    4. Iobroker backitup error.. Wo liegt das problem
    • Humidor
      Humidor @simatec last edited by Humidor
      @simatec hab einen aus 2019 gefunden, das wirds wohl nich sein ?
      2.1.0
      manuelles Backup
      Started iobroker ...
      [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****"}
      [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
      [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups
      mount error(16): Device or resource busy
      Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
      [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups
      [DEBUG] [iobroker] start with {"type":"creator","time":"06:15","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerPV","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","context":{"fileNames":[],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups\nmount error(16): Device or resource busy\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n"},"done":[],"types":[]},"adapter":null},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data/history/"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":true,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
      [DEBUG] [iobroker] - host.raspi4iobrokerpv 2093 states saved
      [DEBUG] [iobroker] - host.raspi4iobrokerpv 2538 objects saved
      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz
      [DEBUG] [iobroker] - done
      [DEBUG] [historyDB] - compress from historyDB started ...
      [DEBUG] [historyDB] - Packed 9MB so far...
      [DEBUG] [historyDB] - Packed 19MB so far...
      [DEBUG] [historyDB] - Backup created: /opt/iobroker/backups/historyDB_2021_03_28-18_02_07_backupiobroker.tar.gz
      [DEBUG] [historyDB] - done
      [DEBUG] [cifs] - done
      [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
      [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
      [DEBUG] [clean] - done
      [DEBUG] [telegram] - [iobroker] used Telegram-Instance: telegram.0
      [DEBUG] [telegram] - done
      [DEBUG] [telegram] start with {"type":"creator","time":"06:15","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerPV","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz","/opt/iobroker/backups/historyDB_2021_03_28-18_02_07_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups\nmount error(16): Device or resource busy\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n"},"done":["iobroker","historyDB"],"types":["iobroker","historyDB"]},"adapter":null},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data/history/"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":true,"telegramWaiting":0,"systemLang":"de","time":"28. Maerz 2021 um 18:02 Uhr"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
      [DEBUG] [historyHTML] - new history html values created
      [DEBUG] [historyHTML] - done
      [DEBUG] [historyJSON] - new history json values created
      [DEBUG] [historyJSON] - done
      [DEBUG] [historyHTML] start with {"type":"creator","time":"06:15","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerPV","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz","/opt/iobroker/backups/historyDB_2021_03_28-18_02_07_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups\nmount error(16): Device or resource busy\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n"},"done":["iobroker","historyDB"],"types":["iobroker","historyDB"]},"adapter":null},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data/history/"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"28. Maerz 2021 um 18:02 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":true,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
      [DEBUG] [historyJSON] start with {"type":"creator","time":"06:15","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerPV","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz","/opt/iobroker/backups/historyDB_2021_03_28-18_02_07_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups\nmount error(16): Device or resource busy\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n"},"done":["iobroker","historyDB"],"types":["iobroker","historyDB"]},"adapter":null},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data/history/"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"28. Maerz 2021 um 18:02 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":true,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
      [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","backupDir":"/opt/iobroker/backups"}
      log
      backitup.0	2021-03-28 18:03:24.952	debug	(14449) system.adapter.admin.0: logging true
      backitup.0	2021-03-28 18:02:39.560	debug	(14449) [iobroker/historyJSON] done
      backitup.0	2021-03-28 18:02:39.559	debug	(14449) [iobroker/historyJSON] new history json values created
      backitup.0	2021-03-28 18:02:39.394	debug	(14449) [iobroker/historyHTML] done
      backitup.0	2021-03-28 18:02:39.392	debug	(14449) [iobroker/historyHTML] new history html values created
      backitup.0	2021-03-28 18:02:39.081	debug	(14449) [iobroker/telegram] done
      backitup.0	2021-03-28 18:02:39.079	debug	(14449) sendTo "send" to system.adapter.telegram.0 from system.adapter.backitup.0
      backitup.0	2021-03-28 18:02:39.065	debug	(14449) [iobroker/telegram] [iobroker] used Telegram-Instance: telegram.0
      backitup.0	2021-03-28 18:02:38.602	debug	(14449) [iobroker/clean] done
      backitup.0	2021-03-28 18:02:38.600	debug	(14449) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
      backitup.0	2021-03-28 18:02:37.995	debug	(14449) [iobroker/cifs] done
      backitup.0	2021-03-28 18:02:36.935	debug	(14449) [iobroker/historyDB] done
      backitup.0	2021-03-28 18:02:36.909	debug	(14449) [iobroker/historyDB] Backup created: /opt/iobroker/backups/historyDB_2021_03_28-18_02_07_backupiobroker.tar.gz
      backitup.0	2021-03-28 18:02:27.441	debug	(14449) [iobroker/historyDB] Packed 19MB so far...
      backitup.0	2021-03-28 18:02:17.442	debug	(14449) [iobroker/historyDB] Packed 9MB so far...
      backitup.0	2021-03-28 18:02:07.439	debug	(14449) [iobroker/historyDB] compress from historyDB started ...
      backitup.0	2021-03-28 18:02:06.682	debug	(14449) [iobroker/iobroker] done
      backitup.0	2021-03-28 18:02:05.589	debug	(14449) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz
      backitup.0	2021-03-28 18:02:02.046	debug	(14449) [iobroker/iobroker] host.raspi4iobrokerpv 2538 objects saved
      backitup.0	2021-03-28 18:02:02.019	debug	(14449) [iobroker/iobroker] host.raspi4iobrokerpv 2093 states saved
      backitup.0	2021-03-28 18:01:59.328	debug	(14449) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
      backitup.0	2021-03-28 18:01:59.328	debug	(14449) [iobroker/mount] mount error(16): Device or resource busy
      backitup.0	2021-03-28 18:01:59.327	debug	(14449) [iobroker/mount] [IGNORED] Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker
      backitup.0	2021-03-28 18:01:59.327	debug	(14449) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
      backitup.0	2021-03-28 18:01:59.326	debug	(14449) [iobroker/mount] mount error(16): Device or resource busy
      backitup.0	2021-03-28 18:01:59.325	debug	(14449) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroke
      backitup.0	2021-03-28 18:01:59.238	debug	(14449) [iobroker/mount] first mount attempt with smb option failed. try next mount attempt without smb option ...
