    4. [Neuer Adapter] EuSec
      locito09 @Mike Hellracer last edited by
      @mike-hellracer sagte in [Neuer Adapter] Eufy-Security:
      Authentifizierung
      schalte mal die 2Fa Authentifizierung aus
      C 1 Reply Last reply Reply Quote 1
        Chrille1507 @locito09 last edited by
        @locito09 Das war es!!!
        Herzlichen Dank 🙂
        D4RKKN1GHT84 1 Reply Last reply Reply Quote 0
        • D4RKKN1GHT84
          D4RKKN1GHT84 @Chrille1507 last edited by
          @chrille1507 Direkt in App deaktiviert?? Hab ich gemacht aber kommt leider immernoch....
            chiroptera @bropat last edited by
            @bropat Habe eben gerade Fehler im Log entdeckt, die irgend etwas mit der Push Benachrichtigung zu tun haben.
            2021-11-24 18:27:01.034 - info: eufy-security.0 (3593) Push notification connection closed
            2021-11-24 18:27:01.035 - info: eufy-security.0 (3593) Disconnect from station T8010N23204602E6
            2021-11-24 18:27:01.038 - info: eufy-security.0 (3593) terminating
            2021-11-24 18:27:01.040 - info: eufy-security.0 (3593) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2021-11-24 18:27:01.043 - info: eufy-security.0 (3593) Disconnected from station T8010N23204602E6
            2021-11-24 18:27:02.055 - info: host.ioBroker stopInstance system.adapter.eufy-security.0 killing pid 3593
            2021-11-24 18:27:02.489 - info: host.ioBroker instance system.adapter.eufy-security.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2021-11-24 18:27:02.693 - info: host.ioBroker instance system.adapter.web.0 started with pid 12859
            2021-11-24 18:27:04.153 - info: host.ioBroker instance system.adapter.eufy-security.0 started with pid 12870
            2021-11-24 18:27:04.950 - info: web.0 (12859) starting. Version 3.4.9 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.5, js-controller: 3.3.18
            2021-11-24 18:27:05.350 - info: web.0 (12859) socket.io server listening on port 8082
            2021-11-24 18:27:05.372 - info: web.0 (12859) Connect extension "eufy-security/build/lib/web.js"
            2021-11-24 18:27:05.379 - info: web.0 (12859) http server listening on port 8082
            2021-11-24 18:27:05.963 - debug: eufy-security.0 (12870) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2021-11-24 18:27:06.198 - debug: eufy-security.0 (12870) Objects client ready ... initialize now
            2021-11-24 18:27:06.200 - debug: eufy-security.0 (12870) Objects create System PubSub Client
            2021-11-24 18:27:06.208 - debug: eufy-security.0 (12870) Objects create User PubSub Client
            2021-11-24 18:27:06.210 - debug: eufy-security.0 (12870) Objects client initialize lua scripts
            2021-11-24 18:27:06.237 - debug: eufy-security.0 (12870) Objects connected to redis: 127.0.0.1:9001
            2021-11-24 18:27:06.243 - silly: eufy-security.0 (12870) redis psubscribe cfg.o.system.user.*
            2021-11-24 18:27:06.252 - debug: eufy-security.0 (12870) objectDB connected
            2021-11-24 18:27:06.255 - debug: eufy-security.0 (12870) Redis States: Use Redis connection: 127.0.0.1:9000
            2021-11-24 18:27:06.275 - debug: eufy-security.0 (12870) States create System PubSub Client
