    4. [gelöst] Fehler in Adapterinstallation
      sanda @Thomas Braun last edited by sanda
      @thomas-braun Da kommen elend viele Errormeldungen raus, hier eine kurze Übersicht, da scheint ja richtig was zerschossen zu sein 😞
      npm ERR! missing: iobroker.admin@5.1.25, required by iobroker.inst@2.0.3
      npm ERR! missing: iobroker.backitup@2.2.2, required by iobroker.inst@2.0.3
      npm ERR! missing: iobroker.discovery@2.7.3, required by iobroker.inst@2.0.3
      npm ERR! missing: iobroker.fb-checkpresence@1.1.10, required by iobroker.inst@2.0.3
      npm ERR! missing: iobroker.followthesun@0.3.5, required by iobroker.inst@2.0.3
      npm ERR! missing: iobroker.growatt@1.1.1, required by iobroker.inst@2.0.3
      npm ERR! missing: iobroker.hm-rega@3.0.32, required by iobroker.inst@2.0.3
      npm ERR! missing: iobroker.hm-rpc@1.14.45, required by iobroker.inst@2.0.3
      npm ERR! missing: iobroker.homekit-controller@0.3.3, required by iobroker.inst@2.0.3
      npm ERR! missing: iobroker.ical@1.11.4, required by iobroker.inst@2.0.3
      npm ERR! missing: iobroker.javascript@5.2.13, required by iobroker.inst@2.0.3
      npm ERR! missing: iobroker.js-controller@3.3.20, required by iobroker.inst@2.0.3
      npm ERR! missing: iobroker.mihome-vacuum@3.3.1, required by iobroker.inst@2.0.3
      Wobei der IOB normal läuft.
        Thomas Braun Most Active @sanda last edited by
        @sanda
        Versuch es so:
        iobroker stop
        cd /opt/iobroker
        sudo -H -u iobroker npm install iobroker.js-controller
        iobroker fix
        iobroker start
          @thomas-braun said in Fehler in Adapterinstallation:
          iobroker fix
          Das hat nun etwas länger mit der Ausgabe gedauert.
          Zu viele Errormeldunge 😠
          npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
          The authenticity of host 'github.com (140.82.121.4)' can't be established.me/iobroker/.npm/_locks/staging-66d2468782e8ffc7
          ECDSA key fingerprint is SHA256:p2QAMXNIC1TJYWeIOttrVc98/R1BUFWu3/LiyKgUfQM.
          Are you sure you want to continue connecting (yes/no)? [       ...........] | extract:iobroker.js-controller: verb lock usi[            ......] \ extract:npm: sill extract npm@7.11.1 extracted to /opt/iobroker/node_modules/.staging/npm-fc55516d
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/common@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
          npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/core@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
          npm WARN typedoc@0.20.28 requires a peer of typescript@3.9.x || 4.0.x || 4.1.x but none is installed. You must install peer dependencies yourself.
          npm ERR! Error while executing:
          npm ERR! /usr/bin/git ls-remote -h -t ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git
          npm ERR!
          npm ERR! Host key verification failed.
          npm ERR! fatal: Could not read from remote repository.
          npm ERR!
          npm ERR! Please make sure you have the correct access rights
          npm ERR! and the repository exists.
          npm ERR!
          npm ERR! exited with error code: 128
          npm ERR!     /home/iobroker/.npm/_logs/2021-11-30T13_48_08_408Z-debug.log
            Homoran Global Moderator Administrators @sanda last edited by
            @sanda sagte in Fehler in Adapterinstallation:
            da isser wieder 😞
              Da hast du aber mal mit einer npm>6 herumhantiert...
              Kannst du mal bitte die ungekürzte Ausgabe von
              cd /opt/iobroker
              npm ls
              geben?
              Homoran S 2 Replies Last reply Reply Quote 0
                Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
                @thomas-braun sagte in Fehler in Adapterinstallation:
                also /opt/iobroker/package-lock.json löschen
                  Hier die Ausgabe, passt nicht mal ins Terminal
                  │ │ ├── cookie@0.4.1
                  │ │ ├── cookie-signature@1.0.6 deduped
                  │ │ ├── debug@2.6.9 deduped
                  │ │ ├── depd@2.0.0
                  │ │ ├── on-headers@1.0.2 deduped
                  │ │ ├── parseurl@1.3.3 deduped
                  │ │ ├── safe-buffer@5.2.1
                  │ │ └── uid-safe@2.1.5 deduped
                  │ ├── iobroker.simple-api@2.6.1 deduped
                  │ ├── iobroker.socketio@3.1.4 deduped
                  │ ├─┬ mime-types@2.1.32
                  │ │ └── mime-db@1.49.0
                  │ ├── passport@0.4.1 deduped
                  │ ├── passport-local@1.0.0 deduped
                  │ ├── passport.socketio@3.7.0 deduped
                  │ ├── request@2.88.2 deduped
                  │ ├─┬ socket.io-client@2.3.0
                  │ │ ├── backo2@1.0.2
                  │ │ ├── base64-arraybuffer@0.1.5
                  │ │ ├── component-bind@1.0.0
                  │ │ ├── component-emitter@1.2.1
                  │ │ ├─┬ debug@4.1.1
                  │ │ │ └── ms@2.1.2
                  │ │ ├─┬ engine.io-client@3.4.3
                  │ │ │ ├── component-emitter@1.3.0
                  │ │ │ ├── component-inherit@0.0.3
                  │ │ │ ├─┬ debug@4.1.1
                  │ │ │ │ └── ms@2.1.2
                  │ │ │ ├── engine.io-parser@2.2.0 deduped
                  │ │ │ ├── has-cors@1.1.0 deduped
                  │ │ │ ├── indexof@0.0.1 deduped
                  │ │ │ ├── parseqs@0.0.5 deduped
                  │ │ │ ├── parseuri@0.0.5 deduped
                  │ │ │ ├─┬ ws@6.1.4
                  │ │ │ │ └── async-limiter@1.0.1 deduped
                  │ │ │ ├── xmlhttprequest-ssl@1.5.5
                  │ │ │ └── yeast@0.1.2
                  │ │ ├── has-binary2@1.0.3 deduped
                  │ │ ├── object-component@0.0.3
                  │ │ ├─┬ parseqs@0.0.5
                  │ │ │ └─┬ better-assert@1.0.2
                  │ │ │   └── callsite@1.0.0 deduped
                  │ │ ├─┬ parseuri@0.0.5
                  │ │ │ └── better-assert@1.0.2 deduped
                  │ │ ├─┬ socket.io-parser@3.3.0
                  │ │ │ ├── component-emitter@1.2.1 deduped
                  │ │ │ ├─┬ debug@3.1.0
                  │ │ │ │ └── ms@2.0.0
                  │ │ │ └── isarray@2.0.1 deduped
                  │ │ └── to-array@0.1.4
                  │ └── xtend@4.0.2
                  ├─┬ iobroker.zigbee@1.5.6
                  │ ├── @iobroker/adapter-core@2.5.1 deduped
                  │ ├─┬ tar@6.1.0
                  │ │ ├── chownr@2.0.0
                  │ │ ├── fs-minipass@2.1.0 deduped
                  │ │ ├── minipass@3.1.3 deduped
                  │ │ ├─┬ minizlib@2.1.2
                  │ │ │ ├── minipass@3.1.3 deduped
                  │ │ │ └── yallist@4.0.0 deduped
                  │ │ ├── mkdirp@1.0.4
                  │ ├── typescript@4.4.4 deduped
                  │ ├─┬ zigbee-herdsman@0.13.110
                  │ │ ├── @babel/cli@7.13.0 extraneous
                  │ │ ├── @babel/preset-env@7.13.9 extraneous
                  │ │ ├── @babel/preset-typescript@7.13.0 extraneous
                  │ │ ├─┬ @serialport/bindings@9.0.4
                  │ │ │ ├─┬ @serialport/binding-abstract@9.0.7
                  │ │ │ │ └── debug@4.3.1 deduped
                  │ │ │ ├─┬ @serialport/parser-readline@9.0.7
                  │ │ │ │ └── @serialport/parser-delimiter@9.0.7 deduped
                  │ │ │ ├─┬ bindings@1.5.0
                  │ │ │ │ └── file-uri-to-path@1.0.0
                  │ │ │ ├── debug@4.3.1 deduped
                  │ │ │ ├── nan@2.14.2
                  │ │ │ └─┬ prebuild-install@6.0.1
                  │ │ │   ├── detect-libc@1.0.3
                  │ │ │   ├── expand-template@2.0.3
                  │ │ │   ├── github-from-package@0.0.0
                  │ │ │   ├── minimist@1.2.5
                  │ │ │   ├── mkdirp-classic@0.5.3
                  │ │ │   ├── napi-build-utils@1.0.2
                  │ │ │   ├─┬ node-abi@2.20.0
                  │ │ │   │ └── semver@5.7.1
                  │ │ │   ├── noop-logger@0.1.1
                  │ │ │   ├─┬ npmlog@4.1.2
                  │ │ │   │ ├─┬ are-we-there-yet@1.1.5
                  │ │ │   │ │ ├── delegates@1.0.0
                  │ │ │   │ │ └─┬ readable-stream@2.3.7
                  │ │ │   │ │   ├── core-util-is@1.0.2
                  │ │ │   │ │   ├── inherits@2.0.4 deduped
                  │ │ │   │ │   ├── isarray@1.0.0
                  │ │ │   │ │   ├── process-nextick-args@2.0.1
                  │ │ │   │ │   ├── safe-buffer@5.1.2 deduped
                  │ │ │   │ │   ├─┬ string_decoder@1.1.1
                  │ │ │   │ │   │ └── safe-buffer@5.1.2 deduped
                  │ │ │   │ │   └── util-deprecate@1.0.2
                  │ │ │   │ ├── console-control-strings@1.1.0
                  │ │ │   │ ├─┬ gauge@2.7.4
                  │ │ │   │ │ ├── aproba@1.2.0
                  │ │ │   │ │ ├── console-control-strings@1.1.0 deduped
                  │ │ │   │ │ ├── has-unicode@2.0.1
                  │ │ │   │ │ ├── object-assign@4.1.1 deduped
                  │ │ │   │ │ ├── signal-exit@3.0.3
                  │ │ │   │ │ ├─┬ string-width@1.0.2
                  │ │ │   │ │ │ ├── code-point-at@1.1.0
                  │ │ │   │ │ │ ├─┬ is-fullwidth-code-point@1.0.0
                  │ │ │   │ │ │ │ └── number-is-nan@1.0.1
                  │ │ │   │ │ │ └── strip-ansi@3.0.1 deduped
                  │ │ │   │ │ ├─┬ strip-ansi@3.0.1
                  │ │ │   │ │ │ └── ansi-regex@2.1.1
                  │ │ │   │ │ └─┬ wide-align@1.1.3
                  │ │ │   │ │   └── string-width@1.0.2 deduped
                  │ │ │   │ └── set-blocking@2.0.0
                  │ │ │   ├─┬ pump@3.0.0
                  │ │ │   │ ├─┬ end-of-stream@1.4.4
                  │ │ │   │ │ └── once@1.4.0 deduped
                  │ │ │   │ └─┬ once@1.4.0
                  │ │ │   │   └── wrappy@1.0.2
                  │ │ │   ├─┬ rc@1.2.8
                  │ │ │   │ ├── deep-extend@0.6.0
                  │ │ │   │ ├── ini@1.3.8
                  │ │ │   │ ├── minimist@1.2.5 deduped
                  │ │ │   │ └── strip-json-comments@2.0.1
                  │ │ │   ├─┬ simple-get@3.1.0
                  │ │ │   │ ├─┬ decompress-response@4.2.1
                  │ │ │   │ │ └── mimic-response@2.1.0
                  │ │ │   │ ├── once@1.4.0 deduped
                  │ │ │   │ └── simple-concat@1.0.1
                  │ │ │   ├─┬ tar-fs@2.1.1
                  │ │ │   │ ├── chownr@1.1.4
                  │ │ │   │ ├── mkdirp-classic@0.5.3 deduped
                  │ │ │   │ ├── pump@3.0.0 deduped
                  │ │ │   │ └─┬ tar-stream@2.2.0
                  │ │ │   │   ├─┬ bl@4.1.0
                  │ │ │   │   │ ├─┬ buffer@5.7.1
                  │ │ │   │   │ │ ├── base64-js@1.5.1
                  │ │ │   │   │ │ └── ieee754@1.2.1
                  │ │ │   │   │ └─┬ readable-stream@3.6.0
                  │ │ │   │   │   ├── string_decoder@1.1.1 deduped
                  │ │ │   │   │   └── util-deprecate@1.0.2 deduped
                  │ │ │   │   ├── end-of-stream@1.4.4 deduped
                  │ │ │   │   ├── fs-constants@1.0.0
                  │ │ │   ├─┬ tunnel-agent@0.6.0
                  │ │ │   └── which-pm-runs@1.0.0
                  │ │ ├── @types/debounce@1.2.0 extraneous
                  │ │ ├── @types/debug@4.1.5 extraneous
                  │ │ ├── @types/jest@26.0.20 extraneous
                  │ │ ├── @types/mz@2.7.3 extraneous
                  │ │ ├── @types/nedb@1.8.11 extraneous
                  │ │ ├── @types/serialport@8.0.1 extraneous
                  │ │ ├── @typescript-eslint/eslint-plugin@4.16.1 extraneous
                  │ │ ├── @typescript-eslint/parser@4.16.1 extraneous
                  │ │ ├── debounce@1.2.0
                  │ │ ├─┬ debug@4.3.1
                  │ │ │ └── ms@2.1.2
                  │ │ ├── eslint@7.21.0 extraneous
                  │ │ ├── fast-deep-equal@3.1.3
                  │ │ ├── jest@26.6.3 extraneous
                  │ │ ├── mixin-deep@2.0.1
                  │ │ ├─┬ mz@2.7.0
                  │ │ │ ├── any-promise@1.3.0
                  │ │ │ └─┬ thenify-all@1.6.0
                  │ │ │   └─┬ thenify@3.3.1
                  │ │ │     └── any-promise@1.3.0 deduped
                  │ │ ├─┬ serialport@9.0.6
                  │ │ │ ├─┬ @serialport/binding-mock@9.0.7
                  │ │ │ │ ├── @serialport/binding-abstract@9.0.7 deduped
                  │ │ │ ├── @serialport/bindings@9.0.4 deduped
                  │ │ │ ├── @serialport/parser-byte-length@9.0.7
                  │ │ │ ├── @serialport/parser-cctalk@9.0.7
                  │ │ │ ├── @serialport/parser-delimiter@9.0.7
                  │ │ │ ├── @serialport/parser-inter-byte-timeout@9.0.7
                  │ │ │ ├── @serialport/parser-readline@9.0.7 deduped
                  │ │ │ ├── @serialport/parser-ready@9.0.7
                  │ │ │ ├── @serialport/parser-regex@9.0.7
                  │ │ │ ├─┬ @serialport/stream@9.0.7
                  │ │ ├── slip@1.0.2
                  │ │ ├── typedoc@0.20.28 extraneous
                  │ │ ├── typedoc-plugin-markdown@3.6.0 extraneous
                  │ │ ├── typedoc-plugin-no-inherit@1.2.0 extraneous
                  │ │ ├── typedoc-plugin-sourcefile-url@1.0.6 extraneous
                  │ │ └── UNMET PEER DEPENDENCY typescript@4.2.2 extraneous
                  │ └─┬ zigbee-herdsman-converters@14.0.162
                  │   ├─┬ axios@0.21.1
                  │   │ └── follow-redirects@1.14.1
                  │   ├── buffer-crc32@0.2.13
                  │   ├── eslint@7.27.0 extraneous
                  │   ├── eslint-config-google@0.14.0 extraneous
                  │   ├── eslint-plugin-jest@24.3.6 extraneous
                  │   ├─┬ https-proxy-agent@5.0.0
                  │   │ ├─┬ agent-base@6.0.2
                  │   │ └─┬ debug@4.3.1
                  │   │   └── ms@2.1.2
                  │   ├─┬ tar-stream@2.2.0
                  │   │ ├─┬ bl@4.1.0
                  │   │ │ └── readable-stream@3.6.0 deduped
                  │   │   ├─┬ string_decoder@1.3.0
                  │   │   │ └── safe-buffer@5.2.1
                  │   └─┬ zigbee-herdsman@0.13.107
                  │     │ ├── nan@2.14.2
                  │     │   ├─┬ pump@3.0.0
                  │     │   ├─┬ rc@1.2.8
                  │     │   │ ├── ini@1.3.8
                  │     │   │   ├─┬ bl@4.1.0
                  │     ├─┬ debug@4.3.1
                  │     │ └── ms@2.1.2
                  │     ├─┬ mz@2.7.0
                  │     ├── slip@1.0.2
                  ├── semver@5.7.1
                  └─┬ yargs@7.1.1
                    ├── camelcase@3.0.0
                    ├─┬ cliui@3.2.0
                    │ ├── string-width@1.0.2 deduped
                    │ └─┬ wrap-ansi@2.1.0
                    ├── decamelize@1.2.0