      backitup.0	2021-03-28 18:01:55.647	debug	(14449) system.adapter.admin.0: logging false
      backitup.0	2021-03-28 18:01:49.159	debug	(14449) Backup has started ...
      backitup.0	2021-03-28 18:01:49.156	error	(14449) [iobroker] Backup folder not created: Error: EPERM: operation not permitted, chmod '/opt/iobroker/backups'Please reinstall backitup and run "iobroker fix"!!
      backitup.0	2021-03-28 18:01:47.336	debug	(14449) sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"858269950":{"firstName":"Richard"}}
      backitup.0	2021-03-28 18:01:47.333	debug	(14449) telegram-instance: telegram.0
      backitup.0	2021-03-28 18:01:24.555	debug	(14449) Start all Adapter after Restore enabled
      backitup.0	2021-03-28 18:01:16.924	debug	(14449) detect last backup file: iobroker_2021_03_28-11_31_14_ioBrokerPV_backupiobroker.tar.gz
      backitup.0	2021-03-28 18:01:16.921	debug	(14449) detect backup file 8 from cifs: iobroker_2021_03_28-11_31_14_ioBrokerPV_backupiobroker.tar.gz
      backitup.0	2021-03-28 18:01:16.920	debug	(14449) detect backup file 7 from cifs: iobroker_2021_03_28-11_27_22_ioBrokerPV_backupiobroker.tar.gz
      backitup.0	2021-03-28 18:01:16.919	debug	(14449) detect backup file 6 from cifs: iobroker_2021_03_28-10_57_31_ioBrokerPV_backupiobroker.tar.gz
      backitup.0	2021-03-28 18:01:16.918	debug	(14449) detect backup file 5 from cifs: iobroker_2021_03_27-06_15_23_ioBrokerPV_backupiobroker.tar.gz
      backitup.0	2021-03-28 18:01:16.917	debug	(14449) detect backup file 4 from cifs: iobroker_2021_03_27-06_10_22_backupiobroker.tar.gz
      backitup.0	2021-03-28 18:01:16.916	debug	(14449) detect backup file 3 from cifs: iobroker_2021_03_26-06_15_22_ioBrokerPV_backupiobroker.tar.gz
      backitup.0	2021-03-28 18:01:16.915	debug	(14449) detect backup file 2 from cifs: iobroker_2021_03_26-06_10_22_backupiobroker.tar.gz
      backitup.0	2021-03-28 18:01:16.913	debug	(14449) detect backup file 1 from cifs: iobroker_2021_03_25-06_15_24_ioBrokerPV_backupiobroker.tar.gz
      backitup.0	2021-03-28 18:01:16.192	debug	(14449) system.adapter.admin.0: logging true
      backitup.0	2021-03-28 18:01:14.902	error	Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
      backitup.0	2021-03-28 18:01:14.902	error	mount error(16): Device or resource busy
      backitup.0	2021-03-28 18:01:14.902	error	(14449) Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups
      backitup.0	2021-03-28 18:01:14.854	debug	(14449) first mount attempt with smb option failed. try next mount attempt without smb option ...
      backitup.0	2021-03-28 18:01:14.722	debug	(14449) [iobroker] 10 15 06 */1 * *
      backitup.0	2021-03-28 18:01:14.676	info	(14449) [iobroker] backup was activated at 06:15 every 1 day(s)
      backitup.0	2021-03-28 18:01:14.346	info	(14449) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.21.0, js-controller: 3.2.16
      wendy2702 crunchip simatec 3 Replies Last reply Reply Quote 0
      • wendy2702
        wendy2702 @Humidor last edited by
        @humidor sagte in Iobroker backitup error.. Wo liegt das problem:
          crunchip Forum Testing Most Active @Humidor last edited by
          https://forum.iobroker.net/topic/27267/test-adapter-backitup-v2-1-x
          • simatec
            simatec Developer Most Active @Humidor last edited by
            So wie es ausschaut ist bereits ein mount gesetzt
            sudo umount /opt/iobroker/backups
            Humidor 2 Replies Last reply Reply Quote 0
            • Humidor
              @simatec sagte in Iobroker backitup error.. Wo liegt das problem:
              ioBroker fix habe ich gemacht inkl. alles was sonst noch an update usw. zu tun ist
              den unmount habe ich gerade gemacht
              ein gerader gestarteter manueller Backup startet nicht (Fenster bleibt leer)
              log von heute - files wurden am NAS angelegt, Fehlermeldung wurde versandt.
              2021-03-31 06:15:10.291 - error: backitup.0 (32188) [iobroker] Backup folder not created: Error: EPERM: operation not permitted, chmod '/opt/iobroker/backups'Please reinstall backitup and run "iobroker fix"!!
              2021-03-31 06:15:10.300 - debug: backitup.0 (32188) Backup has started ...
              2021-03-31 06:15:21.081 - debug: backitup.0 (32188) [iobroker/mount] first mount attempt with smb option failed. try next mount attempt without smb option ...