            2021-11-24 18:27:06.277 - debug: eufy-security.0 (12870) States create User PubSub Client
            2021-11-24 18:27:06.291 - debug: eufy-security.0 (12870) States connected to redis: 127.0.0.1:9000
            2021-11-24 18:27:06.292 - debug: eufy-security.0 (12870) statesDB connected
            2021-11-24 18:27:06.359 - warn: web.0 (12859) State "web.0.info.connection" has no existing object, this might lead to an error in future versions
            2021-11-24 18:27:06.542 - info: eufy-security.0 (12870) starting. Version 0.7.1 in /opt/iobroker/node_modules/iobroker.eufy-security, node: v12.22.5, js-controller: 3.3.18
            2021-11-24 18:27:06.596 - silly: eufy-security.0 (12870) States system redis pmessage system.adapter.eufy-security.0.logLevel/system.adapter.eufy-security.0.logLevel:{"val":"silly","ack":true,"ts":1637778426581,"q":0,"from":"system.adapter.eufy-security.0","lc":1637778426581}
            2021-11-24 18:27:06.678 - debug: eufy-security.0 (12870) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
            2021-11-24 18:27:06.694 - debug: eufy-security.0 (12870) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
            2021-11-24 18:27:06.713 - debug: eufy-security.0 (12870) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
            2021-11-24 18:27:06.778 - debug: eufy-security.0 (12870) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
            2021-11-24 18:27:06.792 - debug: eufy-security.0 (12870) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
            2021-11-24 18:27:06.800 - debug: eufy-security.0 (12870) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
            2021-11-24 18:27:06.808 - debug: eufy-security.0 (12870) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
            2021-11-24 18:27:06.825 - debug: eufy-security.0 (12870) Load previous login_hash: ["8609c239e93f00b21848ad9ed250ab90"]
            2021-11-24 18:27:06.826 - debug: eufy-security.0 (12870) Load previous api_base: ["https://security-app-eu.eufylife.com/v1"]
            2021-11-24 18:27:06.826 - debug: eufy-security.0 (12870) Load previous token: [{"token":"4fedfe0fb2387730a6c76d406439ca76aa222efa797a81fd","tokenExpiration":1638023496000}]
            2021-11-24 18:27:06.829 - debug: eufy-security.0 (12870) [HTTPApi.authenticate] Authenticate and get an access token [{"token":"4fedfe0fb2387730a6c76d406439ca76aa222efa797a81fd","tokenExpiration":"2021-11-27T14:31:36.000Z"}]
            2021-11-24 18:27:06.831 - debug: eufy-security.0 (12870) [HTTPApi.request] Request: [{"method":"get","endpoint":"app/trust_device/list","baseUrl":"https://security-app-eu.eufylife.com/v1","token":"4fedfe0fb2387730a6c76d406439ca76aa222efa797a81fd","headers":{"app_version":"v2.8.0_887","os_type":"android","os_version":"30","phone_model":"IOBROKER","country":"US","language":"de","openudid":"9a7a15b4545b53a4","uid":"","net_type":"wifi","mnc":"02","mcc":"262","sn":"eb207381bd72","Model_type":"PHONE","timezone":"GMT+00:00"}}]
            2021-11-24 18:27:07.018 - debug: eufy-security.0 (12870) [HTTPApi.listTrustDevice] Response: [""]
            2021-11-24 18:27:07.019 - error: eufy-security.0 (12870) Status return code not 200 [{"status":204,"statusText":"No Content"}]
