    4. Zigbee startet nicht mehr
    • David G.
      David G. @Thomas Braun last edited by David G.
      @thomas-braun sagte in Zigbee startet nicht mehr:
      @david-g
      iobroker add zigbee
      liefert?
      pi@iobroker:~ $ iobroker add zigbee
      NPM version: 6.14.15
      npm install iobroker.zigbee@1.5.6 --loglevel error --prefix "/opt/iobroker" (System call)
      Traceback (most recent call last):
        File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py", line 47, in <module>
          import gyp
        File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 10, in <module>
          import gyp.input
        File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 7, in <module>
          import ast
      ImportError: No module named ast
      gyp ERR! configure error
      gyp ERR! stack Error: `gyp` failed with exit code: 1
      gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
      gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)
      gyp ERR! System Linux 5.10.63-v7l+
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings
      gyp ERR! node -v v14.18.2
      gyp ERR! node-gyp -v v5.1.0
      gyp ERR! not ok
          import gyp
          import gyp.input
          import ast
      gyp ERR! cwd /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@serialport/bindings
      gyp ERR! not ok
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! @serialport/bindings@9.0.4 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the @serialport/bindings@9.0.4 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /home/iobroker/.npm/_logs/2021-12-01T20_54_28_658Z-debug.log
      host.iobroker Cannot install iobroker.zigbee@1.5.6: 1
      pi@iobroker:~ $
      Anbei das erwähnte log aus Zeile 51.
        Thomas Braun Most Active @David G. last edited by
        @david-g
        Mach den Cache mal leer:
        cd /opt/iobroker
        npm cache clean --force
        • David G.
          Leider nichts
          pi@iobroker:~ $ cd /opt/iobroker
          pi@iobroker:/opt/iobroker $ npm cache clean --force      npm WARN using --force I sure hope you know what you are doing.
          pi@iobroker:/opt/iobroker $ iobroker add zigbee
              import gyp
              import gyp.input
              import ast
          gyp ERR! not ok
              import gyp
              import gyp.input
              import ast
          gyp ERR! not ok
          npm ERR! errno 1
          npm ERR!
          npm ERR!     /home/iobroker/.npm/_logs/2021-12-01T21_26_11_036Z-debug.log
          Auch ein
          npm rebuild
          hat nichts gebracht.
            @david-g
            cd /opt/iobroker
            npm ls
            • David G.
              Sprengt leider, was ich hier posten darf.
              Hab es als txt angegangen.
              npm ls.txt
                @david-g
                Da stimmt was mit irgendeinem vis-Zeug nicht.
                Mir fällt aber nix mehr dazu ein. Außer ZigBee komplett rauswerfen und nach einem Neustart noch mal ins System ziehen.
                • David G.
                  Okay,
                  danke für deine Unterstützung.
                  Zigbee hatte ich schonmal komplett runter geworfen (Instanz gelöscht und Adapter über den Papierkorb gelöscht).
                  Ggf werde ich am Wochenende das System neu aufsetzen.
                  Mal sehen, ob ich sql und nut wieder konfiguriert bekomme. Da hatte ich was Probleme mit 😅
                  EDIT:
                  Das System läuft jetzt wieder.
                  Mache ca alle 3 Monate ein Image auf eine SD-Karte.
                  Hab ich zurück auf meine SSD gespielt und das Backup durchlaufen lassen.
                  Hätte den Fehler zwar gerne gefunden, auch um zu sehen woran es nun lag, jedoch war es mir jetzt wichtiger, dass das System wieder läuft.
                    Philipp.Schlegel @arteck last edited by
                    @arteck
                    Hi, tatsächlich trifft mich dasselbe Problem. Der FI flog raus, sofortiger Shutdown, nach Neustart startet der Adapter nicht mehr vollständig. LOG sieht für mich ebenso nach fehlerhaftem Serialport aus:
                    zigbee.0	2021-12-02 08:04:51.703	error	Error herdsman start
                    zigbee.0	2021-12-02 08:04:51.702	error	Failed to start Zigbee
                    zigbee.0	2021-12-02 08:04:51.702	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                    zigbee.0	2021-12-02 08:04:51.465	info	Installed Version: ioBroker/ioBroker.zigbee#5149bcb2392471287f6a60f855ffe690d74da714
                    zigbee.0	2021-12-02 08:04:51.419	info	Starting Zigbee npm ...
