    4. Diskussion zum HowTo nodejs-Installation und upgrade
      rettroo @Thomas Braun last edited by
      @thomas-braun said in Diskussion zum HowTo nodejs-Installation und upgrade:
      sudo reboot
      Funktioniert, DANKE!
        Thomas Braun Most Active @rettroo last edited by
        @rettroo
        Gegencheck:
        which node npm &&  node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
          aaach@debian:~$ which node npm &&  node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
          /usr/bin/node
          /usr/bin/npm
          v14.18.1
          6.14.15
          OK:1 http://security.debian.org/debian-security buster/updates InRelease
          OK:2 http://deb.debian.org/debian buster InRelease
          OK:3 http://deb.debian.org/debian buster-updates InRelease
          OK:4 https://deb.nodesource.com/node_14.x buster InRelease
          Alle Pakete sind aktuell.
          nodejs:
            Installiert:           14.18.1-deb-1nodesource1
            Installationskandidat: 14.18.1-deb-1nodesource1
            Versionstabelle:
           *** 14.18.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_14.x buster/main amd64 Packages
                  100 /var/lib/dpkg/status
               10.24.0~dfsg-1~deb10u1 500
                  500 http://deb.debian.org/debian buster/main amd64 Packages
                  500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
            @rettroo
            Passt.
            • Z
              zanabria @Thomas Braun last edited by
              @thomas-braun sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
              @rettroo
              Passt.
              Mein Nodejs Update bricht mit folgdender Fehlermedlung ab:
              root@raspberrypi:/opt/iobroker# cd /opt/iobroker
              root@raspberrypi:/opt/iobroker# iobroker stop
              root@raspberrypi:/opt/iobroker# curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
              Installing the NodeSource Node.js 14.x repo...
              Populating apt-get cache...
              • apt-get update
                OK:1 http://archive.raspberrypi.org/debian buster InRelease
                OK:2 https://deb.nodesource.com/node_12.x buster InRelease
                OK:3 https://repo.z-wave.me/z-way/raspbian buster InRelease
                Holen:4 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                E: Für das Depot »http://raspbian.raspberrypi.org/raspbian buster InRelease« wurde der »Suite«-Wert von »stable« in »oldsta ble« geändert.
                N: Sie müssen dies explizit bestätigen, bevor Aktualisierungen von diesem Depot angewendet werden können. Lesen Sie die apt -secure(8)-Handbuchseite, wenn Sie weitere Informationen benötigen.
                Error executing command, exiting.
              Was läuft hier falsch?
              bahnuhr Thomas Braun 2 Replies Last reply Reply Quote 0
              • bahnuhr
                bahnuhr Forum Testing Most Active @zanabria last edited by
                @zanabria sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                apt-get update
                lass das get weg.
                also:
                apt update
                  Thomas Braun Most Active @zanabria last edited by Thomas Braun
                  Du meldest dich als root an. Das läuft falsch.
                  Und du aktualisierst dein System zu selten.
                  • Z
                    Wenn ich ohne su installieren will kommt die Meldung, der User hat keine Berechtigung zum updaten?
                      @zanabria
                      Dann ist der user nicht in der Gruppe sudo drin.
                      groups
                      liefert?
                      • Z
                        zanabria @bahnuhr last edited by
                        @bahnuhr
                        das "apt-get update" ist Teil der Updateroutine. Aufgerufen durch
                        "curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -"
                          @zanabria
                          Zuerst die user gerade rücken.
                          root abmelden.
                          Dann mit dem richtigen sudo-user das System auf Stand bringen:
                          sudo apt update
                          sudo apt full-upgrade
                          sudo reboot
                          Danach kannst du dich um nodeJS kümmern.
                          • Z
                            zanabria@raspberrypi:~ $ groups
                            es gibt
                            "users"
                            zurück
                            • Z
                              sudo apt update
                              zanabria@raspberrypi:~ $ sudo apt update
                              [sudo] Passwort für zanabria:
                              Leider darf der Benutzer zanabria »/usr/bin/apt update« als root auf raspberrypi nicht ausführen.
                              Das kommt als Fehlermeldung
                                @zanabria
                                Dann mit einem user, der es darf (z. B. der pi) (wenn es da gar keinen mehr geben sollte zur Not mit dem root)
                                sudo usermod -aG sudo zanabria
                                  es gibt
                                  "users"
                                  zurück
                                  Das ist deutlich zu wenig. Wie und warum hast du den user angelegt?
                                  • Z
                                    zanabria@raspberrypi:~ $ sudo usermod -aG sudo zanabria
                                    Leider darf der Benutzer zanabria »/usr/sbin/usermod -aG sudo zanabria« als root auf raspberrypi nicht ausführen.
                                    Das kommt zurück!!!
                                      @zanabria #
                                      Logisch.
                                      Deswegen ja auch:
                                      • Z
                                        habe immer alles nach Weisung gemacht.
                                        Beim update von Node_10 auf 12 hat alles wunderbar gefunzt.
                                          Wer hat denn die Weisung gegeben: "Du legst dir einen zusätzlichen User mit zu wenig Rechten an und hampelst dann für den Rest als root durch das System?"
                                          Das hat mit dem konkreten Upgrade von nodeJS nix zu tun, das ist grundsätzlich Mumpitz.
                                          • Z
                                            wie kann ich dem User zanabria die Rechte erweitern?
                                            nodejs
                                            91
                                            844
                                            223636