              2021-03-31 06:15:21.161 - debug: backitup.0 (32188) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups
              2021-03-31 06:15:21.163 - debug: backitup.0 (32188) [iobroker/mount] mount error(16): Device or resource busy
              2021-03-31 06:15:21.164 - debug: backitup.0 (32188) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
              2021-03-31 06:15:21.165 - debug: backitup.0 (32188) [iobroker/mount] [IGNORED] Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups
              2021-03-31 06:15:21.166 - debug: backitup.0 (32188) [iobroker/mount] mount error(16): Device or resource busy
              2021-03-31 06:15:21.166 - debug: backitup.0 (32188) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
              2021-03-31 06:15:23.856 - debug: backitup.0 (32188) [iobroker/iobroker] host.raspi4iobrokerpv 2149 states saved
              2021-03-31 06:15:23.889 - debug: backitup.0 (32188) [iobroker/iobroker] host.raspi4iobrokerpv 2595 objects saved
              2021-03-31 06:15:27.198 - debug: backitup.0 (32188) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2021_03_31-06_15_21_ioBrokerPV_backupiobroker.tar.gz
              2021-03-31 06:15:28.251 - debug: backitup.0 (32188) [iobroker/iobroker] done
              2021-03-31 06:15:29.089 - debug: backitup.0 (32188) [iobroker/historyDB] The following files were found for the backup: 20210202,20210203,20210204,20210205,20210206,20210207,20210208,20210209,20210210,20210211,20210212,20210213,20210214,20210215,20210216,20210217,20210218,20210219,20210220,20210221,20210222,20210223,20210224,20210225,20210226,20210227,20210228,20210301,20210302,20210303,20210304,20210305,20210306,20210307,20210308,20210309,20210310,20210311,20210312,20210313,20210314,20210315,20210316,20210317,20210318,20210319,20210320,20210321,20210322,20210323,20210324,20210325,20210326,20210327,20210328,20210329,20210330,20210331
              2021-03-31 06:15:39.048 - debug: backitup.0 (32188) [iobroker/historyDB] Packed 11MB so far...
              2021-03-31 06:15:49.042 - debug: backitup.0 (32188) [iobroker/historyDB] Packed 21MB so far...
              2021-03-31 06:15:57.276 - debug: backitup.0 (32188) [iobroker/historyDB] Backup created: /opt/iobroker/backups/historyDB_2021_03_31-06_15_29_backupiobroker.tar.gz
              2021-03-31 06:15:57.278 - debug: backitup.0 (32188) [iobroker/historyDB] done
              2021-03-31 06:15:58.336 - debug: backitup.0 (32188) [iobroker/cifs] done
              2021-03-31 06:15:58.942 - debug: backitup.0 (32188) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
              2021-03-31 06:15:58.944 - debug: backitup.0 (32188) [iobroker/clean] done
              2021-03-31 06:15:59.413 - debug: backitup.0 (32188) [iobroker/telegram] [iobroker] used Telegram-Instance: telegram.0
              2021-03-31 06:15:59.425 - debug: backitup.0 (32188) sendTo "send" to system.adapter.telegram.0 from system.adapter.backitup.0
              2021-03-31 06:15:59.428 - debug: backitup.0 (32188) [iobroker/telegram] done
              2021-03-31 06:15:59.734 - debug: backitup.0 (32188) [iobroker/historyHTML] new history html values created
              2021-03-31 06:15:59.736 - debug: backitup.0 (32188) [iobroker/historyHTML] done
              2021-03-31 06:15:59.894 - debug: backitup.0 (32188) [iobroker/historyJSON] new history json values created
              2021-03-31 06:15:59.895 - debug: backitup.0 (32188) [iobroker/historyJSON] done
              • Humidor
                @simatec
                gerade gemacht:
                iobroker stop
                sudo apt-get update
                sudo apt-get upgrade
                iobroker fix
                curl -fsL https://iobroker.net/fix.sh | bash -
                iobroker start
                ... gewartet bis wieder alle Adapter online sind....
                manuelles Backup gestartet
                Adapter 2.0.4 - schaut gut aus, file ohne Fehler angelegt.
                2021-03-31 08:08:07.487 - debug: backitup.0 (24853) Redis Objects: Use Redis connection: 127.0.0.1:9001
                2021-03-31 08:08:07.527 - debug: backitup.0 (24853) Objects client ready ... initialize now
                2021-03-31 08:08:07.530 - debug: backitup.0 (24853) Objects create System PubSub Client
                2021-03-31 08:08:07.531 - debug: backitup.0 (24853) Objects create User PubSub Client
                2021-03-31 08:08:07.532 - debug: backitup.0 (24853) Objects client initialize lua scripts
                2021-03-31 08:08:07.545 - debug: backitup.0 (24853) Objects connected to redis: 127.0.0.1:9001
                2021-03-31 08:08:07.554 - debug: backitup.0 (24853) objectDB connected
                2021-03-31 08:08:07.557 - debug: backitup.0 (24853) Redis States: Use Redis connection: 127.0.0.1:9000
                2021-03-31 08:08:07.565 - debug: backitup.0 (24853) States create System PubSub Client
                2021-03-31 08:08:07.566 - debug: backitup.0 (24853) States create User PubSub Client
                2021-03-31 08:08:07.574 - debug: backitup.0 (24853) States connected to redis: 127.0.0.1:9000
                2021-03-31 08:08:07.575 - debug: backitup.0 (24853) statesDB connected
                2021-03-31 08:08:08.090 - debug: backitup.0 (24853) Plugin sentry Initialize Plugin (enabled=true)
