    4. [ESPHome] Beta release
      arne007 last edited by
      hallo zusammen, kann mir jemand sagen, warum ich ESPHome nicht installiert bekomme:
      0 info it worked if it ends with ok
      1 verbose cli [
      1 verbose cli '/usr/local/bin/node',
      1 verbose cli '/usr/local/bin/npm',
      1 verbose cli 'install',
      1 verbose cli 'esphome/esphome#1424091ee51a31d75558f8e4a029ea80edb4d415',
      1 verbose cli '--prefix',
      1 verbose cli '/opt/iobroker'
      1 verbose cli ]
      2 info using npm@6.14.11
      3 info using node@v14.15.4
      4 verbose npm-session 03dd482e48963b72
      5 silly install loadCurrentTree
      6 silly install readLocalPackageData
      7 silly fetchPackageMetaData error for github:esphome/esphome#1424091ee51a31d75558f8e4a029ea80edb4d415 premature close
      8 timing stage:rollbackFailedOptional Completed in 2ms
      9 timing stage:runTopLevelLifecycles Completed in 8223ms
      10 verbose stack Error: premature close
      10 verbose stack at PassThrough.onclose (/usr/local/lib/node_modules/npm/node_modules/end-of-stream/index.js:47:67)
      10 verbose stack at PassThrough.emit (events.js:327:22)
      10 verbose stack at emitCloseNT (internal/streams/destroy.js:87:10)
      10 verbose stack at processTicksAndRejections (internal/process/task_queues.js:79:21)
      11 verbose cwd /opt/iobroker
      12 verbose Linux 5.10.63-v7l+
      13 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "esphome/esphome#1424091ee51a31d75558f8e4a029ea80edb4d415" "--prefix" "/opt/iobroker"
      14 verbose node v14.15.4
      15 verbose npm v6.14.11
      16 error premature close
      17 verbose exit [ 1, true ]
        Thomas Braun Most Active @arne007 last edited by
        @arne007 sagte in [ESPHome] Beta release:
        NodeJS ist falsch installiert.
          arne007 @Thomas Braun last edited by
          @thomas-braun falsche Version installiert? Wenn ja, welche sollte ich nehmen?
            Thomas Braun Most Active @arne007 last edited by Thomas Braun
            @arne007
            Steht in meiner Signatur.
            Lies insbesondere den Teil mit den falschen Pfaden besonders gründlich.
            Johannes Bauerstatter 1 Reply Last reply Reply Quote 0
            • Johannes Bauerstatter
              Johannes Bauerstatter @Thomas Braun last edited by
              Hallo, irgendwie mags bei mir auch nicht. Welche Version ist falsch?
              npm: 6.14.15
              node: 14.18.2
              python: 3.9.7
              $ ./iobroker add esphome  --host raspberrypi
              NPM version: 6.14.15
              npm install iobroker.esphome@0.2.4 --loglevel error --prefix "/opt/iobroker" (System call)
              Exception:
              Traceback (most recent call last):  File "/tmp/tmpvlou37m4/pip.zip/pip/basecommand.py", line 215, in main    status = self.run(options, args)  File "/tmp/tmpvlou37m4/pip.zip/pip/commands/install.py", line 272, in run    with self._build_session(options) as session:  File "/tmp/tmpvlou37m4/pip.zip/pip/basecommand.py", line 66, in _build_session    session = PipSession(  File "/tmp/tmpvlou37m4/pip.zip/pip/download.py", line 329, in __init__    self.headers["User-Agent"] = user_agent()  File "/tmp/tmpvlou37m4/pip.zip/pip/download.py", line 93, in user_agent    from pip._vendor import distro  File "<frozen importlib._bootstrap>", line 1007, in _find_and_load  File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked  File "<frozen importlib._bootstrap>", line 664, in _load_unlocked  File "<frozen importlib._bootstrap>", line 627, in _load_backward_compatible  File "<frozen zipimport>", line 259, in load_module  File "/tmp/tmpvlou37m4/pip.zip/pip/_vendor/distro.py", line 1050, in <module>    _distro = LinuxDistribution()  File "/tmp/tmpvlou37m4/pip.zip/pip/_vendor/distro.py", line 593, in __init__    self._lsb_release_info = self._get_lsb_release_info() \  File "/tmp/tmpvlou37m4/pip.zip/pip/_vendor/distro.py", line 931, in _get_lsb_release_info    raise subprocess.CalledProcessError(code, cmd, stdout, stderr)subprocess.CalledProcessError: Command 'lsb_release -a' returned non-zero exit status 1.
