    4. Adapter wird nicht installiert
    • ChrisNett
      ChrisNett last edited by
      Halllo,
      danke bin leider gerade erst zum testen gekommen.
      pi@PI4:~ $ iobroker update -i
      Used repository: Stable (default)
      hash changed or no sources cached => force download of new sources
      update done
      Adapter    "admin"         : 5.1.25   , installed 5.1.25
      Adapter    "alexa2"        : 3.11.2   , installed 3.11.2
      Adapter    "backitup"      : 2.2.2    , installed 2.2.2
      Adapter    "broadlink2"    : 2.1.5    , installed 2.1.5
      Adapter    "cloud"         : 4.1.0    , installed 4.1.0
      Adapter    "coronavirus-statistics": 0.8.7   , installed 0.8.7
      Adapter    "denon"         : 1.11.2   , installed 1.11.2
      Adapter    "devices"       : 1.0.9    , installed 1.0.9
      Adapter    "discovery"     : 2.7.3    , installed 2.7.3
      Adapter    "dwd"           : 2.7.7    , installed 2.7.7
      Adapter    "echarts"       : 1.0.3    , installed 1.0.3
      Adapter    "fb-checkpresence": 1.1.10  , installed 1.1.10
      Adapter    "feiertage"     : 1.0.23   , installed 1.0.23
      Adapter    "flot"          : 1.10.7   , installed 1.10.7
      Adapter    "history"       : 1.9.13   , installed 1.9.13
      Adapter    "hmip"          : 1.13.2   , installed 1.13.2
      Adapter    "hs100"         : 2.0.6    , installed 2.0.6
      Adapter    "ical"          : 1.11.4   , installed 1.11.4
      Adapter    "icons-addictive-flavour-png": 0.1.0   , installed 0.1.0
      Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
      Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
      Adapter    "info"          : 1.9.8    , installed 1.9.8
      Adapter    "iot"           : 1.8.24   , installed 1.8.24
      Adapter    "javascript"    : 5.2.13   , installed 5.2.13
      Controller "js-controller" : 3.3.21   , installed 3.3.18 [Updateable]
      Adapter    "landroid"      : 1.0.3    , installed 1.0.3
      Adapter    "logparser"     : 1.1.0    , installed 1.1.0
      Adapter    "mihome"        : 1.3.7    , installed 1.3.7
      Adapter    "mihome-vacuum" : 3.3.1    , installed 3.3.1
      Adapter    "moma"          : 1.2.9    , installed 1.2.9
      Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
      Adapter    "onvif"         : 0.4.4    , installed 0.4.4
      Adapter    "parser"        : 1.0.7    , installed 1.0.7
      Adapter    "pegelalarm"    : 1.2.3    , installed 1.2.3
      Adapter    "ping"          : 1.5.0    , installed 1.5.0
      Adapter    "pollenflug"    : 1.0.6    , installed 1.0.6
      Adapter    "radar2"        : 2.0.3    , installed 2.0.3
      Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
      Adapter    "samsung"       : 0.2.9    , installed 0.2.9
      Adapter    "seq"           : 0.2.10   , installed 0.2.10
      Adapter    "shelly"        : 4.0.7    , installed 4.0.8
      Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
      Adapter    "socketio"      : 3.1.4    , installed 3.1.4
      Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
      Adapter    "spotify-premium": 1.0.0   , installed 1.1.3
      Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
      Adapter    "telegram"      : 1.10.0   , installed 1.10.0
      Adapter    "text2command"  : 2.1.1    , installed 2.1.1
      Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
      Adapter    "trashschedule" : 1.2.0    , installed 1.2.0
      Adapter    "unifi"         : 0.5.10   , installed 0.5.10
      Adapter    "upnp"          : 1.0.19   , installed 1.0.19
      Adapter    "vis"           : 1.4.5    , installed 1.4.5
      Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
      Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
      Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
      Adapter    "vis-inventwo"  : 3.2.0    , installed 3.2.0
      Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
      Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
      Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
      Adapter    "web"           : 3.4.9    , installed 3.4.9
      Adapter    "wifilight"     : 1.1.0    , installed 1.1.0
      Adapter    "worx"          : 1.5.5    , installed 1.5.5
      Adapter    "zigbee"        : 1.5.6    , installed 1.5.6
      • Glasfaser
        Glasfaser @ChrisNett last edited by
        @christian-sandkaulen sagte in Adapter wird nicht installiert:
        ist doch da ...
        ChrisNett 1 Reply Last reply Reply Quote 0
        • ChrisNett
          ChrisNett @Glasfaser last edited by
          @glasfaser
          Ja aber ich sehe ihn noch bei den Instanzen
          ChrisNett crunchip 2 Replies Last reply Reply Quote 0
          • ChrisNett
            ChrisNett @ChrisNett last edited by
            Shift Reload habe ich gemacht auf dem handy im edge und chrome sehe ich den nicht
              crunchip Forum Testing Most Active @ChrisNett last edited by
              @christian-sandkaulen ist denn überhaupt eine Instanz installiert?
              • ChrisNett
                ChrisNett @crunchip last edited by
                @crunchip sagte in Adapter wird nicht installiert:
                ohh wie meinst du das? ich habe den über den adapter instaliert Expertenmodus und dann diese version die 0.8.8. lief gar nicht...
                  @christian-sandkaulen da muss ne 1 stehen, wenn nicht, rechts auf das +
                  • ChrisNett
                    @crunchip
                    okay damit habe ich den jetzt wieder drinn,... aber genau das hatte ich eigentlich schon gemacht... mal sehen ob er jetzt wieder die Updates macht.
                      dann müsste dort ne 2 stehen
                      Bei Adapter, die manuell per Git und nicht per iobroker installiert werden, muss manuell eine Instanz hinzugefügt werden
                      • ChrisNett
                        @crunchip
                        Ich habe "nur" eine Instanz 0
                        434
