Wenn Tür auf (Astro) dann Licht an
ich versuche wie verrückt einzustellen, dass wenn die Tür öffnet - bei Sonnenuntergang - dass das Licht angeht und das solange bis die Sonne wieder aufgeht.
on({id: "bshb.0.hdm:HomeMaticIP:3014F711A000009A1859781C.ShutterContact.value"/*value*/, change: "ne"}, async function (obj) { var value = obj.state.val; var oldValue = obj.oldState.val; if (getState("bshb.0.hdm:HomeMaticIP:3014F711A000009A1859781C.ShutterContact.value").val == 'OPEN' && compareTime(getAstroDate("sunsetStart", undefined, -30), getAstroDate("sunrise", undefined, 0), "between", null)) { setState("shelly.0.SHSW-1#76935D#1.Relay0.Switch"/*Switch*/, true); } }); 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
Ich habe auch schon die Astro Datensätze in den Objekten drin, allerdings weiß ich nicht wie ich blockly damit ansteuere.
Hat jemand einen Tipp?
@jb1985 setz mal einen debug Baustein über das falls, in dem du den Wert von value anzeigen lässt
außerdem darf ein Astroereignis nicht tagesübergreifend sein, also muss es hier heißen
NICHT zwischen sonnen auf und sonnenuntergang -
@jb1985 sagte in Wenn Tür auf (Astro) dann Licht an:
was ist der sinn dahinter, daß das licht angeht wenn die tür aufgeht? warum nicht gleich sunset - sunrise?
ist mit smartcontrol ein akt in 2 minuten... -
@da_woody sagte in Wenn Tür auf (Astro) dann Licht an:
Wenn man die Haustür öffnet das im Flur das Licht angeht.
@homoran sagte in Wenn Tür auf (Astro) dann Licht an:
Ja, hab das gerade mit sonnenaufgang probiert. Damit funktioniert es.
Werde mal auf den Sonnenuntergang warten.
aber nur im Dunkeln!
weil das eben nicht geht
sorry, dann hab ich deinen satz falsch verstanden. ich hab das so interpretiert: nach sunset, tür auf, licht brennt dann bis sunrise...
doch, mit smartcontrol...
läuft bei mir seit einem knappen jahr so beim hauseingang...
selbst das wäre ja ein anderer Usecase.
Wenn die Außenbeleuchtung nur an sein soll, wenn jemand zu Hause ist -
Jetzt geht das Licht jetzt sogar an. Als würde die Astrozeit gar nicht interessieren. Weil Sonnenuntergang ist ja noch nicht.
meine terrassenbeleuchtung. 3 shelly bulb die sich im 15 min abstand einschalten nur wenn jemand zu hause ist. und sich dann abschalten, wenn alexa die gute nachtroutine angesagt bekommt..
So, ich denke so wird das funktionieren!
Da fehlt ja auch die notwendige Logik zu
Außerdem wäre das ja nur ein einziger Moment, in genau dem dann auch noch die Tür aufgehen muss -
nein!
NICHT zwischen Aufgang und Untergang -
@homoran andersrum hatte ich gerade funktioniert. Das Licht ist (Tagsüber) angegangen, also Aufgang und Untergang.
Sollte somit Aufgang und Untergang bei Dunkelheit das Licht einschalten.
das habe ich schon verstanden nur
@homoran mache ich das ohne "zwischen" funktioniert es gar nicht.
Ich werde es mal heute Abend testen.
natürlich brauchst du eine Logik.
Einfach die Uhrzeit des Sonnenuntergangs anzugeben bringt nix.Zwischen ist auch richtig!
aber nicht Sonnenuntergang (heute) und Sonnenaufgang(ebenfalls heute)
Was du willst ist heute auf die Zeit von Morgen zuzugreifen, das geht nicht.Das geht nur mit
@homoran Cool Danke! Habe ich gemacht und werde es mal heute Abend testen.
Funktioniert, Besten Dank!
