    4. Zigbee Adapter - Pairing findet keine Geräte
      Thomas Braun Most Active @deriobroker last edited by
      @deriobroker sagte in Zigbee Adapter - Pairing findet keine Geräte:
      Hat einer eine Idee?
      Ohne ein Log File nicht.
        deriobroker @Thomas Braun last edited by deriobroker
        021-11-27 18:32:28.173 - info: host.iobroker instance system.adapter.zigbee.0 started with pid 6267
        2021-11-27 18:32:30.878 - debug: zigbee.0 (6267) Redis Objects: Use Redis connection: 0.0.0.0:9001
        2021-11-27 18:32:30.914 - debug: zigbee.0 (6267) Objects client ready ... initialize now
        2021-11-27 18:32:30.916 - debug: zigbee.0 (6267) Objects create System PubSub Client
        2021-11-27 18:32:30.917 - debug: zigbee.0 (6267) Objects create User PubSub Client
        2021-11-27 18:32:30.918 - debug: zigbee.0 (6267) Objects client initialize lua scripts
        2021-11-27 18:32:30.935 - debug: zigbee.0 (6267) Objects connected to redis: 0.0.0.0:9001
        2021-11-27 18:32:30.945 - debug: zigbee.0 (6267) objectDB connected
        2021-11-27 18:32:30.947 - debug: zigbee.0 (6267) Redis States: Use Redis connection: 0.0.0.0:9000
        2021-11-27 18:32:30.958 - debug: zigbee.0 (6267) States create System PubSub Client
        2021-11-27 18:32:30.959 - debug: zigbee.0 (6267) States create User PubSub Client
        2021-11-27 18:32:30.971 - debug: zigbee.0 (6267) States connected to redis: 0.0.0.0:9000
        2021-11-27 18:32:30.972 - debug: zigbee.0 (6267) statesDB connected
        2021-11-27 18:32:31.280 - debug: zigbee.0 (6267) Plugin sentry Do not initialize Plugin (enabled=false)
        2021-11-27 18:32:31.290 - debug: zigbee.0 (6267) Plugin sentry destroyed because not initialized correctly
        2021-11-27 18:32:31.298 - info: zigbee.0 (6267) starting. Version 1.6.7 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.7, js-controller: 3.3.20
        2021-11-27 18:32:31.339 - debug: zigbee.0 (6267) Using zigbee-herdsman with settings: {"network":{"panID":6755,"extendedPanID":[138,253,173,54,202,78,217,155],"channelList":[11],"networkKey":[220,225,164,223,95,203,10,5,174,195,38,179,49,95,198,172]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"deconz"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
        2021-11-27 18:32:31.398 - info: zigbee.0 (6267) Starting Zigbee npm ...
        2021-11-27 18:32:31.400 - debug: zigbee.0 (6267) Starting zigbee-herdsman...
        2021-11-27 18:32:31.943 - info: zigbee.0 (6267) Installed Version: ioBroker/ioBroker.zigbee
        2021-11-27 18:32:31.957 - debug: zigbee.0 (6267) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2021_11_27-18_32_31.tar.gz success
        2021-11-27 18:32:31.969 - debug: zigbee.0 (6267) zigbee-herdsman started
        2021-11-27 18:32:31.974 - info: zigbee.0 (6267) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}}
        2021-11-27 18:32:31.998 - debug: zigbee.0 (6267) Zigbee network parameters: panID=6755 channel=11 extendedPanID=(ausgeblendet)
        2021-11-27 18:32:31.999 - info: zigbee.0 (6267) Unable to disable LED, unsupported function.
        2021-11-27 18:32:32.000 - info: zigbee.0 (6267) --> transmitPower : normal
        2021-11-27 18:32:32.001 - info: zigbee.0 (6267) Unable to set transmit power, unsupported function.
        2021-11-27 18:32:32.003 - info: zigbee.0 (6267) Currently no devices.
