    4. Test Coronavirus Statistics for ioBroker
      jlssmt @ChrisNett last edited by
      @christian-sandkaulen
      instanz reiter. admin/entwicklermodus aktivieren
      adapter anklicken
      von info auf debug switchen.
      • ChrisNett
        @jlssmt
        danke
        coronavirus-statistics.0
        2021-11-22 18:30:38.131	debug	Data from COVID-19 API received : [object Object]
        2021-11-22 18:30:21.821	debug	Configuration object before config load : {"deleteUnused":false,"getContinents":false,"getGermanyFederalStates":true,"getGermanyCities":false,"getGermanyCounties":false,"getAllGermanyFederalStates":false,"getAllGermanyCities":false,"getAllGermanyCounties":false,"loadAllCountrys":false,"selectedGermanyFederalStates":[],"selectedGermanyCities":[],"selectedGermanyCounties":[],"countries":[]}
        2021-11-22 18:30:21.734	info	starting. Version 0.8.8-0 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.5, js-controller: 3.3.18
        2021-11-22 18:30:18.846	debug	Plugin sentry Initialize Plugin (enabled=true)
        2021-11-22 18:30:08.225	debug	statesDB connected
        2021-11-22 18:30:08.224	debug	States connected to redis: 127.0.0.1:9000
        2021-11-22 18:30:08.186	debug	States create User PubSub Client
        2021-11-22 18:30:08.182	debug	States create System PubSub Client
        2021-11-22 18:30:08.160	debug	Redis States: Use Redis connection: 127.0.0.1:9000
        2021-11-22 18:30:08.157	debug	objectDB connected
        2021-11-22 18:30:08.145	debug	Objects connected to redis: 127.0.0.1:9001
        2021-11-22 18:30:08.118	debug	Objects client initialize lua scripts
        2021-11-22 18:30:08.116	debug	Objects create User PubSub Client
        2021-11-22 18:30:08.114	debug	Objects create System PubSub Client
        2021-11-22 18:30:08.108	debug	Objects client ready ... initialize now
        2021-11-22 18:30:07.995	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
        2021-11-22 18:15:36.831	debug	Write value : false
        2021-11-22 18:15:36.830	debug	Create_state called for : global_totals.deaths with value : 5171700
        2021-11-22 18:15:36.730	debug	Write value : false
        2021-11-22 18:15:36.729	debug	Create_state called for : global_totals.todayCases with value : 268721
        2021-11-22 18:15:36.660	debug	Write value : false
        2021-11-22 18:15:36.660	debug	Create_state called for : global_totals.cases with value : 258107112
        2021-11-22 18:15:36.613	debug	Write value : false
        2021-11-22 18:15:36.611	debug	Create_state called for : global_totals.updated with value : 1637600864486
        2021-11-22 18:15:36.563	debug	Data from COVID-19 API received : [object Object]
        2021-11-22 18:15:13.866	debug	Configuration object before config load : {"deleteUnused":false,"getContinents":false,"getGermanyFederalStates":true,"getGermanyCities":false,"getGermanyCounties":false,"getAllGermanyFederalStates":false,"getAllGermanyCities":false,"getAllGermanyCounties":false,"loadAllCountrys":false,"selectedGermanyFederalStates":[],"selectedGermanyCities":[],"selectedGermanyCounties":[],"countries":[]}
        2021-11-22 18:15:13.819	info	starting. Version 0.8.8-0 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.5, js-controller: 3.3.18
        2021-11-22 18:15:13.406	debug	Plugin sentry Initialize Plugin (enabled=true)
        2021-11-22 18:15:12.645	debug	statesDB connected
        2021-11-22 18:15:12.643	debug	States connected to redis: 127.0.0.1:9000
        2021-11-22 18:15:12.601	debug	States create User PubSub Client
        2021-11-22 18:15:12.599	debug	States create System PubSub Client
        2021-11-22 18:15:12.577	debug	Redis States: Use Redis connection: 127.0.0.1:9000
        2021-11-22 18:15:12.574	debug	objectDB connected
        2021-11-22 18:15:12.562	debug	Objects connected to redis: 127.0.0.1:9001
        2021-11-22 18:15:12.485	debug	Objects client initialize lua scripts
        2021-11-22 18:15:12.483	debug	Objects create User PubSub Client
        2021-11-22 18:15:12.480	debug	Objects create System PubSub Client
        2021-11-22 18:15:12.475	debug	Objects client ready ... initialize now
        2021-11-22 18:15:12.397	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
        jetzt habe ich noch mal alle instanzen gelöscht und neu installiert... jetzt komme ich nicht mal in die config rein...
