    4. Fehler bei Installation
      Homoran Global Moderator Administrators @Xnetworker X last edited by
      @xnetworker-x sagte in Fehler bei Installation:
      Die Anleitung von der Seite https://www.iobroker.net/#de/download habe ich gemeint.
      Danke!
      die muss dann noch angepasst werden.
      Hier die "eigentliche" Seite dafür:
      https://www.iobroker.net/#de/documentation/install/linux.md
      • Xnetworker X
        Xnetworker X @Thomas Braun last edited by
        pi@raspberrypi:~ $ sudo apt remove nodejs node-*
        Reading package lists... Done
        Building dependency tree... Done
        Note, selecting 'node-jsdom' instead of 'node-data-urls'
        Note, selecting 'node-jsdom' instead of 'node-decimal.js'
        Note, selecting 'node-jsdom' instead of 'node-domexception'
        Note, selecting 'node-jsdom' instead of 'node-html-encoding-sniffer'
        Package 'node-zeparser' is not installed, so not removed
        Package 'node-zipfile' is not installed, so not removed
        You might want to run 'apt --fix-broken install' to correct these.
        The following packages have unmet dependencies:
         libreoffice-help-common : Depends: libjs-normalize.css
        E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
        pi@raspberrypi:~ $ sudo apt dist-upgrade
         nodejs : Depends: libnode72 (= 12.22.5~dfsg-2~11u1) but it is not installed
        pi@raspberrypi:~ $ sudo apt install nodejs
        The following packages were automatically installed and are no longer required:
          gyp libc-ares2 libfuse2 libjs-highlight.js libjs-inherits libjs-is-typedarray libjs-psl libjs-typedarray-to-buffer
          libssl-dev libuv1-dev node-abbrev node-agent-base node-ajv node-ansi node-ansi-regex node-ansi-styles node-ansistyles
          node-aproba node-archy node-are-we-there-yet node-asap node-asn1 node-assert-plus node-asynckit node-aws-sign2 node-aws4
          node-balanced-match node-bcrypt-pbkdf node-brace-expansion node-builtins node-cacache node-caseless node-chalk node-chownr
          node-clone node-color-convert node-color-name node-colors node-columnify node-combined-stream node-concat-map
          node-console-control-strings node-copy-concurrently node-core-util-is node-dashdash node-debug node-defaults
          node-delayed-stream node-delegates node-depd node-ecc-jsbn node-encoding node-err-code node-escape-string-regexp
          node-extend node-extsprintf node-fast-deep-equal node-forever-agent node-form-data node-fs-write-stream-atomic
          node-fs.realpath node-function-bind node-gauge node-getpass node-glob node-graceful-fs node-har-schema node-har-validator
          node-has-flag node-has-unicode node-hosted-git-info node-http-signature node-https-proxy-agent node-iconv-lite node-iferr
          node-imurmurhash node-indent-string node-inflight node-inherits node-ini node-ip node-ip-regex node-is-typedarray
          node-isarray node-isexe node-isstream node-jsbn node-json-parse-better-errors node-json-schema node-json-schema-traverse
          node-json-stable-stringify node-json-stringify-safe node-jsonify node-jsonparse node-jsonstream node-jsprim node-leven
          node-lockfile node-lru-cache node-mime node-mime-types node-minimatch node-mkdirp node-move-concurrently node-ms
          node-mute-stream node-nopt node-normalize-package-data node-npm-bundled node-npm-package-arg node-npmlog node-number-is-nan
          node-oauth-sign node-object-assign node-once node-opener node-osenv node-p-map node-path-is-absolute node-performance-now
          node-process-nextick-args node-promise-inflight node-promise-retry node-promzard node-psl node-puka node-punycode node-qs
          node-read node-read-package-json node-readable-stream node-request node-resolve node-resolve-from node-retry node-rimraf
          node-run-queue node-safe-buffer node-semver node-set-blocking node-signal-exit node-slash node-spdx-correct
          node-spdx-exceptions node-spdx-expression-parse node-spdx-license-ids node-sshpk node-ssri node-string-decoder
          node-string-width node-strip-ansi node-supports-color node-tar node-text-table node-through node-tough-cookie
          node-tunnel-agent node-tweetnacl node-typedarray-to-buffer node-unique-filename node-universalify node-uri-js
          node-util-deprecate node-uuid node-validate-npm-package-license node-validate-npm-package-name node-verror node-wcwidth.js
          node-which node-wide-align node-wrappy node-write-file-atomic node-yallist nodejs-doc python-is-python2
        Use 'sudo apt autoremove' to remove them.