                File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 20061, in <module>
                  main()
                File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 194, in main    bootstrap(tmpdir=tmpdir)
                File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 172, in bootstrap    sys.exit(pip.main(["install", "--upgrade"] + args))  File "/tmp/tmpvlou37m4/pip.zip/pip/__init__.py", line 233, in main  File "/tmp/tmpvlou37m4/pip.zip/pip/basecommand.py", line 248, in main  File "/tmp/tmpvlou37m4/pip.zip/pip/basecommand.py", line 66, in _build_session  File "/tmp/tmpvlou37m4/pip.zip/pip/download.py", line 329, in __init__
                File "/tmp/tmpvlou37m4/pip.zip/pip/download.py", line 93, in user_agent  File "<frozen importlib._bootstrap>", line 1007, in _find_and_load  File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked  File "<frozen importlib._bootstrap>", line 664, in _load_unlocked  File "<frozen importlib._bootstrap>", line 627, in _load_backward_compatible
                File "<frozen zipimport>", line 259, in load_module  File "/tmp/tmpvlou37m4/pip.zip/pip/_vendor/distro.py", line 1050, in <module>  File "/tmp/tmpvlou37m4/pip.zip/pip/_vendor/distro.py", line 593, in __init__  File "/tmp/tmpvlou37m4/pip.zip/pip/_vendor/distro.py", line 931, in _get_lsb_release_info
              Error: Exited with code 1.
                  at ChildProcess.<anonymous> (/opt/iobroker/node_modules/nopy/src/api.js:277:20)    at ChildProcess.emit (events.js:400:28)    at maybeClose (internal/child_process.js:1058:16)    at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
              npm ERR! code ELIFECYCLE
              npm ERR! errno 1
              npm ERR! iobroker.esphome@0.2.4 install: `npip install`
              npm ERR! Exit status 1npm ERR! npm ERR! Failed at the iobroker.esphome@0.2.4 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
              npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-12-03T11_34_34_767Z-debug.log
              ERROR: host.raspberrypi Cannot install iobroker.esphome@0.2.4: 1
              ERROR: process exited with code 25
                Thomas Braun Most Active @Johannes Bauerstatter last edited by Thomas Braun
                @johannes-bauerstatter sagte in [ESPHome] Beta release:
                lsb_release -a
                Was kommt da in der Konsole zurück?
                  pi@raspberrypi:~ $ lsb_release -a
                    File "/usr/bin/lsb_release", line 25, in <module>
                      import lsb_release
                  ModuleNotFoundError: No module named 'lsb_release'
                    Da ist irgendwas kaputt.
                    sudo apt update
                    sudo apt install --reinstall lsb-release
                      Johannes Bauerstatter @Thomas Braun last edited by Johannes Bauerstatter
                      Ist eine ganz frische Installation auf einem Raspi 4.
                      pi@raspberrypi:~ $ sudo apt install --reinstall lsb-release
                      Reading package lists... Done
                      Building dependency tree... Done
                      0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
                      Need to get 28.1 kB of archives.
                      After this operation, 0 B of additional disk space will be used.