                    ├── get-caller-file@1.0.3
                    ├─┬ os-locale@1.4.0
                    │ └─┬ lcid@1.0.0
                    │   └── invert-kv@1.0.0
                    ├─┬ read-pkg-up@1.0.1
                    │ ├─┬ find-up@1.1.2
                    │ │ ├─┬ path-exists@2.1.0
                    │ │ │ └── pinkie-promise@2.0.1 deduped
                    │ │ └─┬ pinkie-promise@2.0.1
                    │ │   └── pinkie@2.0.4
                    │ └─┬ read-pkg@1.1.0
                    │   ├─┬ load-json-file@1.1.0
                    │   │ ├── graceful-fs@4.2.4 deduped
                    │   │ ├─┬ parse-json@2.2.0
                    │   │ │ └── error-ex@1.3.2 deduped
                    │   │ ├── pify@2.3.0
                    │   │ ├── pinkie-promise@2.0.1 deduped
                    │   │ └─┬ strip-bom@2.0.0
                    │   │   └── is-utf8@0.2.1
                    │   ├─┬ normalize-package-data@2.5.0
                    │   │ ├── hosted-git-info@2.8.8
                    │   │ ├─┬ resolve@1.17.0
                    │   │ │ └── path-parse@1.0.6 deduped
                    │   │ ├── semver@5.7.1 deduped
                    │   │ └── validate-npm-package-license@3.0.4 deduped
                    │   └─┬ path-type@1.1.0
                    │     ├── pify@2.3.0 deduped
                    ├── require-directory@2.1.1
                    ├── require-main-filename@1.0.1
                    ├── set-blocking@2.0.0
                    ├── which-module@1.0.0
                    ├── y18n@3.2.1
                    └─┬ yargs-parser@5.0.0-security.0
                      ├── camelcase@3.0.0 deduped
                      └─┬ object.assign@4.1.0
                        ├── define-properties@1.1.3 deduped
                        ├── function-bind@1.1.1 deduped
                        ├── has-symbols@1.0.1
                        └── object-keys@1.1.1
                  npm ERR! missing: iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#f64a6083778ce5b12274eadb73e78cf28568fccc, required by iobroker.inst@2.0.3
                  npm ERR! peer dep missing: @angular/common@>= 5.0.0, required by xmlhttprequest-ts@1.0.1
                  npm ERR! peer dep missing: @angular/core@>= 5.0.0, required by xmlhttprequest-ts@1.0.1
                  npm ERR! missing: xmlhttprequest@^1.8.0, required by iobroker.javascript@5.2.13
                  npm ERR! missing: cron@1.8.2, required by iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#f64a6083778ce5b12274eadb73e78cf28568fccc
                  npm ERR! missing: iobroker-adapter-helpers@0.0.8, required by iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#f64a6083778ce5b12274eadb73e78cf28568fccc
                  npm ERR! missing: @sentry/node@5.30.0, required by iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#f64a6083778ce5b12274eadb73e78cf28568fccc
                  npm ERR! missing: npm@7.11.1, required by iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#f64a6083778ce5b12274eadb73e78cf28568fccc
                  npm ERR! missing: node-schedule@1.3.2, required by iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#f64a6083778ce5b12274eadb73e78cf28568fccc
                  npm ERR! missing: @sentry/core@5.30.0, required by @sentry/node@5.30.0
                  npm ERR! missing: @sentry/hub@5.30.0, required by @sentry/node@5.30.0
                  npm ERR! missing: @sentry/tracing@5.30.0, required by @sentry/node@5.30.0
                  npm ERR! missing: @sentry/types@5.30.0, required by @sentry/node@5.30.0
                  npm ERR! missing: @sentry/utils@5.30.0, required by @sentry/node@5.30.0
                  npm ERR! missing: cookie@0.4.1, required by @sentry/node@5.30.0
                  npm ERR! missing: @sentry/hub@5.30.0, required by @sentry/core@5.30.0
                  npm ERR! missing: @sentry/minimal@5.30.0, required by @sentry/core@5.30.0
                  npm ERR! missing: @sentry/types@5.30.0, required by @sentry/core@5.30.0
                  npm ERR! missing: @sentry/utils@5.30.0, required by @sentry/core@5.30.0
                  npm ERR! missing: @sentry/hub@5.30.0, required by @sentry/minimal@5.30.0
                  npm ERR! missing: @sentry/types@5.30.0, required by @sentry/minimal@5.30.0
                  npm ERR! missing: @sentry/types@5.30.0, required by @sentry/hub@5.30.0
                  npm ERR! missing: @sentry/utils@5.30.0, required by @sentry/hub@5.30.0
                  npm ERR! missing: @sentry/hub@5.30.0, required by @sentry/tracing@5.30.0
                  npm ERR! missing: @sentry/minimal@5.30.0, required by @sentry/tracing@5.30.0
                  npm ERR! missing: @sentry/types@5.30.0, required by @sentry/tracing@5.30.0
                  npm ERR! missing: @sentry/utils@5.30.0, required by @sentry/tracing@5.30.0
                  npm ERR! missing: @sentry/types@5.30.0, required by @sentry/utils@5.30.0
                  npm ERR! missing: @npmcli/arborist@2.4.0, required by npm@7.11.1
                  npm ERR! missing: @npmcli/ci-detect@1.3.0, required by npm@7.11.1
                  npm ERR! missing: @npmcli/config@2.2.0, required by npm@7.11.1
                  npm ERR! missing: @npmcli/run-script@1.8.5, required by npm@7.11.1
                  npm ERR! missing: abbrev@1.1.1, required by npm@7.11.1
                  npm ERR! missing: ansicolors@0.3.2, required by npm@7.11.1
                  npm ERR! missing: ansistyles@0.1.3, required by npm@7.11.1
                  npm ERR! missing: archy@1.0.0, required by npm@7.11.1
                  npm ERR! missing: byte-size@7.0.1, required by npm@7.11.1
                  npm ERR! missing: cacache@15.0.6, required by npm@7.11.1
                  npm ERR! missing: chalk@4.1.1, required by npm@7.11.1
                  npm ERR! missing: chownr@2.0.0, required by npm@7.11.1
                  npm ERR! missing: cli-columns@3.1.2, required by npm@7.11.1
                  npm ERR! missing: cli-table3@0.6.0, required by npm@7.11.1
                  npm ERR! missing: columnify@1.5.4, required by npm@7.11.1
                  npm ERR! missing: glob@7.1.6, required by npm@7.11.1
                  npm ERR! missing: graceful-fs@4.2.6, required by npm@7.11.1
                  npm ERR! missing: hosted-git-info@4.0.2, required by npm@7.11.1
                  npm ERR! missing: ini@2.0.0, required by npm@7.11.1
                  npm ERR! missing: init-package-json@2.0.3, required by npm@7.11.1
                  npm ERR! missing: is-cidr@4.0.2, required by npm@7.11.1
                  npm ERR! missing: json-parse-even-better-errors@2.3.1, required by npm@7.11.1
                  npm ERR! missing: leven@3.1.0, required by npm@7.11.1
                  npm ERR! missing: libnpmaccess@4.0.2, required by npm@7.11.1
                  npm ERR! missing: libnpmdiff@2.0.4, required by npm@7.11.1
                  npm ERR! missing: libnpmexec@1.0.1, required by npm@7.11.1
                  npm ERR! missing: libnpmfund@1.0.2, required by npm@7.11.1
                  npm ERR! missing: libnpmhook@6.0.2, required by npm@7.11.1
                  npm ERR! missing: libnpmorg@2.0.2, required by npm@7.11.1
                  npm ERR! missing: libnpmpack@2.0.1, required by npm@7.11.1
                  npm ERR! missing: libnpmpublish@4.0.1, required by npm@7.11.1
                  npm ERR! missing: libnpmsearch@3.1.1, required by npm@7.11.1
                  npm ERR! missing: libnpmteam@2.0.3, required by npm@7.11.1
                  npm ERR! missing: libnpmversion@1.2.0, required by npm@7.11.1
                  npm ERR! missing: make-fetch-happen@8.0.14, required by npm@7.11.1
                  npm ERR! missing: minipass@3.1.3, required by npm@7.11.1
                  npm ERR! missing: minipass-pipeline@1.2.4, required by npm@7.11.1
                  npm ERR! missing: mkdirp@1.0.4, required by npm@7.11.1
                  npm ERR! missing: mkdirp-infer-owner@2.0.0, required by npm@7.11.1
                  npm ERR! missing: ms@2.1.3, required by npm@7.11.1
                  npm ERR! missing: node-gyp@7.1.2, required by npm@7.11.1
                  npm ERR! missing: nopt@5.0.0, required by npm@7.11.1
                  npm ERR! missing: npm-audit-report@2.1.4, required by npm@7.11.1
                  npm ERR! missing: npm-package-arg@8.1.2, required by npm@7.11.1
                  npm ERR! missing: npm-pick-manifest@6.1.1, required by npm@7.11.1
                  npm ERR! missing: npm-profile@5.0.3, required by npm@7.11.1
                  npm ERR! missing: npm-registry-fetch@10.1.1, required by npm@7.11.1
                  npm ERR! missing: npm-user-validate@1.0.1, required by npm@7.11.1
                  npm ERR! missing: npmlog@4.1.2, required by npm@7.11.1
                  npm ERR! missing: opener@1.5.2, required by npm@7.11.1
                  npm ERR! missing: pacote@11.3.3, required by npm@7.11.1
                  npm ERR! missing: parse-conflict-json@1.1.1, required by npm@7.11.1
                  npm ERR! missing: qrcode-terminal@0.12.0, required by npm@7.11.1
                  npm ERR! missing: read@1.0.7, required by npm@7.11.1
                  npm ERR! missing: read-package-json@3.0.1, required by npm@7.11.1
                  npm ERR! missing: read-package-json-fast@2.0.2, required by npm@7.11.1
                  npm ERR! missing: readdir-scoped-modules@1.1.0, required by npm@7.11.1
                  npm ERR! missing: rimraf@3.0.2, required by npm@7.11.1
                  npm ERR! missing: semver@7.3.5, required by npm@7.11.1
                  npm ERR! missing: ssri@8.0.1, required by npm@7.11.1
                  npm ERR! missing: tar@6.1.0, required by npm@7.11.1
                  npm ERR! missing: text-table@0.2.0, required by npm@7.11.1
                  npm ERR! missing: tiny-relative-date@1.3.0, required by npm@7.11.1
                  npm ERR! missing: treeverse@1.0.4, required by npm@7.11.1
                  npm ERR! missing: validate-npm-package-name@3.0.0, required by npm@7.11.1
                  npm ERR! missing: which@2.0.2, required by npm@7.11.1
                  npm ERR! missing: write-file-atomic@3.0.3, required by npm@7.11.1
                  npm ERR! missing: @npmcli/installed-package-contents@1.0.7, required by @npmcli/arborist@2.4.0
                  npm ERR! missing: @npmcli/map-workspaces@1.0.3, required by @npmcli/arborist@2.4.0
                  npm ERR! missing: @npmcli/metavuln-calculator@1.1.1, required by @npmcli/arborist@2.4.0
                  npm ERR! missing: @npmcli/move-file@1.1.2, required by @npmcli/arborist@2.4.0
                  npm ERR! missing: @npmcli/name-from-folder@1.0.1, required by @npmcli/arborist@2.4.0
                  npm ERR! missing: @npmcli/node-gyp@1.0.2, required by @npmcli/arborist@2.4.0
                  npm ERR! missing: @npmcli/run-script@1.8.5, required by @npmcli/arborist@2.4.0
                  npm ERR! missing: bin-links@2.2.1, required by @npmcli/arborist@2.4.0
                  npm ERR! missing: cacache@15.0.6, required by @npmcli/arborist@2.4.0
                  npm ERR! missing: common-ancestor-path@1.0.1, required by @npmcli/arborist@2.4.0
                  npm ERR! missing: json-parse-even-better-errors@2.3.1, required by @npmcli/arborist@2.4.0
                  npm ERR! missing: json-stringify-nice@1.1.3, required by @npmcli/arborist@2.4.0
                  npm ERR! missing: mkdirp-infer-owner@2.0.0, required by @npmcli/arborist@2.4.0
                  npm ERR! missing: npm-install-checks@4.0.0, required by @npmcli/arborist@2.4.0
                  npm ERR! missing: npm-package-arg@8.1.2, required by @npmcli/arborist@2.4.0
                  npm ERR! missing: npm-pick-manifest@6.1.1, required by @npmcli/arborist@2.4.0
                  npm ERR! missing: npm-registry-fetch@10.1.1, required by @npmcli/arborist@2.4.0
                  npm ERR! missing: pacote@11.3.3, required by @npmcli/arborist@2.4.0
                  npm ERR! missing: parse-conflict-json@1.1.1, required by @npmcli/arborist@2.4.0
                  npm ERR! missing: promise-all-reject-late@1.0.1, required by @npmcli/arborist@2.4.0
                  npm ERR! missing: promise-call-limit@1.0.1, required by @npmcli/arborist@2.4.0
                  npm ERR! missing: read-package-json-fast@2.0.2, required by @npmcli/arborist@2.4.0
                  npm ERR! missing: readdir-scoped-modules@1.1.0, required by @npmcli/arborist@2.4.0
                  npm ERR! missing: semver@7.3.5, required by @npmcli/arborist@2.4.0
                  npm ERR! missing: tar@6.1.0, required by @npmcli/arborist@2.4.0
                  npm ERR! missing: treeverse@1.0.4, required by @npmcli/arborist@2.4.0
                  npm ERR! missing: walk-up-path@1.0.0, required by @npmcli/arborist@2.4.0
                  npm ERR! missing: npm-bundled@1.1.2, required by @npmcli/installed-package-contents@1.0.7
                  npm ERR! missing: npm-normalize-package-bin@1.0.1, required by @npmcli/installed-package-contents@1.0.7
                  npm ERR! missing: npm-normalize-package-bin@1.0.1, required by npm-bundled@1.1.2
                  npm ERR! missing: @npmcli/name-from-folder@1.0.1, required by @npmcli/map-workspaces@1.0.3
                  npm ERR! missing: glob@7.1.6, required by @npmcli/map-workspaces@1.0.3
                  npm ERR! missing: minimatch@3.0.4, required by @npmcli/map-workspaces@1.0.3
                  npm ERR! missing: read-package-json-fast@2.0.2, required by @npmcli/map-workspaces@1.0.3
                  npm ERR! missing: cacache@15.0.6, required by @npmcli/metavuln-calculator@1.1.1
                  npm ERR! missing: pacote@11.3.3, required by @npmcli/metavuln-calculator@1.1.1
                  npm ERR! missing: semver@7.3.5, required by @npmcli/metavuln-calculator@1.1.1
                  npm ERR! missing: mkdirp@1.0.4, required by @npmcli/move-file@1.1.2
                  npm ERR! missing: rimraf@3.0.2, required by @npmcli/move-file@1.1.2
                  npm ERR! missing: cmd-shim@4.1.0, required by bin-links@2.2.1
                  npm ERR! missing: mkdirp@1.0.4, required by bin-links@2.2.1
                  npm ERR! missing: npm-normalize-package-bin@1.0.1, required by bin-links@2.2.1
                  npm ERR! missing: read-cmd-shim@2.0.0, required by bin-links@2.2.1
                  npm ERR! missing: rimraf@3.0.2, required by bin-links@2.2.1
                  npm ERR! missing: write-file-atomic@3.0.3, required by bin-links@2.2.1
                  npm ERR! missing: mkdirp-infer-owner@2.0.0, required by cmd-shim@4.1.0
                  npm ERR! missing: semver@7.3.5, required by npm-install-checks@4.0.0
                  npm ERR! missing: ini@2.0.0, required by @npmcli/config@2.2.0
                  npm ERR! missing: mkdirp-infer-owner@2.0.0, required by @npmcli/config@2.2.0
                  npm ERR! missing: nopt@5.0.0, required by @npmcli/config@2.2.0
                  npm ERR! missing: semver@7.3.5, required by @npmcli/config@2.2.0