        ChrisNett 1 Reply Last reply Reply Quote 0
        • ChrisNett
          ChrisNett @ChrisNett last edited by
          moin,
          habe noch mal alles gelöscht und dann erst die 0.8.7 installier und dann über den link die 0.8.8.
          coronavirus-statistics.0	2021-11-23 08:10:28.611	debug	(13076) Write value : false
          coronavirus-statistics.0	2021-11-23 08:10:28.610	debug	(13076) Create_state called for : global_totals.tests with value : 4217355433
          coronavirus-statistics.0	2021-11-23 08:10:28.490	debug	(13076) Write value : false
          coronavirus-statistics.0	2021-11-23 08:10:28.489	debug	(13076) Create_state called for : global_totals.deathsPerOneMillion with value : 664
          coronavirus-statistics.0	2021-11-23 08:10:28.370	debug	(13076) Write value : false
          coronavirus-statistics.0	2021-11-23 08:10:28.370	debug	(13076) Create_state called for : global_totals.casesPerOneMillion with value : 33159
          coronavirus-statistics.0	2021-11-23 08:10:28.333	debug	(13076) Write value : false
          coronavirus-statistics.0	2021-11-23 08:10:28.332	debug	(13076) Create_state called for : global_totals.critical with value : 80585
          coronavirus-statistics.0	2021-11-23 08:10:28.277	debug	(13076) Write value : false
          coronavirus-statistics.0	2021-11-23 08:10:28.276	debug	(13076) Create_state called for : global_totals.active with value : 19347150
          coronavirus-statistics.0	2021-11-23 08:10:28.217	debug	(13076) Write value : false
          coronavirus-statistics.0	2021-11-23 08:10:28.216	debug	(13076) Create_state called for : global_totals.todayRecovered with value : 91155
          coronavirus-statistics.0	2021-11-23 08:10:27.755	debug	(13076) Write value : false
          coronavirus-statistics.0	2021-11-23 08:10:27.754	debug	(13076) Create_state called for : global_totals.recovered with value : 233946445
          coronavirus-statistics.0	2021-11-23 08:10:27.677	debug	(13076) Write value : false
          coronavirus-statistics.0	2021-11-23 08:10:27.676	debug	(13076) Create_state called for : global_totals.todayDeaths with value : 1078
          coronavirus-statistics.0	2021-11-23 08:10:27.614	debug	(13076) Write value : false
          coronavirus-statistics.0	2021-11-23 08:10:27.613	debug	(13076) Create_state called for : global_totals.deaths with value : 5175770
          coronavirus-statistics.0	2021-11-23 08:10:27.580	debug	(13076) Write value : false
          coronavirus-statistics.0	2021-11-23 08:10:27.578	debug	(13076) Create_state called for : global_totals.todayCases with value : 59461
          coronavirus-statistics.0	2021-11-23 08:10:27.372	debug	(13076) Write value : false
          coronavirus-statistics.0	2021-11-23 08:10:27.370	debug	(13076) Create_state called for : global_totals.cases with value : 258469365
          coronavirus-statistics.0	2021-11-23 08:10:27.253	debug	(13076) Write value : false
          coronavirus-statistics.0	2021-11-23 08:10:27.251	debug	(13076) Create_state called for : global_totals.updated with value : 1637650667675
          coronavirus-statistics.0	2021-11-23 08:10:27.191	debug	(13076) Data from COVID-19 API received : [object Object]
          coronavirus-statistics.0	2021-11-23 08:10:09.321	debug	(13076) Configuration object before config load : {"deleteUnused":false,"getContinents":false,"getGermanyFederalStates":true,"getGermanyCities":false,"getGermanyCounties":true,"getAllGermanyFederalSt
          coronavirus-statistics.0	2021-11-23 08:10:09.249	info	(13076) starting. Version 0.8.8-0 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.5, js-controller: 3.3.18
          der scheint jetzt zu laufen, aber ich habe keinen Index ..
          worann könnte es liegen?
          blue231181 1 Reply Last reply Reply Quote 0
          • blue231181
            blue231181 @ChrisNett last edited by
            @christian-sandkaulen warte mal ab... bei mir dauerte es über das Wochenende und nun habe ich die Werte ohne weiteres zutun.
            @jlssmt leider wird die Hospitalisierungs-Inzidenz nicht aktualisiert (laut Screenshot) Hier könnte ich mir allerdings vorstellen das es daran liegt das es keinen Timestamp dafür gibt...? (als Laie, nicht hauen)
              jlssmt @blue231181 last edited by
              @blue231181
              Was meinst du mit timestamp?
              iobroker vergibt je state einen internen Timestamp und das Datum ist in deinem Screenshot unten doch auch?
