    5. Json korrekt parsen
    Json korrekt parsen
      Joker971 last edited by
      Hi allerseits,
      ich bekomme folgende Payload von meinem Mqtt und muss hier ein paar Werte rausholen. Das klappt soweit auch aber bei einem Wert scheitere ich. Hier mal zunächst die Payload:
        "end_device_ids": {
          "device_id": "bodensensor-hinten",
          "application_ids": {
            "application_id": "garden-soil-sensors"
          "dev_eui": "",
          "join_eui": "",
          "dev_addr": ""
        "correlation_ids": [
          "as:up:01FMJMEY3F4R8BRK933ZF831B8",
          "gs:conn:01FMHQKYR8ACAACXVMR5ETGBX0",
          "gs:up:host:01FMHQKYRRTNB1Y256R5BBFZ5B",
          "gs:uplink:01FMJMEXW5QENYW0X7ESBWKT7E",
          "ns:uplink:01FMJMEXW6V0WTERVH73FZ316Q",
          "rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01FMJMEXW64H4ZYQGZ6JYFSBK3",
          "rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01FMJMEY3ETSZPN33KJ591WZ1K"
        "received_at": "2021-11-15T20:26:20.655807658Z",
        "uplink_message": {
          "session_key_id": "AX0kon3s3ubZFDDLFdgJEw==",
          "f_port": 2,
          "f_cnt": 9,
          "frm_payload": "DS4AAAAACLQAABA=",
          "decoded_payload": {
            "Bat": "3.374 V",
            "TempC_DS18B20": "0.00 °C",
            "conduct_SOIL": "0 uS/cm",
            "temp_SOIL": "22.28 °C",
            "water_SOIL": "0.00 %"
          "rx_metadata": [
              "gateway_ids": {
                "gateway_id": "myindoorgatewayhub",
                "eui": ""
              "time": "2021-11-15T20:26:20.344300985Z",
              "timestamp": 177918228,
              "rssi": -63,
              "channel_rssi": -63,
              "snr": 10.75,
              "location": {
                "latitude": 51.7100722182447,
                "longitude": 7.923237383365632,
                "altitude": 5,
                "source": "SOURCE_REGISTRY"
              "uplink_token": "CiAKHgoSbXlpbmRvb3JnYXRld2F5aHViEghYoMv//oBEFBCUoutUGgwI7ITLjAYQuPfgyAEgoOyC5pbwBioMCOyEy4wGELm7lqQB"
          "settings": {
            "data_rate": {
              "lora": {
                "bandwidth": 125000,
                "spreading_factor": 7
            "coding_rate": "4/5",
            "frequency": "867900000",
          "received_at": "2021-11-15T20:26:20.422462557Z",
          "consumed_airtime": "0.061696s",
          "locations": {
            "user": {
              "latitude": 51.71014867049504,
              "longitude": 7.923138141632081,
          "version_ids": {
            "brand_id": "dragino",
            "model_id": "lse01",
            "hardware_version": "_unknown_hw_version_",
            "firmware_version": "1.3",
            "band_id": "EU_863_870"
          "network_ids": {
            "net_id": "000013",
            "tenant_id": "ttn",
            "cluster_id": "ttn-eu1"
      Ich bekomme die Werte indem ich die Payload mit dem "JSON nach Objekt" Baustein in ein Objekt umwandle und mit dem "ATTRIB" Baustein und der Pfadangabe bekomme ich die Werte bis auf einen!
      Folgende Pfade funktionieren super und ich kriege ein Ergebniss:
      uplink_message.decoded_payload.Bat
      uplink_message.decoded_payload.water_SOIL
      uplink_message.decoded_payload.conduct_SOIL
      uplink_message.decoded_payload.temp_SOIL
      Ich möchte aber noch den Wert rssi haben der in rx_metadata steckt. Vergeblich.
      Dieser Pfad funktioniert nicht:
      uplink_message.rx_metadata[0].rssi
      Das sollte er aber oder übersehe ich hier was ?
      Wenn ich nur uplink_message.rx_metadata verwende bekomme ich alles angezeigt was da drin steckt, darunter auch rssi aber ich kann nicht explizit darauf zugreifen.
      Jemand eine Idee ?
      Homoran F OliverIO 3 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @Joker971 last edited by
        @joker971
        Was hast du bereits gemacht?
        Blockly oder js?
        Wenn ich mich jetzt in den Ebenen nicht verrant habe müüsste es sein:
        Attribut von: uplink_message.rx_metadata.0.rssi
          Homoran Global Moderator Administrators @Homoran last edited by Homoran
          @homoran sagte in Json korrekt parsen:
          @joker971
          Blockly oder js?
          @joker971 sagte in Json korrekt parsen:
          keine Array-Klammern sondern Punkte zur Ebenentrennung
          J F 2 Replies Last reply Reply Quote 0
            fastfoot @Joker971 last edited by
            versuche uplink_message.rx_metadata.0.rssi. getAttr() funktioniert hier nicht wie erwartet
              Joker971 @Homoran last edited by
              Alles hab ich versucht, nur nicht die Klammern mal weg zu lassen 😇
              Daaaaanke für den Denkanstoss, das funktioniert jetzt 👍
              • OliverIO
                OliverIO @Joker971 last edited by
                @joker971
                so müsste korrekt sein
                bei meinem test kam -63 raus
                  fastfoot @Homoran last edited by
                  ja, in JS würde man es aber mit Klammer machen (müssen!)
                  • OliverIO
                    OliverIO @fastfoot last edited by OliverIO
                    @fastfoot
                    ich habe es in JS getestet und eckige array-klammern verwendet
                    am besten du schreibst deine version mal hin
                      fastfoot @OliverIO last edited by
                      @oliverio sagte in Json korrekt parsen:
                      @fastfoot
                      ich gehe davo aus dass er es in Blockly probiert hat, welches getAttr() verwendet und dort klappt das mit Klammer eben nicht 🙂
                      J Homoran 2 Replies Last reply Reply Quote 0
                        Joker971 @fastfoot last edited by
                        Es geht jetzt, ohne Klammern !
                        Danke euch 😄
                          Homoran Global Moderator Administrators @fastfoot last edited by Homoran
                          @fastfoot sagte in Json korrekt parsen:
                          ich auch, seine Formulierung:
                          waren ziemlich eindeutig.
                          und in Blockly muss man .0. sattt [0] nehmen, außer man geht mehrstufig vor indem man erst das Array zelegt und dann darin weitermacht
                            Ja natürlich Blockly, das ist doch auch das Blockly-Forum 🤓
                            blockly
                            647
