    • amg_666
      amg_666 @da_Woody last edited by
      nur mal zur Info: Die 1.4.0 läuft bei mir nicht rund:
      host.iobroker
      	2021-12-01 10:05:02.849	error	instance system.adapter.shuttercontrol.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.iobroker
      	2021-12-01 10:05:02.849	error	Caught by controller[0]: at listOnTimeout (node:internal/timers:557:17)
      host.iobroker
      	2021-12-01 10:05:02.849	error	Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:30:56)
      host.iobroker
      	2021-12-01 10:05:02.849	error	Caught by controller[0]: at checkPendingAlarm (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/shutterAlarm.js:661:12)
      host.iobroker
      	2021-12-01 10:05:02.849	error	Caught by controller[0]: at new Promise (<anonymous>)
      host.iobroker
      	2021-12-01 10:05:02.849	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.shuttercontrol/lib/shutterAlarm.js:672:83
      host.iobroker
      	2021-12-01 10:05:02.848	error	Caught by controller[0]: at Adapter.getForeignStateAsync (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1651:16)
      host.iobroker
      	2021-12-01 10:05:02.848	error	Caught by controller[0]: at new Promise (<anonymous>)
      host.iobroker
      	2021-12-01 10:05:02.848	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1652:16
      host.iobroker
      	2021-12-01 10:05:02.848	error	Caught by controller[0]: at Adapter.getForeignState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6815:17)
      host.iobroker
      	2021-12-01 10:05:02.848	error	Caught by controller[0]: at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:501:19)
      host.iobroker
      	2021-12-01 10:05:02.848	error	Caught by controller[0]: Error: The id is empty! Please provide a valid id.
      host.iobroker
      	2021-12-01 10:05:02.847	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      Ich nutze allerdings schon npm 8.1.0 und node.js 16.13.0, nehme mal an dass es daran liegt.
      Ich wollte das hier auch nur zur Info posten, bin auf die 1.3.9 zurück und die läuft stabil
      • simatec
        simatec Developer Most Active @amg_666 last edited by
        @amg_666 Zeige mal bitte deine Config der Alarm Settings
        • amg_666
          amg_666 @simatec last edited by
          @simatec Was genau meinst du? Die shuttercontrol Instanz steht auf "warn"
          • simatec
            • amg_666
              @simatec ok, da habe ich nix eingetragen:
              • simatec
                @amg_666 OK ... Fehler gefunden ... 1.4.1 kommt mit Fix
                • BanditFG
                  BanditFG last edited by
                  @simatec ist das mit dem Umstellen auf Debug jetzt so richtig??
                  und wie komme ich dann an den LOG um ihn hier zu posten??
                  danke für die HIlfe
                  • da_Woody
                    da_Woody @BanditFG last edited by
                    @banditfg richtig, dann solltest du im protokoll alles sehn können. filtern auf shuttercontrol, kopieren, in codetags hier einfügen.
                    • simatec
                      Ab sofort steht auf Github und in Kürze auch im latest die Version 1.4.1 zur Verfügung.
                      Da ab Version 1.4.0 der Code komplett überarbeitet und neu geschrieben wurde, bitte alles intensiv testen und bei Fehlern hier die Config und den debug-Log posten.