              Ganz ehrlich. Ich hab keine Ahnung warum es bei euch teilweise nicht funktioniert. Ich hab es produktiv am Laufen und da funktioniert es tadellos. Habe auch die Daten für heute. Es ist auch nahezu die selbe Logik wie für die Vaccination und Hospital Ordner/ Channel.
              Ich warte mal auf @Dutchman. Vllt weiß der was...
              • N
                nousefor82 last edited by
                @jlssmt :
                Servus,
                wäre es möglich über diese Seite
                [https://krankenhausampel.info/](Link Adresse)
                die Datenpunkte für die Krankenhausampel abzugreifen und in den Adapter zu übernehmen?
                Viele Grüße!
                • Dutchman
                  Dutchman Developer Most Active Administrators @jlssmt last edited by
                  @jlssmt sagte in Test Coronavirus Statistics for ioBroker:
                  @blue231181
                  🤔 erhole mich gerade von ner ziemlich starken Erkältung schaue so schnell wie möglich
                  Latzi 1 Reply Last reply Reply Quote 2
                  • Latzi
                    Latzi @Dutchman last edited by
                    @dutchman sagte in Test Coronavirus Statistics for ioBroker:
                    Gute Besserung !!!
                    ChrisNett 1 Reply Last reply Reply Quote 2
                    • ChrisNett
                      ChrisNett @Latzi last edited by
                      gute Besserung!
                      host.PI4	2021-11-25 09:48:33.861	info	stopInstance canceled schedule system.adapter.coronavirus-statistics.0
                      host.PI4	2021-11-25 09:48:33.860	info	stopInstance system.adapter.coronavirus-statistics.0 (force=false, process=false)
                      host.PI4	2021-11-25 09:48:26.841	warn	instance system.adapter.coronavirus-statistics.0 terminated due to SIGKILL
                      coronavirus-statistics.0	2021-11-25 09:47:48.892	info	(31947) starting. Version 0.8.8-0 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.5, js-controller: 3.3.18
                      host.PI4	2021-11-25 09:47:44.660	info	instance system.adapter.coronavirus-statistics.0 started with pid 31947
                      host.PI4	2021-11-25 09:47:44.600	info	instance scheduled system.adapter.coronavirus-statistics.0 */15 * * * *
                      host.PI4	2021-11-25 09:47:41.396	info	stopInstance canceled schedule system.adapter.coronavirus-statistics.0
                      host.PI4	2021-11-25 09:47:41.386	info	stopInstance system.adapter.coronavirus-statistics.0 (force=false, process=false)
                      host.PI4	2021-11-25 09:45:12.773	warn	instance system.adapter.coronavirus-statistics.0 terminated due to SIGKILL
                      host.PI4	2021-11-25 09:45:00.104	warn	instance system.adapter.coronavirus-statistics.0 already running with pid 30702
                      coronavirus-statistics.0	2021-11-25 09:44:36.612	info	(30702) starting. Version 0.8.8-0 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.5, js-controller: 3.3.18
                      coronavirus-statistics.0	2021-11-25 09:50:22.921	debug	(32672) Plugin sentry Initialize Plugin (enabled=true)
                      coronavirus-statistics.0	2021-11-25 09:50:21.360	debug	(32672) statesDB connected
                      coronavirus-statistics.0	2021-11-25 09:50:21.358	debug	(32672) States connected to redis: 127.0.0.1:9000
                      coronavirus-statistics.0	2021-11-25 09:50:21.323	debug	(32672) States create User PubSub Client
                      coronavirus-statistics.0	2021-11-25 09:50:21.321	debug	(32672) States create System PubSub Client
                      coronavirus-statistics.0	2021-11-25 09:50:21.294	debug	(32672) Redis States: Use Redis connection: 127.0.0.1:9000
                      coronavirus-statistics.0	2021-11-25 09:50:21.291	debug	(32672) objectDB connected
                      coronavirus-statistics.0	2021-11-25 09:50:21.278	debug	(32672) Objects connected to redis: 127.0.0.1:9001
                      coronavirus-statistics.0	2021-11-25 09:50:21.219	debug	(32672) Objects client initialize lua scripts
                      coronavirus-statistics.0	2021-11-25 09:50:21.216	debug	(32672) Objects create User PubSub Client
                      coronavirus-statistics.0	2021-11-25 09:50:21.214	debug	(32672) Objects create System PubSub Client
                      coronavirus-statistics.0	2021-11-25 09:50:20.814	debug	(32672) Objects client ready ... initialize now
                      coronavirus-statistics.0	2021-11-25 09:50:20.492	debug	(32672) Redis Objects: Use Redis connection: 127.0.0.1:9001
                      coronavirus-statistics.0	2021-11-25 09:49:12.488	debug	(32220) Write value : false
                      coronavirus-statistics.0	2021-11-25 09:49:12.476	debug	(32220) Create_state called for : global_totals.cases with value : 259822223
