    4. Raspberry OS lite Image for/with ioBroker
      Thomas Braun Most Active @Beekeeper last edited by Thomas Braun
      @beekeeper
      Wo kommt der Quark eigentlich immer her?
      Der Befehl iobroker wird NICHT per sudo eingeleitet!
      iobroker status
      iobroker list instances
      iobroker list adapters
        Beekeeper @Thomas Braun last edited by
        @thomas-braun Danke für die schnelle Antwort. Ich dachte sudo schadet im Zweifelsfall nicht und sorgt immer für ausreichende Rechte.
        iobroker status:
        Objects type: file
        States type: file
        • instance is alive
        iobroker list adapters:
        system.adapter.admin : admin - v5.1.25
        Also scheint zu laufen, oder?
          @beekeeper
          Doch, es schadet, weil es nämlich genau die Rechte verfummeln kann. Finger weg von root-Rechten, wenn man keine braucht.
          Bitte Konsolentext in CodeTags posten. Und bitte auch vollständig. Inkl. Login prompt.
          iobroker stop
          iobroker fix
          iobroker start
            @thomas-braun Habe alles nochmal durchlaufen lassen:
            login as: pi
            pi@192.168.0.80's password:
            Linux raspberrypi 5.10.52-v7l+ #1440 SMP Tue Jul 27 09:55:21 BST 2021 armv7l
            The programs included with the Debian GNU/Linux system are free software;
            the exact distribution terms for each program are described in the
            individual files in /usr/share/doc/*/copyright.
            Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
            permitted by applicable law.
            Last login: Tue Oct  5 20:05:46 2021
            SSH is enabled and the default password for the 'pi' user has not been changed.
            This is a security risk - please login as the 'pi' user and type 'passwd' to set a new password.
            pi@raspberrypi:~ $ iobroker stop
            pi@raspberrypi:~ $ iobroker fix
            library: loaded
            Library version=2021-08-05
                Welcome to the ioBroker installation fixer!
                Script version: 2021-04-07
                You might need to enter your password a couple of times.
                Installing prerequisites (1/3)
            OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
            OK:2 http://archive.raspberrypi.org/debian buster InRelease
            OK:3 https://deb.nodesource.com/node_14.x buster InRelease
            Installed gcc-c++
                Checking ioBroker user and directory permissions (2/3)
            Created /etc/sudoers.d/iobroker
            Fixing directory permissions...
                Checking autostart (3/3)
            Enabling autostart...
            Autostart enabled!
                Your installation was fixed successfully
                Run iobroker start to start ioBroker again!
            pi@raspberrypi:~ $ iobroker start
            pi@raspberrypi:~ $ iobroker status
            Objects type: file
            States  type: file
            pi@raspberrypi:~ $ iobroker list instances
            + instance is alive
            pi@raspberrypi:~ $ iobroker list adapters
            pi@raspberrypi:~ $
            Leider noch keine Besserung
              @beekeeper
              iobroker add admin
              Und änder das Standardpasswort.
                @thomas-braun said in Raspberry OS lite Image for/with ioBroker:
                iobroker add admin
                Vielen Dank, dass hat geklappt. Passwort ändere ich jetzt auch noch
                  fischer_slarcor.de @andre last edited by
                  Hallo, ich bekomme die Vis nicht zum laufen, was soll ich tun?
                  Habe bereits mehrer Images ausprobiert und auch manuell schon auf gesetzt nix geht - keine WEB Oberfläche
                  Meine alte jedoch geht - jedoch Alexa Instanz veraltet.
                  Bitte um Hilfe.
                  Danke.
                  F.S.
                  Thomas Braun X 2 Replies Last reply Reply Quote 0
                    Thomas Braun Most Active @fischer_slarcor.de last edited by
                    @fischer_slarcor-de
                    Bitte eigenen Thread eröffnen. Das ist ein anderes Thema.
                    • X
                      XWing @fischer_slarcor.de last edited by
                      @fischer_slarcor-de
                      Ich habe das gleiche Problem. Es ließ sich alles installieren. Nur Vis und Flot wollen nicht. Es kommt die Fehlermeldung: Keine Versionsinfo für web.
                      Das gleiche beim Flot Adapter.
                        Thomas Braun Most Active @XWing last edited by
                        @xwing
                        iobroker upload all
                        mal probieren.
                        • X
                          XWing @Thomas Braun last edited by
                          Das hat leider nicht geholfen:
                            Thomas Braun Most Active @XWing last edited by Thomas Braun
                            @xwing
                            Bitte keine Screenshots, hier sind Rückmeldungen aus dem logfile oder dem Terminal gefragt.
                            iobroker update -i
                              Homoran Global Moderator Administrators @XWing last edited by
                              @xwing sagte in Raspberry OS lite Image for/with ioBroker:
                              läuft web überhaupt?
                              • X
                                Habe gerade gemerkt, daß dies nicht der Fall war.
                                Jetzt läuft es, aber den Vis Adapter bekomme ich nicht installiert. Es kommt immer obige Fehlermeldung.
                                Im Protokoll gibt es leider keine Einträge, wenn ich eine Installation versuche. Es kommt ja auch zu keinem Installationsvorgang. Nach dem Abnicken der Lizenz kommt obige Meldung.
                                  @xwing mach mal einene forced refresh und versuch es noch mal
                                    Irgendwas kommt da mit Sicherheit...
                                    • X
                                      Da stand wirklich nichts.
                                      Ich habe das Problem jetzt gelöst:
                                      cd /opt/iobroker
                                      npm uninstall iobroker.vis
                                      Danach konnte ich den Adapter über die Oberfläche installieren.
                                      • I
                                        IORalf last edited by
                                        Ich habe das Image auf einem Nano 2 installiert.
                                        Startet soweit bis zum login, keyboard etc. angepasst und WLan eingetragen
                                        Im Startlog steht Starting LSB: starts IoBroker...
                                        My IP Adress is 192.168.1.139
                                        Starting OpenBSD ....
                                        Wenn ich im Browser die IP Adresse eingebe kommt die Fehlermeldung
                                        192.168.1.139 hat die Verbindung abgelehnt.
                                        Per Putty/SSH kein Problem
                                          Thomas Braun Most Active @IORalf last edited by Thomas Braun
                                          @ioralf sagte in Raspberry OS lite Image for/with ioBroker:
                                          OpenBSD ist ein anderes Betriebssystem. Was hast du da installiert? Oder ist das nicht die komplette Meldung?
                                          Und warum installiert man nicht einfach ein Raspberry Lite selber und haut den ioBroker noch per Einzeiler hinterher? Werd ich wohl nie verstehen...
                                          • I
                                            IORalf last edited by IORalf
                                            Ich kann meinen Eintrag leider nicht ändern,
                                            mit :8081 geht auch die Weboberfläche
                                            Starting OpenBSD ... - steht halt so im Log, oder was war die Frage
                                            31.7k
                                            79.9k
                                            191
                                            123960
