    4. Test Adapter Meteoalarm v2.0.x
      sigi234 Forum Testing Most Active @jackblackson last edited by sigi234
      @jackblackson
      Hallo, neuer Fehler:
      meteoalarm.0
      2021-10-01 05:32:02.062	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      meteoalarm.0
      2021-10-01 05:32:02.061	info	terminating
      meteoalarm.0
      2021-10-01 05:32:01.973	error	Cannot read property '0' of undefined
      meteoalarm.0
      2021-10-01 05:32:01.973	error	TypeError: Cannot read property '0' of undefined at C:\Program Files\iobroker\Home\node_modules\iobroker.meteoalarm\main.js:173:46 at Parser.<anonymous> (C:\Program Files\iobroker\Home\node_modules\xml2js\lib\parser.js:304:18) at Parser.emit (events.js:314:20) at Parser.EventEmitter.emit (domain.js:483:12) at SAXParser.onclosetag (C:\Program Files\iobroker\Home\node_modules\xml2js\lib\parser.js:262:26) at emit (C:\Program Files\iobroker\Home\node_modules\sax\lib\sax.js:624:35) at emitNode (C:\Program Files\iobroker\Home\node_modules\sax\lib\sax.js:629:5) at closeTag (C:\Program Files\iobroker\Home\node_modules\sax\lib\sax.js:889:7) at SAXParser.write (C:\Program Files\iobroker\Home\node_modules\sax\lib\sax.js:1436:13) at Parser.exports.Parser.Parser.parseString (C:\Program Files\iobroker\Home\node_modules\xml2js\lib\parser.js:323:31)
      meteoalarm.0
      2021-10-01 05:32:01.968	error	unhandled promise rejection: Cannot read property '0' of undefined
      meteoalarm.0
      2021-10-01 05:32:01.968	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      meteoalarm.0
      2021-10-01 05:32:01.676	info	starting. Version 2.0.6 in C:/Program Files/iobroker/Home/node_modules/iobroker.meteoalarm, node: v12.22.6, js-controller: 3.3.18
      Edit:
      gelöst mit Version 2.0.7
      • jackblackson
        jackblackson last edited by jackblackson
        @sigi234 Heute ist wohl das erste Mal, das es keinen Wetteralarm gibt, der Feed für ganz Österreich ist leer 🙂 Hab es behoben in v2.0.7 - https://github.com/jack-blackson/ioBroker.meteoalarm. Danke für eure Tests!
        sigi234 da_Woody 2 Replies Last reply Reply Quote 0
          @jackblackson sagte in Test Adapter Meteoalarm v2.0.x:
          meteoalarm.0
          2021-10-01 07:15:02.690	info	Terminated (NO_ERROR): Without reason
          meteoalarm.0
          2021-10-01 07:15:02.689	info	Updated Weather Alarms for Oberösterreich -> 0 warning(s) found
          meteoalarm.0
          2021-10-01 07:15:02.349	info	starting. Version 2.0.7 in C:/Program Files/iobroker/Home/node_modules/iobroker.meteoalarm, node: v12.22.6, js-controller: 3.3.18
          • da_Woody
            da_Woody @jackblackson last edited by
            @jackblackson hehe, kommt davon, wenn man nicht scrollt. 2.0.6 gelesen, gleich drübergejubelt. dann erst weiter gescrollt, oops, da is ja noch eine 2.0.7.
            keine fehlermeldung im moment... 👍
              mrhary last edited by
              Kann man die Anzahl der aktuellen Meldungen irgendwie ausgeben, bräuchte es für meine Benachrichtigungen
              jackblackson 1 Reply Last reply Reply Quote 0
              • jackblackson
                jackblackson @mrhary last edited by jackblackson
                @mrhary Aktuell nicht. Du meinst einfach im Hauptordner ein Objekt mit "Anzahl aktive Alarme"?
                Ich hab dir grad in Version 2.0.8 den Datenpunkt hinzugefügt, du kannst es dir gerne ansehen, einfach über diesen Link installieren: https://github.com/jack-blackson/ioBroker.meteoalarm/tarball/v2.0.8
                M da_Woody 2 Replies Last reply Reply Quote 0
                  mrhary @jackblackson last edited by
                  @jackblackson cool probier ich dann gleich
                  • da_Woody
                    da_Woody @jackblackson last edited by da_Woody
                    @jackblackson hüstel...
                    welcher wäre das?
                    krawutzikapuzi, plötzlich sind se da... 😄
                      @jackblackson
                      jetzt kommt dieser Fehler: Ev. wegen JS Update?