        The following packages will be upgraded:
          nodejs
        1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        Need to get 0 B/22.9 MB of archives.
        After this operation, 115 MB of additional disk space will be used.
        Reading changelogs... Done
        (Reading database ... 166330 files and directories currently installed.)
        Preparing to unpack .../nodejs_14.18.1-deb-1nodesource1_armhf.deb ...
        Unpacking nodejs (14.18.1-deb-1nodesource1) over (12.22.5~dfsg-2~11u1) ...
        dpkg: error processing archive /var/cache/apt/archives/nodejs_14.18.1-deb-1nodesource1_armhf.deb (--unpack):
         trying to overwrite '/usr/share/doc/nodejs/api/embedding.json.gz', which is also in package nodejs-doc 12.22.5~dfsg-2~11u1
        dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
        Errors were encountered while processing:
        E: Sub-process /usr/bin/dpkg returned an error code (1)
        pi@raspberrypi:~ $ sudo reboot
          Thomas Braun Most Active @Xnetworker X last edited by Thomas Braun
          nodejs-doc
          sudo apt autoremove
          sudo apt remove nodejs-doc
          Und bitte das Raspberry OS NICHT in der Desktop-Variante verwenden.
          Am besten nochmal neuinstallieren, diesmal in der Lite-Version.
          Xnetworker X 2 Replies Last reply Reply Quote 0
          • Xnetworker X
            Dann stehe ich vor dem Problem, wie ich von der SD-Karte auf die SSD die Daten kopiere. Dies habe ich über das Tool SD Copy durchgeführt. Habe dazu keine andere Anleitung gefunden. Nutze das Argon M.2 Gehäuse mit einer 500GB -SSD
            • Xnetworker X
              @thomas-braun said in Fehler bei Installation:
              sudo apt autoremove
              pi@raspberrypi:~ $ sudo apt autoremove
              pi@raspberrypi:~ $ sudo apt remove nodejs-doc
               nodejs : Depends: libnode72 (= 12.22.5~dfsg-2~11u1) but it is not going to be installed
                        Recommends: nodejs-doc but it is not going to be installed
                @xnetworker-x
                Mach es mit dem Raspberry Pi Imager
                https://www.raspberrypi.com/software/
                Da kann man das 32bit Rasperry OS lite aussuchen, nicht das Recommended Desktop-Ding verwenden.
                • Xnetworker X
                  @thomas-braun Wie kopiere ich dann die SD-Karte auf die SSD?
                  • Xnetworker X
                    @thomas-braun Den habe ich auch genutzt. Nur nicht die Lite-Version
                      Warum nicht?
                      Xnetworker X 1 Reply Last reply Reply Quote 0
                        Was hast du vor?
                        Installier es auf die SD-Karte und dann stellst du das von dort auf SSD-Betreib um. Gibt irgendwo Anleitungen dazu, wie das gemacht wird.
                        Ich betreibe meine Raspberrys nur mit SD-Karten.
                        • Xnetworker X
                          Warum nicht?
                          Weil ich in der Desktop-Version das Klonetool genutzt habe.
                          • Xnetworker X
                            Was hast du vor?
                            Dazu müssen doch aber alle Daten von der SD auf die SSD kopiert werden. Habe leider noch keine funktionierende Anleitung gefunden.
                              Für einen Server wird kein Desktop installiert.
                              1201