                2021-03-31 08:08:08.348 - info: backitup.0 (24853) starting. Version 2.0.4 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.0, js-controller: 3.2.16
                2021-03-31 08:08:08.446 - info: backitup.0 (24853) [iobroker] backup was activated at 06:15 every 1 day(s)
                2021-03-31 08:08:08.485 - debug: backitup.0 (24853) [iobroker] 10 15 06 */1 * *
                2021-03-31 08:08:09.122 - debug: backitup.0 (24853) mount successfully completed
                2021-03-31 08:08:11.097 - info: host.raspi4iobrokerpv instance system.adapter.vis.0 terminated while should be started once
                2021-03-31 08:08:11.205 - debug: backitup.0 (24853) detect backup file 1 from cifs: iobroker_2021_03_25-06_15_24_ioBrokerPV_backupiobroker.tar.gz
                2021-03-31 08:08:11.206 - debug: backitup.0 (24853) detect backup file 2 from cifs: iobroker_2021_03_26-06_10_22_backupiobroker.tar.gz
                2021-03-31 08:08:11.207 - debug: backitup.0 (24853) detect backup file 3 from cifs: iobroker_2021_03_26-06_15_22_ioBrokerPV_backupiobroker.tar.gz
                2021-03-31 08:08:11.207 - debug: backitup.0 (24853) detect backup file 4 from cifs: iobroker_2021_03_27-06_10_22_backupiobroker.tar.gz
                2021-03-31 08:08:11.208 - debug: backitup.0 (24853) detect backup file 5 from cifs: iobroker_2021_03_27-06_15_23_ioBrokerPV_backupiobroker.tar.gz
                2021-03-31 08:08:11.208 - debug: backitup.0 (24853) detect backup file 6 from cifs: iobroker_2021_03_28-10_57_31_ioBrokerPV_backupiobroker.tar.gz
                2021-03-31 08:08:11.209 - debug: backitup.0 (24853) detect backup file 7 from cifs: iobroker_2021_03_28-11_27_22_ioBrokerPV_backupiobroker.tar.gz
                2021-03-31 08:08:11.210 - debug: backitup.0 (24853) detect backup file 8 from cifs: iobroker_2021_03_28-11_31_14_ioBrokerPV_backupiobroker.tar.gz
                2021-03-31 08:08:11.210 - debug: backitup.0 (24853) detect backup file 9 from cifs: iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz
                2021-03-31 08:08:11.211 - debug: backitup.0 (24853) detect backup file 10 from cifs: iobroker_2021_03_29-06_15_21_ioBrokerPV_backupiobroker.tar.gz
                2021-03-31 08:08:11.211 - debug: backitup.0 (24853) detect backup file 11 from cifs: iobroker_2021_03_30-06_15_21_ioBrokerPV_backupiobroker.tar.gz
                2021-03-31 08:08:11.212 - debug: backitup.0 (24853) detect backup file 12 from cifs: iobroker_2021_03_30-07_26_27_ioBrokerPV_backupiobroker.tar.gz
                2021-03-31 08:08:11.213 - debug: backitup.0 (24853) detect backup file 13 from cifs: iobroker_2021_03_31-06_15_21_ioBrokerPV_backupiobroker.tar.gz
                2021-03-31 08:08:11.215 - debug: backitup.0 (24853) detect last backup file: iobroker_2021_03_31-06_15_21_ioBrokerPV_backupiobroker.tar.gz
                2021-03-31 08:08:11.851 - info: host.raspi4iobrokerpv instance system.adapter.shelly.0 started with pid 24897
                2021-03-31 08:08:15.998 - info: host.raspi4iobrokerpv instance system.adapter.influxdb.0 started with pid 24912
                2021-03-31 08:08:18.174 - info: influxdb.0 (24912) starting. Version 1.9.4 in /opt/iobroker/node_modules/iobroker.influxdb, node: v12.22.0, js-controller: 3.2.16
                2021-03-31 08:08:18.223 - info: influxdb.0 (24912) No stored data from last exit found
                2021-03-31 08:08:18.225 - info: influxdb.0 (24912) Connecting http://localhost:8086 ...
                2021-03-31 08:08:18.324 - info: influxdb.0 (24912) enabled logging of kecontact.0.pf, Alias=false, 1 points now activated
                2021-03-31 08:08:18.325 - info: influxdb.0 (24912) enabled logging of kecontact.0.p, Alias=false, 2 points now activated
                2021-03-31 08:08:18.326 - info: influxdb.0 (24912) enabled logging of kecontact.0.i3, Alias=false, 3 points now activated
                2021-03-31 08:08:18.327 - info: influxdb.0 (24912) enabled logging of kecontact.0.i2, Alias=false, 4 points now activated
                2021-03-31 08:08:18.328 - info: influxdb.0 (24912) enabled logging of kecontact.0.i1, Alias=false, 5 points now activated
                2021-03-31 08:08:18.329 - info: influxdb.0 (24912) enabled logging of kecontact.0.u3, Alias=false, 6 points now activated
                2021-03-31 08:08:18.330 - info: influxdb.0 (24912) enabled logging of kecontact.0.u2, Alias=false, 7 points now activated
                2021-03-31 08:08:18.331 - info: influxdb.0 (24912) enabled logging of kecontact.0.u1, Alias=false, 8 points now activated
                2021-03-31 08:08:18.332 - info: influxdb.0 (24912) enabled logging of kecontact.0.currentUser, Alias=false, 9 points now activated
                2021-03-31 08:08:18.333 - info: influxdb.0 (24912) enabled logging of kecontact.0.enableUser, Alias=false, 10 points now activated
                2021-03-31 08:08:18.334 - info: influxdb.0 (24912) enabled logging of 0_userdata.0.AMIS.170, Alias=false, 11 points now activated
                2021-03-31 08:08:18.335 - info: influxdb.0 (24912) enabled logging of 0_userdata.0.AMIS.270, Alias=false, 12 points now activated
                2021-03-31 08:08:18.336 - info: influxdb.0 (24912) enabled logging of shelly.0.SHPLG-S#EED8F9#1.Relay0.Switch, Alias=false, 13 points now activated
                2021-03-31 08:08:18.337 - info: influxdb.0 (24912) enabled logging of shelly.0.SHPLG-S#EED8F9#1.Relay0.Power, Alias=false, 14 points now activated
