    4. Test Alpha Homekit-Controller 0.0.x
    • I
      invidianer @apollon77 last edited by invidianer
      @apollon77
      Hier die Installation:
      2021-11-07 08:54:04.847 - info: host.raspberrypi iobroker add homekit-controller auto --host raspberrypi
      2021-11-07 08:54:07.678 - info: host.raspberrypi iobroker NPM version: 6.14.15
      2021-11-07 08:54:07.681 - info: host.raspberrypi iobroker npm install iobroker.homekit-controller@0.3.3 --loglevel error --prefix "/opt/iobroker" (System call)
      2021-11-07 08:54:54.166 - info: host.raspberrypi iobroker node-pre-gyp ERR! install response status 404 Not Found on https://github.com/abandonware/node-bluetooth-hci-socket/releases/download/0.5.3-8/bluetooth_hci_socket-0.5.3-8-node-v72-linux-arm.tar.gz
      2021-11-07 08:54:57.973 - info: host.raspberrypi iobroker In file included from /home/iobroker/.cache/node-gyp/12.22.7/include/node/node_buffer.h:25,
      2021-11-07 08:54:57.974 - info: host.raspberrypi iobroker from ../src/BluetoothHciSocket.cpp:7:/home/iobroker/.cache/node-gyp/12.22.7/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local, v8::Local, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/12.22.7/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~../src/BluetoothHciSocket.cpp:635:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(binding, BluetoothHciSocket::Init); ^~~~~~~~~~~
      2021-11-07 08:54:58.197 - info: host.raspberrypi iobroker ../src/BluetoothHciSocket.cpp: In member function ‘int BluetoothHciSocket::kernelDisconnectWorkArounds(int, char*)’:
      2021-11-07 08:54:58.198 - info: host.raspberrypi iobroker ../src/BluetoothHciSocket.cpp:401:1: warning: control reaches end of non-void function [-Wreturn-type] } ^
      2021-11-07 08:55:05.946 - info: host.raspberrypi iobroker host.raspberrypi install adapter homekit-controller
      2021-11-07 08:55:05.983 - info: host.raspberrypi iobroker upload [10] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/js/runtime-main.f705f273.js static/js/runtime-main.f705f273.js application/javascript
      2021-11-07 08:55:06.078 - info: host.raspberrypi iobroker upload [9] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/js/main.73ad8aca.chunk.js static/js/main.73ad8aca.chunk.js application/javascript
      2021-11-07 08:55:06.136 - info: host.raspberrypi iobroker upload [8] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/js/2.e5a95dd3.chunk.js.LICENSE.txt static/js/2.e5a95dd3.chunk.js.LICENSE.txt text/plain
      2021-11-07 08:55:06.198 - info: host.raspberrypi iobroker upload [7] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/js/2.e5a95dd3.chunk.js static/js/2.e5a95dd3.chunk.js application/javascript
      2021-11-07 08:55:06.293 - info: host.raspberrypi iobroker upload [6] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
      2021-11-07 08:55:06.352 - info: host.raspberrypi iobroker upload [5] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
      2021-11-07 08:55:06.429 - info: host.raspberrypi iobroker upload [4] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/manifest.json manifest.json application/json
      2021-11-07 08:55:06.489 - info: host.raspberrypi iobroker upload [3] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/index_m.html index_m.html text/html
      2021-11-07 08:55:06.554 - info: host.raspberrypi iobroker upload [2] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/homekit-controller.png homekit-controller.png image/png
      2021-11-07 08:55:06.617 - info: host.raspberrypi iobroker upload [1] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
      2021-11-07 08:55:06.677 - info: host.raspberrypi iobroker upload [0] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/asset-manifest.json asset-manifest.json application/json
      2021-11-07 08:55:06.903 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.homekit-controller created/updated
      2021-11-07 08:55:06.973 - info: host.raspberrypi iobroker host.raspberrypi create instance homekit-controller
      2021-11-07 08:55:06.983 - info: host.raspberrypi iobroker host.raspberrypi object homekit-controller.0.info.connection created
      2021-11-07 08:55:07.017 - info: host.raspberrypi iobroker host.raspberrypi object homekit-controller.0.info created
      2021-11-07 08:55:07.052 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.homekit-controller.0.logLevel created
      2021-11-07 08:55:07.086 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.homekit-controller.0.sigKill created
      2021-11-07 08:55:07.121 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.homekit-controller.0.eventLoopLag created
      2021-11-07 08:55:07.168 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.homekit-controller.0.outputCount created
      2021-11-07 08:55:07.203 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.homekit-controller.0.inputCount created
      2021-11-07 08:55:07.240 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.homekit-controller.0.uptime created
