    4. [HowTo] InfluxDB 2.1 auf Debian 11 (proxmox CT) installieren
      ftd @lobomau last edited by
      @lobomau zu 4) 2.1.1 ist aktuell .... https://portal.influxdata.com/downloads/
      lobomau 2 Replies Last reply Reply Quote 0
      • lobomau
        lobomau @ftd last edited by
        @ftd ja, stimmt. hab ich von gehört. Das wäre tatsächlich auch noch eine Möglichkeit. Teste ich mal zwischendurch.
          Homoran Global Moderator Administrators @lobomau last edited by
          @lobomau hab's jetzt die no-subscription license nicht gefunden, oder braucht es die bei Proxmox v7 nicht mehr?
          lobomau 1 Reply Last reply Reply Quote 0
          • lobomau
            lobomau @Homoran last edited by
            @homoran also... direkt "apt install influxdb" ging auch. Dann ist erstmal nur 1.6.7. installiert. 1.8.10 ist aber die aktuellste 1.8.
            InfluxDBian login: root
            Password:
            Linux InfluxDBian 5.13.19-1-pve #1 SMP PVE 5.13.19-3 (Tue, 23 Nov 2021 13:31:19 +0100) x86_64
            The programs included with the Debian GNU/Linux system are free software;
            the exact distribution terms for each program are described in the
            individual files in /usr/share/doc/*/copyright.
            Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
            permitted by applicable law.
            Last login: Fri Dec  3 10:39:39 CET 2021 on tty1
            root@InfluxDBian:~# apt install influxdb
            Reading package lists... Done
            Building dependency tree... Done
            The following NEW packages will be installed:
              influxdb
            0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
            Need to get 5010 kB of archives.
            After this operation, 19.0 MB of additional disk space will be used.
            Get:1 http://ftp.debian.org/debian bullseye/main amd64 influxdb amd64 1.6.7~rc0-1+b5 [5010 kB]
            Fetched 5010 kB in 0s (10.2 MB/s)
            Selecting previously unselected package influxdb.
            (Reading database ... 20396 files and directories currently installed.)
            Preparing to unpack .../influxdb_1.6.7~rc0-1+b5_amd64.deb ...
            Unpacking influxdb (1.6.7~rc0-1+b5) ...
            Setting up influxdb (1.6.7~rc0-1+b5) ...
            Adding system user `influxdb' (UID 107) ...
            Adding new user `influxdb' (UID 107) with group `nogroup' ...
            Not creating home directory `/var/lib/influxdb'.
            Adding group `influxdb' (GID 115) ...
            Done.
            Adding user `influxdb' to group `influxdb' ...
            Adding user influxdb to group influxdb
            Done.
            Created symlink /etc/systemd/system/influxd.service -> /lib/systemd/system/influxdb.service.
            Created symlink /etc/systemd/system/multi-user.target.wants/influxdb.service -> /lib/systemd/system/influxdb.service.
            Processing triggers for man-db (2.9.4-2) ...
            root@InfluxDBian:~# influx
            -bash: influx: command not found
            root@InfluxDBian:~# influxd
             8888888           .d888 888                   8888888b.  888888b.
               888            d88P"  888                   888  "Y88b 888  "88b
               888            888    888                   888    888 888  .88P
               888   88888b.  888888 888 888  888 888  888 888    888 8888888K.
               888   888 "88b 888    888 888  888  Y8bd8P' 888    888 888  "Y88b
               888   888  888 888    888 888  888   X88K   888    888 888    888
               888   888  888 888    888 Y88b 888 .d8""8b. 888  .d88P 888   d88P
             8888888 888  888 888    888  "Y88888 888  888 8888888P"  8888888P"
            2021-12-03T10:28:29.761197Z     info    InfluxDB starting       {"log_id": "0YByFwlG000", "version": "1.6.7~rc0", "branch": "unknown", "commit": "unknown"}
            2021-12-03T10:28:29.761262Z     info    Go runtime      {"log_id": "0YByFwlG000", "version": "go1.15.9", "maxprocs": 2}
            run: open server: listen: listen tcp 127.0.0.1:8088: bind: address already in use
            root@InfluxDBian:~#
            lobomau Homoran 2 Replies Last reply Reply Quote 0
            • lobomau
              lobomau @lobomau last edited by
              @lobomau ok... jetzt habe ich den korrekten Befehl gefunden für lsb_release:
              apt install -y lsb-release
              Ich fahre nochmal ein backup ein und fange von vorne an...