                      coronavirus-statistics.0	2021-11-25 09:49:12.420	debug	(32220) Write value : false
                      coronavirus-statistics.0	2021-11-25 09:49:12.419	debug	(32220) Create_state called for : global_totals.updated with value : 1637829494275
                      coronavirus-statistics.0	2021-11-25 09:49:12.365	debug	(32220) Data from COVID-19 API received : [object Object]
                      coronavirus-statistics.0	2021-11-25 09:48:44.279	debug	(32220) Configuration object before config load : {"deleteUnused":false,"getContinents":false,"getGermanyFederalStates":false,"getGermanyCities":false,"getGermanyCounties":false,"getAllGermanyFederal
                      coronavirus-statistics.0	2021-11-25 09:48:44.218	info	(32220) starting. Version 0.8.8-0 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.5, js-controller: 3.3.18
                      mal mein log
                        JuergenB last edited by JuergenB
                        nach mehreren Anläufen, bekomme ich in der Version 0.8.8. auch die Hospitalisierungsraten angezeigt. Vielen Dank für den Service!!!
                        Jedoch bleibt für Niedersachsen ein Problem: Die relevante Hospitalisierungsrate sind nicht die Werte des RKI, sondern wird seitens des Landes Niedersachsen gesondert berechnet. So beträgt diese 7,3 anstatt der RKI Zahl 2,5. Gibt es eine Möglichkeit, dies in dem Adapter zu berücksichtigen?
                          RMortan last edited by
                          Hallo ich bekomme immer dieses "Fehler"/Warn angeziegt kann mir einer weiter helfen...
                          es sieht auch si aus als würden sich die zahlen nicht wirklich mehr updaten.
                          mfg
                          instance system.adapter.coronavirus-statistics.0 already running with pid 6886
                          • O
                            obakuhl Developer @RMortan last edited by
                            @rmortan Es scheint schon ein Prozess zu laufen. Stoppe die Instanz im ioBroker und dann am besten den betroffenen Prozess killen.
                            Dazu folgendes über die Kommandozeile machen:
                            ps auxww|grep io
                            Dadurch werde alle relevanten ioBroker Prozesse aufgelistet. Dort sollte dann der betroffene Prozess mit der ID 6886 auftauchen.
                            Mit
                            kill -9 6886
                            sollte das Problem gelöst sein.
                              RMortan @obakuhl last edited by
                              @obakuhl
                              hey ich bekomme da im Putty dann die Antwort diese Operation ist nicht erlaubt.
                                jlssmt @RMortan last edited by
                                @rmortan
                                sudo davor?
                                Ansonsten System schon mal neugestartet?
                                  RMortan @jlssmt last edited by
                                  @jlssmt
                                  danke für das Zaunfeld... 😁
                                  na mal sehen wie lange es jetzt läuft ohne diese Fehler Meldung
                                  grüße
                                  • ChrisNett
                                    ChrisNett @RMortan last edited by
                                    ich bin bestimmt blind aber wo sehe ich in den Objekten die t tage inzidenz Deutschland ? Hatte das bis jetzt immer nur für meinen Landkreis ausgewertet...
                                      Ist glaube ich nicht drin, da die Länderdaten von der JHU kommen und die JHU die 7-Tage inzidenz nicht ausgibt. Die 7tage inzidenz interessiert global auch keinen, bzw. wird nicht ausgewertet.
                                      • ChrisNett
                                        ChrisNett @jlssmt last edited by
                                        mich ja auch nicht... aber die tageschau schon 🙂
                                          jlssmt @ChrisNett last edited by jlssmt
                                          Ja gut. Wenn sie dich nicht interessiert, keine Maßnahmen auf Basis dieser Zahl entschieden werden und Gesundheitsexperten diese Zahl als nicht aussagekräftig für den Pandemiestatus sehen, dann kann sie ja draußen bleiben. Weil mich interessiert sie auch nicht 😉
                                          • ChrisNett
                                            @jlssmt
                                            war mehr eine anfrage der Chefin...
                                            adapter installation adapterentwicklung testen
                                            120
                                            1177
                                            328811