      2021-11-07 08:55:07.275 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.homekit-controller.0.memRss created
      2021-11-07 08:55:07.309 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.homekit-controller.0.memHeapTotal created
      2021-11-07 08:55:07.342 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.homekit-controller.0.memHeapUsed created
      2021-11-07 08:55:07.375 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.homekit-controller.0.cputime created
      2021-11-07 08:55:07.416 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.homekit-controller.0.cpu created
      2021-11-07 08:55:07.451 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.homekit-controller.0.compactMode created
      2021-11-07 08:55:07.487 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.homekit-controller.0.connected created
      2021-11-07 08:55:07.525 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.homekit-controller.0.alive created
      2021-11-07 08:55:07.558 - info: host.raspberrypi iobroker host.raspberrypi Set default value of homekit-controller.0.info.connection: false
      2021-11-07 08:55:07.613 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.homekit-controller.0 created
      2021-11-07 08:55:08.735 - info: host.raspberrypi iobroker exit 0
      2021-11-07 08:55:10.762 - info: host.raspberrypi instance system.adapter.homekit-controller.0 started with pid 1361
      Und dann danach:
      2021-11-07 09:05:48.121	info	starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v12.22.7, js-controller: 3.3.18
      2021-11-07 09:05:48.106	info	Plugin sentry Sentry Plugin disabled for this process because data reporting is disabled on instance
      2021-11-07 09:05:43.202	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-11-07 09:05:43.201	info	terminating
      2021-11-07 09:05:43.191	info	Got terminate signal TERMINATE_YOURSELF
      2021-11-07 09:05:37.424	info	IP-4F:07:44:53:78:FA (ioBrokerBridge A051) found without known pairing data and already paired: ignoring
      2021-11-07 09:05:37.415	info	IP-12:88:48:42:4E:1B (Philips hue - 1918BC) found without known pairing data and already paired: ignoring
      2021-11-07 09:05:37.405	info	IP-4F:07:44:53:78:FA (ioBrokerBridge A051) found without known pairing data and already paired: ignoring
      2021-11-07 09:05:36.941	info	starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v12.22.7, js-controller: 3.3.18
      2021-11-07 09:05:33.349	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-11-07 09:05:33.347	info	terminating
      2021-11-07 09:05:33.334	info	Got terminate signal TERMINATE_YOURSELF
      2021-11-07 08:57:30.466	info	IP-4F:07:44:53:78:FA (ioBrokerBridge A051) found without known pairing data and already paired: ignoring
      2021-11-07 08:57:30.458	info	IP-4F:07:44:53:78:FA (ioBrokerBridge A051) found without known pairing data and already paired: ignoring
      2021-11-07 08:57:30.448	info	IP-12:88:48:42:4E:1B (Philips hue - 1918BC) found without known pairing data and already paired: ignoring
      2021-11-07 08:57:29.977	info	starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v12.22.7, js-controller: 3.3.18
      2021-11-07 08:57:20.780	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-11-07 08:57:20.778	info	terminating
      2021-11-07 08:57:20.764	info	Got terminate signal TERMINATE_YOURSELF
      2021-11-07 08:55:49.914	info	IP-4F:07:44:53:78:FA (ioBrokerBridge A051) found without known pairing data and already paired: ignoring
      2021-11-07 08:55:49.903	info	IP-4F:07:44:53:78:FA (ioBrokerBridge A051) found without known pairing data and already paired: ignoring
      2021-11-07 08:55:49.873	info	IP-12:88:48:42:4E:1B (Philips hue - 1918BC) found without known pairing data and already paired: ignoring
      2021-11-07 08:55:49.425	info	starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v12.22.7, js-controller: 3.3.18
      2021-11-07 08:55:43.809	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-11-07 08:55:43.805	info	terminating
      2021-11-07 08:55:43.793	info	Got terminate signal TERMINATE_YOURSELF
      2021-11-07 08:55:13.231	info	IP-4F:07:44:53:78:FA (ioBrokerBridge A051) found without known pairing data and already paired: ignoring
      2021-11-07 08:55:13.223	info	IP-4F:07:44:53:78:FA (ioBrokerBridge A051) found without known pairing data and already paired: ignoring
      2021-11-07 08:55:13.207	info	IP-12:88:48:42:4E:1B (Philips hue - 1918BC) found without known pairing data and already paired: ignoring
      2021-11-07 08:55:13.023	info	starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v12.22.7, js-controller: 3.3.18
      Eve Weather hat BLE/Thread und ist bei mir mit einem HomePod mini verbunden und liefert die Daten an die Home App und die Eve App.
        apollon77 @invidianer last edited by
        @invidianer Hi,
        Also ich sehe hier nicht das irgendwas von BLE ankommt als Discovery. Und Ist auch kein Debug log 🙂 (Instanzen - Expertenmodus - Loglevel info-> debug setzen für die Instanz.