                @lobomau sagte in [HowTo?] InfluxDB 1.8.x auf Debian 11 (proxmox) installieren:
                es ging nicht um Influx - es geht um Proxmox Grundinstallation
                • dslraser
                  dslraser Forum Testing Most Active @Homoran last edited by dslraser
                  @homoran sagte in [HowTo?] InfluxDB 1.8.x auf Debian 11 (proxmox) installieren:
                  Ich habe es damit gemacht.
                  https://pve.proxmox.com/wiki/Package_Repositories
                  und das sieht dann so aus
                  lobomau 1 Reply Last reply Reply Quote 1
                  • lobomau
                    lobomau @dslraser last edited by lobomau
                    @dslraser ja, das könnte es sein. Korrigiere ich mal und teste nochmal...
                    Edit.: hab ich doch, oder?
                    /etc/apt/sources.list:
                    #deb http://ftp.de.debian.org/debian bullseye main contrib
                    deb http://ftp.debian.org/debian bullseye main contrib
                    deb http://ftp.debian.org/debian bullseye-updates main contrib
                    #deb http://ftp.de.debian.org/debian bullseye-updates main contrib
                    deb http://download.proxmox.com/debian/pve bullseye pve-no-subscription
                    # security updates
                    #deb http://security.debian.org bullseye-security main contrib
                    deb http://security.debian.org/debian-security bullseye-security main contrib
                    #deb http://deb.debian.org/debian-security bullseye-security main
                    lobomau dslraser 2 Replies Last reply Reply Quote 0
                    • lobomau
                      lobomau @lobomau last edited by lobomau
                      Edit.: ich habe die Installation für InfluxDB 1.8 verworfen und gleich 2.1. versucht. Ging dann auch ohne Schwierigkeiten. HowTo habe ich darauf hin angepasst.
                      Bei Punkt 11 hänge ich nun 😞
                      Last login: Fri Dec  3 11:58:39 CET 2021 on tty1
                      root@InfluxDBian:~# systemctl status influxdb.service
                      * influxdb.service - InfluxDB is an open-source, distributed, time series database
                           Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: e>
                           Active: activating (start) since Fri 2021-12-03 12:08:57 CET; 1min 16s ago
                             Docs: https://docs.influxdata.com/influxdb/
                      Cntrl PID: 2406 (influxd-systemd)
                            Tasks: 2 (limit: 9300)
                           Memory: 1000.0K
                              CPU: 2.178s
                           CGroup: /system.slice/influxdb.service
                                   |-2406 /bin/bash -e /usr/lib/influxdb/scripts/influxd-systemd-start.sh
                                   `-2685 sleep 1
                      Dec 03 12:10:04 InfluxDBian influxd-systemd-start.sh[2406]: InfluxDB API unavailable>
                      Dec 03 12:10:05 InfluxDBian influxd-systemd-start.sh[2406]: InfluxDB API unavailable>
                      Dec 03 12:10:06 InfluxDBian influxd-systemd-start.sh[2406]: InfluxDB API unavailable>
                      Dec 03 12:10:07 InfluxDBian influxd-systemd-start.sh[2406]: InfluxDB API unavailable>
                      Dec 03 12:10:08 InfluxDBian influxd-systemd-start.sh[2406]: InfluxDB API unavailable>
                      Dec 03 12:10:09 InfluxDBian influxd-systemd-start.sh[2406]: InfluxDB API unavailable>
                      Dec 03 12:10:10 InfluxDBian influxd-systemd-start.sh[2406]: InfluxDB API unavailable>
                      Dec 03 12:10:11 InfluxDBian influxd-systemd-start.sh[2406]: InfluxDB API unavailable>
                      Dec 03 12:10:12 InfluxDBian influxd-systemd-start.sh[2406]: InfluxDB API unavailable>
                      Dec 03 12:10:13 InfluxDBian influxd-systemd-start.sh[2406]: InfluxDB API unavailable>
                      lines 1-22/22 (END)...skipping...
                           Memory: 1000.0K
                              CPU: 2.178s
                                   `-2685 sleep 1
                      • lobomau
                        lobomau @ftd last edited by lobomau
                        @ftd so, habe das einfach mal nach deinem link gemacht. Ist dann nicht so schwierig. Ich werde sehen wie ich meine alte Datenbank aus 1.8 in 2.1 bekomme.