        2021-11-27 18:32:32.004 - info: zigbee.0 (6267) Zigbee started
        2021-11-27 18:32:34.439 - debug: zigbee.0 (6267) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
        2021-11-27 18:32:34.448 - debug: zigbee.0 (6267) getGroups result: {}
        2021-11-27 18:32:34.449 - debug: zigbee.0 (6267) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
        2021-11-27 18:32:34.467 - debug: zigbee.0 (6267) LQI succeeded for 'Coordinator'
        2021-11-27 18:32:34.495 - debug: zigbee.0 (6267) getCoorinatorInfo result: {"installSource":"ioBroker/ioBroker.zigbee","channel":"11","port":"/dev/ttyACM0","type":"ConBee2/RaspBee2","revision":"0x26720700","version":"0-0.38.114.0."}
        2021-11-27 18:32:34.496 - debug: zigbee.0 (6267) sendTo "getCoordinatorInfo" to system.adapter.admin.0 from system.adapter.zigbee.0
        2021-11-27 18:32:34.507 - debug: zigbee.0 (6267) Routing for 'Coordinator': {"table":[]}
        2021-11-27 18:32:34.508 - debug: zigbee.0 (6267) Routing table succeeded for 'Coordinator'
        2021-11-27 18:32:34.508 - debug: zigbee.0 (6267) Get map succeeded []
        2021-11-27 18:32:34.509 - debug: zigbee.0 (6267) getMap result: {"lqis":[],"routing":[]}
        2021-11-27 18:32:34.510 - debug: zigbee.0 (6267) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
        2021-11-27 18:32:34.627 - debug: zigbee.0 (6267) List of ports: [{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyAMA0"}]
        2021-11-27 18:32:34.628 - debug: zigbee.0 (6267) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
        2021-11-27 18:32:34.650 - debug: zigbee.0 (6267) getDevices result: [{"_id":"0x00212effff077c8a","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00212effff077c8a","_networkAddress":0,"_manufacturerID":0,"_endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":2,"profileID":257,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":3,"profileID":261,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":4,"profileID":263,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":5,"profileID":264,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":6,"profileID":265,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":8,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":10,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":11,"profileID":260,"deviceID":1024,"inputClusters":[1281],"outputClusters":[1280,1282],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":12,"profileID":49246,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":13,"profileID":260,"deviceID":5,"inputClusters":[25],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":47,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":110,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":null},"mapped":null,"endpoint":{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},"endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":2,"profileID":257,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":3,"profileID":261,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":4,"profileID":263,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":5,"profileID":264,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":6,"profileID":265,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":8,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":10,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":11,"profileID":260,"deviceID":1024,"inputClusters":[1281],"outputClusters":[1280,1282],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":12,"profileID":49246,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":13,"profileID":260,"deviceID":5,"inputClusters":[25],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":47,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":110,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"name":"0x00212effff077c8a"},"common":{},"native":{}}]
        2021-11-27 18:32:34.651 - debug: zigbee.0 (6267) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
        2021-11-27 18:32:34.703 - debug: zigbee.0 (6267) getExclude result: []
        2021-11-27 18:32:34.704 - debug: zigbee.0 (6267) getBinding result: []
        2021-11-27 18:32:34.705 - debug: zigbee.0 (6267) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
        2021-11-27 18:32:34.714 - debug: zigbee.0 (6267) sendTo "getExclude" to system.adapter.admin.0 from system.adapter.zigbee.0
        2021-11-27 18:32:37.185 - info: zigbee.0 (6267) Zigbee: allowing new devices to join.
        2021-11-27 18:32:37.187 - debug: zigbee.0 (6267) sendTo "letsPairing" to system.adapter.admin.0 from system.adapter.zigbee.0: Start pairing!
        2021-11-27 18:33:38.462 - info: zigbee.0 (6267) Zigbee: stop joining
          @deriobroker
          Die PAN-Id prüfen, das sieht komisch aus.
            Ich habe die Pan-ID noch einmal auf 16x D zurückgesetzt als auch eine eigene generiert:
            2021-11-27 20:27:00.959 - info: host.iobroker stopInstance system.adapter.zigbee.0 (force=false, process=true)
            2021-11-27 20:27:01.045 - info: zigbee.0 (10137) Got terminate signal TERMINATE_YOURSELF
            2021-11-27 20:27:01.046 - info: host.iobroker stopInstance system.adapter.zigbee.0 send kill signal
            2021-11-27 20:27:01.047 - info: zigbee.0 (10137) cleaned everything up...
            2021-11-27 20:27:01.049 - info: zigbee.0 (10137) Zigbee: disabling joining new devices.
