      Fortune95 @simatec last edited by
      @simatec
      Installiert ist die neuste v1.4.1.
      Reicht das so oder benötigst du die gesamte Config als Export?
      2021-12-01 17:43:21.270 - info: shuttercontrol.0 (11888) Button openLiving Set ID: Büro value: 0%
      2021-12-01 17:43:21.304 - debug: shuttercontrol.0 (11888) shutterUpButton Büro old height: 100% new height: 0%
      2021-12-01 17:43:27.286 - debug: shuttercontrol.0 (11888) start buttonAction
      2021-12-01 17:43:27.296 - debug: shuttercontrol.0 (11888) shutterUpButton Büro already up at: 0% - setting current action: up
      2021-12-01 17:43:52.354 - debug: shuttercontrol.0 (11888) TriggerID changed: alias.0.Büro.Fensterkontakt_Buero.ACTUAL Value: 1
      2021-12-01 17:43:52.358 - debug: shuttercontrol.0 (11888) Büro - shutter conversion is:true
      2021-12-01 17:43:52.372 - debug: shuttercontrol.0 (11888) Büro - shutter trigger drive-up is:70
      2021-12-01 17:43:52.373 - debug: shuttercontrol.0 (11888) Büro - shutter trigger change is:upDown
      2021-12-01 17:43:52.374 - debug: shuttercontrol.0 (11888) #2 save trigger action: up for device: Büro
      2021-12-01 17:43:52.375 - debug: shuttercontrol.0 (11888) #2 save trigger height: 0% for device: Büro
      2021-12-01 17:45:00.050 - debug: shuttercontrol.0 (11888) check in time 01.03. 30.09.
      2021-12-01 17:45:00.052 - debug: shuttercontrol.0 (11888) Start Mon Mar 01 2021
      2021-12-01 17:45:00.053 - debug: shuttercontrol.0 (11888) End Thu Sep 30 2021
      2021-12-01 17:45:00.053 - debug: shuttercontrol.0 (11888) we are not in period, after start Mon Mar 01 2021 and before end Thu Sep 30 2021
      2021-12-01 17:45:00.055 - debug: shuttercontrol.0 (11888) check xmas for Büro
      2021-12-01 17:45:00.101 - debug: shuttercontrol.0 (11888) calculate astrodata ...
      2021-12-01 17:45:00.102 - debug: shuttercontrol.0 (11888) Sun Azimut: 249°
      2021-12-01 17:45:00.102 - debug: shuttercontrol.0 (11888) Sun Elevation: -11.2°
      2021-12-01 17:45:00.119 - info: shuttercontrol.0 (11888) Living down #17 Set ID: Büro value: 100%
      2021-12-01 17:45:00.135 - debug: shuttercontrol.0 (11888) last automatic Action for Büro: Down_LivingTime
      2021-12-01 17:45:00.136 - debug: shuttercontrol.0 (11888) shutterDownLiving #1 Büro old height: 0% new height: 100%
      2021-12-01 17:45:44.823 - debug: shuttercontrol.0 (11888) TriggerID changed: alias.0.Büro.Fensterkontakt_Buero.ACTUAL Value: 0
      2021-12-01 17:45:44.825 - debug: shuttercontrol.0 (11888) Büro - shutter conversion is:true
      2021-12-01 17:45:44.833 - debug: shuttercontrol.0 (11888) Büro - shutter current state.val is:100
      2021-12-01 17:45:44.834 - debug: shuttercontrol.0 (11888) Büro - shutter current Height is:100
      2021-12-01 17:45:44.834 - debug: shuttercontrol.0 (11888) Büro - shutter trigger Height is:0
      2021-12-01 17:45:44.835 - debug: shuttercontrol.0 (11888) Büro - shutter trigger Action is:up
      2021-12-01 17:45:44.835 - debug: shuttercontrol.0 (11888) Büro - shutter trigger Change is:upDown
      2021-12-01 17:45:44.840 - info: shuttercontrol.0 (11888) Window is still closed -> drive to last height: Set ID: Büro value: 0%
      2021-12-01 17:45:44.853 - debug: shuttercontrol.0 (11888) save back trigger action: up for device: Büro
      • simatec
        simatec Developer Most Active @Fortune95 last edited by
        @fortune95 danke dir … Ich schaue mir das mal an
        • simatec
          @fortune95 Kannst du bitte Schritt für Schritt erklären, was wann bei dir passiert? Ich kann dein Fehler aktuell so nicht nachstellen und nachvollziehen.
          • Nightfly1983
            Nightfly1983 last edited by
            Habe gestern mit der Version 1.4.1 nochmal die Weihnachtseinstellungen probiert und mich gefreut wie ein Schnitzel, denn alle Rollläden sind bei den entsprechenden Fenstern auf ihre Weihnachtsposition gefahren. Jedoch kam die Ernüchterung heute Morgen, denn 23Uhr sind die entsprechenden Rollläden dann leider nicht komplett wie eingestellt zu gefahren.
            Werde es nochmal im Debug anschauen und berichten, evtl. fehlte eine Einstellung.
            B simatec 2 Replies Last reply Reply Quote 0
              biker1602 @Nightfly1983 last edited by
              @nightfly1983 Also bei mir funktioniert das tadellos. Sie fahren bei Sonnenuntergang auf 50% runter und so wie ich es eingestellt habe um 23 Uhr ganz runter. Ich bin begeistert. Das ging aber auch schon davor bei mir.