        ABER: Wenn er BLE findet dann wird dort auch nur eine meldung wie bei den anderen kommen nämlich "gefunden aber schon gepaired ignoriere es". Du müsstest es erst unpairen mit deiner Home App bzw dem Home Mini damit der Adapter es finden würde - wenn BLE tut ... und bist sicher das der Rechner wo es läuft nen BLE cheip/Stick hat der nicht schon von was anderem genutzt wird?
        • I
          @apollon77
          Hmm, bin jetzt nicht sicher, was Du meinst. Mein ioBroker läuft auf einem Raspberry Pi und hat keinen Stick oder so.
          Er steht im Dachgeschoss, der Weather hängt außen vor der Küche und ist verbunden mit einem HomePod mini im Wohnzimmer. Da ich im Haus 9 HomePod minis verteilt habe, sollte das Thread-Netzwerk im ganzen Haus verfügbar sein und die HomePod minis sind ja ebenfalls per Wifi verbunden. So dachte ich, daß das alles auch irgendwie in den ioBroker zu bringen sei? 🤷‍♂️
            apollon77 @invidianer last edited by apollon77
            @invidianer ok dann mal langsam. Der Adapter kann maximal über BLE mit dem Gerät direkt reden - wenn es nicht schon gepaired ist. Das sollte Ggf zu weit weg sein.
            Wenn der adapter thread könnte gäbs ne Auswahl und du bräuchtest Hardware dafür. Weiterhin HomeKit via Thread ist noch nicht offengelegt … also bitte genau lesen was der Adapter kann und möglich ist.
            • I
              @apollon77
              Ok, danke!
                Hc-Yami last edited by Hc-Yami
                danke @apollon77 für die Mühe der Enticklung des Adapters.
                Sofern der Adapter das erfüllt, was ich mir gerade vorstelle, wäre das für mich ein riesen Pluspunkt den ich schon lange vermisse.
                Ich besitze ein Nuki Smartlock. Ich möchte dieses eigentlich lokal, ohne Bridge nutzen. Denn die Bridge möchte zwangsläufig ins Internet.
                Nun habe in der Nuki App Homekit und Bluetooth aktiviert. Weiterhin habe ich der virtuellen Maschine auf der ioBroker läuft ein Bluetooth Dongle zugewiesen. Leider findet der Adapter keine Geräte. Wüsstest du wie wir uns dem annähern könnten?
                Grüße! 🙂
                	2021-11-15 13:01:45.876	debug	state homekit-controller.0.info.connection changed: false (ack = true)
                	2021-11-15 13:01:45.654	info	starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v12.22.4, js-controller: 3.3.18
                	2021-11-15 13:01:45.600	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                	2021-11-15 13:01:45.596	debug	Plugin sentry Initialize Plugin (enabled=true)
                	2021-11-15 13:01:44.798	debug	Objects client initialize lua scripts
                	2021-11-15 13:01:44.796	debug	Objects create User PubSub Client
                	2021-11-15 13:01:44.794	debug	Objects create System PubSub Client
                	2021-11-15 13:01:44.792	debug	Objects client ready ... initialize now
                	2021-11-15 13:01:44.759	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                	2021-11-15 13:01:14.455	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                	2021-11-15 13:01:14.454	info	terminating
                	2021-11-15 13:01:14.448	info	Got terminate signal TERMINATE_YOURSELF
                  apollon77 @Hc-Yami last edited by
                  @hc-yami Der Haken bei Bluetooth in der Konfig ist gesetzt? Ansonsten ist das Debug Log viel zu kurz ... Entweder da fehlt nahezu alles oder was anderes ist komisch bei Dir
                    Ritter last edited by
                    habe versucht eine meross MSL120 E27 Lampe zu verbinden. Zuerst mit der meross App die Lampe ins WLAN gebracht und funktioniert dann auch mit der App. Im Homekit Adapter findet er sie aber nicht. Gibts hier noch etwas zu beachten? Firmwareupdate für die Lampe hab ich auch schon durchgeführt.
                      apollon77 @Ritter last edited by
                      @ritter wenn du sie registrierst dann ist sie danach in der meross App und in deinem
                      Apple Home drin und gepaired. Geh auf dein Apple Home App (nicht in die meross App!!) und entferne das Gerät dort. Danach sollte sie aufzufinden sein. Siehe auch Adapter readme
                        Ritter @apollon77 last edited by
                        @apollon77 Ich habe sie nur in der meross App gekoppelt. Ich habe keine Apple Geräte und sie damit auch nicht in Apple Home drin. Ist das vorher notwendig sie mit Apple Home zu koppeln? Dachte ich muss sie nur mit der App ins WLAN bringen. Sonst bräuchte ich ja einen Apple Home Emulator den es wahrscheinlich nicht gibt.