            2021-11-27 20:27:01.531 - info: zigbee.0 (10137) terminating
            2021-11-27 20:27:01.532 - info: zigbee.0 (10137) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2021-11-27 20:27:02.053 - info: host.iobroker stopInstance system.adapter.zigbee.0 killing pid 10137
            2021-11-27 20:27:02.203 - info: host.iobroker instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2021-11-27 20:27:04.084 - info: host.iobroker instance system.adapter.zigbee.0 started with pid 10269
            2021-11-27 20:27:06.728 - debug: zigbee.0 (10269) Redis Objects: Use Redis connection: 0.0.0.0:9001
            2021-11-27 20:27:06.774 - debug: zigbee.0 (10269) Objects client ready ... initialize now
            2021-11-27 20:27:06.776 - debug: zigbee.0 (10269) Objects create System PubSub Client
            2021-11-27 20:27:06.777 - debug: zigbee.0 (10269) Objects create User PubSub Client
            2021-11-27 20:27:06.778 - debug: zigbee.0 (10269) Objects client initialize lua scripts
            2021-11-27 20:27:06.795 - debug: zigbee.0 (10269) Objects connected to redis: 0.0.0.0:9001
            2021-11-27 20:27:06.805 - debug: zigbee.0 (10269) objectDB connected
            2021-11-27 20:27:06.807 - debug: zigbee.0 (10269) Redis States: Use Redis connection: 0.0.0.0:9000
            2021-11-27 20:27:06.817 - debug: zigbee.0 (10269) States create System PubSub Client
            2021-11-27 20:27:06.819 - debug: zigbee.0 (10269) States create User PubSub Client
            2021-11-27 20:27:06.831 - debug: zigbee.0 (10269) States connected to redis: 0.0.0.0:9000
            2021-11-27 20:27:06.832 - debug: zigbee.0 (10269) statesDB connected
            2021-11-27 20:27:07.069 - debug: zigbee.0 (10269) Plugin sentry Do not initialize Plugin (enabled=false)
            2021-11-27 20:27:07.078 - debug: zigbee.0 (10269) Plugin sentry destroyed because not initialized correctly
            2021-11-27 20:27:07.086 - info: zigbee.0 (10269) starting. Version 1.6.7 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.7, js-controller: 3.3.20
            2021-11-27 20:27:07.130 - debug: zigbee.0 (10269) Using zigbee-herdsman with settings: {"network":{"panID":6753,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[220,225,164,223,95,203,10,5,174,195,38,179,49,95,198,172]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"deconz"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
            2021-11-27 20:27:07.195 - info: zigbee.0 (10269) Starting Zigbee npm ...
            2021-11-27 20:27:07.196 - debug: zigbee.0 (10269) Starting zigbee-herdsman...
            2021-11-27 20:27:07.690 - info: zigbee.0 (10269) Installed Version: ioBroker/ioBroker.zigbee
            2021-11-27 20:27:07.710 - debug: zigbee.0 (10269) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2021_11_27-20_27_07.tar.gz success
            2021-11-27 20:27:07.723 - debug: zigbee.0 (10269) zigbee-herdsman started
            2021-11-27 20:27:07.728 - info: zigbee.0 (10269) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}}
            2021-11-27 20:27:07.748 - debug: zigbee.0 (10269) Zigbee network parameters: panID=6753 channel=11 extendedPanID=dddddddddddddddd
            2021-11-27 20:27:07.749 - info: zigbee.0 (10269) Unable to disable LED, unsupported function.
            2021-11-27 20:27:07.750 - info: zigbee.0 (10269) --> transmitPower : normal
            2021-11-27 20:27:07.751 - info: zigbee.0 (10269) Unable to set transmit power, unsupported function.
            2021-11-27 20:27:07.752 - info: zigbee.0 (10269) Currently no devices.
            2021-11-27 20:27:07.753 - info: zigbee.0 (10269) Zigbee started
            2021-11-27 20:27:47.932 - debug: zigbee.0 (10269) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
            2021-11-27 20:27:47.941 - debug: zigbee.0 (10269) getGroups result: {}
            2021-11-27 20:27:47.942 - debug: zigbee.0 (10269) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
            2021-11-27 20:27:47.962 - debug: zigbee.0 (10269) LQI succeeded for 'Coordinator'
            2021-11-27 20:27:47.974 - debug: zigbee.0 (10269) getCoorinatorInfo result: {"installSource":"ioBroker/ioBroker.zigbee","channel":"11","port":"/dev/ttyACM0","type":"ConBee2/RaspBee2","revision":"0x26720700","version":"0-0.38.114.0."}
            2021-11-27 20:27:47.975 - debug: zigbee.0 (10269) sendTo "getCoordinatorInfo" to system.adapter.admin.0 from system.adapter.zigbee.0
            2021-11-27 20:27:47.979 - debug: zigbee.0 (10269) Routing for 'Coordinator': {"table":[]}
            2021-11-27 20:27:47.980 - debug: zigbee.0 (10269) Routing table succeeded for 'Coordinator'
            2021-11-27 20:27:47.981 - debug: zigbee.0 (10269) Get map succeeded []
            2021-11-27 20:27:47.982 - debug: zigbee.0 (10269) getMap result: {"lqis":[],"routing":[]}
            2021-11-27 20:27:47.983 - debug: zigbee.0 (10269) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
            2021-11-27 20:27:48.118 - debug: zigbee.0 (10269) List of ports: [{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyAMA0"}]
            2021-11-27 20:27:48.119 - debug: zigbee.0 (10269) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