            2021-11-24 18:27:07.020 - debug: eufy-security.0 (12870) [EufySecurity.saveCloudToken] Save cloud token and token expiration [{"token":"4fedfe0fb2387730a6c76d406439ca76aa222efa797a81fd","tokenExpiration":"2021-11-27T14:31:36.000Z"}]
            2021-11-24 18:27:07.023 - debug: eufy-security.0 (12870) [PushNotificationService._open] Login with previous push credentials... [{"fidResponse":{"name":"projects/348804314802/installations/doVTOqkGSoCceZiGgvpEFW","fid":"doVTOqkGSoCceZiGgvpEFW","refreshToken":"2_fDNPBWCmQrGqlSAIOI-6AQmz7HaWxBO8XIy6pRQ3G6KxS9NFlTxqUQPIhonMQ_jR","authToken":{"token":"eyJhbGciOiJFUzI1NiIsInR5cCI6IkpXVCJ9.eyJhcHBJZCI6IjE6MzQ4ODA0MzE0ODAyOmFuZHJvaWQ6NDQwYTY3NzNiMzYyMGRhNyIsImV4cCI6MTYzODI4MjQ2MCwiZmlkIjoiZG9WVE9xa0dTb0NjZVppR2d2cEVGVyIsInByb2plY3ROdW1iZXIiOjM0ODgwNDMxNDgwMn0.AB2LPV8wRAIgf5w1XDqZFbm9OwyI_LB3f3BALGDAmVxIRic6pg3QrhQCIGPRVAMwok4xqcclOAbvBxwk3ZTPb1SfYi1KAlHAoXT-","expiresIn":"604800s","expiresAt":1638282461613}},"checkinResponse":{"statsOk":true,"timeMs":"1637677661901","androidId":"3665856936539641979","securityToken":"5677464626826698121","versionInfo":"o5d_uoi7I1oTQKri541rkWUV5h_T1Bc","deviceDataVersionInfo":"ABFEt1WyLAfufWjl_YfAHRzJw8p4OqL3HnB62dHxYgqYJcT1qfCOD-RSNgSrmrRNUAzFe9hukmSs0DwQVZOv3NhVto8u6gYgKxWm1oPEq2o8_JQ1qi4Wu1WE3S27Abni4-PY3NiPsLPNSUNA2gpUcPJ54u8NLOiz3iRrv80oOr2FJbSHiVLNQWaIy7HTsBI_bM4ssyhHvg650YqORbNb3RYKxw0paEOR6G-AJuvvtDxetKp1FHUb2GbJvXJP81333PwKZHgwi6Yl1XypVozIU7QsTyLRT2t33XLFOhY19dlg_oicXquu140nKWsM2iARWRMsCdsZRP1ECA2Cn5dYoWDby6zpUEfTMWMW7kt9BhqX3lOTaylf1cg"},"gcmResponse":{"token":"doVTOqkGSoCceZiGgvpEFW:APA91bFUX0eB4o11CSnzwECz4YXKN8TjS9R_MToey3tCqEDe1e2abRbMWri6UgRKtxNq8FwJ9SNG_4dqstIo5MiEyeQGcpg2oE9G5jfXcX6G0_Jqw_Ua_GIVS3JhZKvhtB47yRgt_vMM"}}]
            2021-11-24 18:27:07.027 - debug: eufy-security.0 (12870) [HTTPApi.request] Request: [{"method":"post","endpoint":"family/get_invites","baseUrl":"https://security-app-eu.eufylife.com/v1","token":"4fedfe0fb2387730a6c76d406439ca76aa222efa797a81fd","data":{"num":100,"orderby":"","own":false,"page":0,"transaction":"1637778427026"},"headers":{"app_version":"v2.8.0_887","os_type":"android","os_version":"30","phone_model":"IOBROKER","country":"US","language":"de","openudid":"9a7a15b4545b53a4","uid":"","net_type":"wifi","mnc":"02","mcc":"262","sn":"eb207381bd72","Model_type":"PHONE","timezone":"GMT+00:00"}}]
            2021-11-24 18:27:07.204 - debug: eufy-security.0 (12870) [HTTPApi.getInvites] Response: [""]
            2021-11-24 18:27:07.205 - error: eufy-security.0 (12870) Status return code not 200 [{"status":204,"statusText":"No Content"}]
            2021-11-24 18:27:07.206 - debug: eufy-security.0 (12870) [HTTPApi.request] Request: [{"method":"post","endpoint":"app/get_hub_list","baseUrl":"https://security-app-eu.eufylife.com/v1","token":"4fedfe0fb2387730a6c76d406439ca76aa222efa797a81fd","headers":{"app_version":"v2.8.0_887","os_type":"android","os_version":"30","phone_model":"IOBROKER","country":"US","language":"de","openudid":"9a7a15b4545b53a4","uid":"","net_type":"wifi","mnc":"02","mcc":"262","sn":"eb207381bd72","Model_type":"PHONE","timezone":"GMT+00:00"}}]
            2021-11-24 18:27:07.310 - debug: eufy-security.0 (12870) [HTTPApi.updateDeviceInfo] Stations - Response: [""]