                  npm ERR! missing: walk-up-path@1.0.0, required by @npmcli/config@2.2.0
                  npm ERR! missing: @npmcli/node-gyp@1.0.2, required by @npmcli/run-script@1.8.5
                  npm ERR! missing: @npmcli/promise-spawn@1.3.2, required by @npmcli/run-script@1.8.5
                  npm ERR! missing: infer-owner@1.0.4, required by @npmcli/run-script@1.8.5
                  npm ERR! missing: node-gyp@7.1.2, required by @npmcli/run-script@1.8.5
                  npm ERR! missing: read-package-json-fast@2.0.2, required by @npmcli/run-script@1.8.5
                  npm ERR! missing: infer-owner@1.0.4, required by @npmcli/promise-spawn@1.3.2
                  npm ERR! missing: @npmcli/move-file@1.1.2, required by cacache@15.0.6
                  npm ERR! missing: chownr@2.0.0, required by cacache@15.0.6
                  npm ERR! missing: fs-minipass@2.1.0, required by cacache@15.0.6
                  npm ERR! missing: glob@7.1.6, required by cacache@15.0.6
                  npm ERR! missing: infer-owner@1.0.4, required by cacache@15.0.6
                  npm ERR! missing: lru-cache@6.0.0, required by cacache@15.0.6
                  npm ERR! missing: minipass@3.1.3, required by cacache@15.0.6
                  npm ERR! missing: minipass-collect@1.0.2, required by cacache@15.0.6
                  npm ERR! missing: minipass-flush@1.0.5, required by cacache@15.0.6
                  npm ERR! missing: minipass-pipeline@1.2.4, required by cacache@15.0.6
                  npm ERR! missing: mkdirp@1.0.4, required by cacache@15.0.6
                  npm ERR! missing: p-map@4.0.0, required by cacache@15.0.6
                  npm ERR! missing: promise-inflight@1.0.1, required by cacache@15.0.6
                  npm ERR! missing: rimraf@3.0.2, required by cacache@15.0.6
                  npm ERR! missing: ssri@8.0.1, required by cacache@15.0.6
                  npm ERR! missing: tar@6.1.0, required by cacache@15.0.6
                  npm ERR! missing: unique-filename@1.1.1, required by cacache@15.0.6
                  npm ERR! missing: minipass@3.1.3, required by fs-minipass@2.1.0
                  npm ERR! missing: yallist@4.0.0, required by lru-cache@6.0.0
                  npm ERR! missing: minipass@3.1.3, required by minipass-collect@1.0.2
                  npm ERR! missing: minipass@3.1.3, required by minipass-flush@1.0.5
                  npm ERR! missing: aggregate-error@3.1.0, required by p-map@4.0.0
                  npm ERR! missing: clean-stack@2.2.0, required by aggregate-error@3.1.0
                  npm ERR! missing: indent-string@4.0.0, required by aggregate-error@3.1.0
                  npm ERR! missing: unique-slug@2.0.2, required by unique-filename@1.1.1
                  npm ERR! missing: imurmurhash@0.1.4, required by unique-slug@2.0.2
                  npm ERR! missing: ansi-styles@4.3.0, required by chalk@4.1.1
                  npm ERR! missing: supports-color@7.2.0, required by chalk@4.1.1
                  npm ERR! missing: color-convert@2.0.1, required by ansi-styles@4.3.0
                  npm ERR! missing: color-name@1.1.4, required by color-convert@2.0.1
                  npm ERR! missing: has-flag@4.0.0, required by supports-color@7.2.0
                  npm ERR! missing: string-width@2.1.1, required by cli-columns@3.1.2
                  npm ERR! missing: strip-ansi@3.0.1, required by cli-columns@3.1.2
                  npm ERR! missing: is-fullwidth-code-point@2.0.0, required by string-width@2.1.1
                  npm ERR! missing: strip-ansi@4.0.0, required by string-width@2.1.1
                  npm ERR! missing: ansi-regex@3.0.0, required by strip-ansi@4.0.0
                  npm ERR! missing: ansi-regex@2.1.1, required by strip-ansi@3.0.1
                  npm ERR! missing: string-width@4.2.2, required by cli-table3@0.6.0
                  npm ERR! missing: object-assign@4.1.1, required by cli-table3@0.6.0
                  npm ERR! missing: is-fullwidth-code-point@3.0.0, required by string-width@4.2.2
                  npm ERR! missing: strip-ansi@6.0.0, required by string-width@4.2.2
                  npm ERR! missing: emoji-regex@8.0.0, required by string-width@4.2.2
                  npm ERR! missing: ansi-regex@5.0.0, required by strip-ansi@6.0.0
                  npm ERR! missing: strip-ansi@3.0.1, required by columnify@1.5.4
                  npm ERR! missing: wcwidth@1.0.1, required by columnify@1.5.4
                  npm ERR! missing: defaults@1.0.3, required by wcwidth@1.0.1
                  npm ERR! missing: clone@1.0.4, required by defaults@1.0.3
                  npm ERR! missing: fs.realpath@1.0.0, required by glob@7.1.6
                  npm ERR! missing: inflight@1.0.6, required by glob@7.1.6
                  npm ERR! missing: inherits@2.0.4, required by glob@7.1.6
                  npm ERR! missing: minimatch@3.0.4, required by glob@7.1.6
                  npm ERR! missing: once@1.4.0, required by glob@7.1.6
                  npm ERR! missing: path-is-absolute@1.0.1, required by glob@7.1.6
                  npm ERR! missing: once@1.4.0, required by inflight@1.0.6
                  npm ERR! missing: wrappy@1.0.2, required by inflight@1.0.6
                  npm ERR! missing: brace-expansion@1.1.11, required by minimatch@3.0.4
                  npm ERR! missing: balanced-match@1.0.2, required by brace-expansion@1.1.11
                  npm ERR! missing: concat-map@0.0.1, required by brace-expansion@1.1.11
                  npm ERR! missing: wrappy@1.0.2, required by once@1.4.0
                  npm ERR! missing: lru-cache@6.0.0, required by hosted-git-info@4.0.2
                  npm ERR! missing: glob@7.1.6, required by init-package-json@2.0.3
                  npm ERR! missing: npm-package-arg@8.1.2, required by init-package-json@2.0.3
                  npm ERR! missing: promzard@0.3.0, required by init-package-json@2.0.3
                  npm ERR! missing: read@1.0.7, required by init-package-json@2.0.3
                  npm ERR! missing: read-package-json@3.0.1, required by init-package-json@2.0.3
                  npm ERR! missing: semver@7.3.5, required by init-package-json@2.0.3
                  npm ERR! missing: validate-npm-package-license@3.0.4, required by init-package-json@2.0.3
                  npm ERR! missing: validate-npm-package-name@3.0.0, required by init-package-json@2.0.3
                  npm ERR! missing: read@1.0.7, required by promzard@0.3.0
                  npm ERR! missing: spdx-correct@3.1.1, required by validate-npm-package-license@3.0.4
                  npm ERR! missing: spdx-expression-parse@3.0.1, required by validate-npm-package-license@3.0.4
                  npm ERR! missing: spdx-expression-parse@3.0.1, required by spdx-correct@3.1.1
                  npm ERR! missing: spdx-license-ids@3.0.7, required by spdx-correct@3.1.1
                  npm ERR! missing: spdx-exceptions@2.3.0, required by spdx-expression-parse@3.0.1
                  npm ERR! missing: spdx-license-ids@3.0.7, required by spdx-expression-parse@3.0.1
                  npm ERR! missing: cidr-regex@3.1.1, required by is-cidr@4.0.2
                  npm ERR! missing: ip-regex@4.3.0, required by cidr-regex@3.1.1
                  npm ERR! missing: aproba@2.0.0, required by libnpmaccess@4.0.2
                  npm ERR! missing: minipass@3.1.3, required by libnpmaccess@4.0.2
                  npm ERR! missing: npm-package-arg@8.1.2, required by libnpmaccess@4.0.2
                  npm ERR! missing: npm-registry-fetch@10.1.1, required by libnpmaccess@4.0.2
                  npm ERR! missing: @npmcli/disparity-colors@1.0.1, required by libnpmdiff@2.0.4
                  npm ERR! missing: @npmcli/installed-package-contents@1.0.7, required by libnpmdiff@2.0.4
                  npm ERR! missing: binary-extensions@2.2.0, required by libnpmdiff@2.0.4
                  npm ERR! missing: diff@5.0.0, required by libnpmdiff@2.0.4
                  npm ERR! missing: minimatch@3.0.4, required by libnpmdiff@2.0.4
                  npm ERR! missing: npm-package-arg@8.1.2, required by libnpmdiff@2.0.4
                  npm ERR! missing: pacote@11.3.3, required by libnpmdiff@2.0.4
                  npm ERR! missing: tar@6.1.0, required by libnpmdiff@2.0.4
                  npm ERR! missing: ansi-styles@4.3.0, required by @npmcli/disparity-colors@1.0.1
                  npm ERR! missing: @npmcli/arborist@2.4.0, required by libnpmexec@1.0.1
                  npm ERR! missing: @npmcli/ci-detect@1.3.0, required by libnpmexec@1.0.1
                  npm ERR! missing: @npmcli/run-script@1.8.5, required by libnpmexec@1.0.1
                  npm ERR! missing: chalk@4.1.1, required by libnpmexec@1.0.1
                  npm ERR! missing: mkdirp-infer-owner@2.0.0, required by libnpmexec@1.0.1
                  npm ERR! missing: npm-package-arg@8.1.2, required by libnpmexec@1.0.1
                  npm ERR! missing: pacote@11.3.3, required by libnpmexec@1.0.1
                  npm ERR! missing: proc-log@1.0.0, required by libnpmexec@1.0.1
                  npm ERR! missing: read@1.0.7, required by libnpmexec@1.0.1
                  npm ERR! missing: read-package-json-fast@2.0.2, required by libnpmexec@1.0.1
                  npm ERR! missing: @npmcli/arborist@2.4.0, required by libnpmfund@1.0.2
                  npm ERR! missing: aproba@2.0.0, required by libnpmhook@6.0.2
                  npm ERR! missing: npm-registry-fetch@10.1.1, required by libnpmhook@6.0.2
                  npm ERR! missing: aproba@2.0.0, required by libnpmorg@2.0.2
                  npm ERR! missing: npm-registry-fetch@10.1.1, required by libnpmorg@2.0.2
                  npm ERR! missing: @npmcli/run-script@1.8.5, required by libnpmpack@2.0.1
                  npm ERR! missing: npm-package-arg@8.1.2, required by libnpmpack@2.0.1
                  npm ERR! missing: pacote@11.3.3, required by libnpmpack@2.0.1
                  npm ERR! missing: normalize-package-data@3.0.2, required by libnpmpublish@4.0.1
                  npm ERR! missing: npm-package-arg@8.1.2, required by libnpmpublish@4.0.1
                  npm ERR! missing: npm-registry-fetch@10.1.1, required by libnpmpublish@4.0.1
                  npm ERR! missing: semver@7.3.5, required by libnpmpublish@4.0.1
                  npm ERR! missing: ssri@8.0.1, required by libnpmpublish@4.0.1
                  npm ERR! missing: hosted-git-info@4.0.2, required by normalize-package-data@3.0.2
                  npm ERR! missing: resolve@1.20.0, required by normalize-package-data@3.0.2
                  npm ERR! missing: semver@7.3.5, required by normalize-package-data@3.0.2
                  npm ERR! missing: validate-npm-package-license@3.0.4, required by normalize-package-data@3.0.2
                  npm ERR! missing: is-core-module@2.2.0, required by resolve@1.20.0
                  npm ERR! missing: path-parse@1.0.6, required by resolve@1.20.0
                  npm ERR! missing: has@1.0.3, required by is-core-module@2.2.0
                  npm ERR! missing: function-bind@1.1.1, required by has@1.0.3
                  npm ERR! missing: npm-registry-fetch@10.1.1, required by libnpmsearch@3.1.1
                  npm ERR! missing: aproba@2.0.0, required by libnpmteam@2.0.3
                  npm ERR! missing: npm-registry-fetch@10.1.1, required by libnpmteam@2.0.3
                  npm ERR! missing: @npmcli/git@2.0.8, required by libnpmversion@1.2.0
                  npm ERR! missing: @npmcli/run-script@1.8.5, required by libnpmversion@1.2.0
                  npm ERR! missing: json-parse-even-better-errors@2.3.1, required by libnpmversion@1.2.0
                  npm ERR! missing: semver@7.3.5, required by libnpmversion@1.2.0
                  npm ERR! missing: stringify-package@1.0.1, required by libnpmversion@1.2.0
                  npm ERR! missing: @npmcli/promise-spawn@1.3.2, required by @npmcli/git@2.0.8
                  npm ERR! missing: lru-cache@6.0.0, required by @npmcli/git@2.0.8
                  npm ERR! missing: mkdirp@1.0.4, required by @npmcli/git@2.0.8
                  npm ERR! missing: npm-pick-manifest@6.1.1, required by @npmcli/git@2.0.8
                  npm ERR! missing: promise-inflight@1.0.1, required by @npmcli/git@2.0.8
                  npm ERR! missing: promise-retry@2.0.1, required by @npmcli/git@2.0.8
                  npm ERR! missing: semver@7.3.5, required by @npmcli/git@2.0.8
                  npm ERR! missing: which@2.0.2, required by @npmcli/git@2.0.8
                  npm ERR! missing: agentkeepalive@4.1.4, required by make-fetch-happen@8.0.14
                  npm ERR! missing: cacache@15.0.6, required by make-fetch-happen@8.0.14
                  npm ERR! missing: http-cache-semantics@4.1.0, required by make-fetch-happen@8.0.14
                  npm ERR! missing: http-proxy-agent@4.0.1, required by make-fetch-happen@8.0.14
                  npm ERR! missing: https-proxy-agent@5.0.0, required by make-fetch-happen@8.0.14
                  npm ERR! missing: is-lambda@1.0.1, required by make-fetch-happen@8.0.14
                  npm ERR! missing: lru-cache@6.0.0, required by make-fetch-happen@8.0.14
                  npm ERR! missing: minipass@3.1.3, required by make-fetch-happen@8.0.14
                  npm ERR! missing: minipass-collect@1.0.2, required by make-fetch-happen@8.0.14
                  npm ERR! missing: minipass-fetch@1.3.3, required by make-fetch-happen@8.0.14
                  npm ERR! missing: minipass-flush@1.0.5, required by make-fetch-happen@8.0.14
                  npm ERR! missing: minipass-pipeline@1.2.4, required by make-fetch-happen@8.0.14
                  npm ERR! missing: promise-retry@2.0.1, required by make-fetch-happen@8.0.14
                  npm ERR! missing: socks-proxy-agent@5.0.0, required by make-fetch-happen@8.0.14
                  npm ERR! missing: ssri@8.0.1, required by make-fetch-happen@8.0.14
                  npm ERR! missing: debug@4.3.1, required by agentkeepalive@4.1.4
                  npm ERR! missing: depd@1.1.2, required by agentkeepalive@4.1.4
                  npm ERR! missing: humanize-ms@1.2.1, required by agentkeepalive@4.1.4
                  npm ERR! missing: ms@2.1.2, required by debug@4.3.1
                  npm ERR! missing: ms@2.1.3, required by humanize-ms@1.2.1
                  npm ERR! missing: @tootallnate/once@1.1.2, required by http-proxy-agent@4.0.1
                  npm ERR! missing: agent-base@6.0.2, required by http-proxy-agent@4.0.1
                  npm ERR! missing: debug@4.3.1, required by http-proxy-agent@4.0.1
                  npm ERR! missing: debug@4.3.1, required by agent-base@6.0.2
                  npm ERR! missing: agent-base@6.0.2, required by https-proxy-agent@5.0.0
                  npm ERR! missing: debug@4.3.1, required by https-proxy-agent@5.0.0
                  npm ERR! missing: minipass@3.1.3, required by minipass-fetch@1.3.3