                      Get:1 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf lsb-release all 11.1.0+rpi1 [28.1 kB]
                      Fetched 28.1 kB in 1s (19.0 kB/s)
                        File "/usr/bin/apt-listchanges", line 29, in <module>
                          import apt_pkg
                      ModuleNotFoundError: No module named 'apt_pkg'
                      (Reading database ... 50809 files and directories currently installed.)
                      Preparing to unpack .../lsb-release_11.1.0+rpi1_all.deb ...
                      Unpacking lsb-release (11.1.0+rpi1) over (11.1.0+rpi1) ...
                      Setting up lsb-release (11.1.0+rpi1) ...
                      Processing triggers for man-db (2.9.4-2) ...
                      pi@raspberrypi:~ $
                      Exception:Traceback (most recent call last):  File "/tmp/tmpys8yyc8z/pip.zip/pip/basecommand.py", line 215, in main    status = self.run(options, args)  File "/tmp/tmpys8yyc8z/pip.zip/pip/commands/install.py", line 272, in run    with self._build_session(options) as session:  File "/tmp/tmpys8yyc8z/pip.zip/pip/basecommand.py", line 66, in _build_session    session = PipSession(  File "/tmp/tmpys8yyc8z/pip.zip/pip/download.py", line 329, in __init__    self.headers["User-Agent"] = user_agent()  File "/tmp/tmpys8yyc8z/pip.zip/pip/download.py", line 93, in user_agent    from pip._vendor import distro  File "<frozen importlib._bootstrap>", line 1007, in _find_and_load  File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked  File "<frozen importlib._bootstrap>", line 664, in _load_unlocked  File "<frozen importlib._bootstrap>", line 627, in _load_backward_compatible  File "<frozen zipimport>", line 259, in load_module  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 1050, in <module>    _distro = LinuxDistribution()  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 593, in __init__    self._lsb_release_info = self._get_lsb_release_info() \  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 931, in _get_lsb_release_info    raise subprocess.CalledProcessError(code, cmd, stdout, stderr)subprocess.CalledProcessError: Command 'lsb_release -a' returned non-zero exit status 1.
                      Traceback (most recent call last):  File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 20061, in <module>
                          main()  File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 194, in main    bootstrap(tmpdir=tmpdir)  File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 172, in bootstrap    sys.exit(pip.main(["install", "--upgrade"] + args))  File "/tmp/tmpys8yyc8z/pip.zip/pip/__init__.py", line 233, in main  File "/tmp/tmpys8yyc8z/pip.zip/pip/basecommand.py", line 248, in main  File "/tmp/tmpys8yyc8z/pip.zip/pip/basecommand.py", line 66, in _build_session  File "/tmp/tmpys8yyc8z/pip.zip/pip/download.py", line 329, in __init__  File "/tmp/tmpys8yyc8z/pip.zip/pip/download.py", line 93, in user_agent  File "<frozen importlib._bootstrap>", line 1007, in _find_and_load  File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked  File "<frozen importlib._bootstrap>", line 664, in _load_unlocked  File "<frozen importlib._bootstrap>", line 627, in _load_backward_compatible  File "<frozen zipimport>", line 259, in load_module  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 1050, in <module>  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 593, in __init__  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 931, in _get_lsb_release_infosubprocess.CalledProcessError: Command 'lsb_release -a' returned non-zero exit status 1.
                      Error: Exited with code 1.    at ChildProcess.<anonymous> (/opt/iobroker/node_modules/nopy/src/api.js:277:20)    at ChildProcess.emit (events.js:400:28)
                      npm ERR! errno 1
                      npm ERR! iobroker.esphome@0.2.4 install: `npip install`npm ERR! Exit status 1
                      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-12-03T15_55_36_557Z-debug.log
                        ModuleNotFoundError: No module named 'apt_pkg'        (Reading database ... 50809 files and directories currently installed.)
                        Gaaaaaaanz merkwürdige Meldungen. Was zur Hölle hast du da wie installiert?