                          @ritter Hi,
                          ok, wenn Du sicher bist das es nicht gekoppelt ist und das das Gerät Apple Home unterstützt und dein iobroker Rechner im gleichen netzsegment wie die WLAN Lampe ist und so UDP Pakete geroutet werden dann kannst Du den Adapter mal im Debug Log starten. Dann solltest DU sehen falls Sie erkannt und verworfen wird oder sowas
                            Ritter last edited by Ritter
                            Laut Lampen Karton wird es unterstützt. Es sind auch bei beiden Lampen diese Pins mit QR Code drauf und die Meross APP zeigt auch diesen PIN an.
                            Windows Rechner wo iobroker inst. ist hat IP: 192.168.1.31 SUB: 255.255.255.252.0
                            Die Lampe: 192.168.3.142
                            2021-12-05 15:37:30.175	debug	state homekit-controller.0.info.connection changed: false (ack = true)
                            2021-12-05 15:37:30.109	info	starting. Version 0.3.3 in C:/iobroker/node_modules/iobroker.homekit-controller, node: v14.15.4, js-controller: 3.3.21
                            2021-12-05 15:37:29.005	debug	Plugin sentry Initialize Plugin (enabled=true)
                            2021-12-05 15:37:28.786	debug	statesDB connected
                            2021-12-05 15:37:28.786	debug	States connected to redis: 0.0.0.0:9000
                            2021-12-05 15:37:28.760	debug	States create User PubSub Client
                            2021-12-05 15:37:28.760	debug	States create System PubSub Client
                            2021-12-05 15:37:28.743	debug	Redis States: Use Redis connection: 0.0.0.0:9000
                            2021-12-05 15:37:28.741	debug	objectDB connected
                            2021-12-05 15:37:28.734	debug	Objects connected to redis: 0.0.0.0:9001
                            2021-12-05 15:37:28.705	debug	Objects client initialize lua scripts
                            2021-12-05 15:37:28.704	debug	Objects create User PubSub Client
                            2021-12-05 15:37:28.703	debug	Objects create System PubSub Client
                            2021-12-05 15:37:28.702	debug	Objects client ready ... initialize now
                            2021-12-05 15:37:28.655	debug	Redis Objects: Use Redis connection: 0.0.0.0:9001
                            2021-12-05 15:37:24.397	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2021-12-05 15:37:24.397	debug	Plugin sentry destroyed
                            2021-12-05 15:37:24.396	info	terminating
                            2021-12-05 15:37:24.394	info	Got terminate signal TERMINATE_YOURSELF
                            2021-12-05 15:36:22.991	debug	sendTo "getDiscoveredDevices" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                            2021-12-05 15:36:22.990	debug	Response to Command getDiscoveredDevices: {"success":true,"error":false}
                            2021-12-05 15:36:22.990	debug	Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":302,"ack":false,"time":1638714982989},"_id":95084731})
                            2021-12-05 15:36:21.524	debug	sendTo "getDiscoveredDevices" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                            2021-12-05 15:36:21.524	debug	Response to Command getDiscoveredDevices: {"success":true,"error":false}
                            2021-12-05 15:36:21.520	debug	Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":301,"ack":false,"time":1638714981508},"_id":95084730})
                              @ritter Naja 192.168.1 vs 192.168.3 sind zwei Netzsegmente ... Ich kenne jetzt Deine Routerkonfiguration nicht oder du musst sicherstellen das UDP Pakete geroutet werden oder einen ioBroker Slave in das andere Netzsegment stellen.
                              Ohne UDP Pakete gibt es generell kein Apple HomeKit (auch nicht mit Apple App - es sei denn das Handy wäre dann auch in dem netz wie die Lampe).
                                @apollon77 Aber ist es mit der Netzmaske: 255.255.255.252.0 nicht ein Segment? Alle anderen Geräte finden sich untereinander wie das mit UDP ist weis ich nicht, braucht man das nicht auch für VOIP das geht jedenfalls.
                                  Hab der Lampe über die FritzBox jetzt diese Adresse zugewiesen: 192.168.1.142 aber keine Änderung.
                                    Ritter @Ritter last edited by
                                    @ritter sagte in Test Alpha Homekit-Controller 0.0.x:
                                    Hab jetzt noch ein Firmwareupdate für den 24 Port Switch gemacht und nun findet er die Lampe und kann gesteuert werden.
                                      @ritter Na Cool, also war da doch irgendwas mit UDP Routing
                                        Ja, vielleicht aber nur Zufall denn die zweite Lampe findet er nicht.
                                          @ritter Vllt auch ins gleiche Netzsegment bringen?
                                            Auch schon probiert. Zumindest weis ich jetzt das die Lampen es generell können.
                                            260
                                            41433