            2021-11-24 18:27:07.311 - error: eufy-security.0 (12870) Status return code not 200 [{"status":204,"statusText":"No Content"}]
            2021-11-24 18:27:07.312 - debug: eufy-security.0 (12870) [HTTPApi.request] Request: [{"method":"post","endpoint":"app/get_devs_list","baseUrl":"https://security-app-eu.eufylife.com/v1","token":"4fedfe0fb2387730a6c76d406439ca76aa222efa797a81fd","headers":{"app_version":"v2.8.0_887","os_type":"android","os_version":"30","phone_model":"IOBROKER","country":"US","language":"de","openudid":"9a7a15b4545b53a4","uid":"","net_type":"wifi","mnc":"02","mcc":"262","sn":"eb207381bd72","Model_type":"PHONE","timezone":"GMT+00:00"}}]
            2021-11-24 18:27:07.480 - debug: eufy-security.0 (12870) [HTTPApi.updateDeviceInfo] Devices - Response: [""]
            2021-11-24 18:27:07.482 - error: eufy-security.0 (12870) Status return code not 200 [{"status":204,"statusText":"No Content"}]
            2021-11-24 18:27:07.774 - debug: eufy-security.0 (12870) [PushClient.handleParsedMessage] Login response: GCM -> logged in -> waiting for push messages...
            2021-11-24 18:27:07.776 - debug: eufy-security.0 (12870) [HTTPApi.request] Request: [{"method":"post","endpoint":"/apppush/register_push_token","baseUrl":"https://security-app-eu.eufylife.com/v1","token":"4fedfe0fb2387730a6c76d406439ca76aa222efa797a81fd","data":{"is_notification_enable":true,"token":"doVTOqkGSoCceZiGgvpEFW:APA91bE9gHz60Zm9cz3gdyD38hwNxrLB32tBr02OLa4CbbwOmQVt9gVJepnPNxRsPFJck6xgyLw7PwzUuVO6M21fh4OY-Jt51ehC3Uq_6UDXL4BjFPIh99kSEykP4U4Lw0A_OcOhsqwn","transaction":"1637778427776"},"headers":{"app_version":"v2.8.0_887","os_type":"android","os_version":"30","phone_model":"IOBROKER","country":"US","language":"de","openudid":"9a7a15b4545b53a4","uid":"","net_type":"wifi","mnc":"02","mcc":"262","sn":"eb207381bd72","Model_type":"PHONE","timezone":"GMT+00:00"}}]
            2021-11-24 18:27:07.796 - debug: eufy-security.0 (12870) [PushClient.handleParsedMessage] IqStanza: Not implemented [{"tag":7,"object":{"type":"SET","id":"","extension":{"id":12,"data":{"type":"Buffer","data":[]}}}}]
            2021-11-24 18:27:07.908 - debug: eufy-security.0 (12870) [HTTPApi.registerPushToken] Response: [""]
            2021-11-24 18:27:07.909 - error: eufy-security.0 (12870) Status return code not 200 [{"status":204,"statusText":"No Content"}]
            2021-11-24 18:27:07.910 - debug: eufy-security.0 (12870) [HTTPApi.request] Request: [{"method":"post","endpoint":"/app/review/app_push_check","baseUrl":"https://security-app-eu.eufylife.com/v1","token":"4fedfe0fb2387730a6c76d406439ca76aa222efa797a81fd","data":{"app_type":"eufySecurity","transaction":"1637778427910"},"headers":{"app_version":"v2.8.0_887","os_type":"android","os_version":"30","phone_model":"IOBROKER","country":"US","language":"de","openudid":"9a7a15b4545b53a4","uid":"","net_type":"wifi","mnc":"02","mcc":"262","sn":"eb207381bd72","Model_type":"PHONE","timezone":"GMT+00:00"}}]
            2021-11-24 18:27:08.016 - debug: eufy-security.0 (12870) [HTTPApi.checkPushToken] Response: [""]
            2021-11-24 18:27:08.017 - error: eufy-security.0 (12870) Status return code not 200 [{"status":204,"statusText":"No Content"}]