                  npm ERR! missing: minipass-sized@1.0.3, required by minipass-fetch@1.3.3
                  npm ERR! missing: minizlib@2.1.2, required by minipass-fetch@1.3.3
                  npm ERR! missing: safer-buffer@2.1.2, required by iconv-lite@0.6.2
                  npm ERR! missing: minipass@3.1.3, required by minipass-sized@1.0.3
                  npm ERR! missing: err-code@2.0.3, required by promise-retry@2.0.1
                  npm ERR! missing: retry@0.12.0, required by promise-retry@2.0.1
                  npm ERR! missing: agent-base@6.0.2, required by socks-proxy-agent@5.0.0
                  npm ERR! missing: debug@4.3.1, required by socks-proxy-agent@5.0.0
                  npm ERR! missing: socks@2.6.1, required by socks-proxy-agent@5.0.0
                  npm ERR! missing: ip@1.1.5, required by socks@2.6.1
                  npm ERR! missing: smart-buffer@4.1.0, required by socks@2.6.1
                  npm ERR! missing: yallist@4.0.0, required by minipass@3.1.3
                  npm ERR! missing: minipass@3.1.3, required by minipass-pipeline@1.2.4
                  npm ERR! missing: chownr@2.0.0, required by mkdirp-infer-owner@2.0.0
                  npm ERR! missing: infer-owner@1.0.4, required by mkdirp-infer-owner@2.0.0
                  npm ERR! missing: mkdirp@1.0.4, required by mkdirp-infer-owner@2.0.0
                  npm ERR! missing: env-paths@2.2.1, required by node-gyp@7.1.2
                  npm ERR! missing: glob@7.1.6, required by node-gyp@7.1.2
                  npm ERR! missing: graceful-fs@4.2.6, required by node-gyp@7.1.2
                  npm ERR! missing: nopt@5.0.0, required by node-gyp@7.1.2
                  npm ERR! missing: npmlog@4.1.2, required by node-gyp@7.1.2
                  npm ERR! missing: request@2.88.2, required by node-gyp@7.1.2
                  npm ERR! missing: rimraf@3.0.2, required by node-gyp@7.1.2
                  npm ERR! missing: semver@7.3.5, required by node-gyp@7.1.2
                  npm ERR! missing: tar@6.1.0, required by node-gyp@7.1.2
                  npm ERR! missing: which@2.0.2, required by node-gyp@7.1.2
                  npm ERR! missing: aws-sign2@0.7.0, required by request@2.88.2
                  npm ERR! missing: aws4@1.11.0, required by request@2.88.2
                  npm ERR! missing: caseless@0.12.0, required by request@2.88.2
                  npm ERR! missing: combined-stream@1.0.8, required by request@2.88.2
                  npm ERR! missing: extend@3.0.2, required by request@2.88.2
                  npm ERR! missing: forever-agent@0.6.1, required by request@2.88.2
                  npm ERR! missing: form-data@2.3.3, required by request@2.88.2
                  npm ERR! missing: har-validator@5.1.5, required by request@2.88.2
                  npm ERR! missing: http-signature@1.2.0, required by request@2.88.2
                  npm ERR! missing: is-typedarray@1.0.0, required by request@2.88.2
                  npm ERR! missing: isstream@0.1.2, required by request@2.88.2
                  npm ERR! missing: json-stringify-safe@5.0.1, required by request@2.88.2
                  npm ERR! missing: mime-types@2.1.30, required by request@2.88.2
                  npm ERR! missing: oauth-sign@0.9.0, required by request@2.88.2
                  npm ERR! missing: performance-now@2.1.0, required by request@2.88.2
                  npm ERR! missing: qs@6.5.2, required by request@2.88.2
                  npm ERR! missing: tough-cookie@2.5.0, required by request@2.88.2
                  npm ERR! missing: safe-buffer@5.1.2, required by request@2.88.2
                  npm ERR! missing: tunnel-agent@0.6.0, required by request@2.88.2
                  npm ERR! missing: uuid@3.4.0, required by request@2.88.2
                  npm ERR! missing: delayed-stream@1.0.0, required by combined-stream@1.0.8
                  npm ERR! missing: asynckit@0.4.0, required by form-data@2.3.3
                  npm ERR! missing: combined-stream@1.0.8, required by form-data@2.3.3
                  npm ERR! missing: mime-types@2.1.30, required by form-data@2.3.3
                  npm ERR! missing: ajv@6.12.6, required by har-validator@5.1.5
                  npm ERR! missing: har-schema@2.0.0, required by har-validator@5.1.5
                  npm ERR! missing: fast-deep-equal@3.1.3, required by ajv@6.12.6
                  npm ERR! missing: fast-json-stable-stringify@2.1.0, required by ajv@6.12.6
                  npm ERR! missing: json-schema-traverse@0.4.1, required by ajv@6.12.6
                  npm ERR! missing: uri-js@4.4.1, required by ajv@6.12.6
                  npm ERR! missing: punycode@2.1.1, required by uri-js@4.4.1
                  npm ERR! missing: assert-plus@1.0.0, required by http-signature@1.2.0
                  npm ERR! missing: jsprim@1.4.1, required by http-signature@1.2.0
                  npm ERR! missing: sshpk@1.16.1, required by http-signature@1.2.0
                  npm ERR! missing: assert-plus@1.0.0, required by jsprim@1.4.1
                  npm ERR! missing: extsprintf@1.3.0, required by jsprim@1.4.1
                  npm ERR! missing: json-schema@0.2.3, required by jsprim@1.4.1
                  npm ERR! missing: verror@1.10.0, required by jsprim@1.4.1
                  npm ERR! missing: assert-plus@1.0.0, required by verror@1.10.0
                  npm ERR! missing: core-util-is@1.0.2, required by verror@1.10.0
                  npm ERR! missing: extsprintf@1.3.0, required by verror@1.10.0
                  npm ERR! missing: asn1@0.2.4, required by sshpk@1.16.1
                  npm ERR! missing: assert-plus@1.0.0, required by sshpk@1.16.1
                  npm ERR! missing: bcrypt-pbkdf@1.0.2, required by sshpk@1.16.1
                  npm ERR! missing: dashdash@1.14.1, required by sshpk@1.16.1
                  npm ERR! missing: ecc-jsbn@0.1.2, required by sshpk@1.16.1
                  npm ERR! missing: getpass@0.1.7, required by sshpk@1.16.1
                  npm ERR! missing: jsbn@0.1.1, required by sshpk@1.16.1
                  npm ERR! missing: safer-buffer@2.1.2, required by sshpk@1.16.1
                  npm ERR! missing: tweetnacl@0.14.5, required by sshpk@1.16.1
                  npm ERR! missing: safer-buffer@2.1.2, required by asn1@0.2.4
                  npm ERR! missing: tweetnacl@0.14.5, required by bcrypt-pbkdf@1.0.2
                  npm ERR! missing: assert-plus@1.0.0, required by dashdash@1.14.1
                  npm ERR! missing: jsbn@0.1.1, required by ecc-jsbn@0.1.2
                  npm ERR! missing: safer-buffer@2.1.2, required by ecc-jsbn@0.1.2
                  npm ERR! missing: assert-plus@1.0.0, required by getpass@0.1.7
                  npm ERR! missing: mime-db@1.47.0, required by mime-types@2.1.30
                  npm ERR! missing: psl@1.8.0, required by tough-cookie@2.5.0
                  npm ERR! missing: punycode@2.1.1, required by tough-cookie@2.5.0
                  npm ERR! missing: safe-buffer@5.1.2, required by tunnel-agent@0.6.0
                  npm ERR! missing: abbrev@1.1.1, required by nopt@5.0.0
                  npm ERR! missing: chalk@4.1.1, required by npm-audit-report@2.1.4
                  npm ERR! missing: hosted-git-info@4.0.2, required by npm-package-arg@8.1.2
                  npm ERR! missing: semver@7.3.5, required by npm-package-arg@8.1.2
                  npm ERR! missing: validate-npm-package-name@3.0.0, required by npm-package-arg@8.1.2
                  npm ERR! missing: npm-install-checks@4.0.0, required by npm-pick-manifest@6.1.1
                  npm ERR! missing: npm-normalize-package-bin@1.0.1, required by npm-pick-manifest@6.1.1
                  npm ERR! missing: npm-package-arg@8.1.2, required by npm-pick-manifest@6.1.1
                  npm ERR! missing: semver@7.3.5, required by npm-pick-manifest@6.1.1
                  npm ERR! missing: npm-registry-fetch@10.1.1, required by npm-profile@5.0.3
                  npm ERR! missing: lru-cache@6.0.0, required by npm-registry-fetch@10.1.1
                  npm ERR! missing: make-fetch-happen@8.0.14, required by npm-registry-fetch@10.1.1
                  npm ERR! missing: minipass@3.1.3, required by npm-registry-fetch@10.1.1
                  npm ERR! missing: minipass-fetch@1.3.3, required by npm-registry-fetch@10.1.1
                  npm ERR! missing: minipass-json-stream@1.0.1, required by npm-registry-fetch@10.1.1
                  npm ERR! missing: minizlib@2.1.2, required by npm-registry-fetch@10.1.1
                  npm ERR! missing: npm-package-arg@8.1.2, required by npm-registry-fetch@10.1.1
                  npm ERR! missing: jsonparse@1.3.1, required by minipass-json-stream@1.0.1
                  npm ERR! missing: minipass@3.1.3, required by minipass-json-stream@1.0.1
                  npm ERR! missing: minipass@3.1.3, required by minizlib@2.1.2
                  npm ERR! missing: yallist@4.0.0, required by minizlib@2.1.2
                  npm ERR! missing: are-we-there-yet@1.1.5, required by npmlog@4.1.2
                  npm ERR! missing: console-control-strings@1.1.0, required by npmlog@4.1.2
                  npm ERR! missing: gauge@2.7.4, required by npmlog@4.1.2
                  npm ERR! missing: set-blocking@2.0.0, required by npmlog@4.1.2
                  npm ERR! missing: delegates@1.0.0, required by are-we-there-yet@1.1.5
                  npm ERR! missing: readable-stream@2.3.7, required by are-we-there-yet@1.1.5
                  npm ERR! missing: core-util-is@1.0.2, required by readable-stream@2.3.7
                  npm ERR! missing: inherits@2.0.4, required by readable-stream@2.3.7
                  npm ERR! missing: isarray@1.0.0, required by readable-stream@2.3.7
                  npm ERR! missing: process-nextick-args@2.0.1, required by readable-stream@2.3.7
                  npm ERR! missing: safe-buffer@5.1.2, required by readable-stream@2.3.7
                  npm ERR! missing: string_decoder@1.1.1, required by readable-stream@2.3.7
                  npm ERR! missing: util-deprecate@1.0.2, required by readable-stream@2.3.7
                  npm ERR! missing: safe-buffer@5.1.2, required by string_decoder@1.1.1
                  npm ERR! missing: console-control-strings@1.1.0, required by gauge@2.7.4
                  npm ERR! missing: aproba@1.2.0, required by gauge@2.7.4
                  npm ERR! missing: string-width@1.0.2, required by gauge@2.7.4
                  npm ERR! missing: has-unicode@2.0.1, required by gauge@2.7.4
                  npm ERR! missing: object-assign@4.1.1, required by gauge@2.7.4
                  npm ERR! missing: signal-exit@3.0.3, required by gauge@2.7.4
                  npm ERR! missing: strip-ansi@3.0.1, required by gauge@2.7.4
                  npm ERR! missing: wide-align@1.1.3, required by gauge@2.7.4
                  npm ERR! missing: code-point-at@1.1.0, required by string-width@1.0.2
                  npm ERR! missing: is-fullwidth-code-point@1.0.0, required by string-width@1.0.2
                  npm ERR! missing: strip-ansi@3.0.1, required by string-width@1.0.2
                  npm ERR! missing: number-is-nan@1.0.1, required by is-fullwidth-code-point@1.0.0
                  npm ERR! missing: string-width@2.1.1, required by wide-align@1.1.3
                  npm ERR! missing: @npmcli/git@2.0.8, required by pacote@11.3.3
                  npm ERR! missing: @npmcli/installed-package-contents@1.0.7, required by pacote@11.3.3
                  npm ERR! missing: @npmcli/promise-spawn@1.3.2, required by pacote@11.3.3
                  npm ERR! missing: @npmcli/run-script@1.8.5, required by pacote@11.3.3
                  npm ERR! missing: cacache@15.0.6, required by pacote@11.3.3
                  npm ERR! missing: chownr@2.0.0, required by pacote@11.3.3
                  npm ERR! missing: fs-minipass@2.1.0, required by pacote@11.3.3
                  npm ERR! missing: infer-owner@1.0.4, required by pacote@11.3.3
                  npm ERR! missing: minipass@3.1.3, required by pacote@11.3.3
                  npm ERR! missing: mkdirp@1.0.4, required by pacote@11.3.3
                  npm ERR! missing: npm-package-arg@8.1.2, required by pacote@11.3.3
                  npm ERR! missing: npm-packlist@2.1.5, required by pacote@11.3.3
                  npm ERR! missing: npm-pick-manifest@6.1.1, required by pacote@11.3.3
                  npm ERR! missing: npm-registry-fetch@10.1.1, required by pacote@11.3.3
                  npm ERR! missing: promise-retry@2.0.1, required by pacote@11.3.3
                  npm ERR! missing: read-package-json-fast@2.0.2, required by pacote@11.3.3
                  npm ERR! missing: rimraf@3.0.2, required by pacote@11.3.3
                  npm ERR! missing: ssri@8.0.1, required by pacote@11.3.3
                  npm ERR! missing: tar@6.1.0, required by pacote@11.3.3
                  npm ERR! missing: glob@7.1.6, required by npm-packlist@2.1.5
                  npm ERR! missing: ignore-walk@3.0.3, required by npm-packlist@2.1.5
                  npm ERR! missing: npm-bundled@1.1.2, required by npm-packlist@2.1.5
                  npm ERR! missing: npm-normalize-package-bin@1.0.1, required by npm-packlist@2.1.5
                  npm ERR! missing: minimatch@3.0.4, required by ignore-walk@3.0.3
                  npm ERR! missing: json-parse-even-better-errors@2.3.1, required by parse-conflict-json@1.1.1
                  npm ERR! missing: just-diff@3.1.1, required by parse-conflict-json@1.1.1
                  npm ERR! missing: just-diff-apply@3.0.0, required by parse-conflict-json@1.1.1
                  npm ERR! missing: mute-stream@0.0.8, required by read@1.0.7
                  npm ERR! missing: glob@7.1.6, required by read-package-json@3.0.1
                  npm ERR! missing: json-parse-even-better-errors@2.3.1, required by read-package-json@3.0.1
                  npm ERR! missing: normalize-package-data@3.0.2, required by read-package-json@3.0.1
                  npm ERR! missing: npm-normalize-package-bin@1.0.1, required by read-package-json@3.0.1
                  npm ERR! missing: json-parse-even-better-errors@2.3.1, required by read-package-json-fast@2.0.2
                  npm ERR! missing: npm-normalize-package-bin@1.0.1, required by read-package-json-fast@2.0.2
                  npm ERR! missing: debuglog@1.0.1, required by readdir-scoped-modules@1.1.0
                  npm ERR! missing: dezalgo@1.0.3, required by readdir-scoped-modules@1.1.0
                  npm ERR! missing: graceful-fs@4.2.6, required by readdir-scoped-modules@1.1.0
                  npm ERR! missing: once@1.4.0, required by readdir-scoped-modules@1.1.0
                  npm ERR! missing: asap@2.0.6, required by dezalgo@1.0.3
                  npm ERR! missing: wrappy@1.0.2, required by dezalgo@1.0.3
                  npm ERR! missing: glob@7.1.6, required by rimraf@3.0.2
                  npm ERR! missing: lru-cache@6.0.0, required by semver@7.3.5
                  npm ERR! missing: minipass@3.1.3, required by ssri@8.0.1
