                Hallo, es sind ganz "normale" mit TX29DHT-IT von Amazon. Ein JeeLink v3c mit der Firmware aus dem Homatic Forum (LaCrosseITPlusReader.10.1g_HMS_mod3). Die neuere Q Firmware die hier immer mal wieder angesprochen wir habe ich nirgends als einzel Download gefunden. Wie gesagt der Jeelink funktioniert mit CuxD an der CCU2 problemlos. Ich liefer aber gerne mehr Daten wenn gewünscht oder teste neue Versionen vom Adapter.
                                LG
                                  Hallo Marcolotti,
                                  da ich nur Windows habe nützt die Linux Anleitung wenig um das Problem nachzustellen. Aber es wäre schön wenn du den Download Link für den "Q" Sketch des Lacrosse Readers posten könntest.
                                    @photographix:
                                    LG `
                                    Die gleiche Konstellation habe ich auch! Und bei mir rennt alles wunderbar! Es wäre ja gelacht wenn wir den Fehler nicht finden würden
                                    Adrian
                                      @simpixo:
                                      Die gleiche Konstellation habe ich auch! Und bei mir rennt alles wunderbar! Es wäre ja gelacht wenn wir den Fehler nicht finden würden `
                                      Ich weiss nicht wie es bei dir ist - ich bin aber schon auf Admin ist 1.6.12 und js-controller ist 0.16.1.
                                        @photographix:
                                        ich bin aber schon auf Admin ist 1.6.12 und js-controller ist 0.16.1. `
                                        Ja die gleichen Version habe ich auch
                                        Admin - 1.6.12
                                        Js-controller - 0.16.1
                                        JeeLink - 0.3
                                        NodeJS - v4.7.3
                                        mein Jeelink hat die folgende Firmware -> [LaCrosseITPlusReader.10.1h (RFM69CW) @17241 kbps / 868300 kHz]
                                        Meine Adapter Einstellungen so:
                                        Du betreibst deinen jeelink unter windows oder auch unter linux?
                                        Adrian
                                          Nein nur unter Windows. Habe daher COM4 als Port.
                                            Kannst du nochmal die Jeelink auf debug stellen unter Instanz und dann den Log noch mal posten?
                                            Bei mir sieht das nämlich so aus
                                            jeelink
                                            28
                                            185
                                            45375