            2021-11-24 18:27:08.018 - info: eufy-security.0 (12870) Push notification connection closed
            chiroptera
              locito09 @chiroptera last edited by locito09
              @chiroptera
              Aktualisiere den adapter auf die Version 0.7.4
              Siehe Zeile 43 im Log, das Thema hatten wir oben schon mal
              C M 2 Replies Last reply Reply Quote 0
                Chrille1507 @D4RKKN1GHT84 last edited by
                @d4rkkn1ght84 Ja genau. Ich habe es in der App deaktiviert, 10 Minuten gewartet und dann funktionierte es auf Anhieb.
                • Ron Cold
                  Ron Cold last edited by
                  Bei mir verschwindet beim Versuch mich anzumelden das "Passwort Fenster" wenn ich in das Feld klicke. Ist das jemand bekannt? Mache ich einen Fehler?Bild vor und nach dem Klick im Anhang.Bildschirmfoto 2021-11-26 um 15.35.53.png Bildschirmfoto 2021-11-26 um 15.37.40.png
                    locito09 @Ron Cold last edited by locito09
                    @ron-cold
                    Wurde weiter oben schon mal besprochen
                    Lösung:
                    Copy paste
                    Ron Cold 1 Reply Last reply Reply Quote 0
                    • Ron Cold
                      Ron Cold @locito09 last edited by
                      @locito09 leider verschwindet bei der 0.7.4 auch per Copy Paste das PW - den Post hatte ich schon gelesen.
                      Danke trotzdem für den Hinweis 😉
                      Hat vllt. noch jemand eine Idee?
                        chiroptera @Ron Cold last edited by
                        @ron-cold "Verschwindet" bei Copy&Paste zwar, wird aber auf diese Weise trotzdem gespeichert 🙂
                          chiroptera @locito09 last edited by
                          @locito09 said in [Neuer Adapter] Eufy-Security:
                          Scheint in der Tat geholfen zu haben - danke 🙂
                          • Ron Cold
                            Ron Cold @chiroptera last edited by
                            @chiroptera leider wohl nicht
                              Mike Hellracer @Ron Cold last edited by
                              Hat jemand wenn es klingelt auf der VIS schon ein Popup hinbekommen mit LiveView hinbekommen?
                              • nitram-rem
                                nitram-rem last edited by
                                ich habe mir vorgenommen meine Eufy mit Signal zu verklöppeln und dafür Node-red zu verwenden. Dazu habe ich Eufy-Security Adapter installiert und den Signal-CLI. Signal geht schon, also ich kann eine Message verschicken. Jetzt würde ich gerne das Bild noch mit dazu nehmen wenn ein Alarm kommt. Dazu habe ich das Bild liegen unter dem Objekt Punkt: last_event_pic_url. Ich kann das Bild anzeigen wenn ich eine URL in den Browser schmeiße: http://192.xxx.xxx.xxx:8082/eufy-security.0/T8010N23203011B4/last_event/T8114P0220420BB2.jpeg Allerdings funktioniert das so nicht mit der Signal CLI. Da kann ich laut Doku mit dem parameter -a einen lokalen Pfad mitgeben um das Bild dann zu übertragen. Frage ist nun wo ist der lokale Pfad des Eufy Security Adapters oder wie kann ich die Datei herunterladen, lokal abspeichern, dann raus pushen und wieder löschen?