                  npm ERR! missing: chownr@2.0.0, required by tar@6.1.0
                  npm ERR! missing: fs-minipass@2.1.0, required by tar@6.1.0
                  npm ERR! missing: minipass@3.1.3, required by tar@6.1.0
                  npm ERR! missing: minizlib@2.1.2, required by tar@6.1.0
                  npm ERR! missing: mkdirp@1.0.4, required by tar@6.1.0
                  npm ERR! missing: yallist@4.0.0, required by tar@6.1.0
                  npm ERR! missing: builtins@1.0.3, required by validate-npm-package-name@3.0.0
                  npm ERR! missing: isexe@2.0.0, required by which@2.0.2
                  npm ERR! missing: imurmurhash@0.1.4, required by write-file-atomic@3.0.3
                  npm ERR! missing: is-typedarray@1.0.0, required by write-file-atomic@3.0.3
                  npm ERR! missing: signal-exit@3.0.3, required by write-file-atomic@3.0.3
                  npm ERR! missing: typedarray-to-buffer@3.1.5, required by write-file-atomic@3.0.3
                  npm ERR! missing: is-typedarray@1.0.0, required by typedarray-to-buffer@3.1.5
                  npm ERR! missing: cron-parser@2.15.0, required by node-schedule@1.3.2
                  npm ERR! peer dep missing: typescript@3.9.x || 4.0.x || 4.1.x, required by typedoc@0.20.28
                  npm ERR! extraneous: @babel/cli@7.13.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/cli
                  npm ERR! extraneous: @babel/preset-env@7.13.9 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-env
                  npm ERR! extraneous: @babel/preset-typescript@7.13.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-typescript
                  npm ERR! extraneous: @types/debounce@1.2.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/debounce
                  npm ERR! extraneous: @types/debug@4.1.5 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/debug
                  npm ERR! extraneous: @types/jest@26.0.20 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/jest
                  npm ERR! extraneous: @types/mz@2.7.3 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/mz
                  npm ERR! extraneous: @types/nedb@1.8.11 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/nedb
                  npm ERR! extraneous: @types/serialport@8.0.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/serialport
                  npm ERR! extraneous: @typescript-eslint/eslint-plugin@4.16.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin
                  npm ERR! extraneous: @typescript-eslint/parser@4.16.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/parser
                  npm ERR! extraneous: eslint@7.21.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/eslint
                  npm ERR! extraneous: jest@26.6.3 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/jest
                  npm ERR! extraneous: typedoc@0.20.28 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc
                  npm ERR! extraneous: typedoc-plugin-markdown@3.6.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown
                  npm ERR! extraneous: typedoc-plugin-no-inherit@1.2.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-no-inherit
                  npm ERR! extraneous: typedoc-plugin-sourcefile-url@1.0.6 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-sourcefile-url
                  npm ERR! extraneous: eslint@7.27.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint
                  npm ERR! extraneous: eslint-config-google@0.14.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint-config-google
                  npm ERR! extraneous: eslint-plugin-jest@24.3.6 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint-plugin-jest
                  npm ERR! extraneous: jest@26.6.3 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/jest
                  npm ERR! extraneous: @babel/cli@7.13.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/cli
                  npm ERR! extraneous: @babel/preset-env@7.13.9 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/preset-env
                  npm ERR! extraneous: @babel/preset-typescript@7.13.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/preset-typescript
                  npm ERR! extraneous: @types/debounce@1.2.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/debounce
                  npm ERR! extraneous: @types/debug@4.1.5 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/debug
                  npm ERR! extraneous: @types/jest@26.0.20 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/jest
                  npm ERR! extraneous: @types/mz@2.7.3 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/mz
                  npm ERR! extraneous: @types/nedb@1.8.11 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/nedb
                  npm ERR! extraneous: @types/serialport@8.0.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/serialport
                  npm ERR! extraneous: @typescript-eslint/eslint-plugin@4.16.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin
                  npm ERR! extraneous: @typescript-eslint/parser@4.16.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/parser
                  npm ERR! extraneous: eslint@7.21.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/eslint
                  npm ERR! extraneous: jest@26.6.3 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/jest
                  npm ERR! extraneous: typedoc@0.20.28 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc
                  npm ERR! extraneous: typedoc-plugin-markdown@3.6.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown
                  npm ERR! extraneous: typedoc-plugin-no-inherit@1.2.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-no-inherit
                  npm ERR! extraneous: typedoc-plugin-sourcefile-url@1.0.6 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-sourcefile-url
                    Thomas Braun Most Active @sanda last edited by Thomas Braun
                    npm uninstall iobroker.sourceanalytix
                    Siehste, hier kommt noch der Kram von npm@7 mit:
                    Ich wäre ja fast geneigt, hier mal entgegen der sonstigen Empfehlung wirklich wieder npm@7 wieder zu installieren, damit die ganzen Depencies wieder bedient werden.
                      oder ganz einfach
                      @homoran sagte in Fehler in Adapterinstallation:
                        Hast du eigentlich in den Einstellungen des javascript-Adapters noch zusätzliche Module reingeflickt?
                        Wenn ja, welche?
                          @thomas-braun Jetzt wird es etwas sauberer nach sourceanalytics Deinstallation:
                          pi@raspberrypi4-iob:/opt/iobroker $ npm ls
                          iobroker.core@1.0.0 /opt/iobroker
                          ├── iobroker@2.0.3 extraneous
                          ├── iobroker.admin@5.1.25 extraneous
                          ├── iobroker.backitup@2.2.2 extraneous
                          ├── iobroker.discovery@2.7.3 extraneous
                          ├── iobroker.dwd@2.7.7 extraneous
                          ├── iobroker.fb-checkpresence@1.1.10 extraneous
                          ├── iobroker.followthesun@0.3.5 extraneous
                          ├── iobroker.growatt@1.1.1 extraneous
                          ├── iobroker.gruenbeck@0.0.30 extraneous
                          ├── iobroker.hm-rega@3.0.32 extraneous
                          ├── iobroker.hm-rpc@1.14.45 extraneous
                          ├── iobroker.homekit-controller@0.3.3 extraneous
                          ├── iobroker.ical@1.11.4 extraneous
                          ├── iobroker.icons-mfd-png@1.0.2 extraneous
                          ├── iobroker.icons-ultimate-png@1.0.1 extraneous
                          ├── iobroker.influxdb@1.9.5 extraneous
                          ├── iobroker.info@1.9.8 extraneous
                          ├── iobroker.javascript@5.2.13 extraneous
                          ├── iobroker.js-controller@3.3.20 extraneous
                          ├── iobroker.mihome-vacuum@3.3.1 extraneous
                          ├── iobroker.mpd@1.0.6 extraneous
                          ├── iobroker.odl@1.1.4 extraneous
                          ├── iobroker.onvif@0.4.4 extraneous
                          ├── iobroker.plenticore@2.2.0 extraneous
                          ├── iobroker.samsung@0.2.9 extraneous
                          ├── iobroker.schoolfree@1.0.0 extraneous
                          ├── iobroker.shelly@4.0.7 extraneous
                          ├── iobroker.synology@1.1.3 extraneous
                          ├── iobroker.tankerkoenig@2.1.1 extraneous
                          ├── iobroker.telegram@1.10.0 extraneous
                          ├── iobroker.trashschedule@1.2.0 extraneous
                          ├── iobroker.tuya@3.6.9 extraneous
                          ├── iobroker.vis@1.4.5 extraneous
                          ├── iobroker.vis-colorpicker@1.2.0 extraneous
                          ├── iobroker.vis-hqwidgets@1.1.7 extraneous
                          ├── iobroker.vis-inventwo@3.2.0 extraneous
                          ├── iobroker.vis-jqui-mfd@1.0.12 extraneous
                          ├── iobroker.vis-metro@1.1.2 extraneous
                          ├── iobroker.vis-timeandweather@1.1.7 extraneous
                          ├── iobroker.vis-weather@2.5.5 extraneous
                          ├── iobroker.web@3.4.9 extraneous
                          └── iobroker.zigbee@1.5.6 extraneous
                          npm ERR! extraneous: iobroker@2.0.3 /opt/iobroker/node_modules/iobroker
                          npm ERR! extraneous: iobroker.admin@5.1.25 /opt/iobroker/node_modules/iobroker.admin
                          npm ERR! extraneous: iobroker.backitup@2.2.2 /opt/iobroker/node_modules/iobroker.backitup
                          npm ERR! extraneous: iobroker.discovery@2.7.3 /opt/iobroker/node_modules/iobroker.discovery
                          npm ERR! extraneous: iobroker.dwd@2.7.7 /opt/iobroker/node_modules/iobroker.dwd
                          npm ERR! extraneous: iobroker.fb-checkpresence@1.1.10 /opt/iobroker/node_modules/iobroker.fb-checkpresence
                          npm ERR! extraneous: iobroker.followthesun@0.3.5 /opt/iobroker/node_modules/iobroker.followthesun
                          npm ERR! extraneous: iobroker.growatt@1.1.1 /opt/iobroker/node_modules/iobroker.growatt
                          npm ERR! extraneous: iobroker.gruenbeck@0.0.30 /opt/iobroker/node_modules/iobroker.gruenbeck
                          npm ERR! extraneous: iobroker.hm-rega@3.0.32 /opt/iobroker/node_modules/iobroker.hm-rega
                          npm ERR! extraneous: iobroker.hm-rpc@1.14.45 /opt/iobroker/node_modules/iobroker.hm-rpc
                          npm ERR! extraneous: iobroker.homekit-controller@0.3.3 /opt/iobroker/node_modules/iobroker.homekit-controller
                          npm ERR! extraneous: iobroker.ical@1.11.4 /opt/iobroker/node_modules/iobroker.ical
                          npm ERR! extraneous: iobroker.icons-mfd-png@1.0.2 /opt/iobroker/node_modules/iobroker.icons-mfd-png
                          npm ERR! extraneous: iobroker.icons-ultimate-png@1.0.1 /opt/iobroker/node_modules/iobroker.icons-ultimate-png
                          npm ERR! extraneous: iobroker.influxdb@1.9.5 /opt/iobroker/node_modules/iobroker.influxdb
                          npm ERR! extraneous: iobroker.info@1.9.8 /opt/iobroker/node_modules/iobroker.info
                          npm ERR! extraneous: iobroker.javascript@5.2.13 /opt/iobroker/node_modules/iobroker.javascript
                          npm ERR! extraneous: iobroker.js-controller@3.3.20 /opt/iobroker/node_modules/iobroker.js-controller
                          npm ERR! extraneous: iobroker.mihome-vacuum@3.3.1 /opt/iobroker/node_modules/iobroker.mihome-vacuum
                          npm ERR! extraneous: iobroker.mpd@1.0.6 /opt/iobroker/node_modules/iobroker.mpd
                          npm ERR! extraneous: iobroker.odl@1.1.4 /opt/iobroker/node_modules/iobroker.odl
                          npm ERR! extraneous: iobroker.onvif@0.4.4 /opt/iobroker/node_modules/iobroker.onvif
                          npm ERR! extraneous: iobroker.plenticore@2.2.0 /opt/iobroker/node_modules/iobroker.plenticore
                          npm ERR! extraneous: iobroker.samsung@0.2.9 /opt/iobroker/node_modules/iobroker.samsung
                          npm ERR! extraneous: iobroker.schoolfree@1.0.0 /opt/iobroker/node_modules/iobroker.schoolfree
                          npm ERR! extraneous: iobroker.shelly@4.0.7 /opt/iobroker/node_modules/iobroker.shelly
                          npm ERR! extraneous: iobroker.synology@1.1.3 /opt/iobroker/node_modules/iobroker.synology
                          npm ERR! extraneous: iobroker.tankerkoenig@2.1.1 /opt/iobroker/node_modules/iobroker.tankerkoenig
                          npm ERR! extraneous: iobroker.telegram@1.10.0 /opt/iobroker/node_modules/iobroker.telegram
                          npm ERR! extraneous: iobroker.trashschedule@1.2.0 /opt/iobroker/node_modules/iobroker.trashschedule
                          npm ERR! extraneous: iobroker.tuya@3.6.9 /opt/iobroker/node_modules/iobroker.tuya
                          npm ERR! extraneous: iobroker.vis@1.4.5 /opt/iobroker/node_modules/iobroker.vis
                          npm ERR! extraneous: iobroker.vis-colorpicker@1.2.0 /opt/iobroker/node_modules/iobroker.vis-colorpicker
                          npm ERR! extraneous: iobroker.vis-hqwidgets@1.1.7 /opt/iobroker/node_modules/iobroker.vis-hqwidgets
                          npm ERR! extraneous: iobroker.vis-inventwo@3.2.0 /opt/iobroker/node_modules/iobroker.vis-inventwo
                          npm ERR! extraneous: iobroker.vis-jqui-mfd@1.0.12 /opt/iobroker/node_modules/iobroker.vis-jqui-mfd
                          npm ERR! extraneous: iobroker.vis-metro@1.1.2 /opt/iobroker/node_modules/iobroker.vis-metro
                          npm ERR! extraneous: iobroker.vis-timeandweather@1.1.7 /opt/iobroker/node_modules/iobroker.vis-timeandweather
                          npm ERR! extraneous: iobroker.vis-weather@2.5.5 /opt/iobroker/node_modules/iobroker.vis-weather
                          npm ERR! extraneous: iobroker.web@3.4.9 /opt/iobroker/node_modules/iobroker.web
                          npm ERR! extraneous: iobroker.zigbee@1.5.6 /opt/iobroker/node_modules/iobroker.zigbee
                            sanda @Homoran last edited by
                            @homoran das hab ich auch erstmal umbenannt
                              @thomas-braun Nein ich nutze keine zusätzlichen Module im javascript
                                @sanda
                                Okay, das sieht schon wesentlich anders aus.