                        Anleitung sollte so klappen. habe extra nochmal Backup eingespielt und meine Befehle oben genau so eingegeben.
                        Installiert ist es schon mal. Fehlt noch die korrekte konfiguration. Im Augenblick ist der port :8086 anderweitig in Gebrauch weshalb es (noch) einen Fehler gibt.
                        Edit: Ziel/Motivation bei mir ist, alles auf Debian 11 bullseye umzustellen. Bisher ist das nur beim Proxmox und bei einem Pi3-Slave der Fall.
                        Die anderen Container sind Debian 10 und InfluxDB läuft auf Ubuntu 20:
                        • dslraser
                          dslraser Forum Testing Most Active @lobomau last edited by
                          @lobomau sagte in [HowTo] InfluxDB 2.1 auf Debian 11 (proxmox CT) installieren:
                          Ich hatte @Homoran geantwortet, das war nur die Antwort auf seine Frage.
                            @homoran da hat sich nichts geändert, ausser das du in v7 das Repo nun direkt in der proxmox Gui bearbeiten kannst
                              DocGame @lobomau last edited by
                              @lobomau Ich hatte die 1.8 seit einem Jahr erfolgreich im einem Proxmox CT am laufen. Nach Update des Influx-Adapters von 1.9.5 auf 2.2.0 kam keine Verbindung zu InfluxDB zu stande (1.x war in den Adaptereinstellungen eingestellt). Nach einem Downgrade lief wieder alles.
                              Ich habe mich gestern mit deiner Anleitung an das Installieren einer InfluxDB 2.1 CT gemacht. Es hat alles soweit geklappt.
                              Nach dem Updaten des Adapters wollte ich meine Daten eintragen. Wo in aller Welt bekomme ich den Token her? Habe die ganze Nacht "gegoogelt", bin aber leider zu keinem Ergebnis gekommen.
                              Kannst du mir auf die Sprünge helfen?
                              F lobomau 2 Replies Last reply Reply Quote 0
                                @docgame hab zwar die Version noch nicht, aber hier steht es
                                  ftd @DocGame last edited by
                                  @docgame über die GUI... IP-Adresse:8086 --> Data --> API Tokens
                                  • Palm_Maniac
                                    Palm_Maniac last edited by
                                    tolle Anleitung. Wie sieht es denn bei einem Upgrade von V1 auf V2 von influxdb aus, gibt es da einen Weg unter Mitnahme aller bereits vorhandenen Datenbanken? Ich würde gerne wechseln, würde aber ungern meine Daten verlieren, die ich nun schon seit über 1 Jahr aufzeichne.
                                      ftd @Palm_Maniac last edited by
                                      @palm_maniac https://docs.influxdata.com/influxdb/v2.1/upgrade/v1-to-v2/
                                        DocGame @ftd last edited by
                                        @ftd @crunchip Über die GUI hat es geklappt. Habe ich heute nacht schon probiert (aber versehentlich die falsche IP erwischt und bin nicht drauf gekommen).
                                        Grafana habe ich seinerzeit auf dem gleichen Container wie InfluxDB gehabt. Mal sehen ob ich es auch auf dem neuen Container wieder hinbekomme.
                                        Wäre es nicht möglich InfluxDB auf dem alten Container zu löschen und diesen nur noch für Grafana zu nutzen?
                                        Wie geht denn der uninstall? Bin unter Linux leider eine richtige Pfeife.....
                                          @docgame
                                          sudo apt purge influxdb
                                          ggf. noch Verzeichnisse löschen
                                          /var/lib/influxdb/data
                                          /var/lib/influxdb/wal
                                          /var/lib/influxdb/meta
                                          D crunchip 2 Replies Last reply Reply Quote 0
                                            @ftd Ich gebe es für heute auf...
                                            Mit dem eigentlichen Thema hat mein Problem auch nichts mehr zu tun (InfluxDB ist installiert und wird im Moment auch schn vom Adapter mit Daten gefüttert).
                                            Ich habe jetzt doch Grafana in den Container installiert. Das läuft auch....Nur bekomme ich die Datenbank nicht damit verknüpft.
                                            Vielleicht finde ich noch eine Anleitung für "Dummies"
                                            131
                                            32596