                        Ich würd's nochmal ganz frisch installieren.
                        Johannes Bauerstatter O 2 Replies Last reply Reply Quote 0
                          @thomas-braun Ok. Welche Python Version soll ich nehmen?
                            Die vorgesehene/vorinstallierte?
                            Da ist was total schräg bei dir. Hier ist das ganz fluffig:
                            echad@chet:~ $ iobroker install esphome
                            NPM version: 8.1.4
                            host.chet install adapter esphome
                            upload [5] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/words.js words.js application/javascript
                            upload [4] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/style.css style.css text/css
                            upload [3] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/index_m.html index_m.html text/html
                            upload [2] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/dashboard.png img/dashboard.png image/png
                            upload [1] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/esphome.png esphome.png image/png
                            upload [0] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/admin.d.ts admin.d.ts video/mp2t
                            host.chet object system.adapter.esphome created/updated
                            Aus der Readme:
                            Required
                            • NodeJS >= 12.x
                            • Python >=3.7, <4.0
                            • API is activated in YAML
                              Anzic last edited by Anzic
                              Switched to NodeJS version 14 frome 12. The dashboard stopped working. Although the adapter itself works. There is such an error in the log:
                              esphome.0
                              2021-12-03 19:55:22.625	warn	ESPHome Dashboard deactivated
                              esphome.0
                              2021-12-03 19:55:22.589	error	[dashboardProcess ERROR] from esphome.__main__ import mainModuleNotFoundError: No module named 'esphome'
                              esphome.0
                              2021-12-03 19:55:22.588	error	[dashboardProcess ERROR] Traceback (most recent call last): File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/bin/esphome", line 5, in <module>
                              I try to execute iobroker rebuild esphome and iobroker rebuild esphome --install I get this error:
                              root@iobroker:/opt/iobroker# iobroker rebuild esphome --install
                              npm install --loglevel error --production (System call1) in "/opt/iobroker/node_modules/iobroker.esphome"
                              /usr/bin/python3: No module named pip
                              npm ERR! errno 1
                              npm ERR!
                              npm ERR!     /opt/iobroker/.npm/_logs/2021-12-03T17_03_35_839Z-debug.log
                              What you need to do to "rebuild" the adapter and the dashboard works
                              Docker image baunet 6.0.0beta1
                              I managed it myself. this command helped - sudo apt install python3-pip
                                marsmännchen @Thomas Braun last edited by
                                @Dutchman
                                Danke für die Aktualisierung. Funktioniert jetzt auf dem Slave.
                                Aber hast du vielleicht eine Idee darüber :
                                https://forum.iobroker.net/topic/49960/esphome-probe-request-unsuccessful
                                MfG
                                Patrick
                                • Feuersturm
                                  Feuersturm last edited by Feuersturm
                                  @Dutchman Ich hatte heute folgende Fehlermeldung im Log
                                  Ist für die Fargebung rot / gelb der Adapter oder der Admin verantwortlich? Warum wird beim esphome Fehler gelb statt z.B. des Orange (wie bei den Warnungen ) verwendet?
                                  Hier mal der Fehler in lesbarer Form 😉
                                  Bisher hab ich es noch nicht gesehen, dass innerhalb einer Warnung / Fehlers die Farbe wechselt.
                                    Johannes Bauerstatter @Feuersturm last edited by
                                    Hab heute den Pi 5x neu aufgesetzt und bring es einfach nicht zum laufen. Iobroker läuft.
                                    Bei einer Installation war nach 4h Schluss.
                                    Bevor ich jetzt wieder alles mache.
                                    So wäre meine Ausgangslage:
                                    Linux raspberrypi 5.10.63-v7l+ #1488 SMP Thu Nov 18 16:15:28 GMT 2021 armv7l
                                    pi@raspberrypi:~ $ npm -v
                                    6.14.15
                                    pi@raspberrypi:~ $ node -v
                                    v14.18.2
                                    pi@raspberrypi:~ $ python
                                    Python 2.7.18 (default, Jul 14 2021, 08:11:37)
                                    [GCC 10.2.1 20210110] on linux2
                                    Type "help", "copyright", "credits" or "license" for more information.