                2021-03-31 08:08:18.338 - info: influxdb.0 (24912) enabled logging of 0_userdata.0.AMIS.Power, Alias=false, 15 points now activated
                2021-03-31 08:08:18.339 - info: influxdb.0 (24912) enabled logging of modbus.0.inputRegisters.30537_Tagesertrag_kWh, Alias=false, 16 points now activated
                2021-03-31 08:08:18.340 - info: influxdb.0 (24912) enabled logging of modbus.0.inputRegisters.30775_PVLeistung, Alias=false, 17 points now activated
                2021-03-31 08:08:18.341 - info: influxdb.0 (24912) enabled logging of javascript.0.Solar.Wechselrichter.PVLeistungAktuell, Alias=false, 18 points now activated
                2021-03-31 08:08:18.342 - info: influxdb.0 (24912) enabled logging of modbus.1.holdingRegisters.40083_I_AC_Leistung, Alias=false, 19 points now activated
                2021-03-31 08:08:18.343 - info: influxdb.0 (24912) enabled logging of modbus.1.holdingRegisters.40093_I_AC_Energie_WH, Alias=false, 20 points now activated
                2021-03-31 08:08:18.353 - info: influxdb.0 (24912) enabled logging of 0_userdata.0.AMIS.PVPower, Alias=false, 21 points now activated
                2021-03-31 08:08:18.354 - info: influxdb.0 (24912) enabled logging of 0_userdata.0.AMIS.PVÜberschuss, Alias=false, 22 points now activated
                2021-03-31 08:08:18.355 - info: influxdb.0 (24912) enabled logging of javascript.0.Solar.Wechselrichter.PVLeistungAktuellSMA, Alias=false, 23 points now activated
                2021-03-31 08:08:18.356 - info: influxdb.0 (24912) enabled logging of fuelpricemonitor.0.zuHome_Diesel.0.prices.0.amount, Alias=false, 24 points now activated
                2021-03-31 08:08:18.357 - info: influxdb.0 (24912) enabled logging of virtualpowermeter.0.group_grid.VPM_170_Actual, Alias=false, 25 points now activated
                2021-03-31 08:08:18.358 - info: influxdb.0 (24912) enabled logging of virtualpowermeter.0.group_grid.VPM_270_Actual, Alias=false, 26 points now activated
                2021-03-31 08:08:18.359 - info: influxdb.0 (24912) enabled logging of virtualpowermeter.0.group_PowerBank.Virtual_Energy_Power_Powerbank, Alias=false, 27 points now activated
                2021-03-31 08:08:18.360 - info: influxdb.0 (24912) enabled logging of virtualpowermeter.0.group_PowerBank.Virtual_Energy_Total_Powerbank, Alias=false, 28 points now activated
                2021-03-31 08:08:18.394 - info: influxdb.0 (24912) Connected!
                2021-03-31 08:08:18.443 - debug: backitup.0 (24853) mount activ... umount in 2 Seconds!!
                2021-03-31 08:08:19.844 - info: host.raspi4iobrokerpv instance system.adapter.vis-inventwo.0 started with pid 24951
                2021-03-31 08:08:20.507 - debug: backitup.0 (24853) umount successfully completed
                2021-03-31 08:08:23.918 - info: host.raspi4iobrokerpv instance system.adapter.modbus.0 started with pid 24970
                2021-03-31 08:08:27.916 - info: host.raspi4iobrokerpv instance system.adapter.modbus.1 started with pid 24991
                2021-03-31 08:08:31.809 - info: host.raspi4iobrokerpv instance scheduled system.adapter.zoe2.0 */10 * * * *
                2021-03-31 08:08:35.850 - info: host.raspi4iobrokerpv instance system.adapter.info.0 started with pid 25021
                2021-03-31 08:08:39.889 - info: host.raspi4iobrokerpv instance system.adapter.life360.0 started with pid 25130
                2021-03-31 08:08:43.905 - info: host.raspi4iobrokerpv instance system.adapter.fritzdect.0 started with pid 25517
                2021-03-31 08:08:47.741 - debug: backitup.0 (24853) system.adapter.admin.0: logging false
                2021-03-31 08:08:47.862 - info: host.raspi4iobrokerpv instance scheduled system.adapter.fuelpricemonitor.0 25 */20 * * * *
                2021-03-31 08:08:47.887 - info: host.raspi4iobrokerpv instance system.adapter.fuelpricemonitor.0 started with pid 25539
                2021-03-31 08:08:50.014 - info: fuelpricemonitor.0 (25539) starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.fuelpricemonitor, node: v12.22.0, js-controller: 3.2.16
                2021-03-31 08:08:51.962 - info: host.raspi4iobrokerpv instance system.adapter.virtualpowermeter.0 started with pid 25568
                2021-03-31 08:08:54.142 - info: virtualpowermeter.0 (25568) starting. Version 1.4.2 in /opt/iobroker/node_modules/iobroker.virtualpowermeter, node: v12.22.0, js-controller: 3.2.16
                2021-03-31 08:08:54.214 - info: virtualpowermeter.0 (25568) inital all Objects
                2021-03-31 08:08:54.394 - info: virtualpowermeter.0 (25568) initial 0_userdata.0.AMIS.170
                2021-03-31 08:08:54.506 - info: virtualpowermeter.0 (25568) initial done 0_userdata.0.AMIS.170 Destination Power: virtualpowermeter.0.group_grid.Virtual_Energy_Power_170 Destination EnergyTotal: virtualpowermeter.0.group_grid.Virtual_Energy_Total_170 Destination Group: virtualpowermeter.0.group_grid.
                2021-03-31 08:08:54.507 - info: virtualpowermeter.0 (25568) initial 0_userdata.0.AMIS.270
                2021-03-31 08:08:54.551 - info: virtualpowermeter.0 (25568) initial done 0_userdata.0.AMIS.270 Destination Power: virtualpowermeter.0.group_grid.Virtual_Energy_Power_270 Destination EnergyTotal: virtualpowermeter.0.group_grid.Virtual_Energy_Total_270 Destination Group: virtualpowermeter.0.group_grid.