                                Martin
                                  Maddog20102002 @locito09 last edited by Maddog20102002
                                  @locito09 Wie kann ich auf 0.7.4 updaten?
                                  Über normale adaptersuche bekomme ich nur 0.7.0
                                  bin nicht so fit wie man einen adapter direkt von Github installiert
                                  • JohGre
                                    JohGre last edited by JohGre
                                    Hi, habe aktuell seit 2 Tagen folgendes Problem. Adapter ist grün jedoch werden mir keine Bilder mehr in
                                    eufy-security.0.TRxxx.cameras.Txxx.last_event_pic_html
                                    angezeigt. Zwischendurch kommt immer wieder mal die Fehlermeldung.
                                    eufy-security.0  2021-11-27 18:01:44.831	error	Status return code not 200 [{"status":401,"statusText":"Unauthorized"}]
                                    eufy-security.0  2021-11-27 18:01:44.828	error	Status return code 401, invalidate token [{"status":401,"statusText":"Unauthorized"}]
                                    auch das wird bei jeder immer wieder gemeldet
                                    eufy-security.0	2021-11-28 08:51:59.217	error	ffmpegPreviewImage - station: Txxxx device: Txxxx - Error [{}]
                                    eufy-security.0	2021-11-28 08:51:59.216	error	ffmpegPreviewImage(): ffmpeg stderr:ffmpeg version 4.4-static https://johnvansickle.com/ffmpeg/ Copyright (c) 2000-2021 the FFmpeg developers built with gcc 8 (Debian 8.3.0-6) configuration: --enable-gpl --enable-version3 --enable-static --disable-debug --disable-ffplay --disable-indev=sndio --disable-outdev=sndio --cc=gcc --enable-fontconfig --enable-frei0r --enable-gnutls --enable-gmp --enable-libgme --enable-gray --enable-libaom --enable-libfribidi --enable-libass --enable-libvmaf --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-librubberband --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libvorbis --enable-libopus --enable-libtheora --enable-libvidstab --enable-libvo-amrwbenc --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libdav1d --enable-libxvid --enable-libzvbi --enable-libzimg libavutil 56. 70.100 / 56. 70.100 libavcodec 58.134.100 / 58.134.100 libavformat 58. 76.100 / 58. 76.100 libavdevice 58. 13.100 / 58. 13.100 libavfilter 7.110.100 / 7.110.100 libswscale 5. 9.100 / 5. 9.100 libswresample 3. 9.100 / 3. 9.100 libpostproc 55. 9.100 / 55. 9.100[hls @ 0x6ae8c80] Skip ('#EXT-X-VERSION:3')[hls @ 0x6ae8c80] Cannot get correct #EXTINF value of segment /opt/iobroker/iobroker-data/eufy-security.0/Txxxx/last_event/Txxxx0.ts, set to default value to 1ms.[hls @ 0x6ae8c80] Opening '/opt/iobroker/iobroker-data/eufy-security.0/Txxxx/last_event/Txxxx0.ts' for reading[aac @ 0x6af6480] More than one AAC RDB per ADTS frame is not implemented. Update your FFmpeg version to the newest one from Git. If the problem still occurs, it means that your file has a feature which has not been implemented.[aac @ 0x6af6480] Reserved bit set.[aac @ 0x6af6480] Number of scalefactor bands in group (46) exceeds limit (40).[aac @ 0x6af6480] channel element 1.11 is not allocated[aac @ 0x6af6480] Assuming an incorrectly encoded 7.1 channel layout instead of a spec-compliant 7.1(wide) layout, use -strict 1 to decode according to the specification instead.[aac @ 0x6af6480] Number of bands (13) exceeds limit (12).[aac @ 0x6af6480] channel element 1.11 is not allocated[aac @ 0x6af6480] Number of bands (13) exceeds limit (10).