                      meteoalarm.3
                      2021-11-26 08:48:04.014	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 1
                      meteoalarm.3
                      2021-11-26 08:24:09.617	error	DB closed
                      meteoalarm.3
                      2021-11-26 08:24:09.617	error	Error: DB closed at Redis.sendCommand (C:\Program Files\iobroker\Home\node_modules\ioredis\built\redis\index.js:628:24) at Redis.get (C:\Program Files\iobroker\Home\node_modules\ioredis\built\commander.js:122:25) at StateRedisClient.setState (C:\Program Files\iobroker\Home\node_modules\@iobroker\db-states-redis\lib\states\statesInRedisClient.js:479:40) at Adapter.setState (C:\Program Files\iobroker\Home\node_modules\iobroker.js-controller\lib\adapter.js:6213:35)
                      meteoalarm.3
                      2021-11-26 08:24:09.608	error	unhandled promise rejection: DB closed
                      meteoalarm.3
                      2021-11-26 08:24:09.607	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      meteoalarm.3
                      2021-11-26 08:24:08.561	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 1
                      Plattform: Windows
                      RAM: 16 GB
                      Node.js: 14.18.1
                      NPM: 6.14.15
                      JS Controller: 3.3.20
                      Admin: 5.1.28
                      Web: 3.4.16
                      • da_Woody
                        da_Woody last edited by
                        @sigi234 die selben versionen, aber unter linux, keine errors...
                        • jackblackson
                          jackblackson @sigi234 last edited by jackblackson
                          @sigi234 hab grad auch auf 3.3.20 aktualisiert, und bei den Adaptern überall auf die Version im Latest, und bekomme diesen Fehler auch nicht. Welche Region fragst du ab?
                          Ich seh aktuell auch noch nichts im Sentry.
                            @jackblackson
                            Austria - Salzburg
                            • jackblackson
                              @sigi234 Hab grad umgestellt, bei mir find ich diesen Fehler nicht, hab grad noch das node.js aktualisiert auf 14. Einziger Unterschied ist, ich habs auf Linux laufen, nicht auf Windows..
                              da_Woody sigi234 2 Replies Last reply Reply Quote 1
                              • da_Woody
                                @jackblackson sieht irgendwie danach aus, das es an windows liegt...
                                  Auf Version 2.0.8 geupdatet, derzeit kommt kein Fehler.
                                  • da_Woody
                                    da_Woody @sigi234 last edited by
                                    @sigi234 na das haste verschwiegen... 😉
                                      sigi234 Forum Testing Most Active @da_Woody last edited by
                                      @da_woody sagte in Test Adapter Meteoalarm v2.0.x:
                                      Jetzt kommt das schon wieder: V 2.0.10
                                      meteoalarm.5
                                      2021-12-28 20:54:05.320	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 1
                                      meteoalarm.4
                                      2021-12-28 20:52:08.398	error	DB closed
                                      meteoalarm.4
                                      2021-12-28 20:52:08.398	error	Error: DB closed at Redis.sendCommand (C:\Program Files\iobroker\Home\node_modules\ioredis\built\redis\index.js:628:24) at Redis.get (C:\Program Files\iobroker\Home\node_modules\ioredis\built\commander.js:122:25) at StateRedisClient.setState (C:\Program Files\iobroker\Home\node_modules\@iobroker\db-states-redis\lib\states\statesInRedisClient.js:479:40) at Adapter.setState (C:\Program Files\iobroker\Home\node_modules\iobroker.js-controller\lib\adapter.js:6215:35)
                                      meteoalarm.4
                                      2021-12-28 20:52:08.388	error	unhandled promise rejection: DB closed
                                      meteoalarm.4
                                      2021-12-28 20:52:08.388	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      meteoalarm.4
                                      2021-12-28 20:52:07.749	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 2
                                      meteoalarm.5
                                      2021-12-28 20:27:05.600	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 1
                                      meteoalarm.4
                                      2021-12-28 20:26:05.370	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 2
                                      meteoalarm.4
                                      2021-12-28 20:00:12.959	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 2
                                      meteoalarm.5
                                      2021-12-28 20:00:12.233	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 1
                                      • jackblackson
                                        @sigi234 Ok..seh da leider nichts im Sentry. Ist das nur einmal bei der Ausführung passiert, oder mehrmals?
                                          Bei jeder Ausführung
                                          Habe kein Redis:
                                          meteoalarm.4
                                          • jackblackson
                                            @sigi234 Hast du Sentry aktiv, zumindest für diesen Adapter?
                                            412
                                            82292