                      Changelog
                      1.4.1 (2021-12-01)
                      • (simatec) Code cleaning
                      • (simatec) Bugfix Alarm States
                      • (simatec) try & catch added
                      amg_666 1 Reply Last reply Reply Quote 1
                      • amg_666
                        @simatec sieht gut aus:
                        host.iobroker
                        	2021-12-01 13:21:57.436	info	instance system.adapter.shuttercontrol.0 started with pid 1263
                        host.iobroker
                        	2021-12-01 13:21:55.397	info	iobroker exit 0
                        host.iobroker
                        	2021-12-01 13:21:54.983	info	instance system.adapter.shuttercontrol.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        host.iobroker
                        	2021-12-01 13:21:54.392	info	stopInstance system.adapter.shuttercontrol.0 send kill signal
                        host.iobroker
                        	2021-12-01 13:21:54.240	info	stopInstance system.adapter.shuttercontrol.0 (force=false, process=true)
                        host.iobroker
                        	2021-12-01 13:21:54.177	info	iobroker Update "system.adapter.shuttercontrol.0"
                        host.iobroker
                        	2021-12-01 13:21:54.028	info	iobroker upload [0] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/img/info-big.png img/info-big.png image/png
                        host.iobroker
                        	2021-12-01 13:21:53.966	info	iobroker upload [1] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/index_m.html index_m.html text/html
                        host.iobroker
                        	2021-12-01 13:21:53.898	info	iobroker upload [2] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/index_m.js index_m.js application/javascript
                        host.iobroker
                        	2021-12-01 13:21:53.824	info	iobroker upload [3] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/shuttercontrol.png shuttercontrol.png image/png
                        host.iobroker
                        	2021-12-01 13:21:53.765	info	iobroker upload [4] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/style.css style.css text/css
                        host.iobroker
                        	2021-12-01 13:21:53.641	info	iobroker upload [5] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/words.js words.js application/javascript
                        host.iobroker
                        	2021-12-01 13:21:30.161	info	iobroker NPM version: 8.1.0npm install simatec/ioBroker.shuttercontrol --loglevel error --prefix "/opt/iobroker" (System call)
                        host.iobroker
                        	2021-12-01 13:21:29.333	info	iobroker install simatec/ioBroker.shuttercontrol
                        host.iobroker
                        	2021-12-01 13:21:27.687	info	iobroker url simatec/ioBroker.shuttercontrol --host iobroker
                        • simatec
                          @amg_666 Bitte alles intensiv testen. Da in shuttercontrol inzwischen zu viele Funktionen hinzu kamen und der Adapter in seinen Code Bausteinen explodierte, habe ich alles umgeschrieben ... Hoffe der Fehlerteufel hat sich dabei nirgends eingeschlichen
                          • BanditFG
                            shuttercontrol.0
                            4889	2021-12-01 13:30:02.109	debug	status alarm pending for hm-rpc.0.OEQ1299293.1.LEVEL: false
                            shuttercontrol.0
                            4889	2021-12-01 13:30:02.109	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
                            shuttercontrol.0
                            4889	2021-12-01 13:30:00.046	debug	Sun Elevation: 14.4°
                            shuttercontrol.0
                            4889	2021-12-01 13:30:00.045	debug	Sun Azimut: 202.5°
                            shuttercontrol.0
                            4889	2021-12-01 13:30:00.045	debug	calculate astrodata ...
                            shuttercontrol.0
                            4889	2021-12-01 13:28:07.643	debug	status alarm pending for hm-rpc.0.OEQ1299293.1.LEVEL: false
                            shuttercontrol.0
                            4889	2021-12-01 13:28:07.643	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
                            shuttercontrol.0
                            4889	2021-12-01 13:28:05.642	debug	insidetemperature changed: mihome.0.devices.weather_v1_158d0002321724.temperature Value: 18.54
                            shuttercontrol.0
                            4889	2021-12-01 13:28:02.558	debug	status alarm pending for hm-rpc.0.OEQ1299293.1.LEVEL: false
                            shuttercontrol.0
                            4889	2021-12-01 13:28:02.558	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
                            shuttercontrol.0
                            4889	2021-12-01 13:28:00.557	debug	insidetemperature changed: mihome.0.devices.weather_v1_158d000249074a.temperature Value: 19.87
                            shuttercontrol.0
                            4889	2021-12-01 13:27:44.046	debug	status alarm pending for hm-rpc.0.OEQ1299293.1.LEVEL: false
                            shuttercontrol.0
                            4889	2021-12-01 13:27:44.046	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
                            shuttercontrol.0
                            4889	2021-12-01 13:27:42.046	debug	outsidetemperature changed: viessmannapi.0.241772.0.features.heating.sensors.temperature.outside.properties.value.value Value: 6.1
                            shuttercontrol.0
                            4889	2021-12-01 13:27:22.681	debug	status alarm pending for hm-rpc.0.OEQ1299293.1.LEVEL: false
                            shuttercontrol.0
                            4889	2021-12-01 13:27:22.681	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
                            shuttercontrol.0
                            4889	2021-12-01 13:27:20.680	debug	insidetemperature changed: mihome.0.devices.weather_v1_158d000224ce57.temperature Value: 16.07
                            shuttercontrol.0
                            4889	2021-12-01 13:27:11.534	debug	status alarm pending for hm-rpc.0.OEQ1299293.1.LEVEL: false
                            shuttercontrol.0
                            4889	2021-12-01 13:27:11.534	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
                            ich habe nen auch v1.4.1 instlliert und bekomme ständig diese Meldung
                            • simatec
                              simatec Developer Most Active @BanditFG last edited by
                              @banditfg Ja ist ja der debuglog. Da wird alles was im Adapter passiert angezeigt. So wie es ausschaut, reagiert der Adapter nur auf Änderungen deines Temperatursensors ...