                2021-03-31 08:08:54.556 - info: virtualpowermeter.0 (25568) initial fritzdect.0.DECT_116300118701.power
                2021-03-31 08:08:54.580 - info: virtualpowermeter.0 (25568) initial done fritzdect.0.DECT_116300118701.power Destination Power: virtualpowermeter.0.group_PowerBank.Virtual_Energy_Power_Powerbank Destination EnergyTotal: virtualpowermeter.0.group_PowerBank.Virtual_Energy_Total_Powerbank Destination Group: virtualpowermeter.0.group_PowerBank.
                2021-03-31 08:08:54.672 - info: virtualpowermeter.0 (25568) initial completed
                2021-03-31 08:08:54.882 - info: fuelpricemonitor.0 (25539) Terminated (NO_ERROR): Without reason
                2021-03-31 08:08:55.400 - info: fuelpricemonitor.0 (25539) cleaned everything up...
                2021-03-31 08:08:55.460 - info: host.raspi4iobrokerpv instance system.adapter.fuelpricemonitor.0 terminated with code 0 (NO_ERROR)
                2021-03-31 08:09:05.222 - debug: backitup.0 (24853) telegram-instance: telegram.0
                2021-03-31 08:09:05.227 - debug: backitup.0 (24853) sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"858269950":{"firstName":"Richard"}}
                2021-03-31 08:09:09.554 - debug: backitup.0 (24853) Backup has started ...
                2021-03-31 08:09:20.003 - debug: backitup.0 (24853) [iobroker/mount] mount successfully completed
                2021-03-31 08:09:20.007 - debug: backitup.0 (24853) [iobroker/mount] done
                2021-03-31 08:09:22.797 - debug: backitup.0 (24853) [iobroker/iobroker] host.raspi4iobrokerpv 2160 states saved
                2021-03-31 08:09:22.820 - debug: backitup.0 (24853) [iobroker/iobroker] host.raspi4iobrokerpv 2595 objects saved
                2021-03-31 08:09:26.163 - debug: backitup.0 (24853) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2021_03_31-08_09_20_ioBrokerPV_backupiobroker.tar.gz
                2021-03-31 08:09:27.265 - debug: backitup.0 (24853) [iobroker/iobroker] done
                2021-03-31 08:09:28.134 - debug: backitup.0 (24853) [iobroker/historyDB] The following files were found for the backup: 20210202,20210203,20210204,20210205,20210206,20210207,20210208,20210209,20210210,20210211,20210212,20210213,20210214,20210215,20210216,20210217,20210218,20210219,20210220,20210221,20210222,20210223,20210224,20210225,20210226,20210227,20210228,20210301,20210302,20210303,20210304,20210305,20210306,20210307,20210308,20210309,20210310,20210311,20210312,20210313,20210314,20210315,20210316,20210317,20210318,20210319,20210320,20210321,20210322,20210323,20210324,20210325,20210326,20210327,20210328,20210329,20210330,20210331
                2021-03-31 08:09:38.090 - debug: backitup.0 (24853) [iobroker/historyDB] Packed 11MB so far...
                2021-03-31 08:09:48.187 - debug: backitup.0 (24853) [iobroker/historyDB] Packed 21MB so far...
                2021-03-31 08:09:48.507 - debug: backitup.0 (24853) system.adapter.admin.0: logging true
                2021-03-31 08:09:56.738 - debug: backitup.0 (24853) [iobroker/historyDB] Backup created: /opt/iobroker/backups/historyDB_2021_03_31-08_09_28_backupiobroker.tar.gz
                2021-03-31 08:09:56.750 - debug: backitup.0 (24853) [iobroker/historyDB] done
                2021-03-31 08:09:57.815 - debug: backitup.0 (24853) [iobroker/cifs] done
                2021-03-31 08:09:58.417 - debug: backitup.0 (24853) [iobroker/clean] done
                2021-03-31 08:09:58.878 - debug: backitup.0 (24853) [iobroker/telegram] [iobroker] used Telegram-Instance: telegram.0
                2021-03-31 08:09:58.886 - debug: backitup.0 (24853) [iobroker/telegram] done
                2021-03-31 08:09:59.198 - debug: backitup.0 (24853) [iobroker/historyHTML] new history html values created
                2021-03-31 08:09:59.201 - debug: backitup.0 (24853) [iobroker/historyHTML] done
                2021-03-31 08:09:59.367 - debug: backitup.0 (24853) [iobroker/historyJSON] new history json values created
                2021-03-31 08:09:59.369 - debug: backitup.0 (24853) [iobroker/historyJSON] done
                2021-03-31 08:09:59.565 - debug: backitup.0 (24853) [iobroker/umount] mount activ, umount is started ...
                2021-03-31 08:10:00.114 - info: host.raspi4iobrokerpv instance system.adapter.zoe2.0 started with pid 25752
                2021-03-31 08:10:04.622 - debug: backitup.0 (24853) [iobroker/umount] umount successfully completed
                2021-03-31 08:10:04.623 - debug: backitup.0 (24853) [iobroker/umount] done
                2021-03-31 08:10:04.775 - debug: backitup.0 (24853) [iobroker] exec: done
                  arne007 last edited by
                  Habe meinen Pi komplett neu aufgesetzt und wollte jetzt influxDB und Grafana aus dem Backup wiederherstellen. Bekomme jedoch nur folgende Fehlermeldung. Weiß jmd wie ich das Problem löse.