            2021-11-27 20:27:48.222 - debug: zigbee.0 (10269) getDevices result: [{"_id":"0x00212effff077c8a","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00212effff077c8a","_networkAddress":0,"_manufacturerID":0,"_endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":2,"profileID":257,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":3,"profileID":261,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":4,"profileID":263,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":5,"profileID":264,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":6,"profileID":265,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":8,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":10,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":11,"profileID":260,"deviceID":1024,"inputClusters":[1281],"outputClusters":[1280,1282],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":12,"profileID":49246,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":13,"profileID":260,"deviceID":5,"inputClusters":[25],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":47,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":110,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":null},"mapped":null,"endpoint":{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},"endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":2,"profileID":257,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":3,"profileID":261,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":4,"profileID":263,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":5,"profileID":264,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":6,"profileID":265,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":8,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":10,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":11,"profileID":260,"deviceID":1024,"inputClusters":[1281],"outputClusters":[1280,1282],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":12,"profileID":49246,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":13,"profileID":260,"deviceID":5,"inputClusters":[25],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":47,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":110,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"name":"0x00212effff077c8a"},"common":{},"native":{}}]
            2021-11-27 20:27:48.223 - debug: zigbee.0 (10269) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
            2021-11-27 20:27:48.325 - debug: zigbee.0 (10269) getExclude result: []
            2021-11-27 20:27:48.329 - debug: zigbee.0 (10269) getBinding result: []
            2021-11-27 20:27:48.330 - debug: zigbee.0 (10269) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
            2021-11-27 20:27:48.376 - debug: zigbee.0 (10269) sendTo "getExclude" to system.adapter.admin.0 from system.adapter.zigbee.0
            2021-11-27 20:27:50.609 - info: zigbee.0 (10269) Zigbee: allowing new devices to join.
            2021-11-27 20:27:50.611 - debug: zigbee.0 (10269) sendTo "letsPairing" to system.adapter.admin.0 from system.adapter.zigbee.0: Start pairing!
            2021-11-27 20:28:51.931 - info: zigbee.0 (10269) Zigbee: stop joining
            Leider keine Änderung. Die Log deckt den Zeitraum vom Start des Adapters bis zum Ende des Pairingvorgangs ab.
              Das schaut komisch aus. Bei mir steht da die PAN-Id.
              Stell das auf /dev/serial/by-id/GERÄTEDATEI um.
                crunchip Forum Testing Most Active @Thomas Braun last edited by
                @thomas-braun muss dazu nicht vorher der Ordner gelöscht werden
                rm -R /opt/iobroker/iobroker-data/zigbee.0/
                und PanID dddddddd.... soll man nicht mehr verwenden
                Thomas Braun D 2 Replies Last reply Reply Quote 0
                  Thomas Braun Most Active @crunchip last edited by
                  @crunchip sagte in Zigbee Adapter - Pairing findet keine Geräte:
                  Keine Ahnung. Musste ich bei mir noch nie löschen.
                    crunchip Forum Testing Most Active @Thomas Braun last edited by crunchip
                    @thomas-braun muss/sollte man zumindest bei einem Stickwechsel und dies sei ja schliesslich gegeben, wenn er vorher einen anderen versucht hatte, zu installieren
                    Da es mit einem CC2531 schon nicht geklappt hat, habe ich mir einen Conbee 2 gekauft
                      @crunchip
                      Okay.
                      Mein Wechsel von einem raspbee1 auf einen USB-Stick ging ohne.
                        deriobroker @crunchip last edited by deriobroker
                        @crunchip Ich habe den Ordner vorhin auch mal gelöscht, da der Adapter dort scheinbar auch Backups anlegt. Da das Pairing auf dem Gerät aber noch nie geklappt hat, habe ich den Ordner vorsichtshalber auch mal geleert.
                        DDDDDDDDDDDDDDDD habe ich nur beim 2. Versuch nach der Neuinstallation drin gelassen.
                        Also: Adapter deinstallieren, Stick abstecken, Ordner löschen, Stick einstecken, Adapter installieren, einrichten, Adapter starten, Pairing... das sind die Schritte, die ich jetzt mehrmals probiert habe.
                        Edit: Nach Stick 1 habe ich den Raspberry neu aufgesetzt.
                        Das sind die aktuellen Werte.
                          crunchip Forum Testing Most Active @deriobroker last edited by
                          @deriobroker zu conbee kann ich dir nichts sagen, vllt mal entsprechende Threads im Forum suchen
                            @crunchip Ich finde dazu einfach nichts. Ich kann es mir auch nicht erklären, da der Stick an einem anderen iobroker Host ja ohne Probleme funktioniert.
                            Aber danke für deine Hilfe!
                            Edit: Ich habe jetzt auf einem dritten Raspberry erneut den iobroker samt Zigbee Adapter installiert. Das Pairing klappt auf Anhieb. Ich glaube ich setze das System noch einmal komplett zurück...
                            Trotzdem wäre es interessant zu wissen, warum es letztendlich nicht funktioniert.
                            541