                              • BanditFG
                                BanditFG last edited by BanditFG
                                @simatec
                                ich hab auch mit v1.4.1 das Problem das der Wert von Alarm Frost Höhe verschwindet.
                                und zwar so reproduzierbar:
                                ich öffne über den Schraubenschlüssel bei der Shuttercontrol Instanz die Einstellung --> Extra Einstellungen -> Alarm Einstellungen -> gebe dort bei Alarm Frost Höhe den Wert 15 ein und klicke unten auf SPEICHERN
                                dann gehen ich auf Haupteinstellungen wähle einen Rollladen über den Stift aus, schaue mir die Einstellungen da an und klicke unten wieder OK
                                gehe ich dann wieder dort hin wo der Wert für Alarm Frost Höhe eingeben wird ist das Feld leer!!!
                                mach ich irgendwas falsch????
                                PS: nicht nur das Feld für Alarm Frost Höhe, sondern auch die anderen 5 Werte sind weg...
                                simatec amg_666 2 Replies Last reply Reply Quote 0
                                • simatec
                                  @banditfg Die Funktion habe ich nicht eingebaut und muss ich mir anschauen ... Aber ich habe eine Vermutung
                                  BanditFG 1 Reply Last reply Reply Quote 0
                                  • BanditFG
                                    BanditFG @simatec last edited by
                                    @simatec alle 5 Werte verschwinden so, nur die Auslöser Objekt IDs bleiben drin.
                                    • amg_666
                                      amg_666 @BanditFG last edited by
                                      @banditfg Kann ich bestätigen. Ich nutze die Alarme nicht und da standen irgendwelche Defaultwerte drin (Bei Frosthöhe war es 80). Ich habe jetzt genau die Schritte von dir nachvollzogen und jetzt sind da alle Werte leer.
                                      Und weil ich Firefox nutze habe ich sicherheitshalber auch nochmal den Cache gelöscht, das hat aber nix gebracht, scheint ein bug im Adapter zu sein.
                                      simatec 2 Replies Last reply Reply Quote 0
                                      • simatec
                                        @amg_666 Wird gefixt ...
                                        • simatec
                                          @amg_666 Bugfix ist bereits auf Github und kommt mit der nächsten Version
                                            Fortune95 @simatec last edited by
                                            @simatec
                                            Hi, habe das Problem das wenn das Fenster zum Zeitpunkt des Öffnen oder Schließen offen ist, der Rolladen nach dem schließen des Fensters immer in die entgegengesetzte Richtung fährt.
                                            Er wird aber zum eingestellten Zeitpunkt hoch oder auch runter gefahren. Der jeweilige Auto State geht dann von "up/down" auf "None". Der Fensterkontakt liefert nur 2 Zustände. Habe daher die ergänzte Einstellung für "Wert des Fenster/Tür Sensors im angekippten Zustand" auf keins gestellt. Das Problem existiert seitdem diese Option ergänzt wurde.
                                            1.2k
                                            332
                                            7408
                                            10556798