                                Die Urinstallation ist aber auch schon etwas her, oder?
                                schaut ungewohnt aus. Die ganzen extraneous Einträge sind auch ungewöhnlich. Kann es sein, das da zwei Installationen ineinander verschachtelt wurden?
                                Mal z. B.
                                npm list iobroker.icons-mfd-png
                                anschauen.
                                  Das spuckt er mir aus und ja die Installation von IOB ist schon etwas her:
                                  pi@raspberrypi4-iob:/opt/iobroker $ npm list iobroker.icons-mfd-png
                                  └── iobroker.icons-mfd-png@1.0.2  extraneous
                                    @sanda
                                    Was mich irritiert ist, dass bei dir extraneous Module angezeigt werden, offenbar aber ohne das erste Modul.
                                    Bei mir schaut das z. B. so aus:
                                    echad@chet:/opt/iobroker $ npm ls jsonata
                                    iobroker.inst@3.0.0 /opt/iobroker
                                    ├─┬ iobroker.javascript@5.2.16
                                    │ └── jsonata@1.8.5
                                    └── jsonata@1.8.5 extraneous
                                    Ich hab aber offengesagt keine Ahnung was ich dir da empfehlen soll. Mal über eine Neuinstallation nachgedacht?
                                      @thomas-braun Alles neu zu installieren, da brauch ich ja wieder eine Woche, bis alles wieder läuft 😨
                                      Ich habe jetzt js-controller Komplett neu installiert und jetzt nochmals das Kommando ausgeführt, was zuvor schon zu Error-Meldungen geführt hatte, aber jetzt nicht mehr.
                                      pi@raspberrypi4-iob:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                                      > iobroker.js-controller@3.3.21 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                                      > node lib/preinstallCheck.js
                                      NPM version: 6.14.15
                                      > iobroker.js-controller@3.3.21 install /opt/iobroker/node_modules/iobroker.js-controller
                                      > node iobroker.js setup first
                                      object _design/custom updated
                                      object _design/system updated
                                      The following notifications happened during sync:
                                      - Ignoring Directory "hm-rega" because officially not created as meta object. Please remove directory!
                                      - Ignoring Directory "synology.0" because officially not created as meta object. Please remove directory!
                                      - Ignoring Directory "synology.1" because officially not created as meta object. Please remove directory!
                                      + iobroker.js-controller@3.3.21
                                      removed 75 packages and updated 1 package in 65.018s
                                      167 packages are looking for funding
                                        run `npm fund` for details
                                        sanda @sanda last edited by
                                        Anscheinend hab ich es nun hinbekommen. Die Lösung war, das ich anschließend den admin neu installiert habe 😊
                                        Danke euch vielmals 👍
                                          @sanda
                                          Wie schaut denn jetzt ein
                                          cd /opt/iobroker
                                          npm list
                                          aus?
                                            sanda @Thomas Braun last edited by sanda
                                            @thomas-braun da stehen immer noch einige Error-Punkte, aber alles läuft ohne Probleme und neue Adapter lassen sich nun auch installieren.
                                            │ │ │   ├─┬ get-symbol-description@1.0.0
                                            │ │ │   │ ├── call-bind@1.0.2 deduped
                                            │ │ │   │ └── get-intrinsic@1.1.1 deduped
                                            │ │ │   ├── has@1.0.3 deduped
                                            │ │ │   ├── has-symbols@1.0.2
                                            │ │ │   ├─┬ internal-slot@1.0.3
                                            │ │ │   │ ├── get-intrinsic@1.1.1 deduped
                                            │ │ │   │ ├── has@1.0.3 deduped
                                            │ │ │   │ └── side-channel@1.0.4 deduped
                                            │ │ │   ├── is-callable@1.2.4
                                            │ │ │   ├── is-negative-zero@2.0.1
                                            │ │ │   ├─┬ is-regex@1.1.4
                                            │ │ │   │ └─┬ has-tostringtag@1.0.0
                                            │ │ │   │   └── has-symbols@1.0.2 deduped
                                            │ │ │   ├── is-shared-array-buffer@1.0.1
                                            │ │ │   ├─┬ is-string@1.0.7
                                            │ │ │   │ └── has-tostringtag@1.0.0 deduped
                                            │ │ │   ├─┬ is-weakref@1.0.1
                                            │ │ │   │ └── call-bind@1.0.2 deduped
                                            │ │ │   ├── object-inspect@1.11.0
                                            │ │ │   ├── object-keys@1.1.1 deduped
                                            │ │ │   ├─┬ object.assign@4.1.2
                                            │ │ │   │ ├── define-properties@1.1.3 deduped
                                            │ │ │   │ ├── has-symbols@1.0.2 deduped
                                            │ │ │   │ └── object-keys@1.1.1 deduped
                                            │ │ │   ├─┬ string.prototype.trimend@1.0.4
                                            │ │ │   │ └── define-properties@1.1.3 deduped
                                            │ │ │   ├─┬ string.prototype.trimstart@1.0.4
                                            │ │ │   └─┬ unbox-primitive@1.0.1
                                            │ │ │     ├── function-bind@1.1.1 deduped
                                            │ │ │     ├── has-bigints@1.0.1
                                            │ │ │     └─┬ which-boxed-primitive@1.0.2
                                            │ │ │       ├─┬ is-bigint@1.0.4
                                            │ │ │       │ └── has-bigints@1.0.1 deduped
                                            │ │ │       ├─┬ is-boolean-object@1.1.2
                                            │ │ │       ├─┬ is-number-object@1.0.6
                                            │ │ │       ├── is-string@1.0.7 deduped
                                            │ │ │       └── is-symbol@1.0.4 deduped
                                            │ │ ├─┬ bl@1.2.3
                                            │ │ │ ├── readable-stream@2.3.7 deduped
                                            │ │ │ └── safe-buffer@5.2.1 deduped
                                            │ │ ├── bluebird@3.7.2 deduped
                                            │ │ ├── debug@3.2.7 deduped
                                            │ │ ├── depd@1.1.2 deduped
                                            │ │ ├── eventemitter3@3.1.2
                                            │ │ ├── file-type@3.9.0
                                            │ │ ├── mime@1.6.0
                                            │ │ ├─┬ pump@2.0.1
                                            │ │ ├── request@2.88.2 deduped
                                            │ │ └─┬ request-promise@4.2.6
                                            │ │   ├─┬ request-promise-core@1.1.4
                                            │ │   │ └── lodash@4.17.21 deduped
                                            │ │   ├── stealthy-require@1.1.1
                                            │ │   └── tough-cookie@2.5.0 deduped
                                            │ └─┬ socksv5@0.0.6
                                            │   └─┬ ipv6@3.1.1
                                            │     ├─┬ cli@0.4.5
                                            │     │ └── glob@7.2.0 deduped
                                            │     ├─┬ cliff@0.1.10
                                            │     │ ├── colors@1.0.3
                                            │     │ ├── eyes@0.1.8 deduped
                                            │     │ └─┬ winston@0.8.3
                                            │     │   ├── async@0.2.10
                                            │     │   ├── colors@0.6.2
                                            │     │   ├── cycle@1.0.3 deduped
                                            │     │   ├── isstream@0.1.2 deduped
                                            │     │   ├── pkginfo@0.3.1
                                            │     │   └── stack-trace@0.0.10 deduped
                                            │     └── sprintf@0.1.3
                                            ├─┬ iobroker.trashschedule@1.2.0
                                            │ └── @iobroker/adapter-core@2.5.1 deduped
                                            ├─┬ iobroker.vis@1.4.5
                                            │ └── jsonwebtoken@8.5.1 deduped
                                            ├─┬ iobroker.vis-colorpicker@1.2.0
                                            ├─┬ iobroker.vis-inventwo@3.2.0
                                            │ └─┬ np@7.6.0
                                            │   ├─┬ @samverschueren/stream-to-observable@0.3.1
                                            │   │ └── any-observable@0.3.0
                                            │   ├── any-observable@0.5.1
                                            │   ├── async-exit-hook@2.0.1
                                            │   ├─┬ chalk@4.1.2
                                            │   │ ├─┬ ansi-styles@4.3.0
                                            │   │ │ └─┬ color-convert@2.0.1
                                            │   │ │   └── color-name@1.1.4
                                            │   │ └─┬ supports-color@7.2.0
                                            │   │   └── has-flag@4.0.0
                                            │   ├─┬ cosmiconfig@7.0.1
                                            │   │ ├── @types/parse-json@4.0.0
                                            │   │ ├─┬ import-fresh@3.3.0
                                            │   │ │ ├─┬ parent-module@1.0.1
                                            │   │ │ │ └── callsites@3.1.0 deduped
                                            │   │ │ └── resolve-from@4.0.0
                                            │   │ ├─┬ parse-json@5.2.0
                                            │   │ │ ├─┬ @babel/code-frame@7.16.0
                                            │   │ │ │ └─┬ @babel/highlight@7.16.0
                                            │   │ │ │   ├── @babel/helper-validator-identifier@7.15.7
                                            │   │ │ │   ├─┬ chalk@2.4.2
                                            │   │ │ │   │ ├─┬ ansi-styles@3.2.1
                                            │   │ │ │   │ │ └── color-convert@1.9.3 deduped
                                            │   │ │ │   │ ├── escape-string-regexp@1.0.5
                                            │   │ │ │   │ └─┬ supports-color@5.5.0
                                            │   │ │ │   │   └── has-flag@3.0.0
                                            │   │ │ │   └── js-tokens@4.0.0
                                            │   │ │ ├─┬ error-ex@1.3.2
                                            │   │ │ │ └── is-arrayish@0.2.1
                                            │   │ │ ├── json-parse-even-better-errors@2.3.1
                                            │   │ │ └── lines-and-columns@1.2.4
                                            │   │ ├── path-type@4.0.0
                                            │   │ └── yaml@1.10.2
                                            │   ├─┬ del@6.0.0
                                            │   │ ├─┬ globby@11.0.4
                                            │   │ │ ├── array-union@2.1.0
                                            │   │ │ ├─┬ dir-glob@3.0.1
                                            │   │ │ │ └── path-type@4.0.0 deduped
                                            │   │ │ ├─┬ fast-glob@3.2.7
                                            │   │ │ │ ├── @nodelib/fs.stat@2.0.5
                                            │   │ │ │ ├─┬ @nodelib/fs.walk@1.2.8
                                            │   │ │ │ │ ├─┬ @nodelib/fs.scandir@2.1.5
                                            │   │ │ │ │ │ ├── @nodelib/fs.stat@2.0.5 deduped
                                            │   │ │ │ │ │ └─┬ run-parallel@1.2.0
                                            │   │ │ │ │ │   └── queue-microtask@1.2.3
                                            │   │ │ │ │ └─┬ fastq@1.13.0
                                            │   │ │ │ │   └── reusify@1.0.4
                                            │   │ │ │ ├── glob-parent@5.1.2 deduped
                                            │   │ │ │ ├── merge2@1.4.1 deduped
                                            │   │ │ │ └─┬ micromatch@4.0.4
                                            │   │ │ │   ├── braces@3.0.2 deduped
                                            │   │ │ │   └── picomatch@2.3.0 deduped
                                            │   │ │ ├── ignore@5.1.9
                                            │   │ │ └── slash@3.0.0 deduped
                                            │   │ ├── graceful-fs@4.2.8 deduped
                                            │   │ ├── is-glob@4.0.3 deduped
                                            │   │ ├── is-path-cwd@2.2.0
                                            │   │ ├── is-path-inside@3.0.3
                                            │   │ ├─┬ p-map@4.0.0
                                            │   │ │ └─┬ aggregate-error@3.1.0
                                            │   │ │   ├── clean-stack@2.2.0
                                            │   │ │   └── indent-string@4.0.0 deduped
                                            │   │ ├── rimraf@3.0.2 deduped
                                            │   │ └── slash@3.0.0
                                            │   ├── escape-goat@3.0.0
                                            │   ├── escape-string-regexp@4.0.0
                                            │   ├─┬ execa@5.1.1
                                            │   │ ├─┬ cross-spawn@7.0.3
                                            │   │ │ ├── path-key@3.1.1
                                            │   │ │ ├─┬ shebang-command@2.0.0
                                            │   │ │ │ └── shebang-regex@3.0.0
                                            │   │ │ └─┬ which@2.0.2
                                            │   │ │   └── isexe@2.0.0
                                            │   │ ├── get-stream@6.0.1
                                            │   │ ├── human-signals@2.1.0
                                            │   │ ├── is-stream@2.0.1 deduped
                                            │   │ ├── merge-stream@2.0.0
                                            │   │ ├─┬ npm-run-path@4.0.1
                                            │   │ │ └── path-key@3.1.1 deduped
                                            │   │ ├── onetime@5.1.2 deduped
                                            │   │ ├── signal-exit@3.0.6
                                            │   │ └── strip-final-newline@2.0.0
                                            │   ├── github-url-from-git@1.5.0
                                            │   ├── has-yarn@2.1.0
                                            │   ├─┬ hosted-git-info@3.0.8
                                            │   │ └── lru-cache@6.0.0 deduped
                                            │   ├─┬ ignore-walk@3.0.4
                                            │   │ └── minimatch@3.0.4 deduped
                                            │   ├─┬ import-local@3.0.3
                                            │   │ ├─┬ pkg-dir@4.2.0
                                            │   │ │ └── find-up@4.1.0 deduped
                                            │   │ └─┬ resolve-cwd@3.0.0
                                            │   │   └── resolve-from@5.0.0
                                            │   ├─┬ inquirer@7.3.3
                                            │   │ ├─┬ ansi-escapes@4.3.2
                                            │   │ │ └── type-fest@0.21.3
                                            │   │ ├── chalk@4.1.2 deduped
                                            │   │ ├─┬ cli-cursor@3.1.0
                                            │   │ │ └─┬ restore-cursor@3.1.0
                                            │   │ │   ├── onetime@5.1.2 deduped
                                            │   │ │   └── signal-exit@3.0.6 deduped
                                            │   │ ├── cli-width@3.0.0
                                            │   │ ├─┬ external-editor@3.1.0
                                            │   │ │ ├── chardet@0.7.0
                                            │   │ │ ├─┬ iconv-lite@0.4.24
                                            │   │ │ │ └── safer-buffer@2.1.2 deduped
                                            │   │ │ └─┬ tmp@0.0.33
                                            │   │ │   └── os-tmpdir@1.0.2
                                            │   │ ├─┬ figures@3.2.0
                                            │   │ │ └── escape-string-regexp@1.0.5
                                            │   │ ├── lodash@4.17.21 deduped
                                            │   │ ├── mute-stream@0.0.8 deduped
                                            │   │ ├── run-async@2.4.1
                                            │   │ ├── rxjs@6.6.7 deduped
                                            │   │ ├── string-width@4.2.3 deduped
                                            │   │ ├── strip-ansi@6.0.1 deduped
                                            │   │ └── through@2.3.8 deduped
                                            │   ├─┬ is-installed-globally@0.3.2
                                            │   │ ├─┬ global-dirs@2.1.0
                                            │   │ │ └── ini@1.3.7
                                            │   │ └── is-path-inside@3.0.3 deduped
                                            │   ├── is-interactive@1.0.0
                                            │   ├─┬ is-scoped@2.1.0
                                            │   │ └── scoped-regex@2.1.0
                                            │   ├── issue-regex@3.1.0
