    4. [Gelöst] JavaScript Editor keine Anzeige in Log Konsole
      Chris0680 @Glasfaser last edited by
      @glasfaser said in JavaScript Editor keine Anzeige in Log Konsole:
      iobroker list adapters
      54abbf4a-7242-4259-89da-0de43182958e-grafik.png 9c7587b4-5f8e-44af-af8f-061e5adbf40e-grafik.png
        Homoran Global Moderator Administrators @Glasfaser last edited by
        @Chris0680
        @glasfaser sagte in JavaScript Editor keine Anzeige in Log Konsole:
        aber in Code-Tags </>
          Chris0680 @Homoran last edited by Chris0680
          @homoran ```
          pi@ioBroker:~ $ iobroker list adapters
          system.adapter.admin                   : admin          - v5.1.25
          system.adapter.backitup                : backitup       - v2.2.2
          system.adapter.daswetter               : daswetter      - v3.0.9
          system.adapter.deconz                  : deconz         - v1.3.19
          system.adapter.discovery               : discovery      - v2.7.3
          system.adapter.enigma2                 : enigma2        - v1.3.2
          system.adapter.fb-checkpresence        : fb-checkpresence - v1.1.10
          system.adapter.flot                    : flot           - v1.10.7
          system.adapter.hm-rega                 : hm-rega        - v3.0.32
          system.adapter.hm-rpc                  : hm-rpc         - v1.14.45
          system.adapter.icons-mfd-png           : icons-mfd-png  - v1.0.2
          system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.0.2
          system.adapter.info                    : info           - v1.9.8
          system.adapter.javascript              : javascript     - v5.2.13
          system.adapter.scenes                  : scenes         - v2.3.8
          system.adapter.simple-api              : simple-api     - v2.5.3
          system.adapter.sourceanalytix          : sourceanalytix - v0.4.12-2
          system.adapter.sql                     : sql            - v1.15.7
          system.adapter.telegram                : telegram       - v1.10.0
          system.adapter.text2command            : text2command   - v2.1.1
          system.adapter.tr-064                  : tr-064         - v4.2.14
          system.adapter.vis                     : vis            - v1.4.5
          system.adapter.vis-bars                : vis-bars       - v0.1.4
          system.adapter.vis-colorpicker         : vis-colorpicker - v1.2.0
          system.adapter.vis-history             : vis-history    - v1.0.0
          system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.7
          system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
          system.adapter.vis-justgage            : vis-justgage   - v1.0.2
          system.adapter.vis-metro               : vis-metro      - v1.1.2
          system.adapter.vis-players             : vis-players    - v0.1.6
          system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
          system.adapter.web                     : web            - v3.4.9
          system.adapter.zigbee                  : zigbee         - v1.4.4
          pi@ioBroker:~ $
          pi@ioBroker:~ $ iobroker list instances
          + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
            system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
          + system.adapter.deconz.0                 : deconz                : ioBroker                                 -  enabled, port: 8090
          + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
            system.adapter.enigma2.0                : enigma2               : ioBroker                                 - disabled
            system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 - disabled
            system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
          + system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
          + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
          + system.adapter.scenes.0                 : scenes                : ioBroker                                 -  enabled
            system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 - disabled
            system.adapter.sql.0                    : sql                   : ioBroker                                 - disabled, port: 3306
          + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
          + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
            system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
            system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
            system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
            system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
            system.adapter.vis-players.0            : vis-players           : ioBroker                                 - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
            system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
          + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          pi@ioBroker:~ $
          pi@ioBroker:~ $ iobroker update -i
          Used repository: Stable (default)
          hash unchanged, use cached sources
          update done
          Adapter    "admin"         : 5.1.25   , installed 5.1.25
          Adapter    "backitup"      : 2.2.2    , installed 2.2.2
          Adapter    "daswetter"     : 3.0.9    , installed 3.0.9
          Adapter    "deconz"        : 1.3.19   , installed 1.3.19
          Adapter    "discovery"     : 2.7.3    , installed 2.7.3
          Adapter    "fb-checkpresence": 1.1.10  , installed 1.1.10
          Adapter    "flot"          : 1.10.7   , installed 1.10.7
          Adapter    "hm-rega"       : 3.0.32   , installed 3.0.32
          Adapter    "hm-rpc"        : 1.14.45  , installed 1.14.45
          Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
          Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
          Adapter    "info"          : 1.9.8    , installed 1.9.8
          Adapter    "javascript"    : 5.2.13   , installed 5.2.13
          Controller "js-controller" : 3.3.20   , installed 3.3.20
          Adapter    "scenes"        : 2.3.8    , installed 2.3.8
          Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
          Adapter    "socketio"      : 3.1.4    , installed 3.1.5
          Adapter    "sql"           : 1.15.7   , installed 1.15.7
          Adapter    "telegram"      : 1.10.0   , installed 1.10.0
          Adapter    "text2command"  : 2.1.1    , installed 2.1.1
          Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
          Adapter    "vis"           : 1.4.5    , installed 1.4.5
          Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
          Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
          Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
          Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
          Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
          Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
          Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
          Adapter    "vis-players"   : 0.1.6    , installed 0.1.6
          Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
          Adapter    "web"           : 3.4.9    , installed 3.4.9
          pi@ioBroker:~ $
          pi@ioBroker:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
          /usr/bin/nodejs
          v14.18.1
          /usr/bin/node
          v14.18.1
          /usr/bin/npm
          6.14.15
          nodejs:
            Installiert:           14.18.1-deb-1nodesource1
            Installationskandidat: 14.18.1-deb-1nodesource1
            Versionstabelle:
           *** 14.18.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                  100 /var/lib/dpkg/status
               10.24.0~dfsg-1~deb10u1 500
          • Glasfaser
            Glasfaser @Homoran last edited by
            @Chris0680
            @homoran sagte in JavaScript Editor keine Anzeige in Log Konsole:
            Admin 5.1.25
            Probierst du mit deinen Script die ganze Zeit !?
            Was ist mit @Homoran Vorlage !
              @glasfaser keine Änderung
              C Homoran 2 Replies Last reply Reply Quote 0
                Chris0680 @Chris0680 last edited by
                @chris0680 Unglaublich, wenn ich eine zweite JavaScript Instanz erstelle, wird eine Info Meldung beim Neustart angezeigt.
                • Glasfaser
                  Glasfaser @Chris0680 last edited by Glasfaser
                  @chris0680
                  Mache mal ein:
                  iobroker upload all
                  sudo reboot
                    Homoran Global Moderator Administrators @Chris0680 last edited by Homoran
                    @chris0680 sagte in JavaScript Editor keine Anzeige in Log Konsole:
                    tatsächlich?
                    was steht im log?
                    ist ja immerhin eine WARN?
                    obwohl der Block auf Info steht
                    Das stimmt was mit der Instanz nicht
                      @homoran die Lösung war die Instanz einfach zu löschen und neu anzulegen. Trotzdem danke für eure Ratschläge. LG
                      • Glasfaser
                        @chris0680
                        hat kein iobroker upload all geholfen ?
                          @glasfaser hat leider nichts geholfen. Was mach der Befehl eigentlich?
                          Glasfaser Homoran 2 Replies Last reply Reply Quote 0
                          • Glasfaser
                            @chris0680
                            https://forum.iobroker.net/topic/48115/admin-adapter-versions-problem/3?_=1638126463552
                              @chris0680 sagte in [gelöst]JavaScript Editor keine Anzeige in Log Konsole:
                              im Prinzip einen internen Neuinstall
                              1030
