    4. gelöst - Nach Update - nur iobroker-Logo sichtbar
      Hicki last edited by
      Hat funktioniert. Wie jetzt weiter?
      root@ioBroker:~# logout
      Ubuntu 18.04.6 LTS ioBroker tty1
      ioBroker login: hicki
      Password:
      Welcome to Ubuntu 18.04.6 LTS (GNU/Linux 5.4.73-1-pve x86_64)
       * Documentation:  https://help.ubuntu.com
       * Management:     https://landscape.canonical.com
       * Support:        https://ubuntu.com/advantage
      New release '20.04.3 LTS' available.
      Run 'do-release-upgrade' to upgrade to it.
      The programs included with the Ubuntu system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Ubuntu comes with ABSOLUTELY NO WARRANTY, to the extent permitted by
      applicable law.
      To run a command as administrator (user "root"), use "sudo <command>".
      See "man sudo_root" for details.
      hicki@ioBroker:~$ sudo whoami
      [sudo] password for hicki:
      root
      hicki@ioBroker:~$
        Thomas Braun Most Active @Hicki last edited by Thomas Braun
        @hicki
        Gut, und jetzt niemehr als root einloggen. Nur noch mit dem hicki agieren.
        Jetzt die große Löschaktion:
        iobroker stop
        sudo usermod -aG iobroker hicki
        sudo rm /usr/local/bin/node
        sudo rm /usr/local/bin/npm
        sudo apt remove nodejs
        curl -fsSL https://deb.nodesource.com/setup_14.x | sudo -E bash -
        sudo apt update
        sudo apt install nodejs
        sudo ln -s /usr/bin/node /usr/bin/nodejs
        sudo reboot
        Wenn die Kiste wieder oben ist:
        which nodejs node npm && nodejs -v && node -v && npm -v &&  sudo apt update && apt policy nodejs
          Hicki @Thomas Braun last edited by
          fertig
          Password:
          Last login: Wed Dec  1 15:53:53 UTC 2021 on tty1
          hicki@ioBroker:~$ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && apt policy nodejs
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v14.18.2
          v14.18.2
          6.14.15
          Hit:1 http://archive.ubuntu.com/ubuntu bionic InRelease
          Hit:2 https://deb.nodesource.com/node_14.x bionic InRelease
          Hit:3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
          Hit:4 http://archive.ubuntu.com/ubuntu bionic-security InRelease
          Reading package lists... Done
          Building dependency tree
          All packages are up to date.
          nodejs:
            Installed: 14.18.2-1nodesource1
            Candidate: 14.18.2-1nodesource1
            Version table:
           *** 14.18.2-1nodesource1 500
                  500 https://deb.nodesource.com/node_14.x bionic/main amd64 Packages
                  100 /var/lib/dpkg/status
               8.10.0~dfsg-2ubuntu0.4 500
                  500 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
               8.10.0~dfsg-2ubuntu0.2 500
                  500 http://archive.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
               8.10.0~dfsg-2 500
                  500 http://archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
          hicki@ioBroker:~$
            @hicki
            Das sieht gut aus.
            Ich hatte oben noch
            ergänzt. Das solltest du noch machen.
              @thomas-braun sagte in gelöst - Nach Update - nur iobroker-Logo sichtbar:
              @hicki
              Das sieht gut aus.
              Ich hatte oben noch
              erledigt
                @hicki
                Gut, dann sind wir fertig.
                Wenn dir langweilig ist:
                  Wie mache ich das? Und vielen Dank für alles.
                  Meister Mopper Thomas Braun 3 Replies Last reply Reply Quote 0
                  • Meister Mopper
                    Meister Mopper @Hicki last edited by Meister Mopper
                    @hicki
                    Distribution update:
                    sudo apt-get update && sudo apt-get dist-upgrade -y && sudo do-release-upgrade
                    Ergänzung: Ein backup wäre vorher ratsam
                      @hicki
                      Das ist ein Upgrade auf die Version 20.04.3.
                      Das würde ich an deiner Stelle aber mal in Ruhe machen. Dein Bionic 18.04 wird ja noch bis April 2023 unterstützt, da hast du noch etwas Zeit.
                        @hicki
                        Läuft der ioBroker?
                        Da dürften vermutlich auch die Rechte z.T. noch krumm sein.
                        iobroker stop
                        iobroker fix
                        iobroker start
                        repariert auch das noch.
                          @hicki
                          Läuft der ioBroker?
                          iobroker stop
                          iobroker fix
                          iobroker start
                          Vielen Dank und erledigt
                          nur iobroker logo sichtbar
                          2174