                                            │   ├─┬ listr@0.14.3
                                            │   │ ├── @samverschueren/stream-to-observable@0.3.1 deduped
                                            │   │ ├─┬ is-observable@1.1.0
                                            │   │ │ └── symbol-observable@1.2.0
                                            │   │ ├── is-promise@2.2.2
                                            │   │ ├── is-stream@1.1.0
                                            │   │ ├── listr-silent-renderer@1.1.1
                                            │   │ ├─┬ listr-update-renderer@0.5.0
                                            │   │ │ ├─┬ chalk@1.1.3
                                            │   │ │ │ ├── ansi-styles@2.2.1
                                            │   │ │ │ ├─┬ has-ansi@2.0.0
                                            │   │ │ │ │ └── ansi-regex@2.1.1
                                            │   │ │ │ ├── strip-ansi@3.0.1 deduped
                                            │   │ │ │ └── supports-color@2.0.0
                                            │   │ │ ├─┬ cli-truncate@0.2.1
                                            │   │ │ │ ├── slice-ansi@0.0.4
                                            │   │ │ │ └─┬ string-width@1.0.2
                                            │   │ │ │   ├── code-point-at@1.1.0 deduped
                                            │   │ │ │   ├─┬ is-fullwidth-code-point@1.0.0
                                            │   │ │ │   │ └── number-is-nan@1.0.1 deduped
                                            │   │ │ │   └─┬ strip-ansi@3.0.1
                                            │   │ │ ├── elegant-spinner@1.0.1
                                            │   │ │ ├─┬ figures@1.7.0
                                            │   │ │ │ ├── escape-string-regexp@1.0.5 deduped
                                            │   │ │ │ └── object-assign@4.1.1
                                            │   │ │ ├── indent-string@3.2.0
                                            │   │ │ ├─┬ log-symbols@1.0.2
                                            │   │ │ │ └── chalk@1.1.3 deduped
                                            │   │ │ ├─┬ log-update@2.3.0
                                            │   │ │ │ ├── ansi-escapes@3.2.0
                                            │   │ │ │ ├─┬ cli-cursor@2.1.0
                                            │   │ │ │ │ └─┬ restore-cursor@2.0.0
                                            │   │ │ │ │   ├─┬ onetime@2.0.1
                                            │   │ │ │ │   │ └── mimic-fn@1.2.0
                                            │   │ │ │ │   └── signal-exit@3.0.6 deduped
                                            │   │ │ │ └─┬ wrap-ansi@3.0.1
                                            │   │ │ │   ├─┬ string-width@2.1.1
                                            │   │ │ │   │ ├── is-fullwidth-code-point@2.0.0
                                            │   │ │ │   │ └── strip-ansi@4.0.0 deduped
                                            │   │ │ │   └─┬ strip-ansi@4.0.0
                                            │   │ │ │     └── ansi-regex@3.0.0
                                            │   │ ├─┬ listr-verbose-renderer@0.5.0
                                            │   │ │ ├── date-fns@1.30.1
                                            │   │ │ └─┬ figures@2.0.0
                                            │   │ │   └── escape-string-regexp@1.0.5 deduped
                                            │   │ ├── p-map@2.1.0
                                            │   │ └── rxjs@6.6.7 deduped
                                            │   ├─┬ listr-input@0.2.1
                                            │   │ ├── inquirer@7.3.3 deduped
                                            │   │ ├─┬ inquirer-autosubmit-prompt@0.2.0
                                            │   │ │ ├─┬ inquirer@6.5.2
                                            │   │ │ │ ├── chalk@2.4.2 deduped
                                            │   │ │ │ ├── cli-width@2.2.1
                                            │   │ │ │ ├── external-editor@3.1.0 deduped
                                            │   │ │ │ ├─┬ figures@2.0.0
                                            │   │ │ │ │ └── escape-string-regexp@1.0.5 deduped
                                            │   │ │ │ ├── lodash@4.17.21 deduped
                                            │   │ │ │ ├── mute-stream@0.0.7
                                            │   │ │ │ ├── run-async@2.4.1 deduped
                                            │   │ │ │ ├── rxjs@6.6.7 deduped
                                            │   │ │ │ │ └─┬ strip-ansi@4.0.0
                                            │   │ │ │ │   └── ansi-regex@3.0.0
                                            │   │ │ │ ├─┬ strip-ansi@5.2.0
                                            │   │ │ │ │ └── ansi-regex@4.1.0
                                            │   │ │ │ └── through@2.3.8 deduped
                                            │   │ │ └── rxjs@6.6.7 deduped
                                            │   ├─┬ log-symbols@4.1.0
                                            │   │ └── is-unicode-supported@0.1.0
                                            │   ├─┬ meow@8.1.2
                                            │   │ ├── @types/minimist@1.2.2
                                            │   │ ├─┬ camelcase-keys@6.2.2
                                            │   │ │ ├── camelcase@5.3.1
                                            │   │ │ ├── map-obj@4.3.0
                                            │   │ │ └── quick-lru@4.0.1
                                            │   │ ├─┬ decamelize-keys@1.1.0
                                            │   │ │ ├── decamelize@1.2.0 deduped
                                            │   │ │ └── map-obj@1.0.1
                                            │   │ ├── hard-rejection@2.1.0
                                            │   │ ├─┬ minimist-options@4.1.0
                                            │   │ │ ├── arrify@1.0.1
                                            │   │ │ ├── is-plain-obj@1.1.0
                                            │   │ │ └── kind-of@6.0.3
                                            │   │ ├─┬ normalize-package-data@3.0.3
                                            │   │ │ ├─┬ hosted-git-info@4.0.2
                                            │   │ │ │ └── lru-cache@6.0.0 deduped
                                            │   │ │ ├─┬ is-core-module@2.8.0
                                            │   │ │ │ └── has@1.0.3 deduped
                                            │   │ │ ├── semver@7.3.5 deduped
                                            │   │ │ └─┬ validate-npm-package-license@3.0.4
                                            │   │ │   ├─┬ spdx-correct@3.1.1
                                            │   │ │   │ ├── spdx-expression-parse@3.0.1 deduped
                                            │   │ │   │ └── spdx-license-ids@3.0.11
                                            │   │ │   └─┬ spdx-expression-parse@3.0.1
                                            │   │ │     ├── spdx-exceptions@2.3.0
                                            │   │ │     └── spdx-license-ids@3.0.11 deduped
                                            │   │ ├── read-pkg-up@7.0.1 deduped
                                            │   │ ├─┬ redent@3.0.0
                                            │   │ │ ├── indent-string@4.0.0
                                            │   │ │ └─┬ strip-indent@3.0.0
                                            │   │ │   └── min-indent@1.0.1
                                            │   │ ├── trim-newlines@3.0.1
                                            │   │ ├── type-fest@0.18.1
                                            │   │ └── yargs-parser@20.2.9 deduped
                                            │   ├── minimatch@3.0.4 deduped
                                            │   ├─┬ new-github-release-url@1.0.0
                                            │   │ └── type-fest@0.4.1
                                            │   ├─┬ npm-name@6.0.1
                                            │   │ ├─┬ got@10.7.0
                                            │   │ │ ├── @sindresorhus/is@2.1.1
                                            │   │ │ ├─┬ @szmarczak/http-timer@4.0.6
                                            │   │ │ │ └── defer-to-connect@2.0.1
                                            │   │ │ ├─┬ @types/cacheable-request@6.0.2
                                            │   │ │ │ ├── @types/http-cache-semantics@4.0.1
                                            │   │ │ │ ├─┬ @types/keyv@3.1.3
                                            │   │ │ │ │ └── @types/node@16.11.11 deduped
                                            │   │ │ │ ├── @types/node@16.11.11 deduped
                                            │   │ │ │ └─┬ @types/responselike@1.0.0
                                            │   │ │ ├─┬ cacheable-lookup@2.0.1
                                            │   │ │ │ ├── @types/keyv@3.1.3 deduped
                                            │   │ │ │ └─┬ keyv@4.0.4
                                            │   │ │ │   └── json-buffer@3.0.1
                                            │   │ │ ├─┬ cacheable-request@7.0.2
                                            │   │ │ │ ├─┬ clone-response@1.0.2
                                            │   │ │ │ │ └── mimic-response@1.0.1
                                            │   │ │ │ ├─┬ get-stream@5.2.0
                                            │   │ │ │ │ └─┬ pump@3.0.0
                                            │   │ │ │ │   ├── end-of-stream@1.4.4 deduped
                                            │   │ │ │ │   └── once@1.4.0 deduped
                                            │   │ │ │ ├── http-cache-semantics@4.1.0
                                            │   │ │ │ ├── keyv@4.0.4 deduped
                                            │   │ │ │ ├── lowercase-keys@2.0.0 deduped
                                            │   │ │ │ ├── normalize-url@6.1.0
                                            │   │ │ │ └── responselike@2.0.0 deduped
                                            │   │ │ ├─┬ decompress-response@5.0.0
                                            │   │ │ │ └── mimic-response@2.1.0 deduped
                                            │   │ │ ├── duplexer3@0.1.4
                                            │   │ │ ├── mimic-response@2.1.0 deduped
                                            │   │ │ ├── p-cancelable@2.1.1
                                            │   │ │ ├─┬ p-event@4.2.0
                                            │   │ │ │ └─┬ p-timeout@3.2.0
                                            │   │ │ │   └── p-finally@1.0.0
                                            │   │ │ ├─┬ responselike@2.0.0
                                            │   │ │ │ └── lowercase-keys@2.0.0 deduped
                                            │   │ │ ├── to-readable-stream@2.1.0
                                            │   │ │ └── type-fest@0.10.0
                                            │   │ ├── is-scoped@2.1.0 deduped
                                            │   │ ├── is-url-superb@4.0.0
                                            │   │ ├── lodash.zip@4.2.0
                                            │   │ ├── org-regex@1.0.0
                                            │   │ ├─┬ p-map@3.0.0
                                            │   │ │ └── aggregate-error@3.1.0 deduped
                                            │   │ ├─┬ registry-auth-token@4.2.1
                                            │   │ │ └── rc@1.2.8 deduped
                                            │   │ ├─┬ registry-url@5.1.0
                                            │   │ └─┬ validate-npm-package-name@3.0.0
                                            │   │   └── builtins@1.0.3
                                            │   ├─┬ onetime@5.1.2
                                            │   │ └── mimic-fn@2.1.0
                                            │   ├─┬ open@7.4.2
                                            │   │ ├── is-docker@2.2.1
                                            │   │ └─┬ is-wsl@2.2.0
                                            │   │   └── is-docker@2.2.1 deduped
                                            │   ├─┬ ow@0.21.0
                                            │   │ ├── @sindresorhus/is@4.2.0
                                            │   │ ├── callsites@3.1.0
                                            │   │ ├─┬ dot-prop@6.0.1
                                            │   │ │ └── is-obj@2.0.0
                                            │   │ ├── lodash.isequal@4.5.0
                                            │   │ ├── type-fest@0.20.2
                                            │   │ └── vali-date@1.0.0
                                            │   ├─┬ p-memoize@4.0.3
                                            │   │ ├─┬ map-age-cleaner@0.1.3
                                            │   │ │ └── p-defer@1.0.0
                                            │   │ ├── mimic-fn@3.1.0
                                            │   │ └─┬ p-settle@4.1.1
                                            │   │   ├─┬ p-limit@2.3.0
                                            │   │   │ └── p-try@2.2.0
                                            │   │   └── p-reflect@2.1.0
                                            │   ├── p-timeout@4.1.0
                                            │   ├─┬ pkg-dir@5.0.0
                                            │   │ └─┬ find-up@5.0.0
                                            │   │   ├─┬ locate-path@6.0.0
                                            │   │   │ └─┬ p-locate@5.0.0
                                            │   │   │   └─┬ p-limit@3.1.0
                                            │   │   │     └── yocto-queue@0.1.0
                                            │   │   └── path-exists@4.0.0
                                            │   ├─┬ read-pkg-up@7.0.1
                                            │   │ ├─┬ find-up@4.1.0
                                            │   │ │ ├─┬ locate-path@5.0.0
                                            │   │ │ │ └─┬ p-locate@4.1.0
                                            │   │ │ │   └── p-limit@2.3.0 deduped
                                            │   │ │ └── path-exists@4.0.0 deduped
                                            │   │ ├─┬ read-pkg@5.2.0
                                            │   │ │ ├── @types/normalize-package-data@2.4.1
                                            │   │ │ ├─┬ normalize-package-data@2.5.0
                                            │   │ │ │ ├── hosted-git-info@2.8.9
                                            │   │ │ │ ├─┬ resolve@1.20.0
                                            │   │ │ │ │ ├── is-core-module@2.8.0 deduped
                                            │   │ │ │ │ └── path-parse@1.0.7
                                            │   │ │ │ ├── semver@5.7.1
                                            │   │ │ │ └── validate-npm-package-license@3.0.4 deduped
                                            │   │ │ ├── parse-json@5.2.0 deduped
                                            │   │ │ └── type-fest@0.6.0
                                            │   │ └── type-fest@0.8.1
                                            │   ├─┬ rxjs@6.6.7
                                            │   │ └── tslib@1.14.1 deduped
                                            │   ├── split@1.0.1 deduped
                                            │   ├── symbol-observable@3.0.0
                                            │   ├─┬ terminal-link@2.1.1
                                            │   │ ├── ansi-escapes@4.3.2 deduped
                                            │   │ └─┬ supports-hyperlinks@2.2.0
                                            │   │   ├── has-flag@4.0.0 deduped
                                            │   │   └── supports-color@7.2.0 deduped
                                            │   └─┬ update-notifier@5.1.0
                                            │     ├─┬ boxen@5.1.2
                                            │     │ ├─┬ ansi-align@3.0.1
                                            │     │ │ └── string-width@4.2.3 deduped
                                            │     │ ├── camelcase@6.2.1
                                            │     │ ├── cli-boxes@2.2.1
                                            │     │ ├─┬ widest-line@3.1.0
                                            │     │ └─┬ wrap-ansi@7.0.0
                                            │     │   ├── ansi-styles@4.3.0 deduped
                                            │     │   └── strip-ansi@6.0.1 deduped
                                            │     ├─┬ configstore@5.0.1
                                            │     │ ├─┬ dot-prop@5.3.0
                                            │     │ │ └── is-obj@2.0.0 deduped
                                            │     │ ├── make-dir@3.1.0 deduped
                                            │     │ ├─┬ unique-string@2.0.0
                                            │     │ │ └── crypto-random-string@2.0.0
                                            │     │ ├─┬ write-file-atomic@3.0.3
                                            │     │ │ ├── imurmurhash@0.1.4
                                            │     │ │ ├── is-typedarray@1.0.0 deduped
                                            │     │ │ ├── signal-exit@3.0.6 deduped
                                            │     │ │ └─┬ typedarray-to-buffer@3.1.5
                                            │     │ │   └── is-typedarray@1.0.0 deduped
                                            │     │ └── xdg-basedir@4.0.0 deduped
                                            │     ├── has-yarn@2.1.0 deduped
                                            │     ├── import-lazy@2.1.0
                                            │     ├─┬ is-ci@2.0.0
                                            │     │ └── ci-info@2.0.0
                                            │     ├─┬ is-installed-globally@0.4.0
                                            │     │ ├─┬ global-dirs@3.0.0
                                            │     │ │ └── ini@2.0.0
                                            │     ├── is-npm@5.0.0
                                            │     ├── is-yarn-global@0.3.0
                                            │     ├─┬ latest-version@5.1.0
                                            │     │ └─┬ package-json@6.5.0
                                            │     │   ├─┬ got@9.6.0
                                            │     │   │ ├── @sindresorhus/is@0.14.0
                                            │     │   │ ├─┬ @szmarczak/http-timer@1.1.2
                                            │     │   │ │ └── defer-to-connect@1.1.3
                                            │     │   │ ├─┬ cacheable-request@6.1.0