                Tom Haase last edited by
                möchte auch eine kurze Rückmeldung geben.
                Habe von der V. 1.1.5 auf die 1.38 jetzt 1.41 updatet. Ich hatte damals (im Januar ´21, siehe oben) Probleme mit den Fensterkontakten. Diese Probleme konnte @FoxRo lösen und die Lösung ist dann später in den Code mit eingeflossen. Die Steuerung funktionierte bis zum Update in der letzten Woche einwandfrei!
                Nach dem Update fahren plötzlich nicht mehr alle Rolläden, also auch solche ohne Fensterkontakte. Und die mit den Kontakten funktionieren auch nicht mehr beim öffnen und schließen wie bisher.
                Habe gegenwärtig leider überhaupt nicht die Zeit hier mehr zu liefern, also wichtige Logs und Debugs.... Ich möchte nur kurze Rückmeldung geben, dass die aktuelle Version wohl noch nicht rund läuft. Möchte aber auch sagen, dass ich mit Shuttercontrol bisher sehr zufrieden bin.
                Danke @simatec für deine Arbeit.
                lg
                tom
                  @simatec
                  Heute Morgen hat alles funktioniert! 🙂
                  • simatec
                    simatec Developer Most Active @Tom Haase last edited by
                    @tom-haase Hast du nach dem Update die Einstellungen der Rollläden angepasst? Hier sollten die Kippfunktionen der Fensterkontakte auch konfiguriert werden. Wenn du keine hast, dann auf "keins" stellen
                    • simatec
                      simatec Developer Most Active @Nightfly1983 last edited by
                      @nightfly1983 Wie sehen deinen Einstellungen denn aus und welche Version ist installiert?
                      Nightfly1983 1 Reply Last reply Reply Quote 0
                      • Nightfly1983
                        Nightfly1983 @simatec last edited by
                        @simatec Version ist seit gestern 1.4.1
                        Einstellungen würde ich heute Nachmittag mal reinstellen und nochmal kontrollieren, nicht dass durch das Update was deaktiviert wurde.
                        • simatec
                          Ab sofort steht die Version 1.4.2 auf Github und in kürze auch im latest zur Verfügung.
                          Changelog
                          1.4.2 (2021-12-02)
                          • (simatec) Bugfix Alarm settings
                          • (simatec) Bugfix move shutter after closing window
                          • (simatec) better translation for all languages
                          • (simatec) small Bugfixes
                          • amg_666
                            amg_666 @simatec last edited by
                            @simatec die 1.4.2 habe ich erfolgreich installiert, sieht gut aus und der von @BanditFG beschriebene Bug, dass Settings in den Alarmeinstellungen nihct gespeichert werden ist weg, zumindest bei mir behält er jetzt die neu eingetragenen Werte
                            • simatec
                              simatec Developer Most Active @amg_666 last edited by
                              @amg_666 Danke für dein Feedback
                              • Nightfly1983
                                Hab die Version 1.4.2 installiert und geb jetzt erstmal auf 😩
                                Rollläden sind nicht in die Weihnachtsposition gefahren, okay woohoo Frost Alarm hat geklappt. Aber sobald ich bei einem Fenster das Fahren beim Öffnen mache startet der Adapter neu und nix geht. Ich krieg ne Krise.
                                Überlege den Adapter und die Objekte zu löschen und einfach nochmal bei null zu beginnen 🤔
                                • simatec
                                  @nightfly1983 Ohne einen Debuglog und deinen Settings kann dir keiner helfen
                                  • simatec
                                    simatec Developer Most Active @Nightfly1983 last edited by simatec
                                    @nightfly1983 sagte in Test Adapter shuttercontrol v1.4.x:
                                    Gerade bei mir produktiv getestet ... Badfenster war offen und Rollladen blieb oben. Fenster geschlossen, Rollladen fährt runter.
                                    Fenster geöffnet, Rollladen geht auf .... usw.
                                      @simatec
                                      Nachdem das Fenster geschlossen wurde bei zuvor runtergefahrenen Rollladen, wurde ein Auf Befehl wieder ausgeführt:
                                      Der "old height" Wert verbleibt beim schließen des Rolladen bei 0%, dieser wird wohl beim Schließen des Fensters wieder angefahren:
                                      Könnte man den Rollladen bei geöffneten Fenster (Auto Down) direkt auf die eingestellte Position in meinem Fall auf 70% fahren?
                                      • simatec
                                        @fortune95 Ich habe da in Version 1.4.2 was gefixt. Hast du diese installiert?
                                          @simatec
                                          Du bist zu schnell! 🙂 Jetzt ist sie installiert, werde es morgen abend wieder testen...Danke für Deine Mühe!
                                            Fortune95 @Fortune95 last edited by
                                            @simatec
                                            Hi, leider besteht das Problem auch mit der Version 1.4.2
                                            Das speichern der Rolladen Höhe in den Parameter "Old height" macht doch nur Sinn wenn der Rolladen bereits unten ist.
                                            Bei der regulären AutoDown oder AutoUp fahrt müsste dieser mit der neuen Position überschrieben werden, oder?
                                            Debug "beim schließen des Fensters":
                                            Debug "AutoDown" kurz vorher:
                                            1.2k
                                            332
                                            7408
                                            10556688