                  ckitup.0
                  2021-11-26 10:56:12.941	error	[influxDB] infuxDB Restore not completed
                  backitup.0
                  2021-11-26 10:56:12.939	error	[influxDB] Error: EPERM: operation not permitted, utime '/opt/iobroker/backups/influxDBtmp/'
                  backitup.0
                  2021-11-26 10:49:31.947	error	[grafana] Error: EPERM: operation not permitted, utime '/opt/iobroker/backups/grafana_tmp/'
                  backitup.0
                  2021-11-26 10:49:31.945	error	[grafana] Grafana restore not completed
                  backitup.0
                  2021-11-26 10:49:20.599	error	Error: Command failed: sudo mount -t cifs -o username=Arne,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.10/homes/Backup_ioBroker /opt/iobroker/backupsmount error(16): Device or resource busyRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                  backitup.0
                  2021-11-26 10:49:09.218	error	[influxDB] infuxDB Restore not completed
                  backitup.0
                  2021-11-26 10:49:09.211	error	[influxDB] Error: EPERM: operation not permitted, utime '/opt/iobroker/backups/influxDBtmp/'
                  • simatec
                    simatec Developer Most Active @arne007 last edited by
                    @arne007 sagte in Iobroker backitup error.. Wo liegt das problem:
                    Du hast keine Schreibrechte. Wo liegt das Backup? Versuchst du den restore lokal oder über NAS oder der Gleichen herzustellen?
                      arne007 @simatec last edited by arne007
                      @simatec said in Iobroker backitup error.. Wo liegt das problem:
                      über NAS. Welche Schreibrechte muss ich wie / wo ändern?
                      • simatec
                        @arne007 Mit den Angaben von dir kann ich dir das nicht beantworten.
                        cifs-utils installiert?
                        NAS konfiguriert?
                        NAS Config und Backitup Config?
                        fu_zhou 1 Reply Last reply Reply Quote 0
                        • fu_zhou
                          fu_zhou @simatec last edited by
                          @simatec Mhm... ich habe das selbe Problem. Backups werden auf dem NAS angelegt, CIFS-utils sind installiert, die Backups werden auch auf dem NAS gefunden und angezeigt, nur wiederherstellen möchte Backitup nicht:
                          eError: {"errno":-1,"code":"EPERM","syscall":"utime","path":"/opt/iobroker/backups/tmpScripts/"}
                          • simatec
                            simatec Developer Most Active @fu_zhou last edited by
                            @fu_zhou Bitte poste den vollständigen Debuglog und deine Config. Was nutzt du für ein NAS und was hast du dort für Einstellungen?
                            • fu_zhou
                              @simatec Das ist ein älterer Synology Diskstation DS411j.
                              Der in Backitup eingetragene Nutzer hat volle Rechte auf die Ordner, es ist SMB, FTP aktiviert, AFP, NFS, rsync sind nicht aktiviert.
                              Config sieht so aus:
                              Beim SMB Typ habe ich mal auf Verdacht SMB3.0 eingetragen, im NAS kann man SMB3 einstellen, nicht 3.0.2 oder 3.1.1
                              Wie gesagt, die Backups werden auf dem NAS gemacht.
                              Debuglog kommt morgen noch.
                              Danke schon mal!
                              Humidor 1 Reply Last reply Reply Quote 0
                              • Humidor
                                Humidor @fu_zhou last edited by
                                @fu_zhou ich habe SMB 2.0, 3.0 hatte bei mir auch Fehler ausgegeben
                                • fu_zhou
                                  fu_zhou @Humidor last edited by
                                  @humidor Hat nichts geholfen, ich glaube, es liegt an den Rechten (gibt schon einen Thread dazu unter dem Stichwort "utime"). Muss ich mich mal mit beschäftigen, wie das mit den Rechten auf dem NAS ist. Wenn der NAS-Ordner gemountet wird (in /opt/iobroker/backups) gehört der Ordner "backups" root root, kann ich auch nicht ändern mit chown oder so.
                                  • stony2k
                                    stony2k last edited by
                                    Ich bin vom Raspberry Pi zu Proxmos auf einem LCX Container gewechselt. Hier arbeite ich direkt mit dem User root. Mein Backup liegt auf einem NAS. Leider kann ich mein InfluxDB Backup nicht einspielen. Hier ist die Log:
                                    2021-12-05 09:58:45.783 - debug: backitup.0 (5245) nfs-mount command: "sudo mount stony-nas:volume1/public/Sicherungen/ioBroker /opt/iobroker/backups"
                                    2021-12-05 09:58:45.805 - debug: backitup.0 (5245) device is busy... wait 2 Minutes!!
                                    2021-12-05 09:58:45.856 - debug: backitup.0 (5245) mount successfully completed
                                    2021-12-05 09:58:47.898 - debug: backitup.0 (5245) detect backup file 1 from cifs: iobroker_2021_10_10-02_00_20_backupiobroker.tar.gz
                                    2021-12-05 09:58:47.898 - debug: backitup.0 (5245) detect backup file 2 from cifs: iobroker_2021_10_13-02_00_20_backupiobroker.tar.gz
                                    2021-12-05 09:58:47.898 - debug: backitup.0 (5245) detect backup file 3 from cifs: iobroker_2021_10_16-02_00_20_backupiobroker.tar.gz
                                    2021-12-05 09:58:47.898 - debug: backitup.0 (5245) detect backup file 4 from cifs: iobroker_2021_10_19-02_00_20_backupiobroker.tar.gz
                                    2021-12-05 09:58:47.899 - debug: backitup.0 (5245) detect backup file 5 from cifs: iobroker_2021_10_22-02_00_20_backupiobroker.tar.gz
                                    2021-12-05 09:58:47.899 - debug: backitup.0 (5245) detect backup file 6 from cifs: iobroker_2021_10_25-02_00_20_backupiobroker.tar.gz
                                    2021-12-05 09:58:47.899 - debug: backitup.0 (5245) detect backup file 7 from cifs: iobroker_2021_10_28-02_00_20_backupiobroker.tar.gz
                                    2021-12-05 09:58:47.899 - debug: backitup.0 (5245) detect backup file 8 from cifs: iobroker_2021_10_31-02_00_20_backupiobroker.tar.gz