[hls @ 0x6ae8c80] decoding for stream 1 failed[hls @ 0x6ae8c80] Could not find codec parameters for stream 0 (Video: h264 ([27][0][0][0] / 0x001B), none): unspecified sizeConsider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options[hls @ 0x6ae8c80] Could not find codec parameters for stream 1 (Audio: aac (SSR) ([15][0][0][0] / 0x000F), 4.0, fltp): unspecified sample rateConsider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) optionsInput #0, hls, from '/opt/iobroker/iobroker-data/eufy-security.0/Txxxx/last_event/Txxxx.m3u8': Duration: 00:00:00.00, start: 1.400000, bitrate: 1232 kb/s Program 0 Metadata: variant_bitrate : 0 Stream #0:0: Video: h264 ([27][0][0][0] / 0x001B), none, 90k tbr, 90k tbn, 180k tbc Metadata: variant_bitrate : 0 Stream #0:1: Audio: aac (SSR) ([15][0][0][0] / 0x000F), 4.0, fltp Metadata: variant_bitrate : 0Output #0, image2, to '/opt/iobroker/iobroker-data/eufy-security.0/Txxxx/last_event/Txxxx.jpeg':Output file #0 does not contain any stream
                                    eufy-security.0	2021-11-28 08:51:59.215	error	ffmpegPreviewImage(): ffmpeg output:
                                    eufy-security.0	2021-11-28 08:51:59.213	error	ffmpegPreviewImage(): An error occurred: ffmpeg exited with code 1: Output #0, image2, to '/opt/iobroker/iobroker-data/eufy-security.0/Txxxx/last_event/Txxxx.jpeg':Output file #0 does not contain any stream
                                    Kann ich da irgendwas in ffmpeg konfigurieren oder ist das ein EUFY-Problem
                                      locito09 @Marko1974 last edited by locito09
                                      @marko1974
                                      Für alle die den ffmpeg Fehler haben.
                                      Ich habe festgestellt das wen die Kamera weniger als 30s aufnihmt der Fehler nicht mehr kommt.
                                      Habe es bei mir so gelöst und seit dem kein fehler mehr im LOG.
                                      Aufnahmelänge auf 28sek
                                      Seit der Änderung läuft der Adapter schon über 2 Tage ohne Fehlermeldung
                                      @bropat
                                      Kannst du mit dem was anfangen und den Adapter fixen
                                        locito09 @Maddog20102002 last edited by locito09
                                        @maddog20102002
                                        Erweiterten Modus einschalten (kopf Zeichen) benutzerdefinierte Installation , link von Github einfügen
                                        cash 1 Reply Last reply Reply Quote 0
                                        • cash
                                          cash Most Active @locito09 last edited by
                                          habe nun auch zwei Kameras und den Adapter installiert.
                                          Hatte die App per 2 Faktor aktiviert. Beim Adapter start kam auch brav eine Mail mit der Nr nur als ich die Nr eingegeben habe sagte der Adapter falsche Zahl (hatte es kontrolliert passte aber. Hier scheint also noch etwas nicht rund zu laufen. Habe den Adapter dann ohne 2 Faktor in Betrieb genommen.
                                          Ich habe noch eine Frage zur Solor Indoorcam P24. Gibt es keinen Datenpunkt um die Bewegungsverfolgung unter Bewekungserkennung in der App zu deaktiveren?
                                          Ich habe die Kamera im Flur installiert und es nervt ein wenig wenn die Kamera einen dauernd verfolgt (obwohl sie das echt gut macht).
                                          hollywoot C 2 Replies Last reply Reply Quote 0
                                          • hollywoot
                                            hollywoot @cash last edited by hollywoot
                                            @cash sagte in [Neuer Adapter] Eufy-Security:
                                            Versuchs mal 'motionTracking' auf false zu setzen.
                                            adapter cameras doorbell eufy eufycam security
                                            158
                                            1171
                                            445984