                                            │     │   │ │ ├── clone-response@1.0.2 deduped
                                            │     │   │ │ │ └── pump@3.0.0 deduped
                                            │     │   │ │ ├── http-cache-semantics@4.1.0 deduped
                                            │     │   │ │ ├─┬ keyv@3.1.0
                                            │     │   │ │ │ └── json-buffer@3.0.0
                                            │     │   │ │ ├── normalize-url@4.5.1
                                            │     │   │ │ └─┬ responselike@1.0.2
                                            │     │   │ │   └── lowercase-keys@1.0.1 deduped
                                            │     │   │ ├─┬ decompress-response@3.3.0
                                            │     │   │ │ └── mimic-response@1.0.1 deduped
                                            │     │   │ ├── duplexer3@0.1.4 deduped
                                            │     │   │ ├─┬ get-stream@4.1.0
                                            │     │   │ ├── lowercase-keys@1.0.1
                                            │     │   │ ├── mimic-response@1.0.1
                                            │     │   │ ├── p-cancelable@1.1.0
                                            │     │   │ ├── to-readable-stream@1.0.0
                                            │     │   │ └─┬ url-parse-lax@3.0.0
                                            │     │   │   └── prepend-http@2.0.0
                                            │     │   ├── registry-auth-token@4.2.1 deduped
                                            │     │   ├── registry-url@5.1.0 deduped
                                            │     │   └── semver@6.3.0
                                            │     ├─┬ pupa@2.1.1
                                            │     │ └── escape-goat@2.1.1
                                            │     ├─┬ semver-diff@3.1.1
                                            ├─┬ iobroker.web@3.4.9
                                            │ ├── @iobroker/adapter-core@2.5.1 deduped
                                            │ ├── body-parser@1.19.0 deduped
                                            │ ├── connect-flash@0.1.1 deduped
                                            │ ├── cookie-parser@1.4.6 deduped
                                            │ ├── express@4.17.1 deduped
                                            │ ├── express-session@1.17.2 deduped
                                            │ ├─┬ iobroker.simple-api@2.6.2
                                            │ │ └── @iobroker/adapter-core@2.5.1 deduped
                                            │ ├─┬ iobroker.socketio@3.1.5
                                            │ │ ├── @iobroker/adapter-core@2.5.1 deduped
                                            │ │ ├─┬ axios@0.23.0
                                            │ │ │ └── follow-redirects@1.14.5 deduped
                                            │ │ ├── cookie-parser@1.4.6 deduped
                                            │ │ ├── express-session@1.17.2 deduped
                                            │ │ └─┬ socket.io@2.4.1
                                            │ │   ├─┬ debug@4.1.1
                                            │ │   │ └── ms@2.1.3 deduped
                                            │ │   ├─┬ engine.io@3.5.0
                                            │ │   │ ├── accepts@1.3.7 deduped
                                            │ │   │ ├── base64id@2.0.0
                                            │ │   │ ├── cookie@0.4.1
                                            │ │   │ ├─┬ debug@4.1.1
                                            │ │   │ │ └── ms@2.1.3 deduped
                                            │ │   │ ├── engine.io-parser@2.2.1 deduped
                                            │ │   │ └── ws@7.4.6
                                            │ │   ├── has-binary2@1.0.3 deduped
                                            │ │   ├── socket.io-adapter@1.1.2
                                            │ │   ├── socket.io-client@2.4.0 deduped
                                            │ │   └─┬ socket.io-parser@3.4.1
                                            │ │     ├── component-emitter@1.2.1
                                            │ │     ├─┬ debug@4.1.1
                                            │ │     └── isarray@2.0.1
                                            │ ├─┬ mime-types@2.1.34
                                            │ │ └── mime-db@1.51.0
                                            │ ├─┬ passport@0.4.1
                                            │ │ ├── passport-strategy@1.0.0 deduped
                                            │ │ └── pause@0.0.1 deduped
                                            │ ├── passport-local@1.0.0 deduped
                                            │ ├── passport.socketio@3.7.0 deduped
                                            │ ├─┬ socket.io-client@2.4.0
                                            │ │ ├── backo2@1.0.2
                                            │ │ ├── component-bind@1.0.0
                                            │ │ ├── component-emitter@1.3.0
                                            │ │ ├─┬ debug@3.1.0
                                            │ │ │ └── ms@2.0.0
                                            │ │ ├─┬ engine.io-client@3.5.2
                                            │ │ │ ├── component-emitter@1.3.0 deduped
                                            │ │ │ ├── component-inherit@0.0.3
                                            │ │ │ ├─┬ debug@3.1.0
                                            │ │ │ │ └── ms@2.0.0
                                            │ │ │ ├─┬ engine.io-parser@2.2.1
                                            │ │ │ │ ├── after@0.8.2
                                            │ │ │ │ ├── arraybuffer.slice@0.0.7
                                            │ │ │ │ ├── base64-arraybuffer@0.1.4
                                            │ │ │ │ ├── blob@0.0.5
                                            │ │ │ │ └── has-binary2@1.0.3 deduped
                                            │ │ │ ├── has-cors@1.1.0
                                            │ │ │ ├── indexof@0.0.1 deduped
                                            │ │ │ ├── parseqs@0.0.6 deduped
                                            │ │ │ ├── parseuri@0.0.6 deduped
                                            │ │ │ ├── ws@7.4.6
                                            │ │ │ ├── xmlhttprequest-ssl@1.6.3
                                            │ │ │ └── yeast@0.1.2
                                            │ │ ├─┬ has-binary2@1.0.3
                                            │ │ │ └── isarray@2.0.1
                                            │ │ ├─┬ socket.io-parser@3.3.2
                                            │ │ │ ├── debug@3.1.0 deduped
                                            │ │ └── to-array@0.1.4
                                            │ └── xtend@4.0.2
                                            └─┬ iobroker.zigbee@1.5.6
                                              ├── tar@6.1.11 deduped
                                              ├── typescript@4.5.2 deduped
                                              ├─┬ zigbee-herdsman@0.13.110
                                              │ ├── @babel/cli@7.13.0 extraneous
                                              │ ├── @babel/preset-env@7.13.9 extraneous
                                              │ ├── @babel/preset-typescript@7.13.0 extraneous
                                              │ ├─┬ @serialport/bindings@9.0.4
                                              │ │ ├─┬ @serialport/binding-abstract@9.0.7
                                              │ │ │ └── debug@4.3.1 deduped
                                              │ │ ├─┬ @serialport/parser-readline@9.0.7
                                              │ │ │ └── @serialport/parser-delimiter@9.0.7 deduped
                                              │ │ ├─┬ bindings@1.5.0
                                              │ │ │ └── file-uri-to-path@1.0.0
                                              │ │ ├── debug@4.3.1 deduped
                                              │ │ ├── nan@2.14.2
                                              │ │ └─┬ prebuild-install@6.0.1
                                              │ │   ├── detect-libc@1.0.3
                                              │ │   ├── expand-template@2.0.3
                                              │ │   ├── github-from-package@0.0.0
                                              │ │   ├── minimist@1.2.5
                                              │ │   ├── mkdirp-classic@0.5.3
                                              │ │   ├── napi-build-utils@1.0.2
                                              │ │   ├─┬ node-abi@2.20.0
                                              │ │   │ └── semver@5.7.1
                                              │ │   ├── noop-logger@0.1.1
                                              │ │   ├─┬ npmlog@4.1.2
                                              │ │   │ ├─┬ are-we-there-yet@1.1.5
                                              │ │   │ │ ├── delegates@1.0.0
                                              │ │   │ │ └─┬ readable-stream@2.3.7
                                              │ │   │ │   ├── core-util-is@1.0.2
                                              │ │   │ │   ├── inherits@2.0.4 deduped
                                              │ │   │ │   ├── isarray@1.0.0
                                              │ │   │ │   ├── process-nextick-args@2.0.1
                                              │ │   │ │   ├── safe-buffer@5.1.2 deduped
                                              │ │   │ │   ├─┬ string_decoder@1.1.1
                                              │ │   │ │   │ └── safe-buffer@5.1.2 deduped
                                              │ │   │ │   └── util-deprecate@1.0.2
                                              │ │   │ ├── console-control-strings@1.1.0
                                              │ │   │ ├─┬ gauge@2.7.4
                                              │ │   │ │ ├── aproba@1.2.0
                                              │ │   │ │ ├── console-control-strings@1.1.0 deduped
                                              │ │   │ │ ├── has-unicode@2.0.1
                                              │ │   │ │ ├── object-assign@4.1.1 deduped
                                              │ │   │ │ ├── signal-exit@3.0.3
                                              │ │   │ │ ├─┬ string-width@1.0.2
                                              │ │   │ │ │ ├── code-point-at@1.1.0
                                              │ │   │ │ │ ├─┬ is-fullwidth-code-point@1.0.0
                                              │ │   │ │ │ │ └── number-is-nan@1.0.1
                                              │ │   │ │ │ └── strip-ansi@3.0.1 deduped
                                              │ │   │ │ ├─┬ strip-ansi@3.0.1
                                              │ │   │ │ └─┬ wide-align@1.1.3
                                              │ │   │ │   └── string-width@1.0.2 deduped
                                              │ │   │ └── set-blocking@2.0.0
                                              │ │   ├─┬ pump@3.0.0
                                              │ │   │ ├─┬ end-of-stream@1.4.4
                                              │ │   │ └─┬ once@1.4.0
                                              │ │   │   └── wrappy@1.0.2
                                              │ │   ├─┬ rc@1.2.8
                                              │ │   │ ├── deep-extend@0.6.0
                                              │ │   │ ├── ini@1.3.8
                                              │ │   │ ├── minimist@1.2.5 deduped
                                              │ │   │ └── strip-json-comments@2.0.1
                                              │ │   ├─┬ simple-get@3.1.0
                                              │ │   │ ├─┬ decompress-response@4.2.1
                                              │ │   │ ├── once@1.4.0 deduped
                                              │ │   │ └── simple-concat@1.0.1
                                              │ │   ├─┬ tar-fs@2.1.1
                                              │ │   │ ├── chownr@1.1.4
                                              │ │   │ ├── mkdirp-classic@0.5.3 deduped
                                              │ │   │ ├── pump@3.0.0 deduped
                                              │ │   │ └─┬ tar-stream@2.2.0
                                              │ │   │   ├─┬ bl@4.1.0
                                              │ │   │   │ ├─┬ buffer@5.7.1
                                              │ │   │   │ │ ├── base64-js@1.5.1
                                              │ │   │   │ │ └── ieee754@1.2.1
                                              │ │   │   │ └─┬ readable-stream@3.6.0
                                              │ │   │   │   ├── string_decoder@1.1.1 deduped
                                              │ │   │   │   └── util-deprecate@1.0.2 deduped
                                              │ │   │   ├── fs-constants@1.0.0
                                              │ │   ├─┬ tunnel-agent@0.6.0
                                              │ │   └── which-pm-runs@1.0.0
                                              │ ├── @types/debounce@1.2.0 extraneous
                                              │ ├── @types/debug@4.1.5 extraneous
                                              │ ├── @types/jest@26.0.20 extraneous
                                              │ ├── @types/mz@2.7.3 extraneous
                                              │ ├── @types/nedb@1.8.11 extraneous
                                              │ ├── @types/serialport@8.0.1 extraneous
                                              │ ├── @typescript-eslint/eslint-plugin@4.16.1 extraneous
                                              │ ├── @typescript-eslint/parser@4.16.1 extraneous
                                              │ ├── debounce@1.2.0
                                              │ ├─┬ debug@4.3.1
                                              │ │ └── ms@2.1.2
                                              │ ├── eslint@7.21.0 extraneous
                                              │ ├── fast-deep-equal@3.1.3
                                              │ ├── jest@26.6.3 extraneous
                                              │ ├── mixin-deep@2.0.1
                                              │ ├─┬ mz@2.7.0
                                              │ │ ├── any-promise@1.3.0
                                              │ │ └─┬ thenify-all@1.6.0
                                              │ │   └─┬ thenify@3.3.1
                                              │ │     └── any-promise@1.3.0 deduped
                                              │ ├─┬ serialport@9.0.6
                                              │ │ ├─┬ @serialport/binding-mock@9.0.7
                                              │ │ │ ├── @serialport/binding-abstract@9.0.7 deduped
                                              │ │ ├── @serialport/bindings@9.0.4 deduped
                                              │ │ ├── @serialport/parser-byte-length@9.0.7
                                              │ │ ├── @serialport/parser-cctalk@9.0.7
                                              │ │ ├── @serialport/parser-delimiter@9.0.7
                                              │ │ ├── @serialport/parser-inter-byte-timeout@9.0.7
                                              │ │ ├── @serialport/parser-readline@9.0.7 deduped
                                              │ │ ├── @serialport/parser-ready@9.0.7
                                              │ │ ├── @serialport/parser-regex@9.0.7
                                              │ │ ├─┬ @serialport/stream@9.0.7
                                              │ ├── slip@1.0.2
                                              │ ├── typedoc@0.20.28 extraneous
                                              │ ├── typedoc-plugin-markdown@3.6.0 extraneous
                                              │ ├── typedoc-plugin-no-inherit@1.2.0 extraneous
                                              │ ├── typedoc-plugin-sourcefile-url@1.0.6 extraneous
                                              │ └── UNMET PEER DEPENDENCY typescript@4.2.2 extraneous
                                              └─┬ zigbee-herdsman-converters@14.0.162
                                                ├─┬ axios@0.21.1
                                                │ └── follow-redirects@1.14.1
                                                ├── buffer-crc32@0.2.13
                                                ├── eslint@7.27.0 extraneous
                                                ├── eslint-config-google@0.14.0 extraneous
                                                ├── eslint-plugin-jest@24.3.6 extraneous
                                                ├─┬ https-proxy-agent@5.0.0
                                                │ ├─┬ agent-base@6.0.2
                                                │ └─┬ debug@4.3.1
                                                │   └── ms@2.1.2
                                                ├─┬ tar-stream@2.2.0
                                                │ ├─┬ bl@4.1.0
                                                │ │ └── readable-stream@3.6.0 deduped
                                                │ │ └─┬ once@1.4.0
                                                │   ├─┬ string_decoder@1.3.0
                                                └─┬ zigbee-herdsman@0.13.107
                                                  │ ├── nan@2.14.2
                                                  │   ├─┬ npmlog@4.1.2
                                                  │   │ ├─┬ gauge@2.7.4
                                                  │   ├─┬ pump@3.0.0
                                                  │   │ └─┬ once@1.4.0
                                                  │   ├─┬ rc@1.2.8
                                                  │   │ ├── ini@1.3.8
                                                  │   ├─┬ tar-fs@2.1.1
                                                  │   │   ├─┬ bl@4.1.0
                                                  ├── debounce@1.2.0
                                                  ├─┬ debug@4.3.1
                                                  │ └── ms@2.1.2
                                                  ├─┬ mz@2.7.0
                                                  │   └─┬ thenify@3.3.1
                                                  ├── slip@1.0.2
                                            npm ERR! peer dep missing: @angular/common@>= 5.0.0, required by xmlhttprequest-ts@1.0.1
                                            npm ERR! peer dep missing: @angular/core@>= 5.0.0, required by xmlhttprequest-ts@1.0.1
                                            Haben die Error-Meldung irgendeine Auswirkung und müssen beseitigt werden?
                                            1698