                                    >>> quit()
                                    pi@raspberrypi:~ $ python3
                                    Python 3.9.2 (default, Mar 12 2021, 04:06:34)
                                    >>> quit()
                                    pi@raspberrypi:~ $
                                    Ist das so OK? Soll ich lieber im Broker den Adapter installieren oder per npm i ....?
                                      Was soll das aussagen?
                                      Die Versionsnummer sehen aber i. O. aus.
                                        @thomas-braun Der Adapter hat im Iobroker 4h lang installiert und hat sich dann beendet ohne das es installiert wurde. Ich versuch es nochmal.
                                          Und wie hast du das gemacht?
                                          Entweder über die Admin-GUI oder in der Konsole per
                                          Das Beta-Repo muss allerdings dazu aktiv sein.
                                            @thomas-braun Habs über die UI gemacht. Jetzt hab ich es mal über die Konsole per
                                            gestartet.
                                                  creating build/temp.linux-armv7l-3.9
                                                  creating build/temp.linux-armv7l-3.9/c
                                                  arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/python3.9 -c c/_cffi_backend.c -o build/temp.linux-armv7l-3.9/c/_cffi_backend.o
                                                  c/_cffi_backend.c:2:10: fatal error: Python.h: No such file or directory
                                                      2 | #include <Python.h>
                                                  compilation terminated.
                                                  error: command '/usr/bin/arm-linux-gnueabihf-gcc' failed with exit code 1
                                              ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-5ijkwnli/cffi_16d10301de7c4069acead825ae282b6b/setup.py'"'"'; __file__='"'"'/tmp/pip-install-5ijkwnli/cffi_16d10301de7c4069acead825ae282b6b/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-opvq9x1b/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-lf7bqq4f/overlay --compile --install-headers /tmp/pip-build-env-lf7bqq4f/overlay/include/python3.9/cffi Check the logs for full command output.
                                            WARNING: Discarding https://files.pythonhosted.org/packages/9b/77/461087a514d2e8ece1c975d8216bc03f7048e6090c5166bc34115afdaa53/cryptography-3.4.7.tar.gz#sha256=3d10de8116d25649631977cb37da6cbdd2d6fa0e0281d014a5b7d337255ca713 (from https://pypi.org/simple/cryptography/) (requires-python:>=3.6). Command errored out with exit status 1: /usr/bin/python3 /tmp/pip-standalone-pip-eo94u2mi/__env_pip__.zip/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-lf7bqq4f/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- 'setuptools>=40.6.0' wheel 'cffi>=1.12; platform_python_implementation != '"'"'PyPy'"'"'' 'setuptools-rust>=0.11.4' Check the logs for full command output.
                                            pi@raspberrypi:~ $ iobroker update
                                            Used repository: Beta (latest)
                                            hash unchanged, use cached sources
                                            update done
                                            Adapter    "admin"         : 5.2.1    , installed 5.2.1
                                            Adapter    "backitup"      : 2.2.2    , installed 2.2.2
                                            Adapter    "discovery"     : 2.7.5    , installed 2.7.5
                                            Adapter    "esphome"       : 0.2.4    , installed 0.2.4
                                            Adapter    "info"          : 1.9.16   , installed 1.9.16
                                            Controller "js-controller" : 3.3.21   , installed 3.3.21
                                            pi@raspberrypi:~ $
                                            In der Iobroker UI wird er unter Instanzen nicht angezeigt. Bei Adapter steht er als installiert 0.2.4.
                                            Hab schon ein paar Reboots gemacht, aber er erscheint nicht auch das Dashboard kann nicht eingeblendet werden.
                                            591
                                            152464