                                    2021-12-05 09:58:47.899 - debug: backitup.0 (5245) detect backup file 9 from cifs: iobroker_2021_11_01-02_00_20_backupiobroker.tar.gz
                                    2021-12-05 09:58:47.899 - debug: backitup.0 (5245) detect backup file 10 from cifs: iobroker_2021_11_04-02_00_20_backupiobroker.tar.gz
                                    2021-12-05 09:58:47.899 - debug: backitup.0 (5245) detect backup file 11 from cifs: iobroker_2021_11_07-02_00_20_backupiobroker.tar.gz
                                    2021-12-05 09:58:47.899 - debug: backitup.0 (5245) detect backup file 12 from cifs: iobroker_2021_11_10-02_00_20_backupiobroker.tar.gz
                                    2021-12-05 09:58:47.899 - debug: backitup.0 (5245) detect backup file 13 from cifs: iobroker_2021_11_13-02_00_20_backupiobroker.tar.gz
                                    2021-12-05 09:58:47.900 - debug: backitup.0 (5245) detect backup file 14 from cifs: iobroker_2021_11_16-02_00_20_backupiobroker.tar.gz
                                    2021-12-05 09:58:47.900 - debug: backitup.0 (5245) detect backup file 15 from cifs: iobroker_2021_11_19-02_00_20_backupiobroker.tar.gz
                                    2021-12-05 09:58:47.900 - debug: backitup.0 (5245) detect backup file 16 from cifs: iobroker_2021_11_22-02_00_20_backupiobroker.tar.gz
                                    2021-12-05 09:58:47.900 - debug: backitup.0 (5245) detect backup file 17 from cifs: iobroker_2021_11_25-02_00_20_backupiobroker.tar.gz
                                    2021-12-05 09:58:47.900 - debug: backitup.0 (5245) detect backup file 18 from cifs: iobroker_2021_11_28-02_00_20_backupiobroker.tar.gz
                                    2021-12-05 09:58:47.900 - debug: backitup.0 (5245) detect backup file 19 from cifs: iobroker_2021_12_01-02_00_20_backupiobroker.tar.gz
                                    2021-12-05 09:58:47.900 - debug: backitup.0 (5245) detect backup file 20 from cifs: iobroker_2021_12_04-02_00_20_backupiobroker.tar.gz
                                    2021-12-05 09:58:47.900 - debug: backitup.0 (5245) detect backup file 21 from cifs: iobroker_2021_12_04-22_32_23_backupiobroker.tar.gz
                                    2021-12-05 09:58:47.900 - debug: backitup.0 (5245) detect backup file 22 from cifs: iobroker_2021_12_05-09_43_18_backupiobroker.tar.gz
                                    2021-12-05 09:58:47.901 - debug: backitup.0 (5245) detect last backup file: iobroker_2021_12_05-09_43_18_backupiobroker.tar.gz
                                    2021-12-05 09:58:49.723 - debug: backitup.0 (5245) sendTo "getSystemInfo" to system.adapter.admin.0 from system.adapter.backitup.0: linux
                                    2021-12-05 09:58:51.268 - debug: backitup.0 (5245) nfs-mount command: "sudo mount stony-nas:volume1/public/Sicherungen/ioBroker /opt/iobroker/backups"
                                    2021-12-05 09:58:51.271 - debug: backitup.0 (5245) Backup list be read ...
                                    2021-12-05 09:58:51.284 - debug: backitup.0 (5245) device is busy... wait 2 Minutes!!
                                    2021-12-05 09:58:51.331 - debug: backitup.0 (5245) mount successfully completed
                                    2021-12-05 09:58:53.335 - debug: backitup.0 (5245) sendTo "list" to system.adapter.admin.0 from system.adapter.backitup.0
                                    2021-12-05 09:58:55.755 - debug: backitup.0 (5245) mount activ... umount in 2 Seconds!!
                                    2021-12-05 09:58:57.092 - debug: backitup.0 (5245) [influxDB] Try deleting the old InfluxDB tmp directory
                                    2021-12-05 09:58:57.094 - debug: backitup.0 (5245) [influxDB] Created tmp directory
                                    2021-12-05 09:58:57.095 - debug: backitup.0 (5245) [influxDB] Start infuxDB Restore ...
                                    2021-12-05 09:58:57.125 - error: backitup.0 (5245) [influxDB] Error: EACCES: permission denied, utime '/opt/iobroker/backups/influxDBtmp/'
                                    2021-12-05 09:58:57.125 - error: backitup.0 (5245) [influxDB] infuxDB Restore not completed
                                    Der NAS Zugriff funztioniert. Auch konnte ich über den Adapter das, auf dem NAS befindliche, ioBroker Backup wieder einspielen. Der user iobroker hat auf den Ordner auch Rechte:
                                    root@iobroker:~# ls -la /opt/iobroker/backups
                                    total 8
                                    drwxrwxrwx+ 2 iobroker iobroker 4096 Dec  4 21:32 .
                                    drwxrwxr-x+ 6 iobroker iobroker 4096 Dec  5 09:55 ..
                                    Könnt ihr mir helfen?
                                    simatec Thomas Braun 2 Replies Last reply Reply Quote 0
                                    • simatec
                                      simatec Developer Most Active @stony2k last edited by
                                      @stony2k Wie im Log zu sehen, hast du ein Rechteproblem.
                                      Da du mit komplett mit root unterwegs bist, würde ich dir raten, nochmal von vorne anzufangen und dann mit einer vernünftigen Userstruktur arbeiten
                                        Thomas Braun Most Active @stony2k last edited by
                                        @stony2k sagte in Iobroker backitup error.. Wo liegt das problem:
                                        Warum? Das macht man nicht.
                                        stony2k 1 Reply Last reply Reply Quote 1
                                        • stony2k
                                          stony2k @Thomas Braun last edited by
                                          @thomas-braun Weil das der Standardnutzer im Container war. Aber ich gebe dir recht. Aktuell probiere ich aus, wie sich das in einer virtuellen Maschine verhält, außerhalb von einem Container. Hier werde ich auch mit einem nicht-root User arbeiten.
                                            Es sollte genauso Standard und erste Aktion im Container sein sich einen User anzulegen.
                                            156
                                            19319