                    zigbee.0	2021-12-02 08:04:51.417	info	Try to reconnect. 1 attempts left
                    zigbee.0	2021-12-02 08:04:41.415	error	Error herdsman start
                    zigbee.0	2021-12-02 08:04:41.414	error	Failed to start Zigbee
                    zigbee.0	2021-12-02 08:04:41.413	error	Starting zigbee-herdsman problem : "network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby"
                    host.RaspberryPi4IoBroker-Main
                    zigbee.0	2021-12-02 08:04:25.504	info	instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    zigbee.0	2021-12-02 08:03:36.377	info	Installed Version: ioBroker/ioBroker.zigbee#5149bcb2392471287f6a60f855ffe690d74da714
                    zigbee.0	2021-12-02 08:03:35.829	info	Starting Zigbee npm ...
                    zigbee.0	2021-12-02 08:03:35.664	info	starting. Version 1.6.7 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.18.2, js-controller: 3.3.21
                    zigbee.0	2021-12-02 08:03:35.632	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                    An Deine beschriebenen Schritte des Löschens von iobroker.zigbee/serialport/@serialport/zigbee-herdsman-converters/zigbee-herdsman sowie Neuinstallation von GitHub habe ich schon versucht. Das Ergebnis ist immer analog dem Fehlerbild oben.
                    Hat noch jemand eine Idee?
                    Danke und beste Grüße!
                    Phil
                      Thomas Braun Most Active last edited by
                      @philipp-schlegel
                      Setz die beiden Werte mal neu.
                        Philipp.Schlegel @Thomas Braun last edited by
                        Damit komme ich zu einer noch ausgiebigeren Fehlermeldung...
                        zigbee.0	2021-12-02 08:35:17.255	error	Error herdsman start
                        zigbee.0	2021-12-02 08:35:17.254	error	Failed to start Zigbee
                        zigbee.0	2021-12-02 08:35:17.253	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                        zigbee.0	2021-12-02 08:35:17.084	info	Installed Version: ioBroker/ioBroker.zigbee#5149bcb2392471287f6a60f855ffe690d74da714
                        zigbee.0	2021-12-02 08:35:17.063	info	Starting Zigbee npm ...
                        zigbee.0	2021-12-02 08:35:17.062	info	Try to reconnect. 1 attempts left
                        zigbee.0	2021-12-02 08:35:07.060	error	Error herdsman start
                        zigbee.0	2021-12-02 08:35:07.060	error	Failed to start Zigbee
                        zigbee.0	2021-12-02 08:35:07.059	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                        zigbee.0	2021-12-02 08:35:07.057	error	Re-commissioning your network will require re-pairing of all devices!
                        zigbee.0	2021-12-02 08:35:07.056	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                        zigbee.0	2021-12-02 08:35:07.056	error	Please update configuration to prevent further issues.
                        zigbee.0	2021-12-02 08:35:07.055	error	- Channel List: configured=11, adapter=11
                        zigbee.0	2021-12-02 08:35:07.054	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                        zigbee.0	2021-12-02 08:35:07.053	error	- Extended PAN ID: configured=adcaccbdcdddddda, adapter=00124b00219fb99b
                        zigbee.0	2021-12-02 08:35:07.052	error	- PAN ID: configured=601, adapter=601
                        zigbee.0	2021-12-02 08:35:07.051	error	Configuration is not consistent with adapter state/backup!
                          Thomas Braun Most Active @Philipp.Schlegel last edited by
                          @philipp-schlegel
                          Das muss übereinstimmen.
                          Und ich würde den Adapter nicht als git-Version betreiben.
                            arteck Developer Most Active @Thomas Braun last edited by arteck
                            git-Versionen sind nie produktiv.
                            wobei bei Zigbee ist es bissel anders..
                            da sind die release Zeiten bissel anders
                            wir sehen zu dass es immer funktioniert..
                              @thomas-braun TOP! Tausend Dank. Daran hing es tatsächlich.
                              1333
